  4. Zeitplan/Astrozeit
Zeitplan/Astrozeit
astrozeitplaungblockly
13 Beiträge 2 Kommentatoren 791 Aufrufe 2 Beobachtet
    BigMike71
    ich versuche mit der Zeitplanung und Astro eine Lampe zu schalten, ein geht sie, allerdings aus nicht mehr. was mache ich falsch?
    hier das JS dazu und blockley
    schedule('{"time":{"exactTime":true,"start":"05:15"},"period":{"days":1}}', function () {
    setState("sonoff.0.Lampe-5.POWER"/Lampe-5 POWER/, true);
    schedule('{"time":{"exactTime":true,"start":"dawn"},"period":{"days":1}}', function () {
    setState("sonoff.0.Lampe-5.POWER"/Lampe-5 POWER/, false);
    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
    • B BigMike71
      Jan1
      @BigMike71
      Dein Text passt nicht zum Blockly.
      Ich sehe kein Astro Trigger und der Ausschaltblock enthält keine Zeit.
      • J Jan1
        @BigMike71
        BigMike71
        schrieb am zuletzt editiert von BigMike71
        @Jan1
        vieleicht liegt da mein gedankenfehler?
        der trigger ist doch der Zeitplan oder?
        und die Astrozeit zum auschalten ist das dawn dachte ich?
        ich wollte einfacht eine Lampe um 5.15 morgens fest einschalten und dann zur morgendämmerung wieder aus...
        • B BigMike71
          @Jan1
          Jan1
          @BigMike71
          Nimm mal ein vernünftigen CRON und ein Astrotrigger.
          • J Jan1
            @BigMike71
            BigMike71
            @Jan1
            bin noch recht neu bei der sache, habe iobroker erst seit gut einer woche am laufen und bin noch am probieren. hast du vieleicht eine kleine starthilfe?
            • B BigMike71
              @Jan1
              Jan1
              @BigMike71
              Ich schreib vom Handy aus und unter Trigger findest doch was ich geschrieben habe.
              • J Jan1
                @BigMike71
                BigMike71
                @Jan1
                cron ist doch ein Zeitplan oder?
                weil es gibt noch direkte cron einträge bei trigger..
                also ein Zeitplan machen und darin dann die astrotrigger?
                also so:?
                schedule('{"time":{"exactTime":true,"start":"00:00"},"period":{"days":1}}', function () {
                schedule({astro: "sunrise", shift: 0}, function () {
                schedule({astro: "sunset", shift: 0}, function () {
                J 2 Antworten Letzte Antwort
                • B BigMike71
                  @Jan1
                  also so:?
                  Jan1
                  @BigMike71
                  Bei Zeitplan nimmst den Cron, ist einfacher und der Block darunter ist ein Astro Trigger und das was da gebaut hast ist Blödsinn.
                  Das erste war schon fast richtig, nur ohne Astro
                  • B BigMike71
                    @Jan1
                    also so:?
                    Jan1
                    @BigMike71
                    Und wenn Du Code postest, dann in Code Tacks. So kann das keiner lesen.
                    • J Jan1
                      @BigMike71
                      BigMike71
                      @Jan1
                      so, sollte das richtig sein?
                      verstehe leider die logic nicht ganz dahinter wenn nicht...
                      • B BigMike71
                        @Jan1
                        Jan1
                        @BigMike71
                        Wenn ich schreibe, dass der "neue" Aufbau Blödsinn ist und Dein erster gar nicht so falsch war, dann ist das jetzt immer noch Blödsinn.
                        Wenn ich schreibe CRON, dann meine ich das auch, weil ich es einfacher finde:
                        • J Jan1
                          @BigMike71
                          BigMike71
                          @Jan1
                          ok danke,
                          hatte gestern abend noch dies hier gebaut und scheint auch zu funktonieren, da ähnlich wie deins...
                          • B BigMike71
                            @Jan1
                            ok danke,
                            Jan1
                            @BigMike71
                            Das kannst so auch lassen, ich nehme eben lieber den CRON dazu, weil ich es einfacher finde, ist aber Geschmackssache. Siehst ja schon wie es bei Dir aussieht und im Vergleich dazu das ganze mit CRON als Zeitplan. Mit CRON schön übersichtlich, bei Dir eben viel kryptisches Zeug mit drin.
                            Das Prinzip hast verstanden und somit ist das hier gelöst 😊
                            82.8k
