  2. Русский
  3. ioBroker
  4. ioBroker основное
  5. Arduino+Mqtt FAQ для начинающих.
Geplant Angeheftet Gesperrt Verschoben ioBroker основное
39 Beiträge 4 Kommentatoren 22.8k Aufrufe
  • I Offline
    I Offline
    instalator
    @Securbond:
    @instalator:
    @Securbond:
    не посмотришь где я косячу ?
    #include <spi.h> // Ethernet shield
    #include <ethernet.h> // Ethernet shield
    #include <pubsubclient.h> // MQTT
    #include <virtualwire.h>
    #include <easytransfervirtualwire.h>
    #include <wire.h>
    #include <liquidcrystal_i2c.h>
    LiquidCrystal_I2C lcd(0x27,16,2);
    byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
    byte server[] = {192, 168, 0, 102}; //IP Брокера
    IPAddress ip(192, 168, 0, 112);
    ! EthernetClient ethClient;
    PubSubClient client(server, 1883, callback, ethClient);
    #define id_connect "UNO_1"
    #define Prefix_subscribe "UNO/Detskaya/"
    void callback(char* topic, byte* payload, unsigned int length) {
    payload[length] = '\0';
    // Serial.print(topic);
    // Serial.print("=");
    String strTopic = String(topic);
    String strPayload = String((char*)payload);
    // Serial.println(strPayload);
    callback_iobroker(strTopic, strPayload);
    //create object
    EasyTransferVirtualWire ET;
    ! struct SEND_DATA_STRUCTURE
    //put your variable definitions here for the data you want to send
    //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
    //Struct can'e be bigger then 26 bytes for VirtualWire version
    byte ID;
    long TemperatureBMP = 0;
    long TemperatureDS = 0;
    long Pressure = 0;
    ! //give a name to the group of data
    SEND_DATA_STRUCTURE mydata;
    byte ID;
    long Pressure = 0;
    ! void setup(){
    //start the library, pass in the data details
    ET.begin(details(mydata));
    Serial.begin(9600);
    // Initialise the IO and ISR
    vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000); // Bits per sec Скорость порта
    vw_set_rx_pin(8); //порт к которому подключен приемник 433 мГц
    vw_rx_start(); // Start the receiver PLL running
    lcd.init(); // Инициализируем экран
    lcd.backlight(); //Включаем подсветку
    ! Ethernet.begin(mac, ip);
    if (client.connect(id_connect)) {
    client.publish("UNO/Detskaya/Temp", "0");
    client.publish("UNO/Detskaya/Pressure", "0");
    client.subscribe("UNO/Detskaya/#");
    ! void loop(){
    //check and see if a data packet has come in.
    if(ET.receiveData()){
    //this is how you access the variables. [name of the group].[variable name]
    //since we have data, we will blink it out.
    if (mydata.ID == 1)
    int TempBMP= (mydata.TemperatureBMP);
    TempBMP = ((TempBMP)/100);
    float TempDS= (mydata.TemperatureDS);
    TempDS = ((TempDS)/100);
    float Pressure2= (mydata.Pressure);
    Pressure2 = ((Pressure2)/100);
     client.loop();
      if (!client.connected()) {
    client.publish("UNO/Detskaya/Temp", TempDS);
     client.publish("UNO/Detskaya/Pressure", Pressure2);
    // Serial.print(TempBMP); //Вывод информации в COM порт
    // Serial.println(", TempBMP:");
    // Температуру в градусах Цельсия
    Serial.print(TempDS);
    Serial.print(" C°,");
    Serial.print(Pressure2);
    Serial.print(" mm/");
    //Выводим давление в мм.рт ст
    Serial.println();
    Serial.println();
    delay(1000);
                                      //Вывод информации на  LCD Экран
    lcd.clear();//очищаем экран от старых данных
    lcd.setCursor(0,0);//Устанавливаем курсор в начало первой строки
    lcd.print("T1:");//Выводим первую температуру
    lcd.print(TempDS);
    lcd.setCursor(8,0);// устанавливаем курсор на 8 позицию в первой строке
    lcd.print(" T2:");//Выводим вторую температуру
    lcd.print(TempBMP);
    //аналогично выводим вторую строку
    lcd.setCursor(0,1);//Устанавливаем курсор в начало второй строки
    lcd.print("Davlenie:");//Выводим давление
    lcd.print(Pressure2);
    ! }</liquidcrystal_i2c.h></wire.h></easytransfervirtualwire.h></virtualwire.h></pubsubclient.h></ethernet.h></spi.h>
    Ругается -
    >! priemnik433_E2.ino: In function 'void callback(char*, byte*, unsigned int)':
    >! priemnik433_E2:28: error: 'callback_iobroker' was not declared in this scope
    >! priemnik433_E2.ino: In function 'void loop()':
    >! priemnik433_E2:96: error: no matching function for call to 'PubSubClient::publish(const char [18], float&)'
