  4. Radar2 Startet nicht
radar2 adapterradar 2radar2radar2.0 error
9 Beiträge 7 Kommentatoren 1.2k Aufrufe 6 Beobachtet
  • WebrangerW Offline
    WebrangerW Offline
    Webranger
    Ich habe gerade versucht Radar2 nach Anleitung zu installieren.
    Nach kurzer grün phase wird die instanz sofort wieder rot
    hier mal die logs:
    host.debian-iobroker	2020-01-20 20:18:18.136	error	Caught by controller[0]: spawnargs: [ '-n', '192.168.178.79' ] }
    host.debian-iobroker	2020-01-20 20:18:18.136	error	Caught by controller[0]: path: 'arp',
    host.debian-iobroker	2020-01-20 20:18:18.136	error	Caught by controller[0]: syscall: 'spawn arp',
    host.debian-iobroker	2020-01-20 20:18:18.136	error	Caught by controller[0]: code: 'ENOENT',
    host.debian-iobroker	2020-01-20 20:18:18.136	error	Caught by controller[0]: errno: 'ENOENT',
    host.debian-iobroker	2020-01-20 20:18:18.136	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
    host.debian-iobroker	2020-01-20 20:18:18.135	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
    host.debian-iobroker	2020-01-20 20:18:18.135	error	Caught by controller[0]: at onErrorNT (internal/child_process.js:362:16)
    host.debian-iobroker	2020-01-20 20:18:18.135	error	Caught by controller[0]: at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19)
    host.debian-iobroker	2020-01-20 20:18:18.134	error	Caught by controller[0]: { Error: spawn arp ENOENT
    radar2.0	2020-01-20 20:18:18.105	info	(16004) Adapter disconnected and stopped with dostop(false) and callback(true)
    radar2.0	2020-01-20 20:18:18.104	error	at process._tickCallback (internal/process/next_tick.js:181:9)
    radar2.0	2020-01-20 20:18:18.104	error	at _combinedTickCallback (internal/process/next_tick.js:139:11)
    radar2.0	2020-01-20 20:18:18.104	error	at onErrorNT (internal/child_process.js:362:16)
    radar2.0	2020-01-20 20:18:18.104	error	at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19)
    radar2.0	2020-01-20 20:18:18.104	error	(16004) Error: spawn arp ENOENT
    radar2.0	2020-01-20 20:18:18.103	error	(16004) uncaught exception: spawn arp ENOENT
    radar2.0	2020-01-20 20:18:17.740	info	(16004) Will try to scan BT devices: false
    radar2.0	2020-01-20 20:18:17.648	info	(16004) radar2 set to scan every 20 seconds and printers every 720 minutes.
    radar2.0	2020-01-20 20:18:17.647	info	(16004) arp-scan will use the following interfaces: [ 'ens18' ]
    radar2.0	2020-01-20 20:18:17.646	info	(16004) Remove name end for host names: .fritz.box
    radar2.0	2020-01-20 20:18:17.645	info	(16004) use known IP list: [ '1.1.1.1' ]
    radar2.0	2020-01-20 20:18:17.644	info	(16004) use known BT list: []
    radar2.0	2020-01-20 20:18:17.643	info	(16004) radar2 set to flag items away if they are not seen for 2 minutes
    radar2.0	2020-01-20 20:18:17.643	warn	(16004) node-bluetooth not found!
    radar2.0	2020-01-20 20:18:17.641	info	(16004) found '@abandonware/noble'
    radar2.0	2020-01-20 20:18:17.404	info	(16004) Connected with '0.0.0.0' for DHCP Scan
    radar2.0	2020-01-20 20:18:17.233	info	(16004) radar2 initialization started...
    System:
    Betriebssystem
    linux
    os
    linux
    Architektur
    x64
    CPUs
    Geschwindigkeit
    1497 MHz
    Modell
    Common KVM processor
    RAM
    5.8 GB
    System Betriebszeit
    00:19:26
    Node.js
    v8.15.0 (Es gibt eine neuere Version: v8.17.0 - Empfohlene Version v10.18.1)
    NPM
    6.4.1
    Festplatte Größe
    27.43 GB
    Festplatte frei
    20.96 GB
    Anzahl der Adapter
    313
    Betriebszeit
    00:19:19
    Aktive Instanzen
    28
    Hostname
    debian-iobroker
    Kann mir evtl jemand helfen?
    Gruss
    Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
    ostseereiterO 1 Antwort Letzte Antwort
    • WebrangerW Webranger
      hier mal die logs:
      System:
      Betriebssystem
      linux
      os
      linux
      Architektur
      x64
      CPUs
      Geschwindigkeit
      1497 MHz
      Modell
      RAM
      5.8 GB
      System Betriebszeit
      00:19:26
      Node.js
      NPM
      6.4.1
      Festplatte Größe
      27.43 GB
      Festplatte frei
      20.96 GB
      Anzahl der Adapter
      313
      Betriebszeit
      00:19:19
      Aktive Instanzen
      28
      Hostname
      debian-iobroker
      Gruss
      ostseereiterO Offline
      ostseereiter
      @Webranger
      gebe mal diese Befehle in deine Konsole ein und starte den Adapter neu.
      sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
      Gruß OSR
      Plattform
        WebrangerW Offline
        Webranger
        @ostseereiter sagte in Radar2 Startet nicht:
        sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f which l2ping)
        Ich hätte schwören können das hab ich schon drei mal gemacht.
