  4. WICHTIG: Updates von socketio, web, admin (Latest vorerst)
websocketioadmin
387 Beiträge 68 Kommentatoren 101.5k Aufrufe 55 Beobachtet
  • J jf62
    Nach Update auf socket.io 3.0 habe ich in Chrome nur noch das endlos drehende ioBroker Logo. Edge läuft ohne Probleme, deshalb hier als Frage. Hat jemand eine Idee, woran das liegen könnte?
    Alle Adapter, npm und node.js aktuell. PI4 mit 4GB
    F12 im Chrome zeigt folgende Fehler:
    Autofocus processing was blocked because a document's URL has a fragment '#tab-instances/config/system.adapter.iot.0'.
    :8081/#tab-adapters:1 A cookie associated with a cross-site resource at http://github.com/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
    :8081/#tab-adapters:1 A cookie associated with a cross-site resource at https://github.com/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
    :8081/socket.io/?ws=true&EIO=3&transport=polling&t=N0Sfve-:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?EIO=3&transport=polling&t=N0Sfvf6:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?ws=true&EIO=3&transport=polling&t=N0SrX2S:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?EIO=3&transport=polling&t=N0SrX2Y:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?EIO=3&transport=polling&t=N0TUjzk:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?ws=true&EIO=3&transport=polling&t=N0TUjzl:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?EIO=3&transport=polling&t=N0UlMaE:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    7Unchecked runtime.lastError: The message port closed before a response was received.
    :8081/socket.io/?EIO=3&transport=polling&t=N0UtuED:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    :8081/socket.io/?EIO=3&transport=polling&t=N0Utvi4:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    :8081/socket.io/?EIO=3&transport=polling&t=N0Utx9d:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    :8081/socket.io/?EIO=3&transport=polling&t=N0UtzMR:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    :8081/socket.io/?EIO=3&transport=polling&t=N0Ut_Yt:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    :8081/socket.io/?EIO=3&transport=polling&t=N0Uu1lU:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    :8081/socket.io/?EIO=3&transport=polling&t=N0Uu3y9:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
    und weiter unten dann noch:
    2translate.js:24 "Login timeout(sec):": {"en": "Login timeout(sec):", "de": "Login timeout(sec):", "ru": "Login timeout(sec):", "pt": "Login timeout(sec):", "nl": "Login timeout(sec):", "fr": "Login timeout(sec):", "es": "Login timeout(sec):", "pl": "Login timeout(sec):", "it": "Login timeout(sec):", "zh-cn": "Login timeout(sec):"},
    :8081/socket.io/?EIO=3&transport=polling&t=N0Uw0DQ:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?EIO=3&transport=polling&t=N0VZD3O:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?EIO=3&transport=polling&t=N0VZEeJ:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    :8081/socket.io/?EIO=3&transport=polling&t=N0WAcYB:1 Failed to load resource: net::ERR_NETWORK_IO_SUSPENDED
    adminInstances.js:1065 97
    :8081/adapter/javascript/google-blockly/blockly_compressed.js:893 WARNING: No message string for %{BKY_LOGIC_COMPARE_TOOLTIP_EQ}.
    und dann noch:
    Connection.js:89 Uncaught TypeError: t.indexOf is not a function
        at n.<anonymous> (Connection.js:89)
        at n.emit (socket.io.js:3)
        at n.emit (socket.io.js:4)
        at n.emitAll (socket.io.js:2)
        at n.onerror (socket.io.js:2)
        at n.<anonymous> (socket.io.js:4)
        at n.onError (socket.io.js:3)
        at n.onPacket (socket.io.js:3)
        at o.<anonymous> (socket.io.js:3)
    (anonymous) @ Connection.js:89
    n.emit @ socket.io.js:3
    n.emit @ socket.io.js:4
    n.emitAll @ socket.io.js:2
    n.onerror @ socket.io.js:2
    (anonymous) @ socket.io.js:4
    n.onError @ socket.io.js:3
    n.onPacket @ socket.io.js:3
    (anonymous) @ socket.io.js:3
    r @ socket.io.js:3
    e.decodePayload @ socket.io.js:3
    n.onData @ socket.io.js:3
    i.onData @ socket.io.js:3
    i.onLoad @ socket.io.js:3
    hasXDR.r.onreadystatechange @ socket.io.js:3
    DevTools failed to parse SourceMap: chrome-extension://cfhdojbkjhnklbpkdaibdccddilifddb/include.preload.js.map
    DevTools failed to parse SourceMap: chrome-extension://cfhdojbkjhnklbpkdaibdccddilifddb/include.postload.js.map
    DevTools failed to parse SourceMap: http://192.168.10.20:8081/ol.js.map
    DevTools failed to parse SourceMap: http://192.168.10.20:8081/ol.css.map
    @jf62 Also Connection refused und sowas sieht mir nach netzwerk aus. ggf mal rebooten das wirlich alles sauber hochkommt. Das letzte bei dir ist auch javascript wie es aussieht. Bitte updaten 4.3.8
    • D dodi666
      @el_malto sagte in WICHTIG: Updates von socketio, web, admin (Latest vorerst):
      @apollon77 sagte in WICHTIG: Updates von socketio, web, admin (Latest vorerst):
      Alle drei Adapter haben bisher die Version 1.7.2 dieser Library genutzt, welche inzwischen über 3 Jahre alt ist. Wir haben diese Version lange eingesetzt weil bei allen höheren Versionen einige Ältere Geräte - allen voran iPad 1 und 2 (!) - nicht mehr funktionieren.
