  4. JavaScript
  5. HTML Tabelle für BackItUp Adapter
    6.5k
javascripttemplate
82 Beiträge 11 Kommentatoren 14.5k Aufrufe 21 Beobachtet
  • O Oli
    @Glasfaser said in HTML Tabelle für BackItUp Adapter:
    und jetzt wo es auch hingehört :
    welches Widget hast du dafür genommen?
    GlasfaserG Offline
    GlasfaserG Offline
    @Oli
    Materialdesign Table
    hier ist meins :
    [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"backitup.0.history.json","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"countCols":"4","tableLayout":"standard","showHeader":true,"headerTextSize":"small","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":false,"colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","showColumn3":"true","colType3":"text","textAlign3":"left","label0":"Datum","label2":"Quelle","label1":"Meldung","padding_left0":"10","label3":"Speicherort","dataJson":"","padding_left2":"","class":"mdui-table mdui-table-ascard-r250-l mdui-table-striped noSwipe","textSize3":"small","textColor2":"#8f8f8f","textSize2":"small","padding_right3":"","rowHeight":"","textSize0":"small","textSize1":"small","padding_left1":"","textColor0":"#8f8f8f","textColor1":"#8f8f8f","textColor3":"#8f8f8f","imageSize1":"","prefix3":"<span style=\"display: inline-block; word-wrap:break-word;\"></span>","suffix3":"","colorHeaderRowText":"#8f8f8f","colorHeaderRowBackground":"#202020","colorRowBackground":"#2e2e2e","colorRowText":"#8f8f8f","dividers":"","colorBackground":"#202020","prefix2":"<span style=\"display: inline-block; word-wrap:break-word;\">","prefix1":"<span style=\"display: inline-block; word-wrap:break-word;\">","suffix2":"</span>","suffix1":"</span>","columnWidth0":"70","columnWidth1":"40","columnWidth3":"80","columnWidth2":"80","fontFamily3":"Jura-DemiBold","fontFamily2":"Jura-DemiBold","fontFamily1":"Jura-DemiBold","fontFamily0":"Jura-DemiBold","showColumn4":"true","colType4":"text","textAlign4":"center","name":"Tab_Warn-Error","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showColumn5":"true","colType5":"text","textAlign5":"center","colNoWrap0":true,"colNoWrap2":true,"colNoWrap3":true,"columnWidth4":"-2","label4":"Sicherungsgröße"},"style":{"left":"20px","top":"58px","width":"631px","height":"621px","z-index":"400","background":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","background-color":"#2e2e2e","color":"","overflow-y":"auto","border-radius":"10px","font-family":"Jura-DemiBold"},"widgetSet":"materialdesign"}]
    So sieht es dann aus :
    O Q 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      @Oli
      hier ist meins :
      O Online
      O Online
      Oli
      @Glasfaser
      danke
      Oliver
      • liv-in-skyL liv-in-sky
        UPDATE
        im ersten post ist ein neues script für die verarbeitung des neuen json formats - ich wollte keine so breite tabelle erzeugen, daher gibt es neben Storage einen button zum ändern der ansicht
        man kann im html setting die breite auf fest einstellen und somit das "hüpfen" vermeiden (tabellenbreite)
        z.b. let weite="780";
        ps: es gibt noch einen zusätzlichen datenpunkt zum einrichten - siehe script
        simatecS Offline
        simatecS Offline
        simatec
        @liv-in-sky
        Super Arbeit ... werde es nachher auch direkt mal testen...
