  4. Test Meross Adapter 1.2.x
    6.4k
meross
98 Beiträge 15 Kommentatoren 18.4k Aufrufe 14 Beobachtet
  • MyzerATM Offline
    MyzerATM Offline
    MyzerAT
    schrieb am zuletzt editiert von MyzerAT
    #71
    ja musst die Meross Instanz jetzt in der früh Neustarten, da sie gelb war!
    und im log sehe ich folgendes:
    2019-11-28 01:21:45.487 - warn: meross.0 Exception: TypeError: Cannot read property 'toString' of undefined
    2019-11-28 01:21:45.488 - info: meross.0 Device: 1809015737278325180534298f16671f closed: Error: premature close
    2019-11-28 01:21:45.489 - info: meross.0 Device: 1811304781456425182134298f1882c8 closed: Error: premature close
    2019-11-28 01:21:45.490 - info: meross.0 Device: 1811303935030425182134298f187dde closed: Error: premature close
    2019-11-28 01:21:45.490 - info: meross.0 Device: 1811306089340925182134298f187b61 closed: Error: premature close
    2019-11-28 01:21:45.491 - info: meross.0 Device: 1811302076928625182134298f188306 closed: Error: premature close
    2019-11-28 01:21:45.491 - info: meross.0 Device: 1809016208959425180534298f1665ca closed: Error: premature close
    2019-11-28 01:21:45.492 - info: meross.0 Device: 1811301259073025182134298f187dd9 closed: Error: premature close
    2019-11-28 01:21:45.492 - info: meross.0 Device: 1809013215340225180534298f166a51 closed: Error: premature close
    2019-11-28 01:21:45.493 - info: meross.0 Device: 1811305641257125182134298f187fdd closed: Error: premature close
    2019-11-28 01:21:45.493 - info: meross.0 Device: 1809014813536325180534298f166a87 closed: Error: premature close
    2019-11-28 01:21:45.493 - info: meross.0 Device: 1809017394109425180534298f166544 closed: Error: premature close
    2019-11-28 01:21:45.494 - info: meross.0 Device: 1809012709631425180534298f16660a closed: Error: premature close
    2019-11-28 01:21:45.494 - info: meross.0 Device: 1810221956507129085334298f16f380 closed: Error: premature close
    2019-11-28 01:21:45.494 - info: meross.0 Device: 1811305787614825182134298f187da6 closed: Error: premature close
    2019-11-28 01:21:45.495 - info: meross.0 Device: 1809014572480225180534298f166ab5 closed: Error: premature close
    2019-11-28 01:21:45.495 - info: meross.0 Device: 1811301845905925182134298f1880f5 closed: Error: premature close
    2019-11-28 01:21:45.496 - info: meross.0 Device: 19011882830659251h0334298f1a0625 closed: Error: premature close
    2019-11-28 01:21:45.496 - info: meross.0 Device: 1812179492140325182834298f19d01f closed: Error: premature close
    2019-11-28 01:21:45.497 - info: meross.0 Device: 19011873123850251h0334298f1a09a6 closed: Error: premature close
    2019-11-28 01:21:45.497 - info: meross.0 Device: 1812174950278625182834298f19c365 closed: Error: premature close
    2019-11-28 01:21:45.497 - info: meross.0 Device: 19011863874770251h0434298f1a5666 closed: Error: premature close
    2019-11-28 01:21:45.498 - info: meross.0 Device: 19011849037183251h0434298f1a5d0d closed: Error: premature close
    2019-11-28 01:21:45.498 - info: meross.0 Device: 19011818986476251h0434298f1a5b94 closed: Error: premature close
    2019-11-28 01:21:45.499 - info: meross.0 Device: 1809010653847025180534298f16668c closed: Error: premature close
    2019-11-28 01:21:45.991 - info: meross.0 terminating
    2019-11-28 01:21:46.028 - error: Caught by controller[0]: TypeError: Cannot read property 'toString' of undefined
    2019-11-28 01:21:46.028 - error: Caught by controller[0]: at MqttClient.client.on (/opt/iobroker/node_modules/iobroker.meross/node_modules/meross-cloud/index.js:252:38)
    2019-11-28 01:21:46.028 - error: Caught by controller[0]: at emitNone (events.js:111:20)