      Geht es da um die Geräte an sich, also die Hardware oder hat es was mit der iOS Version zu tun? Weil einige ältere iPhones ja auch nur bestimmte iOS Versionen können.
      Beim iPad 2 ist die letzte iOS Version 9.3.6. Genau so wie beim iPad mini 1. Dann würde das iPad mini 1 ja auch nicht mehr gehen. Bei den iPhones wäre es dann alles was kleiner gleich iPhone 4S ist.
      das würde mich auch näher interessieren.
      Benutze derzeit ein iPad2 in Kombination mit der iobroker App zur Darstellung der Vis.
      Funktioniert der Vis-Aufruf auf dem iPad2 nach dem Update generell nicht mehr,
      oder nur über die iobroker App oder den Browser?
      Es ist schon schade, dass man die alten Geräte für die Heimautomatisierung nicht mehr weiter verwenden kann...natürlich ist auch ne Chance was Neues zu kaufen ;-)
      Sascha
      MaufloM Offline
      MaufloM Offline
      Mauflo
      schrieb am zuletzt editiert von Mauflo
      @dodi666 nur zur Info! Ich hab richtig alte Tablets "Qoo!" mit 2 GB und 7". Android 4.1.1 usw. Bislang funktionierte die ioBroker APP. Nun nicht mehr - die IoBroker App bekommt keine Verbindung mehr. Habe aber eine Kiosk Browser APP installiert und verwende die Tablets weiter als Controller. Also man muss alte Geräte nicht gelich entsorgen... ;-)
      RaspberryPi 4 4 GB - Raspbian light Buster - ARMv7 Processor rev 3 (v7l) - Node.js v12.18.0 - NPM 6.14.4 - Aktive Instanzen 18 (admin, alexa2, backitup, broadlink2, ham-wemo, harmony, history, hs100, hue, info, iot, javascript, radar2, scenes, tr-064, web [2x], wifilight) all latest and updated
      • apollon77A apollon77
        @FredF Das das erst in javascript 4.3.5 gefixt wurde ist euch klar? ;-)
        FredFF Online
        FredFF Online
        FredF
        Most Active Forum Testing
        @apollon77 nö war mir nicht klar 🤪
        • ? Offline
          Danke @apollon77 @Bluefox
          Java 4.3.8
          Admin 4.0.1
          Scripte Zugang und Download funktionieren wieder.
            jf62
            schrieb am zuletzt editiert von jf62
            @apollon77
            läuft mit 4.3.8 sporadisch. D.h. geht nach Adapter Neustart (reboot habe ich gemacht) oder geht nicht und logo dreht.
            wenn es geht trotzdem folgende Ausgabe in der Konsole des Browsers
            translate.js:24 "tree": {"en": "tree", "de": "tree", "ru": "tree", "pt": "tree", "nl": "tree", "fr": "tree", "es": "tree", "pl": "tree", "it": "tree", "zh-cn": "tree"},
            jquery.fancytree-all.js:113 Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead.
            v @ jquery.fancytree-all.js:113
            adminInstances.js:1065 83
            adminInstances.js:1065 107
            2Connection.js:89 Uncaught TypeError: t.indexOf is not a function
            adminInstances.js:1065 105
            sigi234S apollon77A 2 Antworten Letzte Antwort
            • J jf62
              @apollon77
              sigi234S Online
              sigi234S Online
              @jf62 sagte in WICHTIG: Updates von socketio, web, admin (Latest vorerst):
              Bei mir auch.
              • Samson71S Offline
                Samson71S Offline
                Samson71
                Ich setze noch alte Galaxy Tab2 10.1 mit Android 4.2.2 ein. Da lief die App ohnehin nicht drauf. Daher alles unter Chrome im Vollbildmodus. Keine Rennpferde aber zuverlässig.
                Kann mir jemand bestätigen, dass das auch nach dem Update noch läuft? Ich habe jetzt von Problemen mit Chrome gelesen, kann aber nicht einordnen, ob das ein generelles oder eher spezielles Problem ist.
                Markus
                Bitte beachten:
                  Kensho
                  Also bei mir funktioniert es nicht. Komme nicht mehr auf Scripte. Dreht sich die ganze Zeit und es kommt noch die Fehlermeldung im Browser "Error: Server Error" bei Chrome. Bei Edge geht es mal und dann auch mal wieder nicht.