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
          eine tabelle für vis (und iqontrol) für die anzeige der erstelleten backitup-backups
          ( @simatec )
          • wie üblich müssen die Fettschrift datenpunkte für das erzeugte html file **angelegt ** und im script auch angegeben werden ( variable: dpVIS (string)) - dazu kommt noch ein refresh dp ( variable: dpRefresh (bool))
          • momentan nur für eine backitup.0 instanz ausgelegt
          • backups können direkt aus der tabelle heraus aufgerufen werden (nur in vis mit html-standard-widget und der datenpunkt dpVIS als binding )
          • getriggert wird die tabelle bei ändrung des json-ausgabe-datenpunktes oder wenn ein backup läuft
          • erforderlich min. version 1.4.x des backitup adapters
          • falls noch wünsche sind und es der adapter als datenpunkt hergibt - bitte posten
             //@liv-in-sky 2020  3.2.21 - 12:00
          //HIER WIRD PFAD UND FILENAME DEFINIERT
          const path444 = "/htmlbackitup.html";                   //FIlenamen definieren
          const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
          let   braucheEinFile=false;                          // bei true wird ein file geschrieben
          let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
          let dpVIS="controll-own.0.TABELLEN.BackItUp"               //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget - Zeichenkette
          let dpRefresh="controll-own.0.TABELLEN.BackItUp_Refresh"   //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget - Boolean
          //let mySchedule=" */20 * * * * * ";
          let farbeNext="#79A2CA"
          let styleNext="i"                                     // style der geräte marken:  möglich b fett; i kursiv; span normal
          let farbeError="#FF0080"
          let styleError="span"                                  // style der geräte marken:  möglich b fett; i kursiv; span normal
          let symbolLink="🟩";        //  👎  💀 ❌  ⚪  ⚫ ⭕  🔴 🔵 🟡  🚧 👀
          let symbolFileView="📃";
          //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
          var htmlFeld1='BackItUp';       var Feld1lAlign="center";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
          var htmlFeld2='Datum';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
          var htmlFeld3='Zeit';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
          var htmlFeld4='Type';        var Feld4lAlign="center";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
          var htmlFeld5='Storage';        var Feld5lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          var htmlFeld6='Error';        var Feld6lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
          //ÜBERSCHRIFT ÜBER TABELLE
          let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
          let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
          const htmlFeldUeber='BackItUp';              // Überschrift und Signature
          const htmlFarbUber="white";                         // Farbe der Überschrift
          const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
          const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
          //MEHRERE TABELLEN NEBENEINANDER
          let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
          const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
          const farbetrennungsLinie="white";
          const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
          const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
          //ÜBERSCHRIFT SPALTEN
          const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
          const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
          const farbeLinieUnterUeberschrift="white";
          const groesseUeberschrift=16;
          const UeberschriftStyle="normal"                     // möglich "bold"
          //GANZE TABELLE
          let abstandZelle="4";
          let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
          let farbeGeradeZeilen="#151515";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
          let weite="950";                                     //Weite der Tabelle
          let zentriert=true;                                   //ganze tabelle zentriert
          const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
          const htmlSchriftart="Ubuntu-Regular"//"Jura-DemiBold";//"Helvetica";
          const htmlSchriftgroesse="14px";
          //FELDER UND RAHMEN
          let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
          const htmlFarbFelderschrift="#BDBDBD";                  // SchriftFarbe der Felder
          const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
          const htmlFarbTableColorGradient1="green";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
          const htmlFarbTableColorGradient2="blue";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
          const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
          let htmlRahmenLinien="cols";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
          const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
          // HIER NICHTS  ÄNDERN
          let borderHelpBottum;
          let borderHelpRight;
          let htmlcenterHelp;
          let htmlcenterHelp2;
          if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
          if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
          if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
          if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
          zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
          zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
          const htmlZentriert='<center>'
          const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                             "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                             " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                            // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                             " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                             " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                             "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                             ".blinkklasse {animation: blink 1s linear infinite;} @keyframes blink {  from {opacity: 0;} to {opacity: 1; }}"+
                             " </style></head><body> <div>";
          //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
          const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
          const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
          const htmlTabUeber3="</tr>";
          var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                             "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                             "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld5+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld6+"&ensp;</td>";
          //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