    2019-11-28 01:21:46.028 - error: Caught by controller[0]: at MqttClient.emit (events.js:208:7)
    2019-11-28 01:21:46.028 - error: Caught by controller[0]: at TLSSocket.f (/opt/iobroker/node_modules/iobroker.meross/node_modules/once/once.js:25:25)
    2019-11-28 01:21:46.029 - error: Caught by controller[0]: at TLSSocket.onfinish (/opt/iobroker/node_modules/iobroker.meross/node_modules/end-of-stream/index.js:30:27)
    2019-11-28 01:21:46.029 - error: Caught by controller[0]: at emitNone (events.js:111:20)
    2019-11-28 01:21:46.029 - error: Caught by controller[0]: at TLSSocket.emit (events.js:208:7)
    2019-11-28 01:21:46.029 - error: Caught by controller[0]: at finishMaybe (_stream_writable.js:613:14)
    2019-11-28 01:21:46.029 - error: Caught by controller[0]: at stream._final (_stream_writable.js:591:5)
    2019-11-28 01:21:46.029 - error: Caught by controller[0]: at TLSSocket.Socket._final (net.js:300:5)
    2019-11-28 01:21:46.029 - error: host.RDJL_Home instance system.adapter.meross.0 terminated with code 0 (OK)
    2019-11-28 01:21:46.029 - info: host.RDJL_Home Restart adapter system.adapter.meross.0 because enabled
    2019-11-28 01:22:07.570 - info: host.RDJL_Home instance system.adapter.cloud.0 started with pid 2576
    2019-11-28 01:22:08.783 - info: cloud.0 starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v8.15.0
    2019-11-28 01:22:08.886 - info: cloud.0 Connecting with https://iobroker.net:10555 with "rudolf.wanke@chello.at_42d923c0-3a67-11e9-a2f7-1b0d8c8476f2"
    2019-11-28 01:22:09.938 - info: cloud.0 Trying to connect as system.user.admin
    2019-11-28 01:22:14.228 - error: cloud.0 Cloud says: timeout
    2019-11-28 01:22:15.232 - info: cloud.0 Connection changed: io server disconnect
    2019-11-28 01:22:16.067 - info: host.RDJL_Home instance system.adapter.meross.0 started with pid 2707
    2019-11-28 01:22:17.316 - info: meross.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.meross, node: v8.15.0
    2019-11-28 01:22:18.291 - info: meross.0 Device 1809010653847025180534298f16668c initialized
    2019-11-28 01:22:18.387 - info: meross.0 Device 19011898369667251h0434298f1a6462 initialized
    2019-11-28 01:22:18.390 - info: meross.0 Device 19011818986476251h0434298f1a5b94 initialized
    2019-11-28 01:22:18.392 - info: meross.0 Device 19011849037183251h0434298f1a5d0d initialized
    2019-11-28 01:22:18.394 - info: meross.0 Device 19011863874770251h0434298f1a5666 initialized
    2019-11-28 01:22:18.395 - info: meross.0 Device 1812174950278625182834298f19c365 initialized
    2019-11-28 01:22:18.397 - info: meross.0 Device 19011873123850251h0334298f1a09a6 initialized
    2019-11-28 01:22:18.398 - info: meross.0 Device 1812179492140325182834298f19d01f initialized
    2019-11-28 01:22:18.400 - info: meross.0 Device 19011882830659251h0334298f1a0625 initialized
    2019-11-28 01:22:18.401 - info: meross.0 Device 1811301845905925182134298f1880f5 initialized
    2019-11-28 01:22:18.403 - info: meross.0 Device 1809014572480225180534298f166ab5 initialized
    2019-11-28 01:22:18.404 - info: meross.0 Device 1810224092789329085334298f16f18d initialized
    2019-11-28 01:22:18.406 - info: meross.0 Device 1811305787614825182134298f187da6 initialized
    2019-11-28 01:22:18.408 - info: meross.0 Device 1810221956507129085334298f16f380 initialized
    2019-11-28 01:22:18.409 - info: meross.0 Device 1809012709631425180534298f16660a initialized
    2019-11-28 01:22:18.411 - info: meross.0 Device 1809017394109425180534298f166544 initialized
    2019-11-28 01:22:18.412 - info: meross.0 Device 1809014813536325180534298f166a87 initialized
    2019-11-28 01:22:18.414 - info: meross.0 Device 1811305641257125182134298f187fdd initialized
