  5. [Gelöst]Aktionen in Zeiträumen ausführen
    5.6k
35 Beiträge 3 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • MyzerATM MyzerAT
    ersetze das script mal damit und poste die ausgabe vom log , nachdem du das fenster auf und zu gemacht hast
      <block type="on_ext" id="%E;Qg2sQ}!9v1Sg%sHem" x="13" y="-137">
        <mutation items="1"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="acRxbE]ZswK);Ip)PKI-">
            <field name="oid">sonoff.0.Sideboard-klein.POWER3</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id="!^){RXmHU_4+SkTBtir|">
            <value name="IF0">
              <block type="logic_operation" id="DHl=v^5C%C{Cga#8qjhS" inline="false">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="logic_compare" id="],0#Ql:7n(|s{K4,whF.">
                    <field name="OP">EQ</field>
                    <value name="A">
                      <block type="on_source" id="yNP^ua:Wx:eA2]71{}v`">
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_boolean" id="fG+x=MXSMg,T$l-Wu:MV">
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_operation" id="zEx-2*a.GvViCT*N:4zl" inline="false">
                    <field name="OP">OR</field>
                    <value name="A">
                      <block type="time_compare_ex" id="cv^Ro;cI@Nx!A1@fg#;q">
                        <mutation end_time="true" actual_time="true"></mutation>
                        <field name="USE_ACTUAL_TIME">TRUE</field>
                        <field name="OPTION">between</field>
                        <value name="START_TIME">
                          <shadow type="text" id="OqH;o!.JKup;0Oo#@Mlj">
                            <field name="TEXT">22:00</field>
                          </shadow>
                        </value>
                        <value name="END_TIME">
                          <shadow type="text" id="v|?OE-sVAfV=A@FHG^?m">
                            <field name="TEXT">00:00</field>
                          </shadow>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="time_compare_ex" id="$Tb(t}ZnZr]]OZNDpG|e">
                          <shadow type="text" id="U8L(2F[VWDui8:_Flr*I">
                          </shadow>
                        </value>
                          <shadow type="text" id="oant[D3^OR4SFtV+d*ak">
                            <field name="TEXT">07:00</field>
                          </shadow>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="control" id="[oyk~?W5%:`0y6v!;|.{">
                <mutation delay_input="false"></mutation>
                <field name="OID">sonoff.0.RF-Bridge.RfKey10</field>
                <value name="VALUE">
                  <block type="logic_boolean" id="e$N/#vg=FvIxr7tWOBrI">
                  </block>
                </value>
                <next>
                  <block type="debug" id="k]M56!p$w_Ikt^*1DV}2">
                    <field name="Severity">warn</field>
                    <value name="TEXT">
                      <shadow type="text" id="=7:noFc;?hNUv/~t)(8L">
                        <field name="TEXT">************************** Fenster offen</field>
                      </shadow>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
            <statement name="ELSE">
              <block type="control" id=",;y2q,ag-)2BQ!.*S3!O">
                <field name="OID">sonoff.0.RF-Bridge.RfKey9</field>
                  <block type="logic_boolean" id="LTBhUs_iW2wPGI+iG0-b">
                  </block>
                </value>
                <next>
                  <block type="debug" id="AEV|F#TMDj~r*]Ve.0!-">
                    <value name="TEXT">
                      <shadow type="text" id="9Xz4=@(+sMGK3GmLNbqC">
                        <field name="TEXT">************************** Fenster geschlossen</field>
                      </shadow>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    Titec
    schrieb am zuletzt editiert von Titec
    @MyzerAT komischerweise schaltet sich das Licht dann auch nicht mehr aus, sondern nur an. Im Log steht folgendes:```
    javascript.0	2019-12-15 13:35:18.103	warn	script.js.common.Automatische_Abläufe.Licht_mit_Lüften_Test: ************************** Fenster geschlossen
    javascript.0	2019-12-15 13:35:18.103	warn	at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
    javascript.0	2019-12-15 13:35:18.102	warn	at Socket.Readable.push (_stream_readable.js:223:10)
    javascript.0	2019-12-15 13:35:18.102	warn	at readableAddChunk (_stream_readable.js:268:11)
    javascript.0	2019-12-15 13:35:18.102	warn	at addChunk (_stream_readable.js:287:12)
    javascript.0	2019-12-15 13:35:18.102	warn	at Socket.emit (events.js:198:13)
    javascript.0	2019-12-15 13:35:18.098	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-12-15 13:35:18.098	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-12-15 13:35:18.098	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-12-15 13:35:18.098	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-12-15 13:35:18.097	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-12-15 13:35:18.097	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-12-15 13:35:18.097	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-12-15 13:35:18.097	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-12-15 13:35:18.097	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-12-15 13:35:18.097	warn	at WebSocket.emit (events.js:198:13)
