  3. Entwicklung
  4. [UMFRAGE] Besteht Interesse an einem Octoprint Adapter
128 Beiträge 42 Kommentatoren 36.3k Aufrufe 28 Beobachtet
  • WebrangerW Webranger
    @George_Best Dann schreib doch auch die Lösung hier auf falls mal einer die Suche benutzt und genau das sucht ;)
    George_Best
    schrieb am zuletzt editiert von George_Best
    #68
    @Webranger sagte in [UMFRAGE] Besteht Interesse an einem Octoprint Adapter:
    Klar - sehr gerne:
    //************ Calculate objects in seconds to HH:MM:SS********************* */
    on({id: new RegExp('octoprint\\.0\\.printjob\\.progress\\.completion' + "|" + 'octoprint\\.0\\.printjob\\.progress\\.printtime'), change: "ne"}, function (obj) {
      var value = obj.state.val;
      //console.log((getDateObject(getState("octoprint.0.printjob.progress.printtime_left").val).getMinutes()));
        // variable for time left and job_time
        // write value from object "printtime_left" (in seconds) to variable
        var value_time_left;
        var job_time
        value_time_left = (getDateObject(getState("octoprint.0.printjob.progress.printtime_left").val));
        job_time = (getDateObject(getState('octoprint.0.printjob.progress.printtime'/*Progress print time*/).val));
        // Hours part
        var hours_value_time_left = Math.floor( value_time_left / 3600 );
        var hours_job_time = Math.floor( job_time / 3600 );
        // Minutes part
        var minutes_value_time_left = Math.floor( (value_time_left%3600) / 60 );
        var minutes_job_time = Math.floor( (job_time%3600) / 60 );
        // Seconds part
        var seconds_value_time_left = Math.floor( value_time_left%60 );
        var seconds_job_time = Math.floor( job_time%60 );
        // Will display time in 10:30:23 format
        var formattedTime_value_time_left = hours_value_time_left + ':' + minutes_value_time_left + ':' + seconds_value_time_left;
        var formattedTime_job_time = hours_job_time + ':' + minutes_job_time + ':' + seconds_job_time;
        //console.log(formattedTime_value_time_left);
        //console.log(formattedTime_job_time);
        //write time_left to object
        setState("javascript.0.3DPrinter.3DPrinter_Time_Left"/*3DPrinter_Time_Left*/, formattedTime_value_time_left, true);
        setState('javascript.0.3DPrinter.3DPrinter_Job_Time'/*3DPrinter Job Time*/, formattedTime_job_time, true);
        //************ Text-to-Speech on Chromecast********************* */
    var  timeout;
    on({id: 'octoprint.0.printjob.progress.completion'/*Progress completion*/, change: "ne"}, function (obj) {
        //console.log(getState("octoprint.0.printjob.progress.completion").val);
            if (getState("octoprint.0.printjob.progress.completion").val == 100) {
                setState("sayit.0.tts.text", "de;" + '3D Drucker ist fertig');
                sendTo("email.0", "send", {
                    text: '3D Drucker ist fertig',
                    to: 'xxxxxxxxxxxxx@gmail.com',
                    subject: '3D Drucker ist fertig'
    Das Script holt die beiden Datenpunkte des octoprint-Adapters "printtime_left" und "printtime", wandelt diese ins Format HH:MM:SS um und schreibt diese dann in zwei (zuvor manuell erstellte) Datenpunkte "3DPrinter_Time_Left" und "3DPrinter_Job_Time".
    Außerdem gebe ich noch "3D Drucker fertig" über Google Home (Chromecast) aus und schicke mir eine Email, sobald der Datenpunkt "completion" bei 100 ist.
    WebrangerW joergeliJ 2 Antworten Letzte Antwort
      bishop
      schrieb am zuletzt editiert von bishop
      #69
      @telekom0815
      sorry für die Verspätung hier der Export von meinem Script.
      Gibt bestimmt noch fehler...Feedback erwünscht
        <variables>
          <variable type="undefined" id="timeout2">timeout2</variable>
          <variable type="undefined" id="timeout">timeout</variable>
        </variables>
        <block type="procedures_defcustomnoreturn" id="L)jSk0=?1664IBxAbQ${" x="413" y="-437">
          <mutation statements="false"></mutation>
          <field name="NAME">Licht</field>
          <field name="SCRIPT">bm9kZV9zc2ggPSByZXF1aXJlKCdub2RlLXNzaCcpOw0Kc3NoID0gbmV3IG5vZGVfc3NoKCk7DQpzc2guY29ubmVjdCh7DQogIGhvc3Q6ICcxOTIuMTY4LjEuOTAnLA0KICB1c2VybmFtZTogJ3BpJywNCiAgcGFzc3dvcmQ6ICdkc2xmbGF0MjM4OCcNCn0pLnRoZW4oKCkgPT4gew0KICBzc2guZXhlY0NvbW1hbmQoInN1ZG8gLi9sZWRyZWxhaXMuc2giKTsNCn0p</field>
        </block>
        <block type="procedures_defcustomnoreturn" id=".(*orQFL])}0jxjU)4Y?" x="412" y="-413">
          <field name="NAME">shutdown</field>
          <field name="SCRIPT">bm9kZV9zc2ggPSByZXF1aXJlKCdub2RlLXNzaCcpOw0Kc3NoID0gbmV3IG5vZGVfc3NoKCk7DQpzc2guY29ubmVjdCh7DQogIGhvc3Q6ICcxOTIuMTY4LjEuOTAnLA0KICB1c2VybmFtZTogJ3VzZXInLA0KICBwYXNzd29yZDogJ3Bhc3N3b3JkJw0KfSkudGhlbigoKSA9PiB7DQogIHNzaC5leGVjQ29tbWFuZCgic3VkbyBzaHV0ZG93biBub3ciKTsNCn0p</field>
        </block>
        <block type="on_ext" id="g{.@~ZsR7(G/6laF9/Q#" x="413" y="-362">
          <mutation items="1"></mutation>
          <value name="OID0">
            <shadow type="field_oid" id="y~e.v;I`cDBP?LqcT?!U">
              <field name="oid">sonoff.0.Pow_62_3dDrucker.POWER</field>
            </shadow>
          </value>
          <statement name="STATEMENT">
            <block type="controls_if" id="bq*f7B;^s0VIfH13or9d" collapsed="true">
              <value name="IF0">
                <block type="logic_compare" id="`)MWIWh=Tk#m/[rK2ME1">
                  <field name="OP">EQ</field>
                  <value name="A">
                    <block type="get_value" id="pI^wpX~rmS#KtR^3V#gW">
                      <field name="OID">sonoff.0.Pow_62_3dDrucker.POWER</field>
                    </block>
                  </value>
                  <value name="B">
                    <block type="logic_boolean" id="Dypo~(SMny:}4_n1*v;o">
                    </block>
                  </value>
                </block>
              </value>
              <statement name="DO0">
                <block type="update" id=")N[JwuYwCAbha*=m~vb#">
                  <mutation delay_input="false"></mutation>
                  <field name="OID">javascript.0.schalter.3d_drucker_rpi_shutdown</field>
                  <value name="VALUE">
                    <block type="logic_boolean" id="SMqJ),5=rxG.tWDzQFHc">
                    </block>
                  </value>
                </block>
              </statement>
            </block>
          </statement>
          <next>
            <block type="on_ext" id="3BKaKP9u)QPYQ%fo_H*,">
              <value name="OID0">
                <shadow type="field_oid" id="/MXW2KlV+JX0__Wts%NE">
                  <field name="oid">javascript.0.schalter.3d_drucker_rpi_shutdown</field>
                </shadow>
              </value>
                <block type="controls_if" id="Y1]RH9fVR^;wJ8Phe!+c" collapsed="true">
                  <value name="IF0">
                    <block type="logic_compare" id="RYf.b.+|Wi,5*:d}+q|h">
                      <value name="A">
                        <block type="get_value" id="HcDY3c]hT.Ge6sRml(#}">
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_boolean" id="id8SS.AOEpq,U9L#tYyw">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="control" id="jhq_UY7!XJ^;i,.Aw16/">
                        <block type="logic_boolean" id="@7s`u,CbB44u*8Kc;{fW">
                        </block>
                      </value>
                    </block>
                  </statement>
                  <value name="IF1">
                    <block type="logic_compare" id="H%jbito/W8rkjv5!omm(">
                      <value name="A">
                        <block type="get_value" id="PZw8r5)!Jn`t%p0d}Ij2">
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_boolean" id="Uee7X#UslzxU]GjttWZ=">
                        </block>
                      </value>
                    </block>
                  </value>
                  <statement name="DO1">
                    <block type="procedures_callcustomnoreturn" id="=#Q;NN(ZtFbYLwV?u3e7">
                      <mutation name="shutdown"></mutation>
                    </block>
                  </statement>
                </block>
              </statement>
              <next>
                <block type="on_ext" id=".lRhF1)wPIdz.yV?=jUi">
                  <value name="OID0">
                    <shadow type="field_oid" id="rD1iSaDm.=Mn4;HAX!SZ">
                      <field name="oid">octoprint.0.info.connection</field>
                    </shadow>
                  </value>
                    <block type="controls_if" id="tceui~t=M5aK2PhN@AiR" collapsed="true">
                      <value name="IF0">
                        <block type="logic_compare" id="B#)x#N+vJUarGf^s_6{+">
                          <value name="A">
                            <block type="get_value" id="JW=V4G%F[o4KPRMMtzl^">
                              <field name="OID">octoprint.0.info.connection</field>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_boolean" id="axn9[abqsx%lro~{tV2(">
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="timeouts_settimeout" id="SM?$]M-Vb4}!n0$moo8W">
                          <field name="NAME">timeout2</field>
                          <field name="DELAY">2</field>
                          <field name="UNIT">min</field>
                            <block type="control" id="7BJy+SZfqlC-1?uxgv}T">
                                <block type="logic_boolean" id="Ae?^~gu-?tkI?Zf=l|05">
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </statement>
                    </block>
                  </statement>
                  <next>
                    <block type="comment" id="/bgI6x_9=9MOPSSqT5y8">