    2019-11-28 01:22:18.415 - info: meross.0 Device 1809013215340225180534298f166a51 initialized
    2019-11-28 01:22:18.417 - info: meross.0 Device 1811301259073025182134298f187dd9 initialized
    2019-11-28 01:22:18.419 - info: meross.0 Device 1809016208959425180534298f1665ca initialized
    2019-11-28 01:22:18.421 - info: meross.0 Device 1811302076928625182134298f188306 initialized
    2019-11-28 01:22:18.422 - info: meross.0 Device 1811306089340925182134298f187b61 initialized
    2019-11-28 01:22:18.424 - info: meross.0 Device 1811303935030425182134298f187dde initialized
    2019-11-28 01:22:18.425 - info: meross.0 Device 1811304781456425182134298f1882c8 initialized
    2019-11-28 01:22:18.427 - info: meross.0 Device 1809015737278325180534298f16671f initialized
    2019-11-28 01:22:18.726 - info: meross.0 Device: 19011898369667251h0434298f1a6462 connected
    2019-11-28 01:22:18.761 - info: meross.0 Device: 19011818986476251h0434298f1a5b94 connected
    2019-11-28 01:22:18.764 - info: meross.0 Device: 19011849037183251h0434298f1a5d0d connected
    2019-11-28 01:22:18.777 - info: meross.0 Device: 1809010653847025180534298f16668c connected
    2019-11-28 01:22:18.781 - info: meross.0 Device: 1812174950278625182834298f19c365 connected
    2019-11-28 01:22:18.800 - info: meross.0 Device: 19011873123850251h0334298f1a09a6 connected
    2019-11-28 01:22:18.802 - info: meross.0 Device: 19011863874770251h0434298f1a5666 connected
    2019-11-28 01:22:18.838 - info: meross.0 Device: 1812179492140325182834298f19d01f connected
    2019-11-28 01:22:18.848 - info: meross.0 Device: 1811301845905925182134298f1880f5 connected
    2019-11-28 01:22:18.857 - info: meross.0 Device: 19011882830659251h0334298f1a0625 connected
    2019-11-28 01:22:18.871 - info: meross.0 Device: 1809014572480225180534298f166ab5 connected
    2019-11-28 01:22:18.882 - info: meross.0 Device: 1811305787614825182134298f187da6 connected
    2019-11-28 01:22:18.884 - info: meross.0 Device: 1810224092789329085334298f16f18d connected
    2019-11-28 01:22:18.905 - info: meross.0 Device: 1809012709631425180534298f16660a connected
    2019-11-28 01:22:18.908 - info: meross.0 Device: 1810221956507129085334298f16f380 connected
    2019-11-28 01:22:18.929 - info: meross.0 Device: 1809017394109425180534298f166544 connected
    2019-11-28 01:22:18.938 - info: meross.0 Device: 1811305641257125182134298f187fdd connected
    2019-11-28 01:22:18.967 - info: meross.0 Device: 1809014813536325180534298f166a87 connected
    2019-11-28 01:22:18.971 - info: meross.0 Device: 1809016208959425180534298f1665ca connected
    2019-11-28 01:22:18.974 - info: meross.0 Device: 1809013215340225180534298f166a51 connected
    2019-11-28 01:22:18.981 - info: meross.0 Device: 1811302076928625182134298f188306 connected
    2019-11-28 01:22:18.983 - info: meross.0 Device: 1811301259073025182134298f187dd9 connected
    2019-11-28 01:22:18.986 - info: meross.0 Device: 1811306089340925182134298f187b61 connected
    2019-11-28 01:22:19.007 - info: meross.0 Device: 1811304781456425182134298f1882c8 connected
    2019-11-28 01:22:19.020 - info: meross.0 Device: 1811303935030425182134298f187dde connected
    2019-11-28 01:22:19.026 - info: meross.0 Device: 1809015737278325180534298f16671f connected
    2019-11-28 01:22:19.465 - info: sql.0 enabled logging of meross.0.1809010653847025180534298f16668c.online, Alias=false
    2019-11-28 01:22:19.544 - info: sql.0 enabled logging of meross.0.1811301845905925182134298f1880f5.online, Alias=false
    2019-11-28 01:22:19.584 - info: sql.0 enabled logging of meross.0.1809014572480225180534298f166ab5.online, Alias=false