          const buttonScript =  '<script> function setOnDblClickCustom( myvalue ) {var Self = this; var2 = myvalue; Self.servConn.setState(var2, true); console.log("backitup")} '+
                                         'function setOnDblClickCustom1( myvalue) {var Self = this; var2 = myvalue; Self.servConn.setState(var2, true); console.log("backitup ccu")} '+
                                       'function setOnFileView() {var Self = this; objID = \"'+dpRefresh+'\";  	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, !states[objID].val); }); console.log(\"setze File in View\")}'
                               '</script>'
                               //var2 = \"backitup.0.oneClick.iobroker\";  Self.servConn.setState(var2, true);
          setStateDelayed(dpRefresh,true,10000);
          var htmlOut="";
          var mix;
          var counter;
          var val1; var val2; var val0; var val3; var val4; var val5;
          var htmlTabUeber="";
          var showFile;
          let myArrCCU;
          let myArrIOB;
          let myArrJSON;
          var htmlTabUeber2;
          function writeHTML(){
          showFile=getState(dpRefresh).val;
          if(!showFile){
          htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFileView\()\">"+symbolFileView + "</button></td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td>";
          } else {
          htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+"Size"+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+"Filename"+"&ensp;<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnFileView\()\">"+symbolFileView + "</button></td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td>";
          htmlOut="";
          counter=-1;
          htmlTabUeber="";
          switch (mehrfachTabelle) {
             case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
             case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
             case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
             case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
          if (!UeberschriftSpalten) {htmlTabUeber=""}
          //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
          //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
          var myJson=[];
          var myJson1=[];
          let anzahlInstanzen=0;
          myArrCCU=[];
          myArrIOB=[]
          myArrJSON=[]
          if (existsState('backitup.0.info.iobrokerNextTime')) {
             $('backitup.*.history.json').each(function(id, i) {//log(i.toString())   backitup.1.oneClick.iobroker
                if ( existsState(id.replace("history.json","oneClick.iobroker"))) myArrIOB.push(id.replace("history.json","oneClick.iobroker"))
                if ( existsState(id.replace("history.json","oneClick.ccu"))) myArrIOB.push(id.replace("history.json","oneClick.ccu"))
                myArrJSON.push(id)
                 anzahlInstanzen++;
                 let ida=id.split('.');
                 let myDP=JSON.parse(getState("backitup."+ida[1]+".history.json").val)
                 for(let iii=0;iii<myDP.length;iii++) {myDP[iii].myInstanz=ida[1]
                                                       myJson.push(myDP[iii]) ;
                                                       //myJson[iii].myInstanz=ida[1];log(ida[1])
                    //log(myJson.toString())
                //  myJson1=myJson1.concat(myJson)
             myJson.sort(function(a, b){
                                         return new Date(b.timestamp).getTime() - new Date(a.timestamp).getTime();      // return parseInt(new Date(b.date).getTime()) - parseInt(a.date);
          let myObj=myJson
          //log(JSON.stringify(myObj))
          if (existsState('backitup.0.history.json')) {
              //myJson=getState("backitup.0.history.json").val
             if(myObj.length>0) {
               myObj.forEach(function(obj) {
                    counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                    val5=obj.error
                    val0="Bkp";
                    val1=obj.date.replace(/(.+) um.+/g,"$1")
                    val2=obj.date.replace(/.+um (.+) /g,"$1")
                    val3=obj.type          //+"<span title=\"I am hovering over the text\">xx</span>"
                  //  val4=obj.storage
                     val4="<span title=\""+obj.name+"\">"+obj.storage+"</span>"
                    let val4help; var val3help;
                    if(obj.hasOwnProperty("name")){ val4help=(obj.name).replace(/(.+)\_backupiobroker.+/,"$1...");val3help=obj.filesize
                                                } else {val4help="upgrade BackItUp Adapter > 1.4.1"; val3help=" - ";}
                    if(showFile) {val4="<span title=\""+obj.name+"\">"+val4help+"</span>"; val3=val3help;}
                  if(val5 !="none") {
                        val0="<font color=\""+farbeError+"\"><"+styleError+">"+val0
                        val1="<font color=\""+farbeError+"\"><"+styleError+">"+val1
                        val2="<font color=\""+farbeError+"\"><"+styleError+">"+val2
                        val3="<font color=\""+farbeError+"\"><"+styleError+">"+val3
                        val4="<font color=\""+farbeError+"\"><"+styleError+">"+val4
                        val5="<font color=\""+farbeError+"\"><"+styleError+">"+val5
               tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
             }); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
             } else {log("Datenpunkt leer- Backup mit BackItUp starten ","warn")
                    val0="<font color=\"red\">Backup mit BackItUp starten";
                    val1=""
                    val2=""
                    val3=""
                    val4=""
                    val5="<font color=\"red\">Datenpunkt leer";
                    tabelleBind();}
            } else {log("Datenpunkt nicht existent - check Version - Script BackItUp Tabelle ","warn");
                    val0="<font color=\"red\"> check Version > v1.4.0";
                    val1=""
                    val2=""
                    val3=""
                    val4=""
                    val5="<font color=\"red\">Datenpunkt nicht existent";
                    tabelleBind();}
                  let marker=false
            for (let aaa=0;aaa<(anzahlInstanzen);aaa++){
                    val0="<font color=\""+farbeNext+"\"><"+styleNext+">Next";
                    val1="<font color=\""+farbeNext+"\"><"+styleNext+">"+(getState("backitup."+aaa+".info.iobrokerNextTime").val).replace(/(.+) um.+/g,"$1")
                    val2="<font color=\""+farbeNext+"\"><"+styleNext+">"+(getState("backitup."+aaa+".info.iobrokerNextTime").val).replace(/.+um (.+) /g,"$1")
                    val3="<font color=\""+farbeNext+"\"><"+styleNext+">"+"Instanz "+aaa;
                    let myDatapointIOB="backitup."+aaa+".oneClick.iobroker"
                    let myDatapointCCU="backitup."+aaa+".oneClick.ccu"
                    val4="<font color=\""+farbeNext+"\"><"+styleNext+">"+"run backup!&emsp; "+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\(\'"+myDatapointIOB+"\')\">"+symbolLink + "</button>"+"<font color=\""+farbeNext+"\"><"+styleNext+">"+"run ccu!&emsp; "+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\(\'"+myDatapointCCU+"\')\">"+symbolLink + "</button>"