                      <field name="COMMENT">Druck abbrechen</field>
                      <next>
                        <block type="on_ext" id="]`}dT6ao59[g0Zi7-8JR">
                          <value name="OID0">
                            <shadow type="field_oid" id="LBh%wWJ6EIHSB8k6[F1-">
                              <field name="oid">zigbee.0.00158d0001e832d0.click</field>
                            </shadow>
                          </value>
                            <block type="controls_if" id="um*;L|HSsNG~}n_7RvJl" collapsed="true">
                              <value name="IF0">
                                <block type="logic_operation" id="p,OaYSoY:[YL+Zf=9,)L">
                                  <field name="OP">AND</field>
                                  <value name="A">
                                    <block type="logic_compare" id="AHZ~4BmMwj*u+R59IT3{">
                                      <value name="A">
                                        <block type="get_value" id="D}UcxJ1Sk=PqTRKjUY=D">
                                          <field name="OID">zigbee.0.00158d0001e832d0.click</field>
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="logic_boolean" id="OD)9Sh(MuozULEVN^)`#">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_compare" id="#.1FXN4{StvBom4=GJya">
                                      <value name="A">
                                        <block type="get_value" id="hv||~J_bAqtb~m:Ba:ql">
                                          <field name="OID">octoprint.0.printer_status</field>
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="text" id="C-KJ-qgD/GSTwX-,ND*L">
                                          <field name="TEXT">Printing</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                <block type="control" id="Qevct?*ro((VFE4%#+o0">
                                  <field name="OID">octoprint.0.command.printjob</field>
                                    <block type="text" id="3y;+U@6WBcueR56Jy/oe">
                                      <field name="TEXT">cancel</field>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                              <value name="IF1">
                                <block type="logic_operation" id="]3rHvQ||5QnEOLf5+ymh">
                                  <value name="A">
                                    <block type="logic_compare" id="?K]y+Tk%R|5-`ABPnU9U">
                                      <value name="A">
                                        <block type="get_value" id="l?oBL,{[]BYF*hzx/.BP">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="logic_boolean" id="ds!DH]e(AJC2V3Fo;SL)">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_compare" id="^:CngW9,,CgWBy*~XRm-">
                                      <value name="A">
                                        <block type="get_value" id="fM[uY=Ev^{lka.T7SMqR">
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="text" id="?H0rQWj/PzXC).^mAZrL">
                                          <field name="TEXT">Operational</field>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                                <block type="control" id="XU3I,=yJ]psvvkPEN~h5">
                                    <block type="text" id="Rno,oYD.kNna/wHj6s#5">
                                      <field name="TEXT">start</field>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </statement>
                          <next>
                            <block type="comment" id="%H|c6ZCu?0Jj|mpe!fk/">
                              <field name="COMMENT">temp einstellung button</field>
                              <next>
                                <block type="on_ext" id="~hcVKGpL=/72CVP6XSlJ">
                                  <value name="OID0">
                                    <shadow type="field_oid" id="|-EXqAGm!ND+A-N;ddc_">
                                      <field name="oid">zigbee.0.00158d0001e832d0.double_click</field>
                                    </shadow>
                                  </value>
                                    <block type="controls_if" id="_MO0.wji;GsHR@M1g|8)" collapsed="true">
                                      <value name="IF0">
                                        <block type="logic_operation" id="xh-(v9+.g5*!4Y:4I,Zk">
                                          <value name="A">
                                            <block type="logic_compare" id="_[MEoh(-#DiY{q4e7fG*">
                                              <value name="A">
                                                <block type="get_value" id="nwK%{g@#-dH},r[Xi@6M">
                                                  <field name="OID">zigbee.0.00158d0001e832d0.double_click</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_boolean" id="ul{tzs2Gz@IuX[rZlOFE">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_operation" id="sL7w4jqN6vak2H4%*aoL" inline="false">
                                              <value name="A">
                                                <block type="logic_compare" id="Y@{QMl3GeuOwy9kBa21W">
                                                  <field name="OP">LTE</field>
                                                  <value name="A">
                                                    <block type="get_value" id="B4iG!1%|qFlp!s295m%Z">
                                                      <field name="OID">octoprint.0.temperature.bed.target</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="3V%|drS@FVJ`:j~3?tz/">
                                                      <field name="NUM">0</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_compare" id="V_YfG}cf!y=P8h|DC9/^">
                                                  <value name="A">
                                                    <block type="get_value" id="(LOs]qM)+^#R}ro?lX7#">
                                                      <field name="OID">octoprint.0.temperature.tool0.target</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="`gAj^-c@9`f!SfMtUb!E">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="comment" id="L,5QpW[=AX7IXmgfWm|0">
                                          <field name="COMMENT">Bett Temperatur</field>
                                          <next>
                                            <block type="control" id="L[d?ER)zE`1|QrD#ovz4">
                                                <block type="math_number" id="@n=w(S..!Jg)`ZL1udp)">
                                                  <field name="NUM">45</field>
                                                </block>
                                              </value>
                                              <next>
                                                <block type="comment" id="aFXN%;?3?g:#6rWXyjPO">
                                                  <field name="COMMENT">Nozzel Temperatur</field>
                                                  <next>
                                                    <block type="control" id="PG6:-RYgozPxp}/C?bay">
                                                        <block type="math_number" id="xetGsWY6TkaMi};ssZXs">
                                                          <field name="NUM">180</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                      <value name="IF1">
                                        <block type="logic_operation" id="CeUEdB|O~7ztxS2_LM4+">
                                          <value name="A">
                                            <block type="logic_compare" id="5od2{|:VlYf69JiDSMJg">
                                              <value name="A">
                                                <block type="get_value" id=")moE*+yiYzqRK;VkFH]+">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_boolean" id="rIZ`y?szmU~M?cs*p9-r">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_operation" id="4xQ;Gag5UM2f]A)MF_;^" inline="false">
                                              <value name="A">
                                                <block type="logic_compare" id="*noWYU*ip2[HWl5Jju4E">
                                                  <field name="OP">GTE</field>
                                                  <value name="A">
                                                    <block type="get_value" id="Y`lLaA6{,jW3kP6^8}FV">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="}Irl~8ZGghE,VFTnNRT%">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_compare" id="8)9Ke8Pb@X?g.o~0?J9g">
                                                  <value name="A">
                                                    <block type="get_value" id="aX.U2O-!C;rC!h}n@!%K">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="4!WIJCN^xC(B)4nNIg3.">
                                                      <field name="NUM">40</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="control" id="A`xL#p+S4Eh~BVL3vvIT">
                                            <block type="math_number" id="TvZ~.tHp,.wCp#1jFg4Z">
                                            </block>
                                          </value>
                                          <next>
                                            <block type="control" id="z@#vdQTEK{iS#2;gC94+">
                                                <block type="math_number" id="%Jf{v!1ywIHx;:3?n4(s">
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                  <next>
                                    <block type="comment" id="7cJNZp)c?U]6L5*OXe3N">
                                      <field name="COMMENT">Licht</field>
