  4. Test Adapter Vaillant multiMatic/senso und myVaillant
    6.6k
multimaticsensovaillanvr900vr920
965 Beiträge 94 Kommentatoren 414.5k Aufrufe 89 Beobachtet
    Sandmanyz
    vaillant.0.xxxxxxxxxxxxxxxxxxxxxxxxxxxx.systemcontrol.configuration.quickmode.quickmode
    vaillant.0.xxxxxxxxxxxxxxxxxxxxxxxxxxxx.systemcontrol.zones01.configuration.quickmode.quickmode
    vaillant.0.xxxxxxxxxxxxxxxxxxxxxxxxxxxx.systemcontrol.zones01.currently_controlled_by.name
    Wenn ich, aus VIS heraus, einen der drei Werte auf "QM_VENTILATION_BOOST" (Stoßlüften) setzen möchte, erscheint diese Fehlermeldung....
    <tr id="log-line-2178" class="log-line log-severity-error log-from-vaillant-0" style="">
    	<td class="log-column-1">vaillant.0</td><td class="log-column-2">2020-01-22 18:35:16.131</td>
    	<td class="log-column-3">error</td>
    	<td class="log-column-4" title="(3812) '<!doctype html><html lang=\'en\'>
    		<head><title>HTTP Status 404 – Not Found</title>
    		   <style type=\'text/css\'>
    			h1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
    			h2 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
    			h3 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
    			body {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;}
    			b {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
    			p {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}
    			a {color:black;} a.name {color:black;}
    			.line {height:1px;background-color:#525D76;border:none;}
    		   </style>
    		</head>
    		<body>
    		   <h1>HTTP Status 404 – Not Found</h1><hr class=\'line\' />
    		   <p><b>Type</b> Status Report</p>
    		   <p><b>Description</b>The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.</p>
    		   <h3>Apache Tomcat/9.0.27</h3>
    		</body>
    		</html>'">(3812) "&lt;!doctype html&gt;&lt;html lang=\"en\"&gt;&lt;head&gt;&lt;title&gt;HTTP Status 404 – Not Found&lt;/title&gt;&lt;style type=\"text/css\"&gt;h1 {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size
    	</td>
    </tr>
    • O Offline
      O Offline
      onkel-ede
      @tombox
      Habe den Adapter vor einer Stunde neu starten müssen, weil sich die Werte nicht mehr aktualisiert haben.
      1:10 h sind die Werte sauber geloggt worden, danach nix mehr und folgender Logeintrag:
      Das Neusortieren der Belegung unter emf --> report0x erfolgt alle 5 min.
      • O onkel-ede
        @tombox
        tombox
        Eine neue Version:
        bitte livereports, emf und systemcontrol objekt ordner löschen
        neuinstallieren und instanz neustarten
        configurationen werden gelöscht bevor neue daten kommen. das bedeutet man muss die objekte ansicht neuladen um wirklich den aktuellen status zu sehen
        parameter haben eine beschreibung
        quickmode muss über parameters05 eingestellt werden
        reauthentifizierung würde ich erstmal bei 10min lassen. Bitte nochmal feedback ob nach 1h ein 401 Fehler kommt.
        emf reports haben jetzt auch ein richtigen namen.
        • O Offline
          O Offline
          onkel-ede
          @tombox
          Seit 1:20 h läuft alles stabil, auch die Reihenfolge der emf-reports passt.
          Jetzt muss ich mal noch rausbekommen, weshalb sich die Werte der emf-reports seit heute morgen nicht geändert haben.
          Vermutlich wird nur der Tageszählerstand geloggt. Das wird aber der Adapter Sourceanalytics zeigen, wenn sich der Wert Mitternacht ändert.
          • O Offline
            O Offline
            onkel-ede
            @tombox
            nach 9h kam heute morgen wieder der bekannte 401-Fehler und steht alle 10min (wegen der reauthentifizierung?) im Log.
            Die unter emf mit history geloggten Werte haben sich Mitternacht nicht geändert, sind also noch auf dem gleichen Stand wie gestern Mittag. Fraglich, wie Vaillant in der App dann den Stromverbrauch der Heizung visualisiert.
            In den Datenpunkten habe ich nichts gefunden, was mit diesen Werten korrespondiert.
            Allerdings ist der letzte Stand in der App vom 19.01., was dies erklären würde:
            • O onkel-ede
              @tombox
              tombox
              @onkel-ede ich habe mal ein relogin alle 4h hinzugefügt.
              Das mit den aktualisieren der Daten ist eigenartig. Ich hätte vermutet das die App nochmal ein Update erzwingt aber mal sehen wann wie oft neue daten in die App kommen.
                Sandmanyz
                @tombox
                Bei mir gibt's noch Probleme. Es erscheint nach einiger Zeit immer noch die Meldung "NOT_AUTHORIZED".
                Manchmal, aber auch nicht immer, bevor die Werte dann wieder aktualisiert werden, sind im Log diese Fehler zu finden...
                2020-01-23 23:04:38.812  - debug: vaillant.0 (4973) "NOT_AUTHORIZED"
                2020-01-23 23:10:04.286  - info: info.0 (541) Popup news was read...
                2020-01-23 23:10:37.866  - error: vaillant.0 (4973) null
                2020-01-23 23:10:37.866  - error: vaillant.0 (4973) 401
                2020-01-23 23:10:37.867  - error: vaillant.0 (4973) [object Object]
                2020-01-23 23:10:37.961  - debug: vaillant.0 (4973) {"body":{"authToken":"811f84f95c554e4ba16d655908913433"},"meta":{}}
                2020-01-23 23:10:38.341  - debug: vaillant.0 (4973) undefined
                Ich habe einen Aktualisierungsintervall von 10 Minuten hinterlegt.
