  4. [Gelöst] JSON als Tabelle anzeigen
    1.7k
vis
13 Beiträge 3 Kommentatoren 601 Aufrufe 3 Beobachtet
  • ? Offline
    ich hab im Forum ein Skript gefunden, dass mir Min/Max/24mean/24median ausrechnet und die Daten in einzelne DP ablegt, was auch wunderbar klappt :)
    Zusätzlich wird ein JSON-Objekt angelegt, das wohl zur Visualisierung dient:
    [{"value":"javascript.0.Status.Luftfeuchte.Sensor","max24h":"javascript.0.Status.Luftfeuchte.Sensor.Max_24h","min24h":"javascript.0.Status.Luftfeuchte.Sensor.Min_24h","mean24h":"javascript.0.Status.Luftfeuchte.Sensor.Mean_24h","median24h":"javascript.0.Status.Luftfeuchte.Sensor.Median_24h","max1h":"javascript.0.Status.Luftfeuchte.Sensor.Max_1h","min1h":"javascript.0.Status.Luftfeuchte.Sensor.Min_1h","mean1h":"javascript.0.Status.Luftfeuchte.Sensor.Mean_1h","data":[33.6,33.5,33.5,33.5,33.6,33.4,33.4,33.5,33.4,33.4,33.4,33.3,33.5,33.5,33.5,33.4,33.5,33.3,33.4,33.4,33.6,33.6,33.5,33.5,33.5,33.6,33.5,33.5,33.5,33.5,33.5,33.4,33.4,33.4,33.4,33.5,33.4,33.3,33.4,33.3,33.4,33.2,33.2,33.3,33.2,33.2,33.2,33.3,33.2,33.2,33.3,33.4,33.1,33.1,33.3,33.1,33.3,33.1,33.2,33.2,33.1,33.4,33.1,33,33.1,33,32.9,32.8,32.6,31.6,34.6,35,34.6,34.5,34.3,34.4,34.5,34.4,34.4,34.2,34.1,34.1,34,34.1,34.1,34.3,34.9,34.3,34.3,34.6,34.5,34.6,34.8,34.9,35,35,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2,35.2]},{"value":"javascript.0.Status.Luftfeuchte.Netatmo","max24h":"javascript.0.Status.Luftfeuchte.Netatmo.Max_24h","min24h":"javascript.0.Status.Luftfeuchte.Netatmo.Min_24h","mean24h":"javascript.0.Status.Luftfeuchte.Netatmo.Mean_24h","median24h":"javascript.0.Status.Luftfeuchte.Netatmo.Median_24h","max1h":"javascript.0.Status.Luftfeuchte.Netatmo.Max_1h","min1h":"javascript.0.Status.Luftfeuchte.Netatmo.Min_1h","mean1h":"javascript.0.Status.Luftfeuchte.Netatmo.Mean_1h","data":[42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,42,44,44,43,44,43,44,44,43,43,43,43,43,43,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44,44]},{"value":"javascript.0.Status.Luftfeuchte.Tado","max24h":"javascript.0.Status.Luftfeuchte.Tado.Max_24h","min24h":"javascript.0.Status.Luftfeuchte.Tado.Min_24h","mean24h":"javascript.0.Status.Luftfeuchte.Tado.Mean_24h","median24h":"javascript.0.Status.Luftfeuchte.Tado.Median_24h","max1h":"javascript.0.Status.Luftfeuchte.Tado.Max_1h","min1h":"javascript.0.Status.Luftfeuchte.Tado.Min_1h","mean1h":"javascript.0.Status.Luftfeuchte.Tado.Mean_1h","data":[37.7,37.6,37.6,37.4,37.4,37.2,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.4,37.5,37.7,37.9,37.7,37.3,37,37,36.9,36.9,36.8,36.8,36.7,36.7,36.6,36.5,36.5,36.2,36.2,36.1,36.1,36.1,36,35.8,35.6,35.6,35.4,35.3,35.2,35.1,35,34.9,34.9,34.8,34.8,34.8,34.7,34.6,34.7,34.7,34.8,34.8,34.7,34.8,34.8,34.8,34.8,34.9,34.9,35,35.1,35,35,34.6,34.6,34.6,34.4,31.3,35.9,35.8,36.1,35.9,35.8,35.8,36.1,36.1,35.8,36,36,35.9,36,36.1,36.1,36.3,36.3,36.3,36.4,36.6,36.6,36.8,36.7,36.8,36.9,36.9,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1,37.1]}]
    Dies habe ich versucht mit dem Standard Basic JSON-Tabellen Widget einzubinden, was aber, egal was ich mache, immer wie Kraut und Rüben aussieht 😬