                                      <next>
                                        <block type="on_ext" id="JH#v!^`pb0Mpp}`Nj,)p">
                                          <value name="OID0">
                                            <shadow type="field_oid" id="S[q1j_h4[wk=V#Y^H)w,">
                                              <field name="oid">zigbee.0.00158d0001e832d0.triple_click</field>
                                            </shadow>
                                          </value>
                                            <block type="controls_if" id="POb=W3`E9[JG+Gu[NdZD">
                                              <value name="IF0">
                                                <block type="logic_compare" id="`@=;,CF]a4%;lKvwPKr]">
                                                  <value name="A">
                                                    <block type="get_value" id="fD]0iFX`,NzyvruDQ_RJ">
                                                      <field name="OID">zigbee.0.00158d0001e832d0.triple_click</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_boolean" id="_#iz]hw`0Iq[sTjPtq/P">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="procedures_callcustomnoreturn" id=",}m+``lap``he:WJF6[@">
                                                  <mutation name="Licht"></mutation>
                                                  <next>
                                                    <block type="control" id="_xRVMZyO;trFt*m_069G" disabled="true">
                                                      <field name="OID">octoprint.0.command.printer</field>
                                                        <block type="text" id="+L{6@Ms4387ig]_FQ-=.">
                                                          <field name="TEXT">home</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="comment" id="tIbGBR3z,ZUwEoogwR~b">
                                              <field name="COMMENT">Drucker ausschalten</field>
                                              <next>
                                                <block type="on_ext" id="J0q~1~aOryAei(bnjTv$">
                                                  <value name="OID0">
                                                    <shadow type="field_oid" id=".4Q(bhe];EXB$@P2X^h(">
                                                      <field name="oid">zigbee.0.00158d0001e832d0.quad_click</field>
                                                    </shadow>
                                                  </value>
                                                    <block type="controls_if" id="zb2RA5uQ-o)(LsZ;u$hK" collapsed="true">
                                                      <value name="IF0">
                                                        <block type="logic_operation" id="i`LcFCn/1En01on6xF/G" inline="false">
                                                          <value name="A">
                                                            <block type="logic_compare" id="A)EYGPyGQv9^C7}}eM3`">
                                                              <value name="A">
        <block type="get_value" id="wr|1U~=Qtc)Yt`-b!5I7">
        <field name="OID">zigbee.0.00158d0001e832d0.quad_click</field>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_boolean" id="N;?x?9SocoQWZa{P3kN.">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="logic_compare" id="V%u!qS9%|QzOHO$Itaoc">
                                                              <field name="OP">NEQ</field>
                                                              <value name="A">
        <block type="get_value" id="-5CP0a0X7{@+|uD9{LCG">
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="text" id="_=#~RYt5E3cJgc^4tmA^">
        <field name="TEXT">	Printing</field>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="control" id="[~*e*X-Wm-`AMi,!Xkfm">
                                                            <block type="logic_boolean" id="-.:wT:^|fu[QSukm=iAq">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
        <block type="on_ext" id="+A7wlutQO8gBfqosc.y3" x="-388" y="12">
          <value name="OID0">
            <shadow type="field_oid" id="L[i=p{|ii-ai*/YAZ@8s">
              <field name="oid">octoprint.0.temperature.bed.actual</field>
            </shadow>
          </value>
          <value name="OID1">
            <shadow type="field_oid" id="SrqWt)hN`dugaePnqgR:">
              <field name="oid">octoprint.0.temperature.tool0.actual</field>
            </shadow>
          </value>
            <block type="controls_if" id="V6]e:v6u:?I_dnQ6L_VO" collapsed="true">
              <value name="IF0">
                <block type="logic_compare" id="|GYXj{b?eejrNKL,dC1c">
                  <value name="A">
                    <block type="get_value" id="NE_0I9@@4+Vx=788NJ{O">
                      <field name="OID">octoprint.0.temperature.bed.actual</field>
                    </block>
                  </value>
                  <value name="B">
                    <block type="text" id="^ZZxvmafdi;Q}c)p)@Kd">
                      <field name="TEXT">50</field>
                    </block>
                  </value>
                </block>
              </value>
                <block type="control" id="vs.J|^}}{M%%SJ1bpk;V">
                  <field name="OID">javascript.0.schalter.3d_drucker_fertig</field>
                    <block type="logic_boolean" id="gvfoVV5t!!Us3^C~!w.H">
                    </block>
                  </value>
                </block>
              </statement>
              <value name="IF1">
                <block type="logic_compare" id=".^Vr3!/]n3+mJC!/xH_P">
                  <field name="OP">LT</field>
                  <value name="A">
                    <block type="get_value" id="SES|c80.WXQ*jSsOhFie">
                    </block>
                  </value>
                  <value name="B">
                    <block type="text" id="yt?GRbeq!O:U6vuzE4-i">
                      <field name="TEXT">40</field>
                    </block>
                  </value>
                </block>
              </value>
                <block type="control" id="W@d-F3O_9HHWW#dCNkL=">
                    <block type="logic_boolean" id="A4H}`x`xaT~u.qw:OMjO">
                    </block>
                  </value>
                </block>
              </statement>
            </block>
          </statement>
          <next>
            <block type="on_ext" id="u:R0u7j.Y,8EdsUCK6kQ">
              <value name="OID0">
                <shadow type="field_oid" id="jgpdw:j!HF59WUplmK}~">
                  <field name="oid">javascript.0.schalter.3d_drucker_fertig</field>
                </shadow>
              </value>
                <block type="controls_if" id="0KU30/v2h#W(!`#[gp76" collapsed="true">
                  <value name="IF0">
                    <block type="logic_compare" id="]-Zb+?Hn_!lMC-aT9alk">
                      <value name="A">
                        <block type="get_value" id="ln#_*!,/omF%2!L4WRp-">
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_boolean" id="pSN^b91_Se1kc2o;W4J^">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="telegram" id="i||{vH9*ebG3rYojyq#~">
                      <field name="INSTANCE">.0</field>
                      <field name="LOG"></field>
                      <value name="MESSAGE">
                        <shadow type="text" id="U][E8N^7Bu/+`G(NxN}#">
                          <field name="TEXT"></field>
                        </shadow>
                        <block type="text_join" id="2b|ng~sPvT|iC)a%*xI7">
                          <value name="ADD0">
                            <block type="text" id="#1kx@/m~N,F+j0]M7kg{">
                              <field name="TEXT">Der 3D-Drucker hat angefangen </field>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="get_value" id="LhG1A9ZJ}qx=J?Fhl^@Y">
                              <field name="OID">octoprint.0.printjob.file.name</field>
                            </block>
                          </value>
                          <value name="ADD2">
                            <block type="text" id="o:.!{V?z_(eK9jLH:hJ|">
                              <field name="TEXT"> zu drucken</field>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                  <value name="IF1">
                    <block type="logic_compare" id="21(9~CU|XRCn:EOXk2/@">
                      <value name="A">
                        <block type="get_value" id="TSvo:2H{H+}IE{#M1`FO">
                        </block>
                      </value>
                      <value name="B">
                        <block type="logic_boolean" id="h=.8?l5o{aiN|)W)LXh@">
                        </block>
                      </value>
                    </block>
                  </value>
                    <block type="telegram" id="ed05d|bQf^sw*MK?SR-6">
                        <shadow type="text" id="sKyyX,f?IkAZP`RFQReF">
                          <field name="TEXT">Die Waschmaschine ist fertig :)</field>
                        </shadow>
                        <block type="text_join" id=":?(LV%}eMmeGg5)=s63{">
                          <mutation items="9"></mutation>
                          <value name="ADD0">
                            <block type="text" id="Me[sfL:79y?isrCAn~-e">
                              <field name="TEXT">Der 3D-Drucker ist fertig! </field>
                            </block>
                          </value>
                          <value name="ADD1">
                            <block type="text_newline" id="=Ln@t]2hKoRekBO*=I$x">