                Gestern (23.01.) um 19:10 Uhr habe ich den Adapter neugestartet und er hat für knapp zwei Stunden aktualisiert. Danach immer mal wieder nicht.
                23.01.2020 - 19:10 bis 20:58 Uhr - 1h, 48 Min --> läuft
                23.01.2020 - 20:58 bis 23:04 Uh - 2h, 06 Min --> NOT_AUTHORIZED
                23.01.2020 - 23:04 bis 00:52 Uhr - 1h, 48 Min --> läuft
                24.01.2020 - 02:40 bis 04:10 Uhr - 1h, 30 Min --> läuft
                24.01.2020 - 04:10 bis 04:28 Uhr - 18 Min --> NOT_AUTHORIZED
                24.01.2020 - 04:28 bis 04:55 Uhr - 27 Min --> läuft
                24.01.2020 - 04:55 bis 06:43 Uhr - 1h, 57 Min --> NOT_AUTHORIZED
                • S Sandmanyz
                  @tombox
                  tombox
                  @Sandmanyz So ich habe den relogin auf 2h gesetzt und wenn ein 401 kommt dann logt er sich automatisch ein. Sollte also jetzt viel stabiler sein
                  • O Offline
                    O Offline
                    onkel-ede
                    @Sandmanyz
                    In Deinem Log taucht ja auch der error 401 auf. Ich dachte schon bei Dir lief zumindest das Logging der Daten sauber durch. Ich habe gestern 20:45 Uhr die Änderung von tombox installiert und den raspi neu gestartet. Seit heute morgen 08:45 Uhr kommt wieder der error 401 (oder das log auf dem ipad zeigt mir nicht mehr an, muss ich heute abend checken).
                    Die Vorlauftemperatur wurde zwischen 02:40 und 08:50 Uhr nicht getrackt, obwohl der disvovery-Stromzähler zeigt, dass geheizt wurde. Danach wurde wieder sauber geloggt, obwohl ich den Adapter nicht neu gestartet habe.
                    10:35 Uhr kam nun auch noch ein error 500 hinzu.
                    Die Daten werden nun alle 10 min und nicht mehr alle 5 min geloggt.
                    • O onkel-ede
                      @Sandmanyz
                      tombox
                      @onkel-ede 500 ist ein fehler von vaillant. Mal schauen ob es jetzt besser ist.
                      • T tombox
                        Meister MopperM Online
                        Meister Mopper
                        ich habe diesen Adapter jetzt auch installiert, betreibe eine ecovit exclusiv. Hier gleich meine erste Frage. Wo finde ich die Daten für den Stromverbrauch? Ich finde sie weder in der App noch in den Objekten.
                        Proxmox und HA ...
                          tombox
                          @Meister-Mopper Wenn du was nicht in der App findest dann wird es auch nicht in den Objekten sein. Ich denke es müsste unter livereports sein.
                          Meister MopperM O 2 Antworten Letzte Antwort
                          • T tombox
                            Meister Mopper
                            @tombox Nö, da taucht bei mir nicht auf.
                            Ich habe im log "(19194) 401 Reauth Error try to relogin." Der Adapter ist jedoch grün. Zu meinem Verständnis. Ist er grün, obwohl er keine Verbindung zum Vaillant-Server hat?
                            Proxmox und HA ...
                              Meister Mopper
                              Jetzt bekomme ich das:
                              vaillant.0	2020-01-24 12:25:15.703	error	(19194) {"errorCode":"NullPointerException"}
                              vaillant.0	2020-01-24 12:25:15.702	error	(19194) 500
                              vaillant.0	2020-01-24 12:25:15.702	error	(19194) null
                              vaillant.0	2020-01-24 12:25:15.574	error	(19194) {"errorCode":"NullPointerException"}
                              vaillant.0	2020-01-24 12:25:15.574	error	(19194) 500
                              vaillant.0	2020-01-24 12:25:15.573	error	(19194) null
                              vaillant.0	2020-01-24 12:25:14.994	info	(19194) 401 Reauth Error try to relogin.
                              vaillant.0	2020-01-24 12:15:15.332	info	(19194) 401 Reauth Error try to relogin.
                              vaillant.0	2020-01-24 12:15:15.104	info	(19194) 401 Reauth Error try to relogin.
                              vaillant.0	2020-01-24 12:05:15.016	info	(19194) 401 Reauth Error try to relogin.
                              Proxmox und HA ...
                              • T tombox
                                O Offline
                                O Offline
                                onkel-ede
                                @tombox sagte in Test Adapter Vaillant multiMatic v0.0.1:
                                Hier findest Du den Stromverbrauch.Ich bin gerade noch dabei zu validieren, ob dieser Wert umgerechnet werden muss:
                                  tombox
                                  @Meister-Mopper pausier mla den adapter für 5min und installiere ihn neu und start ihn wieder
                                  • O onkel-ede
                                    tombox
                                    @onkel-ede Das sieht man aber nur wenn man in der app den statistik teil hat
                                    • T tombox
                                      Meister Mopper
                                      @tombox Eben, und den finde ich in meiner app nicht.
                                      Proxmox und HA ...
                                        tombox
                                        @Meister-Mopper Dann wird sie von deiner Anlage nicht unterstützt. Keine Ahnung was @onkel-ede besonderes hat.
                                        • O Offline
                                          O Offline
                                          onkel-ede
                                          Habe nix besonders, nur eine Wärmepumpe, welche mit Strom betrieben wird.
                                          Meister Mopper hat einen Gas-Brennwertkessel, welcher mit Gas heizt. Ob es für die integrierten Pumpen? eine Strommessung gibt weiß ich nicht. Gaszähler wird vermutlich auch extern liegen.