    javascript.0	2019-12-15 13:35:18.097	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-12-15 13:35:18.097	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-12-15 13:35:18.097	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-12-15 13:35:18.096	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-12-15 13:35:18.096	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:18.096	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-12-15 13:35:18.096	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-12-15 13:35:18.096	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:18.096	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-12-15 13:35:18.096	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-12-15 13:35:18.096	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-12-15 13:35:18.095	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-12-15 13:35:18.095	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-12-15 13:35:18.095	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-12-15 13:35:18.095	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:18.095	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-12-15 13:35:18.095	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0	2019-12-15 13:35:18.095	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0	2019-12-15 13:35:18.095	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:18.094	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-12-15 13:35:18.094	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
    javascript.0	2019-12-15 13:35:18.094	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-12-15 13:35:18.094	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-12-15 13:35:18.094	warn	at Object.<anonymous> (script.js.common.Automatische_Abläufe.Licht_mit_Lüften_Test:8:5)
    javascript.0	2019-12-15 13:35:18.094	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-12-15 13:35:18.093	warn	Wrong type of sonoff.0.RF-Bridge.RfKey9: "boolean". Please fix, while deprecated and will not work in next versions.
    javascript.0	2019-12-15 13:35:15.849	warn	script.js.common.Automatische_Abläufe.Licht_mit_Lüften_Test: ************************** Fenster geschlossen
    javascript.0	2019-12-15 13:35:15.848	warn	at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
    javascript.0	2019-12-15 13:35:15.848	warn	at Socket.Readable.push (_stream_readable.js:223:10)
    javascript.0	2019-12-15 13:35:15.848	warn	at readableAddChunk (_stream_readable.js:268:11)
    javascript.0	2019-12-15 13:35:15.848	warn	at addChunk (_stream_readable.js:287:12)
    javascript.0	2019-12-15 13:35:15.848	warn	at Socket.emit (events.js:198:13)
    javascript.0	2019-12-15 13:35:15.848	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-12-15 13:35:15.848	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-12-15 13:35:15.848	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-12-15 13:35:15.848	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-12-15 13:35:15.847	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-12-15 13:35:15.847	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-12-15 13:35:15.847	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-12-15 13:35:15.847	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-12-15 13:35:15.847	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-12-15 13:35:15.847	warn	at WebSocket.emit (events.js:198:13)
    javascript.0	2019-12-15 13:35:15.847	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-12-15 13:35:15.847	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-12-15 13:35:15.847	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-12-15 13:35:15.846	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-12-15 13:35:15.846	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:15.846	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-12-15 13:35:15.846	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-12-15 13:35:15.846	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:15.846	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-12-15 13:35:15.846	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-12-15 13:35:15.846	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-12-15 13:35:15.846	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-12-15 13:35:15.845	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-12-15 13:35:15.845	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-12-15 13:35:15.845	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:15.845	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-12-15 13:35:15.845	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0	2019-12-15 13:35:15.845	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0	2019-12-15 13:35:15.845	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-12-15 13:35:15.845	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-12-15 13:35:15.844	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3706:37)
    javascript.0	2019-12-15 13:35:15.844	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-12-15 13:35:15.844	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-12-15 13:35:15.844	warn	at Object.<anonymous> (script.js.common.Automatische_Abläufe.Licht_mit_Lüften_Test:8:5)
    javascript.0	2019-12-15 13:35:15.844	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-12-15 13:35:15.843	warn	Wrong type of sonoff.0.RF-Bridge.RfKey9: "boolean". Please fix, while deprecated and will not work in next versions.