                              <field name="Type">\n</field>
                            </block>
                          </value>
                          <value name="ADD2">
                            <block type="text" id="0bN](j4?-62PDxGTFs`K">
                              <field name="TEXT">Das waren </field>
                            </block>
                          </value>
                          <value name="ADD3">
                            <block type="get_value" id="5nYhH(Z-[f`G*,+qIZ;H">
                              <field name="OID">sonoff.0.Pow_62_3dDrucker.ENERGY_Today</field>
                            </block>
                          </value>
                          <value name="ADD4">
                            <block type="text" id=",nn}rYrBfCaxgJPdJkp7">
                              <field name="TEXT"> kWh die für das Drucken verbraucht worden sind.</field>
                            </block>
                          </value>
                          <value name="ADD5">
                            <block type="text_newline" id="y[Hf}4D:ri]xj@q@[wha">
                            </block>
                          </value>
                          <value name="ADD6">
                            <block type="text" id="0%vbNiH.-uK;q[)6ZRx=">
                              <field name="TEXT">Das sind ca.</field>
                            </block>
                          </value>
                          <value name="ADD7">
                            <block type="get_value" id="hCs/qrxQ~vwE?sKSN/10">
                              <field name="OID">javascript.0.Berechnungen.3D_Drucker.Heute</field>
                            </block>
                          </value>
                          <value name="ADD8">
                            <block type="text" id="@sTCB@TuHU6fdmi31@bV">
                              <field name="TEXT">Euro</field>
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="controls_if" id="rfQaG-]RZG[J7N^zgcn}">
                          <value name="IF0">
                            <block type="logic_compare" id="|R+(A4n%[[2~FwDmCB!;">
                              <value name="A">
                                <block type="get_value" id="jfZP8qNUbZ+4PRi3OXZ9">
                                </block>
                              </value>
                              <value name="B">
                                <block type="text" id="NjDd8G#S{W![sJ:pi6bw">
                                </block>
                              </value>
                            </block>
                          </value>
                            <block type="debug" id="mk7sgm[,N@wIZIyGEF+2">
                              <value name="TEXT">
                                <shadow type="text" id="AQ~nPFy6}@Z-b5jNlXDc">
                                  <field name="TEXT">in 10min wird runtergefahren</field>
                                </shadow>
                              </value>
                              <next>
                                <block type="timeouts_settimeout" id="LC5}R,k-3]_F.tzTdv~y">
                                  <field name="DELAY">10</field>
                                    <block type="controls_if" id="G_npA;)|vwA)AvdWb.it">
                                      <value name="IF0">
                                        <block type="logic_compare" id="mm4*,5X2mVm,I[O^!M*|">
                                          <value name="A">
                                            <block type="get_value" id="]qP|`R^KqX*{Qxy-;GB/">
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="text" id="06oZ4u||h!S@CRJuNrEj">
                                              <field name="TEXT">35</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        <block type="control" id="`4mp,TnHO)6@[,=Jg@G}">
                                            <block type="logic_boolean" id="}:_~nb#_A7mJ7[Sq+F5n">
                                            </block>
                                          </value>
                                        </block>
                                      </statement>
                                    </block>
                                  </statement>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </next>
        </block>
      </xml>
      • G George_Best
        Klar - sehr gerne:
            var job_time
            // Hours part
            // Minutes part
            // Seconds part
        var  timeout;
        WebrangerW Offline
        WebrangerW Offline
        Webranger
        schrieb am zuletzt editiert von Webranger
        #70
        @George_Best
        Gerade mal getestet und läuft super. Danke dafür
        Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
        • G George_Best
          Klar - sehr gerne:
              var job_time
              // Hours part
              // Minutes part
              // Seconds part
          var  timeout;
          joergeliJ Online
          joergeliJ Online
          joergeli
          schrieb am zuletzt editiert von joergeli
          #71
          @George_Best
          Hi, ich habe mir erlaubt, Dein Script mit meinem JS-Halbwissen etwas anzupassen, da führende Nullen bei Std, Min und Sec nicht angezeigt wurden.
          Sieht m.E. schöner aus, wenn anstatt 0:35:9 -> 00:35:09 angezeigt wird.
          Meine Datenpunkte javascript.0.OctoPi.Printzeit und javascript.0.OctoPi.Restzeit (Typ Zeichenkette) werden automatisch angelegt.
          Fertigmeldung gebe ich bei mir mit einem anderen Script aus.
          //************ Umrechnung der Druckzeiten von Sekunden nach HH:MM:SS********************* */
          createState('javascript.0.OctoPi.Printzeit', {
              desc: 'Druckdauer',
              type: 'string'
          createState('javascript.0.OctoPi.Restzeit', {
              desc: 'Restzeit',
              type: 'string'
          const restdauer  = 'octoprint.0.printjob.progress.printtime_left'
          const druckdauer = 'octoprint.0.printjob.progress.printtime'
          on({id: [restdauer], change: "lt"} , function (obj) {
              umrechnung();
          //_________________________________________________________________________
          function umrechnung() {
              var time_left = getState("octoprint.0.printjob.progress.printtime_left").val;
              var job_time  = getState('octoprint.0.printjob.progress.printtime').val;
              // Hours
              var hours_restzeit  =  Math.floor( time_left / 3600 );
              var hours_printzeit =  Math.floor( job_time  / 3600 );
              if ( hours_restzeit  < 10 ){var std_restzeit = "0" + String(hours_restzeit);}
                  else var std_restzeit = String(hours_restzeit)
              if ( hours_printzeit < 10 ){var std_printzeit= "0" + String(hours_printzeit); }
                  else var std_printzeit = String(hours_printzeit)
              // Minutes
              var minutes_restzeit  = Math.floor( (time_left%3600) / 60 );
              var minutes_printzeit = Math.floor( (job_time%3600)  / 60 );
              if ( minutes_restzeit  < 10 ){var min_restzeit = "0" + String(minutes_restzeit);}
                  else var min_restzeit = String(minutes_restzeit)
              if ( minutes_printzeit < 10 ){var min_printzeit= "0" + String(minutes_printzeit); }
                  else var min_printzeit = String(minutes_restzeit)
              // Seconds
              var seconds_restzeit  = Math.floor( time_left%60 );
              var seconds_printzeit = Math.floor( job_time%60  );
              if ( seconds_restzeit  < 10 ){var sec_restzeit = "0" + String(seconds_restzeit);}
                  else var sec_restzeit = String(seconds_restzeit)
              if ( seconds_printzeit < 10 ){var sec_printzeit= "0" + String(seconds_printzeit); }
                  else var sec_printzeit = String(seconds_printzeit)
              // Zeit in HH:MM:SS format
              var restzeit  = std_restzeit  + ':' + min_restzeit  + ':' + sec_restzeit;
              var printzeit = std_printzeit + ':' + min_printzeit + ':' + sec_printzeit;
              console.log("Restzeit: " + restzeit);
              console.log("Printzeit: " + printzeit);
              setState("javascript.0.OctoPi.Restzeit", restzeit, true);
              setState('javascript.0.OctoPi.Printzeit', printzeit, true);
          Jörg
          G 1 Antwort Letzte Antwort
          • joergeliJ joergeli
            @George_Best
                desc: 'Druckdauer',
                type: 'string'
                desc: 'Restzeit',
                type: 'string'
                umrechnung();
                // Hours
                // Minutes
                // Seconds
            Jörg
            George_Best
            #72
            @joergeli sagte in [UMFRAGE] Besteht Interesse an einem Octoprint Adapter:
            @George_Best
                desc: 'Druckdauer',
                type: 'string'
                desc: 'Restzeit',
                type: 'string'
            on({id: [restdauer, druckdauer], change: "any"} , function (obj) {
                umrechnung();
                var time_left = (getDateObject(getState("octoprint.0.printjob.progress.printtime_left").val));
                var job_time  = (getDateObject(getState('octoprint.0.printjob.progress.printtime').val));
                // Hours
                // Minutes
                // Seconds
            Jörg
            Hallo Jörg,
            sehr, sehr gerne darfst du das anpassen. Wow😳 - deine Umsetzung ist natürlich die Profi-Version! Klasse Beitrag!