    Gibt es eine Alternative zur einfachen Darstellung? Hat jemand eine Idee, vielleicht @liv-in-sky als Tabellenfachmann? ;-)
    liv-in-skyL sigi234S 2 Antworten Letzte Antwort
      liv-in-skyL Offline
      liv-in-skyL Offline
      @HeinrichB
      moin
      man kann auch ein json über eine schleife laufen lassen und dann in dem dir bekannten tabellen script integrieren
      welche spalten willst du anzeigen ? also wie soll das dargestellt werden - natürlich gibt es eine limitierung für mein script, was das layout angeht - es gibt einen punkt im json , der data heißt - darin sind maßig temperaturwerte - sollen die in der tabelle sichtbar werden ?
      vielleicht kannst du mit excel oder ähnlichen eine kleine voransicht machen - nur zur übersicht - muss kein kunstwerk sein
      • liv-in-skyL liv-in-sky
        @HeinrichB
        moin
        @liv-in-sky Hallo :)
        Danke für die Antwort, aber da lohnt der Aufwand erstmal nicht. Es ist eine kleine statistische Auswertung bei mir zuhause. Wenn das mit Bordmitteln gegangen wäre, super. Aber ansonsten dann doch eher das andere Thema mit den Klimadaten :)
          liv-in-skyL Offline
          liv-in-skyL Offline
          @HeinrichB was wolltest du berechnen
          eigentlich sind es nur 8 werte, die ausgelesen werden müssen also 8 spalten und dann wären noch die daten dazu - was wilst du damit darstellen - einen duchschnitt oder nur den höchsten wert
            @liv-in-sky
            Das Skript habe ich hier im Forum gefunden und das ermittelt für definierbare Sensoren min/max/avg/med für 1h und 24h. Find ich ganz spannend und das liegt auch alles vor.
            Wenn, dann würde ich mir schon alle Spalten anzeigen lassen wollen.
            Wenn Du magst, schick ich dir mein aktuelles Skript mal zu
              @liv-in-sky
              liv-in-skyL Offline
              liv-in-skyL Offline
              @HeinrichB
              irgendwie verstehen wir uns nicht - die 8 datenpunkte (grüner pfeil) auslesen ist klar - aber dann gibt es im json einen unterpunkt , in dem sind viele temperatur daten (rote pfeile) - die sollen doch nicht angezeigt werden - die müssen verarbeitet werden bzw sind die in den "grünen" pfeilen" verarbeitet und wir brauchen die nicht in der tabelle ?
              wenn du nur die 8 anderen punkte willst (grün)- die ja als datenpunkte existieren - können wir direct eine schleife darüberlaufen lassen - das wäre dann wie bei den anderen scripten - dann brauchen wir das json garnicht - dann wäre es egal, ob ich batterie oder ping daten auslese - oder eben diese daten - immer der selbe ablauf
                @HeinrichB
                @liv-in-sky
                Du, ich will dich damit nicht unnötig auslasten, daher nur wenn Du willst.
                Ich bin nicht scharf auf das JSON als solches, sondern eher auf die Ergebnisse ;-)
                Ich gebe Dir mal den kompletten Part aus dem DP. Ob Weg A oder B ist da jetzt
                nicht elementar für mich. Dachte nur, dass das fertige JSON vielleicht die Sache vereinfach :)
                Tado habe ich zugeklappt gelassen.