                  //  getState("backitup."+aaa+".oneClick.iobroker").val ? val5="<font color=\""+farbeNext+"\"><"+styleNext+">"+"<span id=\"blink\" class=\"blinkklasse\"> running</span>" : val5="";
                   // log("bin da"+val5+" ---- "+getState("backitup."+aaa+".oneClick.iobroker").val)
                    getState("backitup."+aaa+".oneClick.ccu").val || getState("backitup."+aaa+".oneClick.iobroker").val  ? val5="<font color=\""+farbeNext+"\"><"+styleNext+">"+"<span id=\"blink\" class=\"blinkklasse\"> running</span>" : val5=""
                   if(getState("backitup."+aaa+".oneClick.ccu").val || getState("backitup."+aaa+".oneClick.iobroker").val || marker ) val4="<font color=\""+farbeNext+"\"><"+styleNext+">"+"<span id=\"blink\" class=\"blinkklasse\"> "+symbolLink+"running</span>"
                     if(getState("backitup."+aaa+".oneClick.ccu").val || getState("backitup."+aaa+".oneClick.iobroker").val) marker=true
                    tabelleBind();
             }//anzahlInstanzen
                    } else {log("kein Backup eingerichtet ","warn");
                    val0="<font color=\"red\"> Keine Definition für nächstes Bckup";
                    val1=""
                    val2=""
                    val3=""
                    val4=""
                    val5="<font color=\"red\">BackItUp konfigurieren und Script restart";
                    tabelleBind();}
          //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
          } // function ende
          //MAIN:
          //schedule(mySchedule,  function () {
          //  writeHTML();
          //  if (braucheEinFile) {writeFile(home, path444 ,htmlOut, function (error) { /* log('file written');*/  });}
           writeHTML();
             				 function tabelleBind(){
               //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
                  case 1:  if(counter%2==0) {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td></tr>"; break; } else
                                            {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td></tr>"; break;}
                  case 2:  if(counter%4==0){
                          if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td>"; }
                                        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td></tr>";} break;
                             }else{
                           if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td>"; }
                                        else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td></tr>";} break;}
                  case 3:  if(counter%2==0)   {
                            if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td>"; }
                                        else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td>";}
                                                         else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td></tr>";}
                                                   } break;}else{
                           if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td>"; }
                                                   } break;}
                  case 4:   if(counter%8==0)   {
                            if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td>"; }
                                            else {if(counter%4==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td>";}
                                                         else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+" >&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\" color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td>";}}
                                                   } break;}else{
                            if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td>"; }
                                            else {if(counter%4==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\"  border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"; color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td>";}
                                                         else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+" style=\" color:"+htmlFarbFelderschrift2+"\">&ensp;"+val5+"&ensp;</td></tr>";}
                                                   } break;}
               } //switch ende
          function tabelleFinish() {
                // tabelle fertigstellen
                 case 1:    break;
                 case 2:
                            if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                            break;
                 case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                           if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                            break;
                 case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                           if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                           break; }
                              var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                 var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                  if (!htmlSignature) htmlUnter="";
                    //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                     var htmlOutVIS="";
                   //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                      if (htmlUberschrift)
                          { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+buttonScript ;
                        } else {
                         zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+buttonScript;
          // log("bin raus aus tabelleBind");
                     if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
           var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
          var htmlEnd="</table>"+htmlUnter+"</div></body>";
           //mit oder ohne überschrift - zentriert oder links
          htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
           //log(htmlOut);
          if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                 on({id:  myArrJSON, change: "ne"}, function (obj) {
                 //log(getState(dpANLEGEN).val+"----refresh");
                 var timeout2 = setTimeout(function () {
             writeHTML();
              }, 1500);
          on({id: myArrIOB, change: "ne"}, function (obj) {
                 var timeout22 = setTimeout(function () {
                  // log("gechanged")
             writeHTML();
             }, 2500);
              on({id: myArrCCU, change: "ne"}, function (obj) {
             writeHTML();
             }, 2500);
          on({id: dpRefresh, change: "any"}, function (obj) {
             writeHTML();
             }, 2500);
          das orginal-template für solche tabellen findet ihr: https://forum.iobroker.net/topic/28021/html-table-für-vis-oder-iqontrol-js-und-blockly
          MicM Offline
          MicM Offline
          Mic
          @liv-in-sky
          Vielen Dank hierfür, werde ich demnächst einbauen :-)
          Offtopic-Frage:
          Wie hast du denn das Bild für diesen Thread gesetzt?