            joergeliJ 1 Antwort Letzte Antwort
            • G George_Best
              @George_Best
                  desc: 'Druckdauer',
                  type: 'string'
                  desc: 'Restzeit',
                  type: 'string'
                  umrechnung();
                  // Hours
                  // Minutes
                  // Seconds
              Jörg
              Hallo Jörg,
              joergeliJ Online
              joergeliJ Online
              joergeli
              #73
              @George_Best
              ich habe mein Script gerade noch mal editiert:
              getDateObject braucht man m.E. nicht, da sich das ja auf das aktuelle Datum bezieht und nichts mit den Druckzeiten zu tun hat.
              Außerdem reicht es eigentlich aus, daß nur getriggert wird, wenn sich die Restdauer ( printtime_left ) verkleinert.
              Die verangene Zeit = Druckdauer ( printtime ) wird ja trotzdem automatisch mit angepasst.
              Hier also noch mal das angepasste Script:
                  desc: 'Druckdauer',
                  type: 'string'
                  desc: 'Restzeit',
                  type: 'string'
              // Triggern, wenn sich Restzeit verkleinert
                  umrechnung();
                  // Hours
                  // Minutes
                  // Seconds
              Nebenbei:
              Es gibt für Octoprint ein sog. DryRun-Plugin.
              Damit kann man einen Druck simulieren, d.h. es werden alle Bewegungen des Druckkopfes ausgeführt, es wird aber kein Filament gefördert und Druckbett, bzw. HotEnd werden auch nicht beheizt.
              Mit dieser Simulation kann man Scripte bzgl. Octoprint gut testen, ohne unnötig Filament zu verbrauchen.
              Jörg
              WebrangerW 1 Antwort Letzte Antwort
                @George_Best
                    desc: 'Druckdauer',
                    type: 'string'
                    desc: 'Restzeit',
                    type: 'string'
                    umrechnung();
                    // Hours
                    // Minutes
                    // Seconds
                Nebenbei:
                Jörg
                WebrangerW Offline
                WebrangerW Offline
                Webranger
                #74
                @joergeli
                Aber irgendwas passt noch nicht so richtig oder?
                Druckdauer/Printtime
                müsste das nicht minutes_printzeit am ende heissen?
                gerade getestet.
                so ist es richtig:
                        else var min_printzeit = String(minutes_printzeit)
                  @joergeli
                  gerade getestet.
                  so ist es richtig:
                  joergeliJ Online
                  joergeliJ Online
                  joergeli
                  #75
                  @Webranger
                  Jepp, Copy & Paste Fehler meinerseits.
                  Sorry
                  Jörg
                  • HALH Offline
                    HALH Offline
                    HAL
                    #76
                    Erstmal Danke an alle und besonders Jörg für den Adapter.
                    Ich bin gerade dabei meinen neuen Prusa i3 MKS zu tunen ( Frontplatte mit Raspi und Touchscreen, Spannungswandler für Raspi, Beleuchtung, Kamera und entkoppelte Standfüße ). Deshalb habe ich gestern abend nicht mehr mit gelesen.
                    Gerade habe ich einen Druck für Gehäuse Teile gestartet und im Display wird eine Restzeit von 20 Stunden angezeigt 😧
                    Dafür möchte ich den Adapter nutzen.
                    Wenn das Hotend weniger als 50° hat ( Druck ist fertig ) den Raspi runterfahren ( shutdown -h now) und dann die HM Steckdose ausschalten.
                    Während des Drucks eine Frage an Alexa stellen ( das klappt schon gut mit z.B. Alexa, sind Fenster offen?) Alexa, wie lange dauert der 3D Druck noch? Und dann die Restzeit angesagt bekommen bzw in VIS darstellen.
                    Jetzt müsste ich alle Infos haben und werde dass später ausprobieren. 😊
                    Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
                    (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
                    • HALH HAL
                      joergeliJ Online
                      joergeliJ Online
                      joergeli
                      #77
                      @HAL
                      Ich bin nicht der Autor des Adapters, nur ein Nutzer desselben.
                      Leider wird der Adapter wohl auch nicht mehr gepflegt.
                      Falls es interessiert, ein paar Fotos/Skizzen von meiner Konfiguration:
                      3D Drucker für den Einstieg
                      Als Kamera verwende ich diese hier: Raspberry Pi Fisheye 160°
                      denn mit dem Fisheye-Objektiv kannst Du die Cam recht nahe am Drucker positionieren und siehst trotzdem das ganze Druckbett.
                      Das mit diesen RaspiCams gelieferte Flachbandkabel ist i.d.R. recht kurz, deshalb habe ich die Cam über ein 1m-Verlängerungskabel angeschlossen.
                      Jörg
                      HALH joergeliJ 2 Antworten Letzte Antwort
                        @HAL
                        Jörg
                        HALH Offline
                        HALH Offline
                        HAL
                        #78
                        @joergeli ,
                        auf Grund Deiner kompetenten Antwort habe ich dich als Author des Adapters vermutet ;-) es ist aber Matthias Kleine info@haus-automatisierung.com.
                        Ich habe momentan zwei USB Kameras ausprobiert, die Beide noch hier "rumlagen". 1.) Logitec C270 und eine
                        2. ) PS3 Eye Kamera.
                        Die PS3 Kamera hat den besseren Weitwinkel, aber zu wenig Auflösung und ich werde die Logitec nutzen.
                        Momentan drucke ich mir eine neue Halterung für die C270 aus; die erste war eine Halterung am Stepermotor der Z-Achse. Man sieht schön das Hotend aber nicht das ganze Druckbild.
                        Dein Javascript habe ich etwas erweitert, damit ich einfacher die Restzeit Stunden und Minuten mit Alexa ausgeben kann. Für VIS habe ich noch nichts fertig, Dein View gefällt mir gut. Magst Du den sharen ?
                        Das Script für das automatischen abschalten am ende des Drucks ist noch in arbeit.
                        VG Uwe
                          @HAL
                          Jörg
                          joergeliJ Online
                          joergeliJ Online
                          joergeli
                          #79
                          @ all:
                          Ich stelle hier mal mein komplettes "Octoprint-Script" zur Verfügung, evtl. hilft es dem Einen oder Anderen.
                          Was kann das Script?:
                          Via vis 3D-Drucker und Octoprint-Raspi mittels Shelly Plug S (WLAN-Steckdose) o.ä. Ein-/Ausschalten.