                Hier mein Skript, dass die DP erzeugt.NICHT VON MIR, sondern aus dem Forum; ich beanspruche daher keine Urheberschaft ;-)
                // Berechnung von gleitendem Durchschnitt, Minimum und Maximum über einen Zeitraum
                // Version 1.4.1
                "use strict";
                const idTable = 'javascript.0.Status.Tabelle';
                createState(idTable, '', {type: 'string'});
                // Berechnet Min/Max, Durschschnitt und Median über die letzten 24h.
                // Berechnet Min/Max, Durschschnitt über die letzte 1h.
                // IDs aller benötigten Datenpunkte
                // Als Array im Array mit folgendem Format:
                //  1\.   original Datenpunktname
                //  2\.  neuer Datenpunktname
                //         Beispiel:   javascript.0.Status.Temperatur.Außen
                //                  javascript.0.Status.Luftfeuchtigkeit.Außen
                //  3\.   Beschreibung des Messwertes (zur Erzeugung neue Datenpunkte)
                //         Beispliele:   Temperatur
                //                  Luftfeuchtigkeit
                //   4\.  Einheit (zur Erzeugung neue Datenpunkte)
                //         Beispiele:   °C, %
                // Ist beliebig erweiterbar und für beliebige Werte nutzbar.
                // Beispiel 1:
                // const idData = [['hm-rpc.3.CUX3200312.1.TEMPERATURE','javascript.0.Status.Temperatur.Außen','Temperatur','°C'],
                //                 ['hm-rpc.3.CUX9002580.1.HUMIDITY'   ,'javascript.0.Status.Luftfeuchtigkeit.Außen','Luftfeuchtigkeit','%']];
                // Beispiel 2:
                // const idData = [['hm-rpc.3.CUX3200312.1.TEMPERATURE','javascript.0.Status.Außen.Temperatur','Temperatur','°C'],
                //                 ['hm-rpc.3.CUX9002580.1.HUMIDITY'   ,'javascript.0.Status.Außen.Luftfeuchtigkeit','Luftfeuchtigkeit','%'],
                //                 ['hm-rpc.3.CUX4007637.1.Data'   ,'javascript.0.Status.Außen.Lichtstärke','Lichtstärke','lux']];
                const idData = [['sonoff.0.Klimasensor.BME280_Humidity','javascript.0.Status.Luftfeuchte.Sensor','Rel. Feuchte','%'],
                                ['netatmo.0.XXX.Wohnzimmer.Humidity.Humidity'   ,'javascript.0.Status.Luftfeuchte.Netatmo','Rel. Feuchte','%'],
                                ['tado.0.337268.Rooms.7.Actual_Humidity'   ,'javascript.0.Status.Luftfeuchte.Tado','Rel. Feuchte','%']];
                //Datenpunkt zur Speicherung aller internen Daten
                const dpData='javascript.0.Status.Statistic';
                // Implementierung -- hier nichts mehr ändern
                // globale Konstanten
                const tc = 10;         // Abtastrate in Minuten
                const statDataLength24 = Math.round((24 * 60) / tc); // Anzahl der Werte für 24h
                const statDataLength1 = Math.round(60 / tc); // Anzahl der Werte für stündlich
                // globale Variablen
                var listStatData;  //interne Speicherung aller Werte
                //Funktion zum einmaligem initialisieren aller Datenpunkte
                function initializeStatData() {
                   // Datenpunkt zur Speicherung der internen Werte erzeugen
                   createState(dpData, 0, false, {
                      read: true,
                      write: true,
                      desc: 'Statistische Daten',
                      type: 'string',
                      def: '',
                      role: 'json'
                   //internes Array initialisieren
                    var needInit = false;
                   try {
                      listStatData = JSON.parse(getState(dpData).val);
                   } catch (ex) {
                      needInit = true;
                   if (needInit || !listStatData || (listStatData.length < idData.length)) {
                      listStatData = new Array(idData.length);
                   //logDebug('initializeStatData for', dpData, listStatData);
                   for (var i = 0; i < idData.length; i++) {
                        if (!listStatData[i]) { listStatData[i] = {}; }
                        listStatData[i].value       = idData[i][1];
                        listStatData[i].max24h		= idData[i][1] + '.Max_24h';
                        listStatData[i].min24h		= idData[i][1] + '.Min_24h';
                        listStatData[i].mean24h		= idData[i][1] + '.Mean_24h';
                        listStatData[i].median24h	= idData[i][1] + '.Median_24h';
                	listStatData[i].max1h		= idData[i][1] + '.Max_1h';
                	listStatData[i].min1h		= idData[i][1] + '.Min_1h';
                	listStatData[i].mean1h		= idData[i][1] + '.Mean_1h';
                	createState(listStatData[i].value, 0, false, {
                            read: true,
                            write: true,
                            desc: idData[i][2]+ ' Aktueller Wert',
                      	    type: 'number',
                            def: 0,
                            unit: idData[i][3],
                            role: 'value'
                	createState(listStatData[i].max24h, 0, false, {
                            read: true,
                            write: true,
                            desc: idData[i][2] + ' Maximum',
                            type: 'number',
                            def: 0,
                            unit: idData[i][3],
                            role: 'value'
                       createState(listStatData[i].min24h, 0, false, {
                            read: true,