    2019-11-28 01:22:19.595 - info: sql.0 enabled logging of meross.0.1811305787614825182134298f187da6.online, Alias=false
    2019-11-28 01:22:19.642 - info: sql.0 enabled logging of meross.0.1810224092789329085334298f16f18d.online, Alias=false
    2019-11-28 01:22:19.648 - info: sql.0 enabled logging of meross.0.1809012709631425180534298f16660a.online, Alias=false
    2019-11-28 01:22:19.657 - info: sql.0 enabled logging of meross.0.1810221956507129085334298f16f380.online, Alias=false
    2019-11-28 01:22:19.658 - info: sql.0 enabled logging of meross.0.1809017394109425180534298f166544.online, Alias=false
    2019-11-28 01:22:19.674 - info: sql.0 enabled logging of meross.0.1811305641257125182134298f187fdd.online, Alias=false
    2019-11-28 01:22:19.711 - info: sql.0 enabled logging of meross.0.1809014813536325180534298f166a87.online, Alias=false
    2019-11-28 01:22:19.711 - info: sql.0 enabled logging of meross.0.1809016208959425180534298f1665ca.online, Alias=false
    2019-11-28 01:22:19.727 - info: sql.0 enabled logging of meross.0.1809013215340225180534298f166a51.online, Alias=false
    2019-11-28 01:22:19.728 - info: sql.0 enabled logging of meross.0.1811302076928625182134298f188306.online, Alias=false
    2019-11-28 01:22:19.762 - info: sql.0 enabled logging of meross.0.1811301259073025182134298f187dd9.online, Alias=false
    2019-11-28 01:22:19.779 - info: sql.0 enabled logging of meross.0.1811306089340925182134298f187b61.online, Alias=false
    2019-11-28 01:22:19.780 - info: sql.0 enabled logging of meross.0.1811304781456425182134298f1882c8.online, Alias=false
    2019-11-28 01:22:19.815 - info: sql.0 enabled logging of meross.0.1811303935030425182134298f187dde.online, Alias=false
    2019-11-28 01:22:19.816 - info: sql.0 enabled logging of meross.0.1809015737278325180534298f16671f.online, Alias=false
    2019-11-28 01:22:19.845 - info: sql.0 enabled logging of meross.0.1809017394109425180534298f166544.0-switch, Alias=false
    2019-11-28 01:22:19.846 - info: sql.0 enabled logging of meross.0.1809010653847025180534298f16668c.0-switch, Alias=false
    2019-11-28 01:22:19.892 - info: sql.0 enabled logging of meross.0.1809016208959425180534298f1665ca.ip, Alias=false
    2019-11-28 01:22:19.893 - info: sql.0 enabled logging of meross.0.1809016208959425180534298f1665ca.0-switch, Alias=false
    2019-11-28 01:22:19.893 - info: sql.0 enabled logging of meross.0.1809013215340225180534298f166a51.0-switch, Alias=false
    2019-11-28 01:22:19.893 - info: sql.0 enabled logging of meross.0.1811301845905925182134298f1880f5.0, Alias=false
    2019-11-28 01:22:19.944 - info: sql.0 enabled logging of meross.0.1811305787614825182134298f187da6.0, Alias=false
    2019-11-28 01:22:19.944 - info: sql.0 enabled logging of meross.0.1809014572480225180534298f166ab5.0-switch, Alias=false
    2019-11-28 01:22:20.023 - info: sql.0 enabled logging of meross.0.1811305641257125182134298f187fdd.0, Alias=false
    2019-11-28 01:22:20.023 - info: sql.0 enabled logging of meross.0.1809017394109425180534298f166544.0-current, Alias=false
    2019-11-28 01:22:20.023 - info: sql.0 enabled logging of meross.0.1809017394109425180534298f166544.0-power, Alias=false
    2019-11-28 01:22:20.076 - info: sql.0 enabled logging of meross.0.1811301259073025182134298f187dd9.0, Alias=false
    2019-11-28 01:22:20.076 - info: sql.0 enabled logging of meross.0.1811302076928625182134298f188306.0, Alias=false
    2019-11-28 01:22:20.116 - info: sql.0 enabled logging of meross.0.1811306089340925182134298f187b61.0, Alias=false
    2019-11-28 01:22:20.129 - info: sql.0 enabled logging of meross.0.1810224092789329085334298f16f18d.1, Alias=false
    2019-11-28 01:22:20.172 - info: sql.0 enabled logging of meross.0.1809014813536325180534298f166a87.0-switch, Alias=false