                          Der OctoPrint-Raspi wird mit ssh.execCommand sauber heruntergefahren, d.h. nicht einfach ausgeschaltet
                          (im Script muss dazu der entspr. User/Passwort des Raspis eingetragen werden!)
                          Octoprint-Instanz wird mit Start des Druckers, bzw. der WLAN-Steckdose gestartet.
                          Octoprint-Instanz wird mit Ausschalten des Druckers, bzw. der WLAN-Steckdose beendet.
                          Anzeige div. Drucker-Parameter in vis: Status des Druckers, Druckdatei/Größe, Druckbett und HotEnd-Temp (ist/soll), Druckzeiten, Druck-Fortschritt.
                          Verschiedene Ansagen ( z.B. Druck ist zu xx% fertig, Octoprint ist online, Druck ist fertig, etc.) mittels PAW-Adapter auf z.B. Android-Smartphone oder Tablet.
                          Was kann es nicht?: Den Drucker steuern, z.B. Druck starten, Druckdatei hochladen, etc.
                          Das muß im Browser über die OctoPrint-Webseite gemacht werden.
                          // Octoprint-Server ein-/ausschalten, bzw. ueberwachen
                          // node-ssh muss in Javascript-Adapter installiert sein !
                          // Die folgenden Variablen werden benoetigt, damit die jeweilige Sprachausgabe - bei entspr. %-Zahl -  nur einmalig erfolgt
                          var twentyfive = 0;     //25% gedruckt
                          var fifty = 0;          //50% gedruckt
                          var seventyfive = 0;    //75% gedruckt
                          var ninety = 0;         //90% gedruckt
                          var done = 0;           //100% gedruckt
                          const octopi_steckdose              = 'shelly.0.SHPLG-S#04168A#1.Relay0.Switch' // Steckdose Octopi und 3D-Drucker
                          const octoprint_adapter             = 'system.adapter.octoprint.0.connected'    //Octoprint-Adapter verbunden
                          const ping_octoprint                = 'javascript.0.ping.Raspi Octoprint'       //Octoprint Ping
                          const octoprint_verbindung          = 'octoprint.0.info.connection'             // Verbindung zum Drucker
                          const anycubic_verbindung           = 'octoprint.0.printer_status'              // Printer Status
                          const anycubic_timedone             = 'octoprint.0.printjob.progress.printtime'
                          const anycubic_timeleft             = 'octoprint.0.printjob.progress.printtime_left'
                          const anycubic_extrudertemp         = 'octoprint.0.temperature.tool0.actual'
                          const anycubic_extrudertemp_soll    = 'octoprint.0.temperature.tool0.target'
                          const anycubic_tempbed              = 'octoprint.0.temperature.bed.actual'
                          const anycubic_tempbed_soll         = 'octoprint.0.temperature.bed.target'
                          const anycubic_fortschritt          = 'octoprint.0.printjob.progress.completion'
                          const anycubic_dateiname            = 'octoprint.0.printjob.file.name'
                          const anycubic_speicherort          = 'octoprint.0.printjob.file.origin'
                          const anycubic_dateigroesse         = 'octoprint.0.printjob.file.size'
                          var pfad = 'javascript.0.OctoPi.';
                          var node_ssh = require('node-ssh');
                          var ssh = new node_ssh();
                          createState( pfad + 'ShutdownState', false, {name: 'State of Shutdown Octopi'});
                          createState( pfad + 'ShuttingDown', {
                              desc: 'Shutdown OctoÜi',
                              type: 'string'
                              desc: 'Druckdauer',
                              type: 'string'
                              desc: 'Restzeit',
                              type: 'string'
                          //____________________________________________________________________________________________________
                          // Umrechnung der Druckzeiten von Sekunden in HH:MM:SS
                          on({id: [anycubic_timeleft], change: "lt"} , function (obj) {
                              umrechnung();
                          //______ pruefen, ob Shutdown-Button gedrueckt wurde ____
                          on('javascript.0.OctoPi.Shutdown', function (obj) {
                              if (!obj.state.ack && obj.state.val == true) {
                                  octopi_shutdown();
                          //______ pruefen, ob Start-Button gedrueckt wurde ____
                              if (!obj.state.ack && obj.state.val == false) {
                                  octopi_startup();
                          function octopi_shutdown() {
                                          lautstaerke();  // PAW-Lautstaerke auf Maximum setzen
                                          twentyfive = 0;
                                          fifty = 0;
                                          seventyfive = 0;
                                          ninety = 0;
                                          done = 0;
                                          //ioBroker OctoPi-Instanz killen
                                          setTimeout(function(){
                                          octo_adapter_off();
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Octoprint-Instanz wurde beendet'});
                                          }, 1000);
                                          sendTo("paw.0",'Tablet_Jörg',{play: true});  // sofort default sound notification abspielen
                                          setState (pfad + 'ShuttingDown', 'Octoprint-Instanz beendet ...', true);
                                          //Sprachansage, dass Octopi heruntergefahren wird
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'OctoPrint-Server wird heruntergefahren'});
                                          log ('__ OctoPrint wird heruntergefahren __');
                                          setState (pfad + 'ShuttingDown', 'OctoPrint wird  gestoppt ...', true);
                                          //Druckzeiten zuruecksetzen
                                          setState("javascript.0.OctoPi.Restzeit", '---', true);
                                          setState('javascript.0.OctoPi.Printzeit', '---', true);
                                          }, 5000);
                                          //Octoprint-Server via SSH herunterfahren
                                          //log ('__ SSH Verbindung gestartet __');
                                          //SSH-Session starten
                                              ssh.connect({
                                                  host: '192.168.192.30',  // IP-Adresse des Octoprint-Raspi
                                                  username: 'xxxxxxx',     //Username
                                                  password: 'xxxxxxx'      //Passwort
                                              }).then(() => {
                                                  ssh.execCommand('echo "xxxxxxx"|sudo -S shutdown -h now');
                                                  // Achtung! Im obigen execCommand muss das Passwort für den Raspi nochmals eingesetzt werden
                                          }, 6000);
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Schatdaun wurde gestartet'});
                                          //log ('__ Shutdown wurde gestartet ... __');
                                          setState (pfad + 'ShuttingDown', 'Shutdown wurde gestartet ...', true);
                                          }, 10000);
                                          //OctoPi Shutdown Fertig-Meldung
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Octoprint-Server ist daun'});
                                          //log ('__ Octoprint-Server ist down __');
                                          setState (pfad + 'ShuttingDown', 'OctoPrint ist down ...', true);
                                          }, 18000);
                                          //OctoPi-Steckdose ausschalten
                                          setState(octopi_steckdose, false);
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'OctoPrint-Steckdose und 3 Deeee Drucker sind ausgeschaltet'});
                                          log ('__ OctoPi-Steckdose ausgeschaltet __');
                                          setState (pfad + 'ShuttingDown', 'OctoPrint ist ausgeschaltet', true);
                                          }, 24000);
                          }   // Ende function octopi_shutdown
                          function octopi_startup() {
                                          lautstaerke();
                                          twentyfive = 0;
                                          fifty = 0;
                                          seventyfive = 0;
                                          ninety = 0;
                                          done = 0;
                                          // Steckdose einschalten
                                          setState(octopi_steckdose, true);
                                          //log('__ OctoPi-Steckdose eingeschaltet __');
                                          //OctoPi-Instanz starten
                                          octo_adapter_on();
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Octoprint-Instanz wurde gestartet'});
                                          }, 2000);
                                          setState (pfad + 'ShuttingDown', 'Instanz wurde gestartet ...', true);
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'OctoPrint-Server wird gestartet'});
                                          log ('__ OctoPrint-Server wird gestartet __');
                                          setState (pfad + 'ShuttingDown', 'OctoPrint wird gestartet ...', true);
                                          }, 6000);
                                          //Geduld1...