    >! priemnik433_E2.ino:96:47: note: candidates are:
    >! In file included from priemnik433_E2.ino:3:0:
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:117:12: note: boolean PubSubClient::publish(const char*, const char*)
    >! boolean publish(const char* topic, const char* payload);
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:117:12: note: no known conversion for argument 2 from 'float' to 'const char*'
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:118:12: note: boolean PubSubClient::publish(const char*, const char*, boolean)
    >! boolean publish(const char* topic, const char* payload, boolean retained);
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:118:12: note: candidate expects 3 arguments, 2 provided
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:119:12: note: boolean PubSubClient::publish(const char*, const uint8_t*, unsigned int)
    >! boolean publish(const char* topic, const uint8_t * payload, unsigned int plength);
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:119:12: note: candidate expects 3 arguments, 2 provided
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:120:12: note: boolean PubSubClient::publish(const char*, const uint8_t*, unsigned int, boolean)
    >! boolean publish(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
    >! C:\Users\Bond-PC\Documents\Arduino\libraries\PubSubClient\src/PubSubClient.h:120:12: note: candidate expects 4 arguments, 2 provided
    >! priemnik433_E2:97: error: no matching function for call to 'PubSubClient::publish(const char [22], float&)'
    >! priemnik433_E2.ino:97:55: note: candidates are:
    >! 'callback_iobroker' was not declared in this scope `
    Типы переменных передаваемые в функцию не совпадают.
    Пробуй так
            char b[5];
        String char_TempDS = String(TempDS);
        char_TempDS.toCharArray(b,5);
        client.publish("UNO/Detskaya/Temp", b);
            String char_Pressure2 = String(Pressure2);
        char_Pressure2.toCharArray(b,5);
    Остались только эти ошибки
    но судя по всему дело все в тех же переменных `
    Ну ругается же на 28 строку - callback_iobroker(strTopic, strPayload);
    Где в коде сама функция, вызываешь функуию callback_iobroker(strTopic, strPayload); а самой функции нету
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
      Securbond
      @instalator:
      @Securbond:
      @instalator:
      Пробуй так
              char b[5];
      Где в коде сама функция, вызываешь функуию callback_iobroker(strTopic, strPayload); а самой функции нету `
      как раз хотел спросить что делает эта функция
      /////////////////////////////////От Брокера//////////////////////////////////////////////
      void callback_iobroker(String strTopic, String strPayload){
        if (strTopic == "0"){
      добавил, ошибок больше стало аааааааа….........
      • I Offline
        I Offline
        instalator
        @Securbond:
        добавил, ошибок больше стало аааааааа…......... `
        Эта функция принимает strTopic от iobroker.
        • I Offline
          I Offline
          instalator
          @instalator:
          @Securbond:
          Для примера:
            if (strTopic == "myhome/Lighting/BedRoom_Main") {
              if (strPayload == "0") {
                digitalWrite(23, 0);
                delay(pause);
                client.publish("myhome/Lighting/BedRoom_Main", "0");
              else if (strPayload == "1") {
                digitalWrite(23, 1);
                delay(pause);
                client.publish("myhome/Lighting/BedRoom_Main", "1");
            Securbond
            @instalator:
            @instalator:
            @Securbond:
            Для примера:
                  delay(pause);
                  delay(pause);
            как понял это обратная связь, если на брокере значение поменять она передает его ардуине так ??
            я эту функцию временно закоментил и залил скетч.
            объекты создались но данные не приходят везде стоит - 0
            • I Offline
              I Offline
              instalator
              @Securbond:
              ! filename="77.JPG" index="0">~~ `
              Правильно понял, это callback.
              а данные у тебя и не будут передаватся брокеру (в коду у тебя так написано), только если ты кабель из ардуины выдернишь и заново вставишь, тогда передадутся данные в iobroker.