                            write: true,
                            desc: idData[i][2] + ' Minimum',
                            type: 'number',
                            def: 0,
                	    unit: idData[i][3],
                            role: 'value'
                       createState(listStatData[i].mean24h, 0, false, {
                            read: true,
                            write: true,
                            desc: idData[i][2] + ' Mittelwert',
                            type: 'number',
                            def: 0,
                            unit: idData[i][3],
                            role: 'value'
                      createState(listStatData[i].median24h, 0, false, {
                            read: true,
                            write: true,
                            desc: idData[i][2] + ' Median',
                            type: 'number',
                            def: 0,
                	        unit: idData[i][3],
                            role: 'value'
                      createState(listStatData[i].max1h, 0, false, {
                            read: true,
                            write: true,
                            type: 'number',
                            def: 0,
                            unit: idData[i][3],
                            role: 'value'
                      createState(listStatData[i].min1h, 0, false, {
                            read: true,
                            write: true,
                            type: 'number',
                            def: 0,
                            unit: idData[i][3],
                            role: 'value'
                      createState(listStatData[i].mean1h, 0, false, {
                            read: true,
                            write: true,
                            type: 'number',
                            def: 0,
                	    unit: idData[i][3],
                	    role: 'value'
                      if (needInit || !listStatData[i].data || (listStatData[i].data.length != statDataLength24)) {
                            listStatData[i].data	= new Array(statDataLength24);
                            // 1\. Script start: Liste und String-Datenpunkt füllen
                            var x = getState(idData[i][0]).val;
                            for (var j = 0; j < statDataLength24; j++) {
                            listStatData[i].data[j] = x;
                          //logDebug(listStatData[i], i);
                            setStateDelayed(listStatData[i].value, x, false, 1000);
                            setStateDelayed(listStatData[i].min24h, x, false, 1000);
                            setStateDelayed(listStatData[i].max24h, x, false, 1000);
                            setStateDelayed(listStatData[i].mean24h, x, false, 1000);
                            setStateDelayed(listStatData[i].median24h, x, false, 1000);
                            setStateDelayed(listStatData[i].min1h, x, false, 1000);
                            setStateDelayed(listStatData[i].max1h, x, false, 1000);
                            setStateDelayed(listStatData[i].mean1h, x, false, 1000);
                   setState(dpData, JSON.stringify(listStatData));
                //Berechnung der Werte
                 function calcStatData() {
                    if (!listStatData || (idData.length != listStatData.length)) {
                         initializeStatData();
                     //logDebug('starting calcStatData');
                    var table = [];
                       var obj = {};
                       var sensor = listStatData[i].value.split('.');
                       obj.Sensor = sensor[4] + ' ' + sensor[3];
                       listStatData[i].data.pop(); //Remove the last element of an array
                       var x = parseFloat(getState(idData[i][0]).val);
                       obj.Wert = x;
                       listStatData[i].data.unshift(x); //Add new items to the beginning of an array
                       setState(listStatData[i].value, x);
                       var min = x;
                       var max = x;
                       var sum = 0.0;
                          var s = parseFloat(listStatData[i].data[j]);
                          if (s < min) min = s;
                          if (s > max) max = s;
                          sum += s;
                          if (j == (statDataLength1-1)) {
                             setState(listStatData[i].min1h, min);
                             setState(listStatData[i].max1h, max);
                             setState(listStatData[i].mean1h, round(sum / statDataLength1, 2));
                       setState(listStatData[i].min24h, min);
                       setState(listStatData[i].max24h, max);
                       setState(listStatData[i].mean24h, round(sum / statDataLength24, 2));
                       setState(listStatData[i].median24h, getMedian(listStatData[i].data));
                       obj.Min_24h = min;
                       obj.Max_24h = max;
                       obj.Mean_24h = round(sum / statDataLength24, 2);
                       obj.Median_24h = getMedian(listStatData[i].data);
                       table[i] = obj;
                    setState(idTable, JSON.stringify(table), true);
                function getMedian(args) {
                  if (!args.length) {return 0}
                  var numbers = args.slice(0).sort((a,b) => a - b);
                  var middle = Math.floor(numbers.length / 2);
                  var isEven = numbers.length % 2 === 0;