                                          setState (pfad + 'ShuttingDown', 'Geduld, Octoprint startet ...', true);
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Bitte noch etwas Geduld, Octoprint startet noch'});
                                          //log ('__ Geduld, Octoprint ist bald bereit __');
                                          }, 14000);
                                          //Geduld2...
                                          setState (pfad + 'ShuttingDown', 'Octoprint ist gleich verfügbar ...', true);
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Geduld, Octoprint ist gleich verfügbar'});
                                          //log ('__ Geduld, Octoprint ist gleich verfügbar __');
                                          }, 21000);
                          }   //Ende function octopi_startup
                          //OctoPi Online-Meldung, wenn Verbindung zum 3D-Drucker hergestellt wurde
                          on({id: anycubic_verbindung, change: 'gt'}, function() {
                                  twentyfive = 0;
                                  fifty = 0;
                                  seventyfive = 0;
                                  ninety = 0;
                                  done = 0;
                                  var stat = getState('octoprint.0.printer_status').val;
                                  if (stat == 'Operational'){
                                      //log ('___ Status= ' + stat + '___');
                                      sendTo("paw.0",'Tablet_Jörg',{tts:  'Octoprint-Server ist onnnlein'});
                                      log ('__ Octoprint-Server ist online __');
                                      setState (pfad + 'ShuttingDown', 'OctoPrint ist online', true);
                                      //Aktualisieren des Views
                                      setState("vis.0.control.command", '{"instance": "FFFFFFFF", "command": "changeView", "data": "Touch/Solaranlagen"}');
                                      }, 100);
                                      setState("vis.0.control.command", '{"instance": "FFFFFFFF", "command": "changeView", "data": "Touch/Anycubic"}');
                                      }, 600);
                                      variablen_abfragen();
                          // Wenn Steckdose ausgeschaltet wird, alles auf 0 setzen (fuer vis)
                          on({id: octopi_steckdose, change: 'lt'}, function() {
                                  setState (anycubic_fortschritt, 0);
                                  setState (anycubic_timedone , 0);
                                  setState (anycubic_timeleft , 0);
                                  setState (anycubic_extrudertemp , 0);
                                  setState (anycubic_extrudertemp_soll , 0);
                                  setState (anycubic_tempbed , 0);
                                  setState (anycubic_tempbed_soll , 0);
                                  setState (anycubic_dateigroesse , 0);
                                  setState (anycubic_speicherort , '---');
                                  setState (anycubic_dateiname , '---');
                          // Octoprint-Datenpunkte abfragen
                          function variablen_abfragen(){
                              //log ('___ Octoprint-Datenpunkte werden gelesen ___');
                              lautstaerke();
                              var verbleibende_zeit   = getState(anycubic_timeleft).val;
                              var bed_temp0           = getState(anycubic_tempbed).val;
                              var bed_temp            = Math.round(bed_temp0 * 1) / 1;          // keine Nachkommastellen ansagen
                              var extruder_temp0      = getState(anycubic_extrudertemp).val;
                              var extruder_temp       = Math.round(extruder_temp0 * 1) / 1;     // keine Nachkommastellen ansagen
                              var druck_fortschritt0  = getState(anycubic_fortschritt).val;
                              var druck_fortschritt   = Math.round(druck_fortschritt0 * 1) / 1; // keine Nachkommastellen ansagen
                              var dateigroesse        = getState(anycubic_dateigroesse).val;
                          }   // Ende function variablen_abfragen
                          //Ansage Druckfortschritt
                          on({id: anycubic_fortschritt, change: 'any'}, function() {
                              lautstaerke();
                              var fortschrSprache     = Math.round(druck_fortschritt0 * 10) / 10;   // 1 Nachkommastelle
                              //var dateigroesse        = getState(anycubic_dateigroesse).val;
                              //log ("fort: " + fortschrSprache);
                              //log ("bett: " + bed_temp0);
                          //Ansage des Druck-Fortschrittes bei 25%
                          if(twentyfive == 0 ){
                                      if(fortschrSprache >= 25 && fortschrSprache <= 27 ){
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Der 3 Deeee Drucker hat ' + druck_fortschritt + 'Prozent des Ausdruckes fertiggestellt'});
                                          }, 2000);
                                          log ('__ AnyCubic ist zu ' + druck_fortschritt + '% fertig __');
                                          twentyfive = 1;
                                      } // Ende if fortschrSprache >= 25
                          //Ansage des Druck-Fortschrittes bei 50%
                          if(fifty == 0 ){
                                      if(fortschrSprache >= 50 && fortschrSprache <= 52 ){
                                          }, 2000);
                                          fifty = 1;
                                      } // Ende if fortschrSprache >= 50
                          //Ansage des Druck-Fortschrittes bei 75%
                          if(seventyfive == 0 ){
                                      if(fortschrSprache >= 75 && fortschrSprache <= 77 ){
                                          }, 2000);
                                          seventyfive = 1;
                                      } // Ende if fortschrSprache >= 75
                          //Ansage des Druck-Fortschrittes bei 90%
                          if(ninety == 0 ){
                                      if(fortschrSprache >= 90 && fortschrSprache <= 92 ){
                                          }, 2000);
                                          ninety = 1;
                                      } // Ende if fortschrSprache >= 90
                          //Ansage, dass der Druck fertig ist, wenn Druckfortschritt = 100% und das Druckbett abgekuehlt ist
                          if(done == 0 ){
                                      if(druck_fortschritt == 100 && bed_temp0 >= 48 && bed_temp0 <= 50 ){
                                          sendTo("paw.0",'Tablet_Jörg',{tts:  'Der 3 Deeee Drucker hat den Ausdruck fertiggestellt und die Druckbett-Temperatur ist auf ' + bed_temp + ' Grad gefallen'});
                                          }, 2000);
                                          //sendTo("paw.0",'Tablet_Jörg',{play: true});  // sofort default sound notification abspielen
                                          log ('__ AnyCubic ist fertig, HotBed: ' + bed_temp + '°C __');
                                          done = 1;
                                      } // Ende if druck_fortschritt == 100
                          }); // Ende Ansage Druckfortschritte
                          function lautstaerke(){
                              sendTo("paw.0",'all',{volume: 15});
                          function octo_adapter_on() {
                              // Octoprint-Adapter einschalten
                              var octo_instanz = getObject("system.adapter.octoprint.0");
                              octo_instanz.common.enabled = true;
                              setObject("system.adapter.octoprint.0", octo_instanz);
                              //log ('__ Octoprint_Instanz wurde gestartet __');
                          function octo_adapter_off() {
                              // Octoprint-Adapter ausschalten
                              octo_instanz.common.enabled = false;
                              //log ('__ Octoprint_Instanz wurde beendet __');
                              // Hours
                              // Minutes
                              // Seconds
                              //console.log("Restzeit: " + restzeit);
                              //console.log("Printzeit: " + printzeit);
                          Hinweise zum Script:
                          Die Parameter/Objekte für die WLAN-Steckdose und Ping müssen natürlich an die eigenen Gegebenheiten angepasst werden.
                          Username/Passwort für Octoprint-Raspi müssen im Script eingetragen werden.
                          Bitte nicht über "komische" Schreibweisen, wie z.B. "Der 3 Deeee Drucker hat ...", wundern, die Sprachausgabe hört sich sonst über den PAW-Adapter blöd an.
                          Wenn der Drucker online ist, wechsele ich kurz auf einen andere vis-View und dann wieder zum Drucker-View zurück, weil bei mir sonst der WebCam-Stream nicht angezeigt wurde. Kann man aber auch rausnehmen und den View manuell im Browser aktualisieren/refreshen.
                          Bitte nicht falsch verstehen:
                          Ich habe nur rudimentäres JS Halbwissen und habe mir das Script größtenteils mit Try & Error zusammengeschustert und kann deshalb nur bedingt Hilfestellung geben.
                          Jörg
                          P.S.