    2019-11-28 01:22:20.218 - info: sql.0 enabled logging of meross.0.1811304781456425182134298f1882c8.0, Alias=false
    2019-11-28 01:22:20.244 - info: sql.0 enabled logging of meross.0.1809010653847025180534298f16668c.0-current, Alias=false
    2019-11-28 01:22:20.250 - info: sql.0 enabled logging of meross.0.1809010653847025180534298f16668c.0-power, Alias=false
    2019-11-28 01:22:20.264 - info: sql.0 enabled logging of meross.0.1811303935030425182134298f187dde.0, Alias=false
    2019-11-28 01:22:20.277 - info: sql.0 enabled logging of meross.0.1809015737278325180534298f16671f.0-switch, Alias=false
    2019-11-28 01:22:20.277 - info: sql.0 enabled logging of meross.0.1809013215340225180534298f166a51.0-current, Alias=false
    2019-11-28 01:22:20.278 - info: sql.0 enabled logging of meross.0.1809013215340225180534298f166a51.0-power, Alias=false
    2019-11-28 01:22:20.278 - info: sql.0 enabled logging of meross.0.1809014572480225180534298f166ab5.0-current, Alias=false
    2019-11-28 01:22:20.320 - info: sql.0 enabled logging of meross.0.1809014572480225180534298f166ab5.0-power, Alias=false
    2019-11-28 01:22:20.324 - info: sql.0 enabled logging of meross.0.1809016208959425180534298f1665ca.0-current, Alias=false
    2019-11-28 01:22:20.325 - info: sql.0 enabled logging of meross.0.1809016208959425180534298f1665ca.0-power, Alias=false
    2019-11-28 01:22:20.377 - info: sql.0 enabled logging of meross.0.1809014813536325180534298f166a87.0-current, Alias=false
    2019-11-28 01:22:20.400 - info: sql.0 enabled logging of meross.0.1809014813536325180534298f166a87.0-power, Alias=false
    2019-11-28 01:22:20.402 - info: sql.0 enabled logging of meross.0.1809015737278325180534298f16671f.0-current, Alias=false
    2019-11-28 01:22:20.402 - info: sql.0 enabled logging of meross.0.1809015737278325180534298f16671f.0-power, Alias=false
    2019-11-28 01:22:38.733 - warn: meross.0 Can not get Abilities for Device 19011898369667251h0434298f1a6462: Error: Timeout
    2019-11-28 01:22:38.763 - warn: meross.0 Can not get Abilities for Device 19011818986476251h0434298f1a5b94: Error: Timeout
    2019-11-28 01:22:38.765 - warn: meross.0 Can not get Abilities for Device 19011849037183251h0434298f1a5d0d: Error: Timeout
    2019-11-28 01:22:38.783 - warn: meross.0 Can not get Abilities for Device 1812174950278625182834298f19c365: Error: Timeout
    2019-11-28 01:22:38.803 - warn: meross.0 Can not get Abilities for Device 19011863874770251h0434298f1a5666: Error: Timeout
    2019-11-28 01:22:38.838 - warn: meross.0 Can not get Abilities for Device 1812179492140325182834298f19d01f: Error: Timeout
    2019-11-28 01:22:38.857 - warn: meross.0 Can not get Abilities for Device 19011882830659251h0334298f1a0625: Error: Timeout
    2019-11-28 01:22:38.906 - warn: meross.0 Can not get Abilities for Device 1809012709631425180534298f16660a: Error: Timeout
    2019-11-28 01:22:38.907 - info: meross.0 Devices initialized
    lg Rudi
    Node 22.23.0
    Nodejs 22.23.0
    npm 10.9.8
    js-controller 7.2.2
    • MyzerATM MyzerAT
      #72
      @MyzerAT Ok, die 1.3.4 (Du hast noch 1.0.0!!) sollte sich an sich anders verhalten und nicht "gelb" hängen bleiben ... Aber mit den Details hier mache ich nachher nochmal ein Update, dann wäre er ggf nicht gecrasht
      • andiko2A Online
        andiko2A Online
        andiko2
        #73
        So ich habe jetzt mal den ioBroker fixer curl -sL https://iobroker.net/fix.sh | bash - drüber laufen lassen und dann noch im Anschluss den Host PC neu gestartet. Im Moment läuft wieder alles und alle Geräte werden erkannt. In der Handy App waren alle vorher nicht erkannten Geräte erreichbar.