                  Java 4.3.8
                  Admin 4.0.0
                  Nodejs 10.19.0
                  NPM 6.13.4
                  • haselchenH Offline
                    haselchenH Offline
                    haselchen
                    #66
                    Bekomme beim web.0 andauernd (jede Minute)
                    <==Connect system.user.admin from ::ffff:192.XX.XX.XXX vis.0
                    <==Disconnect system.user.admin from ::ffff:192.XX.XX.XXX vis.0
                    Macht langsam keinen Spass mehr.
                    Man ist nur noch mit updaten und Fehlerbehebung hier beschäftigt.
                    Samson71S DiginixD K SteffS 4 Antworten Letzte Antwort
                    • haselchenH haselchen
                      Samson71S Offline
                      Samson71S Offline
                      Samson71
                      #67
                      @haselchen sagte in WICHTIG: Updates von socketio, web, admin (Latest vorerst):
                      Gefühlt geht mir das ähnlich. Ich habe ohnehin größten Respekt vor Updates, denn meist bin ich ja als User selber Schuld an Problemen, aber wenn plötzlich 3 (Inwand-)Tablets samt Halterungen für die Tonne sein sollten, dann hört der Spaß echt auf.
                      Markus
                      Bitte beachten:
                        SaiBot1981
                        #68
                        Für alle die es interessiert...
                        iPad2 läuft per Browser Safari mit iqontrol ohne Probleme. VIS Web läuft auch ohne Probleme.
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #69
                          Dann bleib auf dem stable channel und gedulde dich einfach länger. Wer keine Zeit für Pflege hat: "never touch a running system".
                          Wer eigenverantwortlich auf latest geht, sollte den Entwicklern und ihrem Engagement fair gegenüber bleiben.
                          Ohne gäbe es ioBroker gar nicht und ihr könntet euch mit irgend einem geschlossenen proprietären System noch viel mehr rum ärgern.
                          ..:: So long! Tom ::..
                          cashC 1 Antwort Letzte Antwort
                          • DiginixD Diginix
                            cashC Offline
                            cashC Offline
                            cash
                            #70
                            @Diginix Das ist aber ein grundsätzliches Problem. Latest sollte besser Beta heißen damit sollte allen klar sein, das so etwas entweder auf ein Testsystem gehört oder auf ein Produktiv-System wenn der Anwender sich entsprechend auskennt und bei Problemen sich selber schnell zu helfen weiß.
                            Gefühlt sind sehr viele User auf latest und wundern sich dann wenn etwas mal nicht läuft oder Probleme macht.
                            • K Kensho
                              Java 4.3.8
                              Admin 4.0.0
                              Nodejs 10.19.0
                              NPM 6.13.4
                              #71
                              @Kensho JavaScript 4.3.9 bitte nutzen!!!
                              • cashC cash
                                #72
                                @cash und du meinst eine Benennung in Beta würde irgendwas ändern. Am endest es aber das gleiche. Das viele User auf latest gehen ist bekannt. Die Lösung dazu nicht ganz so simpel.
                                • Samson71S Samson71
                                  #73
                                  @Samson71 sagte in WICHTIG: Updates von socketio, web, admin (Latest vorerst):
                                  Hm ... der Info Adapter spuckt eine große Warnung aus wegen dem Updates um die es hier geht. Dieser Forum Post ist überall gepinnt und enthält Details und die Begründungen. In Facebook und teamspeak Ostsee such festgepinnt bzw gewarnt. Das Update ist eine neue Major Version - das sagt auch genug das man nachsehen muss.
                                  Und es ist damit deine freie Entscheidung ob du updatest. Ich weiß nicht wie deutlicher wir es mit den aktuellen Mitteln noch machen sollen.
                                  Ich persönlich finde es schade das die alten Browser und neuere an der Stelle leider inkompatibel werden. Auch die Library kann nur wenig dafür. Wir haben jetzt 3 Jahre gewartet mit diesem Schritt. So langsam werden aber die Bugs und Probleme mit aktuellen Geräten unerträglich.
                                  Ohne diese Änderung meckern User und mit ihr meckern sie auch ... ;-) deswegen haben wir jetzt aktualisiert und eine große Info Kampagne gestartet.
                                  Ich verstehe daher dein Unverständnis nicht so ganz.
                                  MaufloM JB_SullivanJ 2 Antworten Letzte Antwort
                                    sigi234S Online
                                    sigi234S Online
                                    #74
                                    Gibs die schon?
                                      MaufloM Offline
                                      MaufloM Offline
                                      Mauflo
                                      #75
                                      @Samson71 ...abgesehen davon gibt es auch andere Möglichkeiten auf den Tablets eine VIS darzustellen als nur mit der ioBroker APP - versuche mal eine Kiosk Browser APP. Hat bei mir wunderbar geklappt!
                                      • sigi234S sigi234
                                        Gibs die schon?
                                        #76
                                        @sigi234 Sorry ignore. Ich hab version verwechselt :-( need to check.
                                          JB_SullivanJ Offline
                                          JB_Sullivan
                                          #77
                                          Also in meinem Info Adapter wird immer noch auf die Cloud Umstellung hingewiesen 🤠