        Jetzt geht es plötzlich
        Danke dir
        • SantosS Offline
          SantosS Offline
          Santos
          Bei mir startet der Adapter auch nicht, woran könnte es denn liegen?
          Die Befehle habe ich schon 2x eingegeben, iobroker neu gestartet, system ist geupdatet.
          Hier ist der Log
          host.raspberrypi	2020-03-05 20:06:02.414	info	Restart adapter system.adapter.radar2.0 because enabled
          host.raspberrypi	2020-03-05 20:06:02.413	info	instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
          host.raspberrypi	2020-03-05 20:06:02.412	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:61:11) errno: 19, code: 'ENODEV', syscall: 'bind' }
          host.raspberrypi	2020-03-05 20:06:02.412	error	Caught by controller[0]: at process.nextTick (/opt/iobroker/node_modules/@abandonware/noble/lib/noble.js:60:24)
          host.raspberrypi	2020-03-05 20:06:02.411	error	Caught by controller[0]: at NobleBindings.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js:78:13)
          host.raspberrypi	2020-03-05 20:06:02.410	error	Caught by controller[0]: at Hci.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js:100:35)
          host.raspberrypi	2020-03-05 20:06:02.408	error	Caught by controller[0]: { Error: ENODEV, No such device
          radar2.0	2020-03-05 20:06:02.339	info	(1576) Adapter disconnected and stopped with dostop(false) and callback(true)
          radar2.0	2020-03-05 20:06:02.336	error	at process._tickCallback (internal/process/next_tick.js:61:11)
          radar2.0	2020-03-05 20:06:02.336	error	at process.nextTick (/opt/iobroker/node_modules/@abandonware/noble/lib/noble.js:60:24)
          radar2.0	2020-03-05 20:06:02.336	error	at NobleBindings.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js:78:13)
          radar2.0	2020-03-05 20:06:02.336	error	at Hci.init (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js:100:35)
          radar2.0	2020-03-05 20:06:02.336	error	(1576) Error: ENODEV, No such device
          radar2.0	2020-03-05 20:06:02.332	error	(1576) uncaught exception: ENODEV, No such device
          radar2.0	2020-03-05 20:06:02.301	info	(1576) radar2 set to scan every 20 seconds and printers every 720 minutes.
          radar2.0	2020-03-05 20:06:02.297	info	(1576) arp-scan will use the following interfaces: [ 'eth0' ]
          radar2.0	2020-03-05 20:06:02.295	info	(1576) Remove name end for host names: .fritz.box
          radar2.0	2020-03-05 20:06:02.293	info	(1576) use known IP list: [ '1.1.1.1' ]
          radar2.0	2020-03-05 20:06:02.289	info	(1576) use known BT list: [ '01:12:23:34:45:56' ]
          radar2.0	2020-03-05 20:06:02.285	info	(1576) radar2 set to flag items away if they are not seen for 2 minutes
          radar2.0	2020-03-05 20:06:02.284	warn	(1576) node-bluetooth not found!
          radar2.0	2020-03-05 20:06:02.281	info	(1576) found '@abandonware/noble'
          radar2.0	2020-03-05 20:05:58.556	info	(1576) Connected with '0.0.0.0' for DHCP Scan
          radar2.0	2020-03-05 20:05:58.008	info	(1576) radar2 initialization started...
          radar2.0	2020-03-05 20:05:57.738	info	(1576) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v10.17.0
          • ostseereiterO ostseereiter
            @Webranger
            Berchemer
            schrieb am zuletzt editiert von Berchemer
            @Webranger
            gebe mal diese Befehle in deine Konsole ein und starte den Adapter neu.Danke dafür :-)
            Danke dafür :-)
            • cbundC Offline
              cbundC Offline
              cbund
              Die Befehle mit arp-scan funktionieren bei mir nicht. Kann es daran liegen das Radar2 nicht mehr funktioniert?
              Kommt dann:
              sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f which arp-scan)
              readlink: fehlender Operand
              „readlink --help“ liefert weitere Informationen.
              usage: setcap [-q] [-v] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
              Note <filename> must be a regular (non-symlink) file.
              Arp-Scan ist installiert mit Version 1.9.5
              • cbundC Offline
                cbundC Offline
                cbund
                Gelöst: Habe einen Nuc und muss den Bluetoothadapter weiterschleifen an die VM
                  markus-now
                  Hallo, ich bekomme den radar2 Adapter nicht zum Laufen habe ihn so wie in der Anleitung installiert.
                  Version Adapter 1.0.9 und ioBroker als VM auf proxmox.
                  ![Bild Text](radar2.JPG Bild Link)Hat eventuell einer eine Idee was ich falsch mache.
                    madex
                    Also ich hatte die Probleme auch nach einem Umzug von RPI3 auf 4.
                    Folgendes war bei mir erfolgreich:
                    Bluetooth muss an sein:
                    sudo systemctl enable hciuart
                    Diese Befehle nochmal durchgeführt:
                    Siehe auch https://github.com/frankjoke/ioBroker.radar2 bei Installation
                    sudo apt-get install -y coreutils libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
                    # and below need to be run whenever you update nodejs!
                    Installation node-bluetooth
                    npm install node-bluetooth --save
                    Jetzt sind alle gelbe und rote Logeinträge weg und die Radar2 Ojekte sind wieder da.
                    82.9k