        • O Offline
          O Offline
          onkel-ede
          #74
          Habe mal ein Verständnisfrage. Der Meross-Adapter läuft bei mir seit Monaten tadellos. Habe 4 WLAN-Steckdosen in Betrieb, welche per Blockly/Mail Info geben, wenn ein bestimmter Zustand gegeben ist (z.B. GSM fertig).
          Ich habe an der Fritz!Box alle IoT-Komponenten einem eigenen Zugangsprofil zugeordnet (gesperrte Anwendungen - alles, außer Surfen und Mail).
          Nun sind die Steckdosen auch nicht mehr über die Meross-App erreichbar und damit auch nicht über den Adapter im iobroker. Welche Netzwerkanwendungen benötigen denn die Steckdosen, damit sie für die App erreichbar sind?
          • O onkel-ede
            #75
            @onkel-ede sagte in Test Meross Adapter 1.2.x:
            Meross Geräte gehen nur via Cloud. Die brauchen Internetzugang zu den Meross-Servern (also HTTPS)
            • O Offline
              O Offline
              onkel-ede
              #76
              Ok, danke. Läuft wieder.
              • F Offline
                Fatmax
                #77
                Ich habe das Problem, dass der Adapter nicht mehr grün wird.
                Es schaltet lfd. zwischen gelb und rot hin und her.
                Es werden auch unter Objekte keine Datenpunkte angelegt -> es gibt nur den Connection Datenpunkt und der bleibt auf false.
                Im Log kommt Code 7 vor und der Adapter startet lfd. neu.
                Und jetzt das komische dabei:
                Die Werte werden lt. Log aber abgerufen, auch die Skripts funktionieren einwandfrei, nur die Datenpunkt fehlen.
                Version ist 1.3.9
                Was kann ich tun?
                Liebe Grüße,
                Fatmax
                • F Fatmax
                  Version ist 1.3.9
                  Was kann ich tun?
                  #78
                  @Fatmax stoppe Adapter. Kille alle laufenden Prozesse. Starte neu. Geht dann wieder alles? Generell logfile auf Platte im verzeichnis log ansehen und schauen was drin steht wo die Fehler 7 los gingen.
                  Ansonsten: welcher js-Controller?
                  F 1 Antwort Letzte Antwort
                    DocGame
                    #79
                    Ich habe folgendes Problem mit Der Doppel-Aussensteckdose MSS-620.
                    An dieser hatte ich die Weihnachtsbaumsussenbeleuchtung. Nachdem die entfernt wurde habe ich auch die Dose wieder in die Aservatenkammer zurückgelegt.
                    Seither habe ich minütlich Warnungen im Log:
                    meross.0	2020-01-07 18:55:01.010	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:53:40.986	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:52:20.973	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:51:00.963	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:49:40.956	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:48:20.937	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:47:00.925	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:45:40.902	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:44:20.877	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    meross.0	2020-01-07 18:43:00.864	warn	(7940) Can not get Abilities for Device 1909026636379339089948e1e95136a7: Error: Timeout
                    In der App habe ich das Gerät entfernt.....bringt nichts.
