  5. Tastendruck via Blockly simulieren/ auslösen
    5.6k
18 Beiträge 5 Kommentatoren 4.0k Aufrufe 3 Beobachtet
  • dslraserD dslraser
    @haselchen
    wollte ich gerade schreiben....
    haselchenH Offline
    haselchenH Offline
    haselchen
    @dslraser
    Erster Erster 😂😂
    oberfraggerO 1 Antwort Letzte Antwort
    • haselchenH haselchen
      @dslraser
      Erster Erster 😂😂
      oberfraggerO Offline
      oberfragger
      schrieb am zuletzt editiert von oberfragger
      @haselchen @dslraser
      Funktioniert nun mit ausschalten, wirft aber jede Menge Warnings.
      javascript.0	2020-01-09 23:19:06.035	info	(24059) script.js.common.Ambilight: aus
      javascript.0	2020-01-09 23:19:06.033	warn	(24059) at processImmediate (timers.js:658:5)
      javascript.0	2020-01-09 23:19:06.033	warn	(24059) at tryOnImmediate (timers.js:676:5)
      javascript.0	2020-01-09 23:19:06.032	warn	(24059) at runCallback (timers.js:705:18)
      javascript.0	2020-01-09 23:19:06.030	warn	(24059) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4848:37)
      javascript.0	2020-01-09 23:19:06.029	warn	(24059) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
      javascript.0	2020-01-09 23:19:06.029	warn	(24059) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
      hyperion.0	2020-01-09 23:19:06.044	info	(7950) Clearing prio on hyperion!
      javascript.0	2020-01-09 23:19:06.028	warn	(24059) at Object.<anonymous> (script.js.common.Ambilight:10:5)
      javascript.0	2020-01-09 23:19:06.028	warn	(24059) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
      javascript.0	2020-01-09 23:19:06.026	warn	(24059) You are assigning a boolean to the state "hyperion.0.control.clear" which expects a state. Please fix your code to use a state or change the state type to boolean. This warning might become an
      javascript.0	2020-01-09 23:19:06.025	warn	(24059) at processImmediate (timers.js:658:5)
      javascript.0	2020-01-09 23:19:06.025	warn	(24059) at tryOnImmediate (timers.js:676:5)
      javascript.0	2020-01-09 23:19:06.024	warn	(24059) at runCallback (timers.js:705:18)
      javascript.0	2020-01-09 23:19:06.024	warn	(24059) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4848:37)
      javascript.0	2020-01-09 23:19:06.023	warn	(24059) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
      javascript.0	2020-01-09 23:19:06.023	warn	(24059) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
      javascript.0	2020-01-09 23:19:06.022	warn	(24059) at Object.<anonymous> (script.js.common.Ambilight:9:5)
      javascript.0	2020-01-09 23:19:06.022	warn	(24059) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
      javascript.0	2020-01-09 23:19:06.020	warn	(24059) You are assigning a boolean to the state "hyperion.0.control.clear" which expects a state. Please fix your code to use a state or change the state type to boolean. This warning might become an
      hyperion.0	2020-01-09 23:19:01.946	info	(7950) Set Color: 0,143,21
      hyperion.0	2020-01-09 23:19:01.940	info	(7950) Setting color to0,143,21
      hyperion.0	2020-01-09 23:19:01.598	info	(7950) Set Color: 0,117,18
      hyperion.0	2020-01-09 23:19:01.590	info	(7950) Setting color to0,117,18
      hyperion.0	2020-01-09 23:19:01.437	info	(7950) Set Color: 0,122,18
      hyperion.0	2020-01-09 23:19:01.424	info	(7950) Setting color to0,122,18
      javascript.0	2020-01-09 23:18:58.130	info	(24059) script.js.common.Ambilight: an
      • oberfraggerO oberfragger
        haselchenH Offline
        haselchenH Offline
        haselchen
        @oberfragger
        Eines von beiden.
        Entweder nur steuere oder nur aktualisiere
          @oberfragger
          Eines von beiden.
          oberfragger
          @haselchen Das hatte ich ja schon... aber weiter die Warnings.
          Das muss doch irgendwie "sauber" gehen...!?!
            @oberfragger sagte:
            Einen unsauber erstellten Datenpunkt kann man nicht sauber steuern. Datenpunkttyp "state" ist ungültig !
              @oberfragger sagte:
              oberfragger
              @paul53 Da der Datenpunkt "direkt" aus dem Adapter kommt, habe ich da keine Chanche, außer ein Issue zu erzeugen, oder?
                @oberfragger sagte:
                Ja, mach das.
                • ruhigundrelaxedR Offline
                  ruhigundrelaxed
                  Ja, hoppla, da bin ich. Sry.
                  Dieser Fehler geht auf einen PR von Paul53 zurück, der den Typ von "switch" auf "boolean" geändert hat.
                  https://github.com/ruhigundrelaxed/ioBroker.hyperion/pull/29/commits/f9ac8a2f735805ae3ce5c3ccff2a6ad8e65ed8af
                  Er hatte wohl Fehler im Log...
                  iobroker auf debian bullseye amd64 (i5-8259U)
                  homematic -> homegear -> HM-CFG-LAN ~> 11 x hm-cc-rt-dn | 3 x hm-sec-sd
                  knx -> eibd -> SCN‐IP000.01 ~> 4 x AMS-1216.01 | (1 x JAL-0810.01 | 1 x JAL-0410.01) | 2 x BE-16000.01 | …
                  ruhigundrelaxedR paul53P 2 Antworten Letzte Antwort
                  • ruhigundrelaxedR ruhigundrelaxed
                    ruhigundrelaxed
                    @ruhigundrelaxed said in Tastendruck via Blockly simulieren/ auslösen:
                    Quatsch.... Das war der activator, ihr habt das bei clear all bzw. clearall? Ich checke..
                      @ruhigundrelaxed sagte:
                      Der PR wurde nie übernommen. Es gibt einige falsche Typ-Zuweisungen im Code.
                      Zulässig sind nur
                      • string
                      • number
                      • boolean
                      • object
                      • array
                        ruhigundrelaxed
                        Ok. Ich sehe nun meinen Fehler. Ich fixe das.
                          ruhigundrelaxed
                          So, das sollte gefixed sein. (0.0.16) Ich habe den common type auf jeweils einen der von dir oben aufgezählten Typen geändert. @Paul53 ich hatte deinen PR gesehen. Ich dachte auch, dass ich den gemerged hatte...
                            Zeile 290 enthält noch common.type: 'text'
                              oberfragger
                              @paul53 Er ist gerade am frickeln. Sagt er hat ne alte Version hochgeladen.
                              Ich warte mal ab.
                                ruhigundrelaxed
                                ja, er hat gefrickelt. danke, für die zeile 290, hab ich übersehen. mir wird irgendwie schlecht, wenn ich meinen alten code sehe... ich muss den mal grundlegend neu bauen...