    javascript.0	2019-12-15 13:35:05.386	info	script.js.common.Automatische_Abläufe.Licht_mit_Lüften_Test: registered 1 subscription and 0 schedules
    javascript.0	2019-12-15 13:35:05.372	info	Start javascript script.js.common.Automatische_Abläufe.Licht_mit_Lüften_Test
    • MyzerATM Offline
      MyzerATM Offline
      MyzerAT
      schrieb am zuletzt editiert von MyzerAT
      also laut log funktioniert das script, da es außerhalb der Zeit ist wird nur "SONST" ausgeführt, also Fenster ist geschlossen und führt "Bett aus" aus !
      was machen die zwei:
      lg Rudi
      Node 22.23.0
      Nodejs 22.23.0
      npm 10.9.8
      js-controller 7.2.2
      • MyzerATM MyzerAT
        Titec
        @MyzerAT Ich glaube ich hab den Fehler:
        Bett aus schaltet die Funksteckdose aus, Bett ein schaltet sie ein.
        Wenn Sonst ausgeführt wird, wird Bett ein ausgeführt. Wenn ich in der Bedingung statt Wahr, Falsch setze und die beiden Objekte tausche, müsste es ja funktionieren.
        • MyzerATM Offline
          MyzerATM Offline
          MyzerAT
          dann dreh es mal um
          lg Rudi
          Node 22.23.0
          Nodejs 22.23.0
          npm 10.9.8
          js-controller 7.2.2
          • T Titec
            dslraserD Offline
            dslraserD Offline
            dslraser
            @Titec
            hier gibt es einen falschen type laut Log
            • dslraserD dslraser
              @Titec
              Titec
              @dslraser Huch, da haste mich erwischt..
              Bin recht neu mit Blockly und Co, was genau müsste ich dafür ändern? oder stört das nicht?
              @MyzerAT habe ich gemacht. Jetzt sendet er immer den Befehl für Bett aus - Funktioniert also in erster Instanz. Besteht die Möglichkeit, dass er das auch nur macht, wenn die Zeitbedingung erfüllt ist? Sonst wird ja beim Lüften die Steckdose immer ausgestellt, obwohl sie zeitweise an sein soll..
              dslraserD MyzerATM 2 Antworten Letzte Antwort
              • MyzerATM Offline
                MyzerATM Offline
                MyzerAT
                mit was schaltest du die Lampen sonst ein?
                lg Rudi
                Node 22.23.0
                Nodejs 22.23.0
                npm 10.9.8
                js-controller 7.2.2
                • T Titec
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @Titec sagte in Aktionen nur in bestimmten Zeiträumen ausführen:
                  Was ist das für ein Datenpunkt den Du steuern willst ? Zeige mal den RAW von dem Datenpunkt.
                  @MyzerAT
                  warum falls Wert = wahr ?
                  (falls Wert reicht)
                  MyzerATM 1 Antwort Letzte Antwort
                    @MyzerAT
                    (falls Wert reicht)
                    MyzerATM Offline
                    MyzerATM Offline
                    MyzerAT
                    @dslraser
                    weil ich das so gewohnt bin und es so ja auch funktioniert!
                    lg Rudi
                    Node 22.23.0
                    Nodejs 22.23.0
                    npm 10.9.8
                    js-controller 7.2.2
                    • MyzerATM MyzerAT
                      Titec
                      @MyzerAT Über Telegram (Den Text2Command Adapter) oder per Zeisteuerung auch über ein Java Script.
                      Laut irgendeinem Tutorial kann ich hier den State auf false setzen, sobald die Bridge das gesendet hat, setzt sie es wieder auf learned sent.
                      Ist im übrigen eine mit Tasmota geflashte RF-Bridge von Sonoff
                      • MyzerATM Offline
                        MyzerATM Offline
                        MyzerAT
                        was steuerst du damit was an der Steckdose hängt, die Steckdose ist nur per RF Signal erreichbar?