                    In den Objekten habe ich das Gerät auch gelöscht. Hier erscheint es aber wieder (Verkrüppelt).
                    Wie werde ich die Fehler wieder los?
                    • D DocGame
                      #80
                      @DocGame wenn es in app weg ist dann Adapter neu starten und das sollte reichen.
                      • apollon77A apollon77
                        DocGame
                        #81
                        @apollon77
                        Ich kann mich nur schämen....😯
                        Jetzt bin ich schon so lange dabei uns stand so auf dem Schlauch.
                        Geht natürlich. Danke nochmals....
                          Fatmax
                          #82
                          @apollon77 sagte in Test Meross Adapter 1.2.x:
                          @apollon77
                          Ich habe einmal den ganzen Rock64 neu gestartet.
                          Der lief schon seit 50 Tagen durch.
                          Seitdem läuft es wieder einwandfrei.
                          js-controller wäre übrigens 1.5.11
                          Liebe Grüße,
                          Fatmax
                            djsirius
                            #83
                            Moin,
                            kann mir einer anhand der Logdatei sagen, warum sich mein Adapter nicht mit Meross verbinden kann?
                            Vielen Dank!
                            djsirius
                            • D djsirius
                              Moin,
                              Vielen Dank!
                              #84
                              @djsirius Mit dem Log auszug nicht weil da sieht alles ok aus
                                djsirius
                                #85
                                Hi apollon,
                                ich habe den Adapter deinstalliert und neu installiert, dann läuft er!
                                djsirius
                                • D djsirius
                                  Hi apollon,
                                  #86
                                  @djsirius total unlogisch aber naja wenns hilft ;-)
                                    Brainpain187s
                                    #87
                                    @apollon77
                                    Ich habe gerade im Office ein bisschen Smart Stuff installiert. Momentan läuft hier ein IObroker und ein paar Meross Geräte.
                                    2 x Funksteckdosen ==> Funktionieren einwandfrei mit dem Iobroker und dem Yahka Adapter
                                    1 x MSL320 LED Light Strip ==> wird zwar angezeigt, aber nur der Online Status (und der steht immer auf false). Mit der Meross App auf dem Handy funktioniert der Strip einwandfrei.
                                    Liegts evtl. an mir oder will der Adapter irgendwelche speziellen Anforderungen für den LED Strip?
                                    • B Brainpain187s
                                      @apollon77
                                      #88
                                      @brainpain187s Naja Es sind die Geräte nach Typen implementiert. Ich denke Light Strips sind noch nicht drin. Bitte volles Debug log vom Start des Adapters als GitHub issue mit "name" des Geräts.
                                      Dann schaue ich gern mal
                                        Mr Fawlty
                                        #89
                                        ich habe folgendes Problem mit einem MSL320 LED-Streifen:
                                        Wenn der Adapter einmal läuft, funktioniert alles wunderbar (Implementierung kann ich also bestätigen). Beim Neustart von iobroker während des regelmäßigen unbeaufsichtigten Backups erscheint jedoch folgender Fehlereintrag im Log:
                                        Meross Connection Error: Error: 1004: A
                                        Der Adapter bleibt dann auf Status gelb, state "online" ist false, und eine Verbindung nicht möglich. Ein manueller Restart des Adapters behebt das Problem.
                                        Ist dieses Problem bekannt? Was bedeutet die Fehlermeldung?
                                        Für Hinweise wäre ich dankbar...
                                        Meross Adapter: 1.5.1 im compact mode
                                        Node.js: v10.22.0
                                        NPM: 6.14.6
                                        Falls weitere Informationen benötigt werden, lasst es mich bitte wissen.
                                        Danke und Gruß
                                        • M Mr Fawlty
                                          Node.js: v10.22.0
                                          NPM: 6.14.6
                                          Danke und Gruß
                                          #90
                                          @mr-fawlty sagte in Test Meross Adapter 1.2.x:
                                          Die meldung heisst an sich das die Login Daten falsch sind. Falls dein passwort länger als 15 Zeichen ist versuch mal nur die ersten 15 zeichen einzugeben oder ändere Passwort auf was kürzeres