                  return isEven ? (numbers[middle] + numbers[middle - 1]) / 2 : numbers[middle];
                 * round a number
                 * @param    value  to round
                 * @param    exp    exponent to round
                 * @returns         the round number
                function round(value, exp) {
                  if (typeof exp === 'undefined' || +exp === 0)
                    return Math.round(value);
                  value = +value;
                  exp = +exp;
                  if (isNaN(value) || !(typeof exp === 'number' && exp % 1 === 0))
                    return NaN;
                  // Shift
                  var values = value.toString().split('e');
                  value = Math.round(+(values[0] + 'e' + (values[1] ? (+values[1] + exp) : exp)));
                  // Shift back
                  return +(values[0] + 'e' + (values[1] ? (+values[1] - exp) : -exp));
                schedule('*/' + tc + ' * * * *', function () {
                   calcStatData();
                  @liv-in-sky
                  // Version 1.4.1
                  "use strict";
                  //                  Luftfeuchtigkeit
                  //         Beispiele:   °C, %
                  // Beispiel 1:
                  // Beispiel 2:
                        read: true,
                        write: true,
                        type: 'string',
                        def: '',
                        role: 'json'
                     try {
                     } catch (ex) {
                        needInit = true;
                              read: true,
                              write: true,
                        	    type: 'number',
                              def: 0,
                              unit: idData[i][3],
                              role: 'value'
                              read: true,
                              write: true,
                              type: 'number',
                              def: 0,
                              unit: idData[i][3],
                              role: 'value'
                              read: true,
                              write: true,
                              type: 'number',
                              def: 0,
                  	    unit: idData[i][3],
                              role: 'value'
                              read: true,
                              write: true,
                              type: 'number',
                              def: 0,
                              unit: idData[i][3],
                              role: 'value'
                              read: true,
                              write: true,
                              type: 'number',
                              def: 0,
                  	        unit: idData[i][3],
                              role: 'value'
                              read: true,
                              write: true,
                              type: 'number',
                              def: 0,
                              unit: idData[i][3],
                              role: 'value'
                              read: true,
                              write: true,
                              type: 'number',
                              def: 0,
                              unit: idData[i][3],
                              role: 'value'
                              read: true,
                              write: true,
                              type: 'number',
                              def: 0,
                  	    unit: idData[i][3],
                  	    role: 'value'
                      var table = [];
                         var obj = {};
                         obj.Wert = x;
                         var min = x;
                         var max = x;
                         var sum = 0.0;
                            sum += s;
                         obj.Min_24h = min;
                         obj.Max_24h = max;
                         table[i] = obj;
                   * round a number
                    value = +value;
                    exp = +exp;
                      return NaN;
                    // Shift
                    // Shift back
                     calcStatData();
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  @HeinrichB ich laube ich verstehe - dauert ein wenig aber ich schau mal
                    @liv-in-sky Und nochmals; es ist ein Nebenschauplatz. Ich wollte nix eigenes, es ging mir nur um die Darstellung, wenn es da ein Standardfeature gäbe. Wie geschrieben: Klimadaten fände ich spannender :)
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @HeinrichB
                      probier mal
                      wenn es nicht funktioniert, mach ein json export dieser struktur
                      finetuning darfst du machen - farben, überschriften , ...
                      //HIER WIRD PFAD UND FILENAME DEFINIERT
                      const path = "/htmlexample.html";                   //FIlenamen definieren
                      const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                      let   braucheEinFile=true;                          // bei true wird ein file geschrieben
                      let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                      let dpVIS="controll-own.0.AAATEST.TestHTML"         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
                      let mySchedule=" */20 * * * * * ";                       //jede minute
                      //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 5