          • MicM Mic
            @liv-in-sky
            Offtopic-Frage:
            liv-in-skyL Offline
            liv-in-skyL Offline
            @Mic
            MicM 1 Antwort Letzte Antwort
              @Mic
              MicM Offline
              MicM Offline
              Mic
              @liv-in-sky
              Wenn ich auf den Button (getitelt "Bild hochladen") klicke, dann öffnet sich bei mir sofort ein "Explorer-Fenster" zur Auswahl eines Bildes.
              Wie aber bekommt man ein Thread-Logo wie hier gesetzt?
              • MicM Mic
                @liv-in-sky
                liv-in-skyL Offline
                liv-in-skyL Offline
                @Mic wenn ich das mit FF mache geht es wie bei dir (also nicht) - mit chrome hingegen klappt es
                • simatecS simatec
                  @liv-in-sky
                  Ich habe in der Release Version 1.4.1 die json auf Userwunsch noch einmal um den "name" und "filesize" erweitert.
                  Hier ein Beispiel der Ausgabe.
                  [{"date":"02. Maerz 2020 um 15:22 Uhr","name":"iobroker_2020_03_02-15_22_20_dev_backupiobroker.tar.gz","type":"iobroker","storage":"NFS / CIFS-Mount: Ja","filesize":"3MB","error":"none"}]
                  Agria4800A Offline
                  Agria4800A Offline
                  Agria4800
                  @simatec: Danke 👍
                  • MicM Mic
                    @liv-in-sky
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @Mic , tausend mal sorry, ich habe dir voll die falsche info gegeben
                    es ist (getestet mit chrome und neuem microsoft edge und FF)
                    wenn das nicht geht, evtl mal ein anderes forum layout wählen
                      UPDATE
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @liv-in-sky
                      Im iqontrol scheint es noch nicht so zu funktionieren ... Dort besteht in der html wohl nicht die Möglichkeit zu erweitern ...
                      Dort bekomme ich jedenfalls die beiden zusätzlichen Spalten nicht angezeigt
                      • simatecS simatec
                        @liv-in-sky
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @simatec ja das problem ist, das nur im widget die socket-verbindung definiert ist - in einer normalen browser umgebung kann der browser ohne diese socketverbindung den weg nicht zu iobroker finden - iqontrol hat dieses problem
                        ich habe schon mal überlegt , anstatt einer socket, eine simple-api verbindung zu nehmen - habe ich aber noch nicht getestet
                        im html file ist ein javascript eingebunden, welches den socket nutzt
                        • liv-in-skyL Offline
                          liv-in-skyL Offline
                          es gibt ein kleines updatee - der gesamte name wird angezeigt, wenn man länger über dem storage oder file wert stehen bleibt
                          alle settings können wieder zurückkopiert werden - es sind keine neuen settings dazu gekommen
                            Kueppert
                            schrieb am zuletzt editiert von Kueppert
                            irgendwie hab ich anscheinend die zu befüllenden DP nicht verstanden. Ich erhalte leider den einen oder anderen Error:
                            javascript.0	2020-03-10 10:07:00.777	warn	(3064) at Timer.processTimers (timers.js:223:10)
                            javascript.0	2020-03-10 10:07:00.777	warn	(3064) at listOnTimeout (timers.js:263:5)
                            javascript.0	2020-03-10 10:07:00.777	warn	(3064) at tryOnTimeout (timers.js:300:5)
                            javascript.0	2020-03-10 10:07:00.777	warn	(3064) at ontimeout (timers.js:438:13)
                            javascript.0	2020-03-10 10:07:00.777	warn	(3064) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                            javascript.0	2020-03-10 10:07:00.776	warn	(3064) at Object.<anonymous> (script.js.common.Sonstiges.Backitup_History:720:4)
                            javascript.0	2020-03-10 10:07:00.776	warn	(3064) at writeHTML (script.js.common.Sonstiges.Backitup_History:468:7)
                            javascript.0	2020-03-10 10:07:00.776	warn	(3064) at tabelleFinish (script.js.common.Sonstiges.Backitup_History:656:37)
                            javascript.0	2020-03-10 10:07:00.776	warn	(3064) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                            javascript.0	2020-03-10 10:07:00.775	warn	(3064) State "javascript.0.BackItUp.BackItUp" not found
                            javascript.0	2020-03-10 10:07:00.775	warn	(3064) at Timer.processTimers (timers.js:223:10)
                            javascript.0	2020-03-10 10:07:00.775	warn	(3064) at listOnTimeout (timers.js:263:5)
                            javascript.0	2020-03-10 10:07:00.774	warn	(3064) at tryOnTimeout (timers.js:300:5)
                            javascript.0	2020-03-10 10:07:00.774	warn	(3064) at ontimeout (timers.js:438:13)
