  4. Vis wird überlagert angezeigt
    6.0k
    1.5k
vis
11 Beiträge 2 Kommentatoren 325 Aufrufe 2 Beobachtet
  • H Offline
    Hagen Fischer
    Habe ein grosses Problem...
    Betreibe iobroker auf einem Debian System zusammen mit vis 1.2.2.
    Mir wird vis aber nur überlagert angezeigt. Kann mir bitte jemand helfen?
    Bei der Installation kommt dieser Log zustande...
    $ ./iobroker upgrade vis
    Update vis from @1.1.4 to @1.2.2
    NPM version: 6.13.4
    npm install iobroker.vis@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan.h:192,                 from ../src/epoll.cc:15:../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:../node_modules/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’   return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);               ^~~~~~~~
    In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv);                                                            ^
    In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv);                                                            ^In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv);                                                              ^In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv);                                                              ^In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:170:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv);                                                              ^In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv);                                                              ^In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:163:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:../node_modules/nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^In file included from ../src/epoll.cc:12:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:177:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/epoll.cc:15:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1732:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Add(Nan::NAN_METHOD_ARGS_TYPE)’:../src/epoll.cc:210:44: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   int err = epoll->Add(info[0]->Int32Value(), info[1]->Int32Value());                                            ^
    In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:26,                 from ../src/epoll.cc:11:/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/epoll.cc:210:67: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   int err = epoll->Add(info[0]->Int32Value(), info[1]->Int32Value());        ^In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:26,                 from ../src/epoll.cc:11:/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Modify(Nan::NAN_METHOD_ARGS_TYPE)’:../src/epoll.cc:230:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());                                               ^In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:26,                 from ../src/epoll.cc:11:/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/epoll.cc:230:70: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());        ^In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:26,                 from ../src/epoll.cc:11:/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:../src/epoll.cc:247:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]   int err = epoll->Remove(info[0]->Int32Value());                                               ^In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:26,                 from ../src/epoll.cc:11:/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2478:46: note: declared here   V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);                                              ^~~~~~~~~~/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/epoll.cc:12:../src/epoll.cc: At global scope:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:570:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:604:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/epoll.cc:381:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(epoll, Epoll::Init) ^~~~~~~~~~~
    In file included from ../src/epoll.cc:11:/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.15.2/include/node/node_object_wrap.h:85:78:   required from here/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../node_modules/nan/nan_object_wrap.h:66:61:   required from here/home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    make: *** [epoll.target.mk:105: Release/obj.target/epoll/src/epoll.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:189:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.19.0-6-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR!
     cwd /opt/iobroker/node_modules/epollgyp ERR! node -v v10.15.2gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
    upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
    Adapter "system.adapter.vis.0" restarted.
    upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
    upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
    upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
    upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
    upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/rgraph/img/Prev_thermometr.png widgets/rgraph/img/Prev_thermometr.png image/png
    upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/img/Prev_Shutter.png widgets/metro/img/Prev_Shutter.png image/png
    upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/lockLocked.png widgets/hqwidgets/img/lockLocked.png image/png
    upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/js/table.js widgets/basic/js/table.js application/javascript
    upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars.html widgets/bars.html text/html
    upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
    upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
    upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
    upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
    upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
    upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
    upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
    upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
    upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
    upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
    upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
    upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
    upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
    upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
    upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
    upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
    upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
    upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
    upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
    upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
    upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
    upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
    upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
    upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
    upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
    upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
    upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
    upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
    upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
    upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
    upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
    Update "system.adapter.vis.0"
    Adapter "vis" updated
    process exited with code 0
    Und bei öffnen des vis Editors sieht es dann so aus:
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    sigi234S 2 Antworten Letzte Antwort
    • H Hagen Fischer
      NPM version: 6.13.4
      gyp
       ERR! build error
      sigi234S Online
      sigi234S Online
      @Hagen-Fischer
      • H Hagen Fischer
        NPM version: 6.13.4
        gyp
         ERR! build error
        sigi234S Online
        sigi234S Online
        @Hagen-Fischer
        Browser Cache leeren.
        • H Offline
          Hagen Fischer
          leider keine Veränderung...
          • H Hagen Fischer
            sigi234S Online
            sigi234S Online
            @Hagen-Fischer sagte in Vis wird überlagert angezeigt:
            Vis Neustart?
            • H Offline
              Hagen Fischer
              auch schon versucht...Vis neu installiert, iobroker neu gestartet, vis downgrade, Rechner neu gestartet....
              • H Hagen Fischer
                sigi234S Online
                sigi234S Online
                Was sagt den F12?
                • H Offline
                  Hagen Fischer
                  hab keine F12 Taste auf meinem Mac und am Debian Rechner passiert nichts wenn ich F12 drücke...😞
                  • H Hagen Fischer
                    sigi234S Online
                    sigi234S Online
                    Was kommt bei:
                    cd /opt/iobroker
                    iobroker list instances
                    node -v
                    nodejs -v
                    npm -v
                    • H Offline
                      Hagen Fischer
                      @sigi234 said in Vis wird überlagert angezeigt:
                      root@debian:/opt/iobroker# iobroker list instances
                      + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                : alexa2                -  enabled
                      + system.adapter.broadlink2.0            : broadlink2            -  enabled
                      + system.adapter.cloud.0                 : cloud                 -  enabled
                      + system.adapter.discovery.0             : discovery             -  enabled
                        system.adapter.habpanel.0              : habpanel              -  enabled
                      + system.adapter.harmony.0               : harmony               -  enabled
                        system.adapter.ical.0                  : ical                  -  enabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png -  enabled
                        system.adapter.icons-icons8.0          : icons-icons8          -  enabled
                        system.adapter.icons-material-png.0    : icons-material-png    -  enabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
                        system.adapter.icons-ultimate-png.0    : icons-ultimate-png    -  enabled
                      + system.adapter.info.0                  : info                  -  enabled
                      + system.adapter.javascript.0            : javascript            -  enabled
                      + system.adapter.pushover.0              : pushover              -  enabled
                      + system.adapter.ring.0                  : ring                  -  enabled
                        system.adapter.shelly.0                : shelly                - disabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled
                      + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      + system.adapter.text2command.0          : text2command          -  enabled
                        system.adapter.vis.0                   : vis                   -  enabled
                      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.yahka.0                 : yahka                 -  enabled
                      + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ECE994-if00
                      + instance is alive
                      root@debian:/opt/iobroker# node -v
                      v10.15.2
                      root@debian:/opt/iobroker# nodejs -v
                      v10.15.2
                      root@debian:/opt/iobroker# npm -v
                      6.13.4
                      • H Offline
                        Hagen Fischer
                        Habe keine Ahnung was das Problem sein soll...
                        Google sagt irgendwie, das ich der einzige mit dem Problem bin (nichts zu finden)...
                        82.7k