                      var htmlFeld1='Instanz';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left,right or center
                      var htmlFeld2='Alive';        var Feld2lAlign="right";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                      var htmlFeld3='MemUsed';         var Feld3lAlign="right";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                      var htmlFeld4='MemTotal';        var Feld4lAlign="right";                    // überschrift Tabellen Spalte4 und  Ausrichtung left,right or center
                      var htmlFeld5='Status';        var Feld5lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                      var htmlFeld6='Status';        var Feld6lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                      var htmlFeld7='Status';        var Feld7lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                      var htmlFeld8='Status';        var Feld8lAlign="center";                    // überschrift Tabellen Spalte5 und  Ausrichtung left,right or center
                      //hier werden die styles für die tabelle definiert
                      //ÜBERSCHRIFT ÜBER TABELLE
                      let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
                      let   htmlSignature=true;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                      const htmlFeldUeber='Instanzen IOBroker';              // Überschrift und Signature
                      const htmlFarbUber="white";                         // Farbe der Überschrift
                      const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                      const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                      //MEHRERE TABELLEN NEBENEINANDER
                      let   mehrfachTabelle=4;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                      const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                      const htmlFarbTableColorUber="black";               // Überschrift in der tabelle - der einzelnen Spalten
                      //GANZE TABELLE
                      let abstandZelle="1";
                      let weite="auto";                                     //Weite der Tabelle
                      let zentriert=true;                                   //ganze tabelle zentriert
                      const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                      const htmlSchriftart="Helvetica";
                      const htmlSchriftgroesse="14px";
                      //FELDER UND RAHMEN
                      let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                      const htmlFarbFelderschrift="#000000";                  // SchriftFarbe der Felder
                      const htmlFarbFelderschrift2="#000000";                 // SchriftFarbe der Felder für jede 2te Tabelle
                      const htmlFarbTableColorGradient1="grey";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                      const htmlFarbTableColorGradient2="white";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                      const htmlFarbTableBorderColor="blue";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                      let htmlRahmenLinien="all";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                      const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                      // HIER NICHTS  ÄNDERN
                      let borderHelpBottum;
                      let borderHelpRight;
                      let htmlcenterHelp;
                      let htmlcenterHelp2;
                      if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                      if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                      if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                      if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                      zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                      zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                      const htmlZentriert='<center>'
                      const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                         "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                         " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                        // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                         " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                         " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                         "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                         " </style></head><body> <div>";
                      //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                      const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                            "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                      const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
                      const htmlTabUeber3="</tr>";
                      //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 5
                      var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+htmlFeld4+"&ensp;</td><td  align="+Feld5lAlign+">&ensp;"+htmlFeld5+"&ensp;</td><td  align="+Feld6lAlign+">&ensp;"+htmlFeld6+"&ensp;</td><td  align="+Feld7lAlign+">&ensp;"+htmlFeld7+"&ensp;</td><td  align="+Feld8lAlign+">&ensp;"+htmlFeld8+"&ensp;</td>";
