  4. [Gelöst] Blockly einfachen Timer einstellen
blocklytimeriobrokersensor
14 Beiträge 2 Kommentatoren 1.8k Aufrufe 2 Beobachtet
    @mend sagte:
    dann prüft er ja garnicht weiter ob das Fenster immernoch offen ist.
    Wenn das Fenster geschlossen wird, wird das Intervall gestoppt.
     <variables>
       <variable type="" id="J?SRdnY^Iwq2c3:ZdG0a">stunden</variable>
       <variable type="undefined" id="Intervall">Intervall</variable>
     </variables>
     <block type="comment" id="kjjmLopy%Mj[^f7$=q{q" x="-238" y="-537">
       <field name="COMMENT">Fenster</field>
       <next>
         <block type="on_ext" id="G2^IChJ~h]+%W^-SMBaK">
           <mutation items="1"></mutation>
           <value name="OID0">
             <shadow type="field_oid" id="rZJH[[^h$mYxI3/q`M@l">
             </shadow>
           </value>
           <statement name="STATEMENT">
             <block type="variables_set" id="R|UblWWs`M=9u~$8J(tH">
               <field name="VAR" id="J?SRdnY^Iwq2c3:ZdG0a" variabletype="">stunden</field>
               <value name="VALUE">
                 <block type="math_number" id="E52;F!]-1ceQY2Yx7:w?">
                   <field name="NUM">0</field>
                 </block>
               </value>
               <next>
                 <block type="controls_if" id="g0-[wb7|KK)/^TNMW$,Z">
                   <value name="IF0">
                     <block type="on_source" id="m):wrfkei?a;nZApPVHJ">
                     </block>
                   </value>
                   <statement name="DO0">
                     <block type="timeouts_setinterval" id="5Wb#5s3~GXe}mE|r^.AF">
                       <field name="NAME">Intervall</field>
                       <field name="INTERVAL">60</field>
                       <field name="UNIT">min</field>
                         <block type="math_change" id="Zm6SP-fv!}NPE9XnC4/i">
                           <value name="DELTA">
                             <shadow type="math_number" id="j:DhOZ`;D#{m!;|*O?T,">
                               <field name="NUM">1</field>
                             </shadow>
                           </value>
                           <next>
                             <block type="telegram" id="_D?P_[Gy+JGQBalxe5m5">
                               <field name="LOG"></field>
                               <value name="MESSAGE">
                                 <shadow type="text" id="_SQC1PVG%*?UPqKJX6C2">
                                 </shadow>
                                 <block type="text_join" id="j4w9i[Wv](WA8t$)XKRe">
                                   <value name="ADD0">
                                     <block type="text" id="nVfXb`f4NMgZGd@tRK38">
                                       <field name="TEXT">Das Fenster A ist nun seit </field>
                                     </block>
                                   </value>
                                   <value name="ADD1">
                                     <block type="variables_get" id=".FSi/(WZNJgF}G|F/SFv">
                                     </block>
                                   </value>
                                   <value name="ADD2">
                                     <block type="text" id="^VnVIcqIq+w)0aI0_jh0">
                                       <field name="TEXT"> Stunde(n) offen</field>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </statement>
                   <statement name="ELSE">
                     <block type="timeouts_clearinterval" id=".H~+j`!yBQYX;ZoBekcC">
                       <next>
                         <block type="telegram" id="%}Jz;Nnk4~?tF{PY#MdW">
                             <shadow type="text" id=":F*%,qIyyUKbhO/#$!TA">
                               <field name="TEXT">Das Fenster A wurde geschlossen</field>
                             </shadow>
                           </value>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    smartysmart
    schrieb am zuletzt editiert von smartysmart
    Jetzt ist meine Antwort über deiner Antwort gelandet obwohl du zuerst geschrieben hast ... wtf :)
    @admin glaub hab ein Bug gefunden.
    • S smartysmart
      Danke für den Code.
      Werd das gleich mal probieren.
      Damit ich aber in Zukunft auch alleine schaffe hätte ich noch zwei Verständnisfragen ...
      1. "wurde geändert" -> Hab ich dann hier nicht das Problem, dass auch Wenn das Fenster zu ist 1 stunde dass ich ne Meldung bekomme ? Weil hier nicht auf Wahr geprüft wird sondern nur auf eine Änderung ? Das heisst auch eine Änderung von offen nach zu ?
      2. Was macht dieses Falls "Falls -> Wert" ? Prüfen wir hier ob offen ? Wenn ja dann versteh ich nicht wie hier geprüft wird -.-
      @mend sagte:
      Ja. Der mache-Zweig wird ausgeführt, wenn das Fenster geöffnet wird, der sonst-Zweig bei Schließen des Fensters.
        @mend sagte:
        smartysmart
        @paul53 sagte in Blockly einfachen Timer einstellen:
        @mend sagte:
        Aber woher weiss Blockly das er beim geöffnten Fenster den mache-zweig ausführt und beim geschloßenen den sonst-zweig ?
        Wenn da stehen würde "falls -> Wert = wahr" dann würde ich es verstehen, aber ich versteh nicht was in dem Block "Wert" drin steht und woher die Infos von dem Inhalt her kommt.
        P:S VIELEN DANK das Script funktioniert !!!
        • S smartysmart
          @mend sagte:
          @mend sagte:
          Wert enthält den Wert des Trigger-Datenpunktes. Eine Abfrage if(Bedingung) liefert true, wenn die Bedingung erfüllt ist, andernfalls wird false geliefert. Wenn der Wert schon true bzw. false liefert, kann man sich den Vergleich sparen.
            @mend sagte:
            smartysmart
            @mend sagte in Blockly einfachen Timer einstellen:
            ok ich denke ich verstehe. Dadurch dass wird auf "wurde geänderte" abfragen bekommen wir true zurück wenn das Fenster auf geht weil sich der Status vom Datenpunkt ändert ?
            Also müsste das das gleiche Ergebniss bringen ?
            • S smartysmart
              @mend sagte:
              Ja, wenn die richtige ID zugewiesen wird.
                smartysmart
                Alles klar ... TOP Danke :)
                  smartysmart
                  Jetzt ist mir grad aufgefallen, dass er die Meldung mit "Fenster zu" immer bringt sobald man das Fenster auf und zu macht.
                  Ziel wäre die Zu Meldung zu bringen "nur" wenn er nach 1 Stunde wegen Fenster offen gewarnt hat.
                  Wenn das Fenster davor schon zu gemacht wird dann soll er garnichts schreiben.
                  Wenn das zu viel Aufwand ist nehme ich die Fenster zu Nachricht einfach komplett raus, wäre nicht soooo wichtig.
                  • S smartysmart
                    @mend sagte:
                    Beachte, dass setze stunden auf 0 nur im mache-Zweig erfolgt.
                      @mend sagte:
                      smartysmart
                      Danke scheint zu funktionieren