                          Bei Alexa bin ich raus 🙄
                          • HALH HAL
                            @joergeli ,
                            VG Uwe
                            joergeliJ Online
                            joergeliJ Online
                            joergeli
                            #80
                            @HAL
                            Ich habe mal versucht, meinen AnyCubic-View zu exportieren:
                            AnyCubic-View.zip
                            (Als Text-Datei konnte ich es nicht hochladen, da hier nur 10000 Zeichen erlaubt sind.)
                            Ich hoffe, das ist richtig so? (Habe ich zum ersten Mal gemacht)
                            AnyCubic-Viewt
                            Beachte aber, daß da wohl auch die Navigations-Tabs und meine Temperatur-Gauges mit enthalten sind.
                            Selbst erstellte Grafiken könnte ich bei Bedarf nachliefern.
                            Jörg
                            HALH RöstkartoffelR Jürgen B. 0J 3 Antworten Letzte Antwort
                              @HAL
                              AnyCubic-View.zip
                              AnyCubic-Viewt
                              Jörg
                              HALH Offline
                              HALH Offline
                              HAL
                              #81
                              @joergeli
                              Erstmal besten Dank ! VIS ist importiert und einiges funktioniert schon . Dein Script muss ich noch anpassen; bei mir spricht Alexa und das geht "ziemlich" anders. Aber kriege ich hin :-) Ich werde auch vermutlich die Temperatur des Hotend als Trigger für den Shutdown des Raspi verwenden ( shutdown wenn Hotend Temp < 50° ) aber vieles von Deinem Script kann ich verwenden ( bisher habe ich das meiste in Blocky abgebildet , mit native Java bin ich noch am Anfang)
                              VG Uwe
                              • HALH HAL
                                @joergeli
                                VG Uwe
                                joergeliJ Online
                                joergeliJ Online
                                joergeli
                                #82
                                @HAL
                                Ich nehme für die Fertigmeldung
                                also wenn Druckfortschritt = 100% und Bett-Temperatur <= 50°C, d.h. der Drucker abgekühlt ist.
                                Ausschalten mache ich lieber über vis, denn es kommt vor, daß ich nach dem ersten Ausdruck noch einen anderen Druck starten will. Kann man natürlich auch als Trigger zum automatischen Runterfahren verwenden.
                                Vielleicht noch ein Hinweis zu den Variablen twentyfive, fifty, seventyfive, etc.:
                                Je nach Größe des Druckes kommt es vor, daß der Druckfortschritt z.B. 50,1%, 50,6%, 50,8%, etc. ist.
                                Das hat dazu geführt, daß mich mein Tablet (via PAW) vollgelabert hat.
                                Durch die zusätzlichen Variablen setze ich einen Merker, daß die jeweilige Ansage bereits erfolgt ist und mein Tablet "sagt" nur 1 Mal, daß der Drucker z.B. 50% fertiggestellt hat.
                                Noch ein Tip:
                                Standardmäßig aktualisiert der Octoprint-Adapter seine Werte "nur" alle 60 Sekunden.
                                Dieser Zeitraum war mir zu lang, deshalb habe ich die Aktualisierungsrate auf 5 Sekunden verkürzt, siehe hier:
                                Octoprint-Adapter Aktualisierungsintevall
                                Jörg
                                RöstkartoffelR 1 Antwort Letzte Antwort
                                  @HAL
                                  Noch ein Tip:
                                  Jörg
                                  RöstkartoffelR Offline
                                  Röstkartoffel
                                  #83
                                  @joergeli
                                  Danke für das Teilen deiner View und des Skriptes.
                                  Könntest du bitte die Grafiken ebenfalls hochladen? Danke.
                                  Desweiteren habe ich ein Problem, in der main.js den Aktivierungsintervall zu ändern, da ich den entsprechenden Passus nicht finden kann.
                                  Ich finde lediglich diese Textpassage, in der eine Zeitangabe vorkommt:
                                                  this.log.debug('re-creating refresh state timeout');
                                                  this.refreshStateTimeout = setTimeout(this.refreshState.bind(this), 60000);
                                  Ich habe den Adapter ioBroker.octoprint v.0.0.2 von matthias@klein0r.de über Github installiert, dieser läuft auch richtig. Benutzt du einen anderen?
                                  NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
                                  joergeliJ WebrangerW 2 Antworten Letzte Antwort
                                  • RöstkartoffelR Röstkartoffel
                                    @joergeli
                                    joergeliJ Online
                                    joergeliJ Online
                                    joergeli
                                    #84
                                    @Röstkartoffel
                                    Hi, ich habe auch den Octoprint-Adapter V 0.0.2 installiert, allerdings - soweit ich mich erinnere - ganz normal über die ioBroker Adapterliste.
                                    Bei mir gibt es eine Datei /iobroker/node_modules/iobroker.octoprint/main.js und darin hatte ich ich der function main() das Intervall auf 5000 ( = 5 Sekunden) geändert:
                                    function main() {
                                        adapter.subscribeStates('*');
                                        adapter.setState('printer_status', {val: printerStatus, ack: true});
                                        // Refresh State every 5 seconds
                                        refreshState();
                                        setInterval(refreshState, 5000);
                                    Hast Du auch die richtige main.js im Ordner /iobroker/node_modules/iobroker.octoprint/main.js ausgewählt?
                                    Falls Deine main.js - aus welchen Gründen auch immer - anders aussieht, kann ich dazu leider nichts sagen.
                                    Aber probier doch einfach mal, in Deiner main.js die 60000 auf 5000 zu ändern (vorher aber backup der main.js machen).
                                    Danach die Octoprint-Instanz neu starten (wichtig!).
                                    Anbei meine GIF-Bilder (ich hoffe, ich habe keins vergessen)
                                    octoprint-gifs.zip
                                    Jörg
                                      @Röstkartoffel
                                      function main() {
                                          refreshState();
                                      octoprint-gifs.zip
                                      Jörg
                                      Röstkartoffel
                                      schrieb am zuletzt editiert von Röstkartoffel
                                      #85
                                      @joergeli
                                      Die main.js ist in diesem Ordner "/opt/iobroker/node_modules/iobroker.octoprint", richtig?
                                      Ich habe eben mal auf GitHub geschaut, dort steht bei der aktuellen Version folgender Change vom 20. Oktober 2019: "setTimeout instead of setInterval".
                                      Wenn ich mir den Fork von resper vom 21. Januar 2019 ansehe, finde ich eine andere main.js und dort auch deine Einträge.
                                      Ich werde in der mir vorliegenden main.js die 60000 auf 5000 ändern und mal schauen, was passiert.
                                      In deiner zip fehlt leider folgendes Bild: dialog-warning-2.png
                                      Könntest du dieses bitte auch hochladen?
                                      Du machst mit einem Javascript einen Ping auf den OctoPi, kannst du dieses bitte auch bereitstellen?
                                      Danke.
                                      Volker
                                        @joergeli
                                        Danke.
                                        Volker
                                        joergeliJ Online
                                        joergeliJ Online
                                        joergeli
                                        #86
                                        @Röstkartoffel
                                        Anbei das fehlende Bildchen:
                                        Ping:
                                        Das ist ein extra JS, mit dem ich alle meine (W)LAN-Geräte auf on-/offline prüfe.
                                        Im Octoprint-Script prüft es nur, ob der Octoprint-Raspi online ist, bevor verschiedene States abgefragt werden.
                                        Es würde m.E. hier zu weit führen, das auch noch zu verhackstücken.
                                        Edit 17.01.2020: Ich habe den "PING-Abschnitt" jetzt kpl. aus dem Script entfernt, der war unnötig.
                                          @joergeli
                                          WebrangerW Offline
                                          WebrangerW Offline
                                          Webranger
                                          #87
                                          @Röstkartoffel
                                          Bei mir sieht das auch so aus.
                                                  this.refreshStateTimeout = setTimeout(this.refreshState.bind(this), 5000);
                                          hab es getestet und Aktuallisiert nun alle 5 sec
                                          Kann das nachteile für den druck geben weil jetzt höhere abfrage am octoprint?