                            javascript.0	2020-03-10 10:07:00.774	warn	(3064) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                            javascript.0	2020-03-10 10:07:00.774	warn	(3064) at Object.<anonymous> (script.js.common.Sonstiges.Backitup_History:720:4)
                            javascript.0	2020-03-10 10:07:00.774	warn	(3064) at writeHTML (script.js.common.Sonstiges.Backitup_History:252:10)
                            javascript.0	2020-03-10 10:07:00.773	warn	(3064) getState "javascript.0.BackItUp.BackItUp_Refresh" not found (3)
                            javascript.0	2020-03-10 10:07:00.727	warn	(3064) at Timer.processTimers (timers.js:223:10)
                            javascript.0	2020-03-10 10:07:00.727	warn	(3064) at listOnTimeout (timers.js:263:5)
                            javascript.0	2020-03-10 10:07:00.727	warn	(3064) at tryOnTimeout (timers.js:300:5)
                            javascript.0	2020-03-10 10:07:00.726	warn	(3064) at ontimeout (timers.js:438:13)
                            javascript.0	2020-03-10 10:07:00.726	warn	(3064) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                            javascript.0	2020-03-10 10:07:00.726	warn	(3064) at Object.<anonymous> (script.js.common.Sonstiges.Backitup_History:694:4)
                            javascript.0	2020-03-10 10:07:00.726	warn	(3064) at writeHTML (script.js.common.Sonstiges.Backitup_History:468:7)
                            javascript.0	2020-03-10 10:07:00.725	warn	(3064) at tabelleFinish (script.js.common.Sonstiges.Backitup_History:656:37)
                            javascript.0	2020-03-10 10:07:00.725	warn	(3064) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                            javascript.0	2020-03-10 10:07:00.725	warn	(3064) State "javascript.0.BackItUp.BackItUp" not found
                            javascript.0	2020-03-10 10:07:00.722	warn	(3064) at Timer.processTimers (timers.js:223:10)
                            javascript.0	2020-03-10 10:07:00.722	warn	(3064) at listOnTimeout (timers.js:263:5)
                            javascript.0	2020-03-10 10:07:00.722	warn	(3064) at tryOnTimeout (timers.js:300:5)
                            javascript.0	2020-03-10 10:07:00.722	warn	(3064) at ontimeout (timers.js:438:13)
                            javascript.0	2020-03-10 10:07:00.722	warn	(3064) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                            javascript.0	2020-03-10 10:07:00.722	warn	(3064) at Object.<anonymous> (script.js.common.Sonstiges.Backitup_History:694:4)
                            javascript.0	2020-03-10 10:07:00.721	warn	(3064) at writeHTML (script.js.common.Sonstiges.Backitup_History:252:10)
                            javascript.0	2020-03-10 10:07:00.721	warn	(3064) getState "javascript.0.BackItUp.BackItUp_Refresh" not found (3)
                            javascript.0	2020-03-10 10:06:40.024	warn	(3064) at Timer.processTimers (timers.js:223:10)
                            javascript.0	2020-03-10 10:06:40.024	warn	(3064) at listOnTimeout (timers.js:263:5)
                            javascript.0	2020-03-10 10:06:40.024	warn	(3064) at tryOnTimeout (timers.js:300:5)
                            javascript.0	2020-03-10 10:06:40.024	warn	(3064) at ontimeout (timers.js:438:13)
                            javascript.0	2020-03-10 10:06:40.023	warn	(3064) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                            javascript.0	2020-03-10 10:06:40.023	warn	(3064) at Object.<anonymous> (script.js.common.Sonstiges.Backitup_History:720:4)
                            javascript.0	2020-03-10 10:06:40.023	warn	(3064) at writeHTML (script.js.common.Sonstiges.Backitup_History:468:7)
                            javascript.0	2020-03-10 10:06:40.022	warn	(3064) at tabelleFinish (script.js.common.Sonstiges.Backitup_History:656:37)
                            javascript.0	2020-03-10 10:06:40.022	warn	(3064) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                            javascript.0	2020-03-10 10:06:40.015	warn	(3064) State "javascript.0.BackItUp.BackItUp" not found
                            javascript.0	2020-03-10 10:06:40.014	warn	(3064) at Timer.processTimers (timers.js:223:10)
                            javascript.0	2020-03-10 10:06:40.014	warn	(3064) at listOnTimeout (timers.js:263:5)
                            javascript.0	2020-03-10 10:06:40.013	warn	(3064) at tryOnTimeout (timers.js:300:5)
                            javascript.0	2020-03-10 10:06:40.013	warn	(3064) at ontimeout (timers.js:438:13)
                            javascript.0	2020-03-10 10:06:40.013	warn	(3064) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
                            javascript.0	2020-03-10 10:06:40.012	warn	(3064) at Object.<anonymous> (script.js.common.Sonstiges.Backitup_History:720:4)
                            javascript.0	2020-03-10 10:06:40.012	warn	(3064) at writeHTML (script.js.common.Sonstiges.Backitup_History:252:10)
                            javascript.0	2020-03-10 10:06:40.011	warn	(3064) getState "javascript.0.BackItUp.BackItUp_Refresh" not found (3)
                            Was muss denn bei let dpVIS= und let dpRefresh= hin? Vorhandene DP von Backitup?