                      var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+
                                         "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld4+
                                         "&ensp;</td><td align="+Feld5lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld5+"&ensp;</td><td align="+Feld6lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld6+"&ensp;</td><td align="+Feld7lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld7+"&ensp;</td><td align="+Feld8lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\"&ensp;>"+htmlFeld8+"&ensp;</td>";
                      var htmlOut="";
                      var mix;
                      var counter;
                      var val1; var val2; var val0; var val3; var val4; var val5; var val6; var val7;
                      var htmlTabUeber="";
                      function writeHTML(){
                      htmlOut="";
                      counter=-1;
                      htmlTabUeber="";
                      switch (mehrfachTabelle) {
                         case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                         case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                         case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2+htmlTabUeber2+htmlTabUeber3; break;
                         case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                      if (!UeberschriftSpalten) {htmlTabUeber=""}
                      //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                      //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2,val3,val4!!!------------------------------------------------------------
                      $('javascript.*.Status.*.*.Max_1h').each(function(id, i) {           // hier eigene schleife definieren
                              var ida = id.split('.');
                              if( !(id.includes("vis") || id.includes("devices") ||  id.includes("ssss") )){
                                counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                                val0=ida[4];
                                val1=getState(id);
                               // let val1help=getState(id.replace("alive","uptime")).val;
                                val2=(getState(id.replace("Max_1h","Max_24h")).val).toString()+" %";
                                val3=(getState(id.replace("Max_1h","Mean_1h")).val).toString()+" %";
                                val4=(getState(id.replace("Max_1h","Mean_24h")).val).toString()+" %";
                                val5=(getState(id.replace("Max_1h","Median_24h")).val).toString()+" %";
                                val6=(getState(id.replace("Max_1h","Min_1h")).val).toString()+" %";
                                val7=(getState(id.replace("Max_1h","Min_24h")).val).toString()+" %";
                           tabelleBind(); //HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                         }}); //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                      //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                            tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                      } // function ende
                      //MAIN:
                      schedule(mySchedule,  function () {
                       writeHTML();
                       if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                       writeHTML();
                         				 function tabelleBind(){
                           //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 5 Felder definiert, braucht man hier 5 Werte
                               case 1:                    htmlOut=htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>"; break;
                              case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                    else {htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>";} break;
                              case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                    else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>";}
                                                               } break;
                              case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>"; }
                                                        else {if(counter%2==1 )  { htmlOut = htmlOut+"<td  align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}
        else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+"  style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td><td  align="+Feld4lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val3+"&ensp;</td><td align="+Feld5lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td align="+Feld1lAlign+" >&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val2+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val3+"&ensp;</td><td align="+Feld4lAlign+">&ensp;"+val4+"&ensp;</td><td align="+Feld6lAlign+">&ensp;"+val5+"&ensp;</td><td align="+Feld7lAlign+">&ensp;"+val6+"&ensp;</td><td align="+Feld8lAlign+">&ensp;"+val7+"&ensp;</td>";}}
                                                               } break;
                           } //switch ende
                      function tabelleFinish() {
                            // tabelle fertigstellen
                               case 1:    break;
                               case 2:    mix=Math.abs(((counter+1)%2)-mehrfachTabelle);
                                          if(mix==1)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                          break;