              добавь строки в общий луп
              char b[5];
                Securbond
                @instalator:
                @Securbond:
                char b[5];
                client.publish("UNO/Detskaya/Temp", b); `
                А разве сейчас не так ?
                void loop(){
                    if (mydata.ID == 1)
                     client.loop();
                        char b[5];
                • I Offline
                  I Offline
                  instalator
                  @Securbond:
                  @instalator:
                  @Securbond:
                  char b[5];
                  void loop(){
                      if (mydata.ID == 1)
                       client.loop();
                          char b[5];
                  нет, не ужели нельзя чуток подумать и вникнуть в код?
                  void loop(){
                   char b[5];
                      if (mydata.ID == 1)
                       client.loop();
                    Securbond
                    @instalator:
                    @Securbond:
                    @instalator:
                    char b[5];
                    void loop(){
                        if (mydata.ID == 1)
                         client.loop();
                            char b[5];
                    void loop(){
                     char b[5];
                        if (mydata.ID == 1)
                         client.loop();
                    Пришлось еще объявить в начале программы (глобально)
                    float TempDS и float Pressure2,
                    иначе выдавал ошибку
                    но легче не стало на брокер ничего не передает.
                    на LCD всё отображает. :roll: :?
                    • I Offline
                      I Offline
                      instalator
                      @Securbond:
                      на LCD всё отображает. :roll: :? `
                      замени строки :
                      на
                      #define id_connect "UNO-Detskaya"
                        Securbond
                        @instalator:
                        @Securbond:
                        Похоже проблема в подключении к локалке, пока что не вижу шилда в сети …
                        Спасибо, сейчас попробую голый скетч залить. На всякий случай [http://forum.iobroker.net/viewtopic.php?f=33&amp;t=1609](http://forum.iobroker.net/viewtopic.php?f=33&amp;t=1609), мало ли)
                        Проверил резисторную сборку стоят резы на 250 Om
                        И еще, подключил и комп и сеть, раскомментировал отладочные строки
                        тут Serial.print(topic);
                        и
                        тутvoid callback_iobroker(String strTopic, String strPayload){
                        if (strTopic == "UNO/Detskaya/Temp") {
                        Так вот в СОМ порт кроме температуры больше ничего не сыпится, по соединению вообще ноль информации.
                        P.S. Вообще странно, потому что при заливке стандартного скетча вэб сервера, все работает прекрасно :roll: :?:
                        • P Offline
                          pmaster
                          подскажите, что могу делать не так?
                          данные на брокер приходят исправно. но я не могу ничего отправить обратно.
                          беру к примеру выключатель, лампочку, прописываю их на топик их состояния, нажимаю выключатель, на экране лампочки зажигаются, гаснут. а данные от брокера на mqtt сервер не уходят.
                          • I Offline
                            I Offline
                            instalator
                            @pmaster:
                            беру к примеру выключатель, лампочку, прописываю их на топик их состояния, нажимаю выключатель, на экране лампочки зажигаются, гаснут. а данные от брокера на mqtt сервер не уходят. ` вы что то путаете наверное. Иоб выступает в качестве сервера mqtt. Он отправит значение всем подписавшимся на топик клиентам.
                            • P Offline
                              pmaster
                              я ничего не путаю. в качестве сервера у меня стоит mosquitto. Иоб выступает в качестве клиента. С проблемой разобрался :). По умолчанию в клиенте mqtt не стоит галочка "publish" (на топике).
                              сейчас возник вопрос. можно ли отключить получение своих же сообщений? т.е. я публикую сообщение, и оно тут же приходит мне обратно.
                                smoker_vvo
                                instalator - Доброго времени! Есть вопрос по скетчу - скомпилировался, загрузился… работает. НО! температуру кажет -127, типа датчика не видит, а это не правда, запускаем типовой ТЕстер от Ардуино 1.0.6 - датчик есть температуру кажет.
                                Dallas Temperature IC Control Library Demo
                                Locating devices...Found 1 devices.
                                Parasite power is: ON
                                Found device 0 with address: 2880E93A04000010
                                Setting resolution to 9
                                Resolution actually set to: 9
                                Requesting temperatures...DONE
                                Temperature for device: 0
                                Temp C: 25.00 Temp F: 77.00
                                Как видно - адрес найден...
                                Вбиваем его сюда:
                                #define ONE_WIRE_BUS 8
                                #define TEMPERATURE_PRECISION 9 - сам добавил, без нее то же -127
                                OneWire oneWire(ONE_WIRE_BUS);
                                DallasTemperature DS_sensors(&oneWire);
                                // 28 80 E9 3A 04 00 00 10
                                DeviceAddress addr_T1 = { 0x28, 0x80, 0xE9, 0x3A, 0x04, 0x00, 0x00, 0x10 };
                                float T1 = 0;
                                Ну вот результат -
                                • I Offline
                                  I Offline
                                  instalator
                                  @smoker_vvo:
                                  температуру кажет -127, типа датчика не видит, а это не правда, запускаем типовой ТЕстер от Ардуино 1.0.6 - датчик есть температуру кажет. `
                                  версия библиотек какая? попробуй откатить на предыдущую