                            Wenn ich im Skript brauche ein file = true und brauche eine Tabelle= false eintrage, erhalte ich immer noch folgende Fehlermeldungen im Log:
                            javascript.0	2020-03-10 10:19:36.281	warn	(3064) at script.js.common.Sonstiges.Backitup_History:490:2
                            javascript.0	2020-03-10 10:19:36.281	warn	(3064) at writeHTML (script.js.common.Sonstiges.Backitup_History:252:10)
                            javascript.0	2020-03-10 10:19:36.280	warn	(3064) getState "javascript.0.BackItUp.BackItUp_Refresh" not found (3)
                            javascript.0	2020-03-10 10:19:36.279	warn	(3064) at script.js.common.Sonstiges.Backitup_History:232:1
                            javascript.0	2020-03-10 10:19:36.279	warn	(3064) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                            javascript.0	2020-03-10 10:19:36.279	warn	(3064) State "javascript.0.BackItUp.BackItUp_Refresh" not found
                            Danke euch und VG, Thorsten
                            • K Kueppert
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @Kueppert hi
                              du musst diese beiden datenpunkte bei dir im system als zeichenkette anlegen - im admin unter objekte - und diese datenpunkte dann im script eintragen - hast du diese datenpunkte , die du nutzt, angelegt ? wo du diese anlegst ist dem script egal - hauptsache die angelegten datenpunkte stimmen mit denen, die im script eingetrgen sind, überein.
                              0_userdata.0 ist für solche eigenen datenpunkte vorgesehen
                              die datenpunkte von backitup findet das script von selbst - wenn die instanz davon unter backitup.0 angelegt worden ist
                                @Kueppert hi
                                Kueppert
                                @liv-in-sky ahaaa, na das hab ich dann mal gemacht :) Hatte dann nur noch eine Fehlermeldung:
                                javascript.0	2020-03-10 11:11:29.362	warn	(3064) at script.js.common.Sonstiges.Backitup_History:232:1
                                javascript.0	2020-03-10 11:11:29.362	warn	(3064) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1426:20)
                                javascript.0	2020-03-10 11:11:29.361	warn	(3064) You are assigning a boolean to the state "0_userdata.0.BackItUpHistory_Refresh" which expects a string. Please fix your code to use a string or change the state type to boolean. T
                                Hab den Refresh-Datenpunkt dann von Zeichenkette zu Logikwert geändert. Nun hab ich keine Fehlermeldungen mehr. Danke dir :)
                                Hat sich erledigt...steht sogar ganz oben...
                                Jetzt noch eine Verständnisfrage (ich hoffe, ich frage nicht doppelt, weil schon beantwortet^^): wofür sind diese beiden Datenpunkte nun?
                                DPVis = da liegt der HTML-Code, wenn ich das aktiviere? Haben wir im neuen Backitup ja schon drin
                                DPRefresh = damit kann ich die Ansicht der Tabelle aktualisieren?
                                Danke dir und viele Grüße, Thorsten
                                • K Kueppert
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @Kueppert sorry - mein fehler - ändere den refresh in einen boolean typ ( logikwert) - habe ich verkehrt gemacht
                                  • ? Offline
                                    Kann man direkt über die Tabelle nur das IoB Backup anstossen, oder auch das für die CCU?