                               case 3:    mix =Math.abs(((counter+1)%3)-mehrfachTabelle);
                                          if(mix==2)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                          break;
                               case 4:    mix=Math.abs(((counter+1)%4)-mehrfachTabelle);
                                          if(mix==3)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                          break; }
                                          var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                              if (!htmlSignature) htmlUnter="";
                                //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                 var htmlOutVIS="";
                               //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                  if (htmlUberschrift)
                                      { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                                    } else {
                                     zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                      // log("bin raus aus tabelleBind");
                                 if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                       var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                       var htmlEnd="</table>"+htmlUnter+"</div></body>";
                       //mit oder ohne überschrift - zentriert oder links
                      htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                       //log(htmlOut);
                        sigi234S Online
                        sigi234S Online
                        @HeinrichB
                        Einfaches Widget:
                        [{"tpl":"tplTableBody","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","static_value":"[{\"Title\": \"first\", \"Value\": 1, \"_Description\": \"Value1\"}, {\"Title\": \"second\", \"Value\": 2, \"_Description\": \"Value2\"}]","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"table_oid":"javascript.0.Status.Tabelle","new_on_top":true,"max_rows":"4","colCount":"6","colWidth1":"200px","colWidth2":"100px","colWidth3":"100px","colWidth4":"100px","colWidth5":"100px","colWidth6":"100px","hide_header":false,"class":"vis-style","colName3":"Min 24h","colName4":"Max 24h","colName5":"Mean 24h","colName6":"Median 24h"},"style":{"left":"36px","top":"50px","width":"727px","height":"137px","z-index":"1","color":"#cdcace","background-color":"transparent","text-align":"left","font-size":"large","border-width":"","border-style":"none","border-radius":"","border-color":"","font-family":"RobotoCondensed-Light"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"","title_color":"black","title_top":"-10","title_left":"15","header_height":"0","header_color":"#d60000","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"40px","top":"74px","width":"720px","height":"1px","z-index":"4","background-color":"#afacac","font-family":"RobotoCondensed-Light"},"widgetSet":"basic"},{"tpl":"tplFrame","data":{"visibility-cond":"==","visibility-val":1,"title":"Info","title_color":"#d7cec1","title_top":"-29","title_left":"0","header_height":"0","header_color":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/icons-mfd-svg/control_ok.svg","signals-icon-size-0":"72","signals-blink-0":false,"signals-horz-0":"90","signals-vert-0":"81","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"false","signals-icon-1":"/icons-mfd-svg/control_ok.svg","signals-icon-size-1":"72","signals-blink-1":false,"signals-horz-1":"90","signals-vert-1":"81","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/main/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-oid-0":"","signals-oid-1":"","signals-icon-style-1":""},"style":{"left":"19px","top":"34px","width":"765px","height":"174px","font-family":"RobotoCondensed-Light","font-style":"normal","font-variant":"normal","font-weight":"","font-size":"x-large","z-index":"0","background":"#474747","border-width":"0px","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","color":"#d7cec1 "},"widgetSet":"basic"}]
                        • sigi234S sigi234
                          @HeinrichB
                          Einfaches Widget:
                          @sigi234
                          Vielen Dank :)
                            @HeinrichB
                            probier mal
                            //GANZE TABELLE
                            //FELDER UND RAHMEN
                            let htmlcenterHelp;
                            var htmlOut="";
                            var mix;
                            var counter;
                            htmlOut="";
                            counter=-1;
                            htmlTabUeber="";
                                      val0=ida[4];
                                      val1=getState(id);
                            } // function ende
                            //MAIN:
                             writeHTML();
                             writeHTML();
        } break;
        } break;
                                 } //switch ende
                                     case 1:    break;
                                                break;
                                                break;
                                                break; }
                                       var htmlOutVIS="";
                                          } else {
                             //log(htmlOut);
                            @liv-in-sky Danke; schau ich mir auch an :)