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @Beliar_666 ich kann nur auf datenpunkte zugreifen - ich habe kein ccu, daher hab ich das nicht bedacht - es gibt aber einen datenpunkt ccu unter oneClick - den mußte ich dann bei gelegenheit einbinden
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        #66
                                        @Beliar_666
                                        teste mal dieses script - ich kann es ja nicht wirklich testen, da in ccu nix definiert ist
                                        • aufrufen über tabelle "run ccu" - dann erscheint ein running und das sollte auch nach einer zeit wieder verschwinden - anschliessend kontrolliere bitte, ob er auch ein file(backup) erstellt hat
                                         //@liv-in-sky 2020  20.3.2020 - 14:00
                                        const path = "/htmlbackitup.html";                   //FIlenamen definieren
                                        let farbeNext="#AEB404"
                                        let symbolLink="🟡";        //  👎  💀 ❌  ⚪  ⚫ ⭕  🔴 🔵 🟡  🚧 👀
                                        //GANZE TABELLE
                                        //FELDER UND RAHMEN
                                        const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                                        const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                                        let htmlcenterHelp;
                                        const buttonScript =  '<script> function setOnDblClickCustom() {var Self = this; var2 = \"backitup.0.oneClick.iobroker\"; Self.servConn.setState(var2, true); console.log("backitup")} '+
        'function setOnDblClickCustom1() {var Self = this; var2 = \"backitup.0.oneClick.ccu\"; Self.servConn.setState(var2, true); console.log("backitup ccu")} '+
                                                             '</script>'
                                        setState(dpRefresh,true);
                                        var htmlOut="";
                                        var mix;
                                        var counter;
                                        var showFile;var
                                        htmlTabUeber2;
                                        if(!showFile){
                                        } else {
                                        htmlOut="";
                                        counter=-1;
                                        htmlTabUeber="";
                                           let myJson=getState("backitup.0.history.json").val
                                           if(myJson!="[]") {
                                             let myObj=JSON.parse(myJson)
                                                  val5=obj.error
                                                  val0="Bkp";
                                                //  val4=obj.storage
                                                if(val5 !="none") {
                                                  val1=""
                                                  val2=""
                                                  val3=""
                                                  val4=""
                                                  tabelleBind();}
                                                  val1=""
                                                  val2=""
                                                  val3=""
                                                  val4=""
                                                  tabelleBind();}
                                                  val1="<font color=\""+farbeNext+"\"><"+styleNext+">"+(getState("backitup.0.info.iobrokerNextTime").val).replace(/(.+) um.+/g,"$1")
                                                  val2="<font color=\""+farbeNext+"\"><"+styleNext+">"+(getState("backitup.0.info.iobrokerNextTime").val).replace(/.+um (.+) /g,"$1")
                                                  val3="<font color=\""+farbeNext+"\"><"+styleNext+">"+"iobroker"
                                                  val4="<font color=\""+farbeNext+"\"><"+styleNext+">"+"run backup!&emsp; "+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom\()\">"+symbolLink + "</button>"+"<font color=\""+farbeNext+"\"><"+styleNext+">"+"run ccu!&emsp; "+"<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustom1\()\">"+symbolLink + "</button>"
                                                  getState("backitup.0.oneClick.iobroker").val ? val5="<font color=\""+farbeNext+"\"><"+styleNext+">"+"<span id=\"blink\" class=\"blinkklasse\"> running</span>" : val5="";
                                                  getState("backitup.0.oneClick.ccu").val ? val5="<font color=\""+farbeNext+"\"><"+styleNext+">"+"<span id=\"blink\" class=\"blinkklasse\"> running</span>" : val5=""
                                                  tabelleBind();
                                                  val1=""
                                                  val2=""
                                                  val3=""
                                                  val4=""
                                                  tabelleBind();}
                                        } // function ende
                                        //MAIN:
                                        //  writeHTML();
                                        //  if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                         writeHTML();
                                                           }else{
        } break;}else{
        } break;}
        } break;}else{
        } break;}
                                             } //switch ende
                                               case 1:    break;
                                               case 2:
                                                          break;
                                                          break;
                                                         break; }
                                                   var htmlOutVIS="";
                                                      } else {
                                         //log(htmlOut);
                                               on({id: 'backitup.0.history.json', change: "ne"}, function (obj) {
                                           writeHTML();
                                            }, 1500);
                                        on({id: 'backitup.0.oneClick.iobroker', change: "ne"}, function (obj) {
                                           writeHTML();
                                           }, 1500);
                                            on({id: 'backitup.0.oneClick.ccu', change: "ne"}, function (obj) {
                                           writeHTML();
                                           }, 1500);
                                           writeHTML();
                                           }, 1500);
                                        • simatecS simatec
                                          Die Tabelle sieht aber schon richtig schick aus ... Super Arbeit 👍
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #67
                                          @simatec ich hätte da mal eine frage
                                          ich lasse es über cifs auf einen fileserver kopieren - auf dem fileserver läuft ein linux cron job der die backups löscht, die älter als 3 tage sind - daher sind auf dem server nur 3 kopien
                                          angezeigt werden aber sehr viele mittlerweile
                                          was muss ich einstellen, dass dies übereinstimmt ?