                        lg Rudi
                        Node 22.23.0
                        Nodejs 22.23.0
                        npm 10.9.8
                        js-controller 7.2.2
                        • MyzerATM MyzerAT
                          Titec
                          wie meinst du, was steuer ich?
                          Geschaltet wird eine Lampe in diesem Fall und ansteuern tue ich das wie in unserem Beispiel.
                          Ja das sind RF Steckdosen. Stehe nicht so auf die WLAN Dinger und die Sonoff Dinger denen traue ich nicht so wirklich :/
                          • MyzerATM Offline
                            MyzerATM Offline
                            MyzerAT
                            dslraser will den RAW sehen von dem Datenpunk
                            lg Rudi
                            Node 22.23.0
                            Nodejs 22.23.0
                            npm 10.9.8
                            js-controller 7.2.2
                            • MyzerATM MyzerAT
                              Titec
                              @MyzerAT whooops sorry, kommt sofort:
                                "_id": "sonoff.0.RF-Bridge.RfKey9",
                                "common": {
                                  "type": "number",
                                  "role": "value",
                                  "read": true,
                                  "write": true,
                                  "name": "Bett An"
                                "native": {},
                                "type": "state",
                                "from": "system.adapter.sonoff.0",
                                "user": "system.user.admin",
                                "ts": 1575639054544,
                                "acl": {
                                  "object": 1638,
                                  "state": 1638
                              • MyzerATM Offline
                                MyzerATM Offline
                                MyzerAT
                                das ist der falsche RAW, der Fehler tritt ja bei "RfKey9" auf
                                lg Rudi
                                Node 22.23.0
                                Nodejs 22.23.0
                                npm 10.9.8
                                js-controller 7.2.2
                                • MyzerATM MyzerAT
                                  Titec
                                  @MyzerAT ist korrigiert, danke :D
                                  • T Titec
                                    MyzerATM Offline
                                    MyzerATM Offline
                                    MyzerAT
                                    ja das würde gehen, du musst dazu aber einen neuen Datenpunkt anlegen und wenn dieser ausgeführt wird, dann eine Bedingung erstellen das beim öffnen/schließen des Fensters nicht das Licht abgeschaltet wird im Zeitraum xyz. ist aber ein wenig aufwändiger!
                                    fürs Küchenlicht über Tisch zb. mache ich das über einen Taster, wird dieser betätigt, wird ein Datenpunkt auf wahr gestellt und im Script überprüft, ist dieser auf Wahr wird das Licht nicht abgeschaltet, ist dieser auf falsch dann läuft das Script durch und schaltet ab!
                                    lg Rudi
                                    Node 22.23.0
                                    Nodejs 22.23.0
                                    npm 10.9.8
                                    js-controller 7.2.2
                                    T 2 Antworten Letzte Antwort
                                    • MyzerATM MyzerAT
                                      Titec
                                      @MyzerAT Datenpunkte die mir verraten, ob etwas ein/aus geschaltet ist, habe ich mir auch schon in den Kopf gesetzt. Könntest du mir da mal so einen Punkt in Raw schicken, damit ich weiß wie der aussehen muss?
                                      • MyzerATM Offline
                                        MyzerATM Offline
                                        MyzerAT
                                        Einfach ein neues Objekt hinzufügen als Datenpunkt, mehr ist es nicht !
                                        lg Rudi
                                        Node 22.23.0
                                        Nodejs 22.23.0
                                        npm 10.9.8
                                        js-controller 7.2.2
                                        • T Titec
                                            "common": {
                                              "type": "number",
                                              "role": "value",
                                              "read": true,
                                              "write": true,
                                              "name": "Bett An"
                                            "native": {},
                                            "type": "state",
                                            "acl": {
                                              "object": 1638,
                                              "state": 1638
                                          dslraserD Offline
                                          dslraserD Offline
                                          dslraser
                                            "common": {
                                              "type": "number",
                                              "role": "value",
                                              "read": true,
                                              "write": true,
                                              "name": "Bett An"
                                            "native": {},
                                            "type": "state",
                                            "acl": {
                                              "object": 1638,
                                              "state": 1638
                                          der ist nicht vom type boolean sondern Number. Das ist also eine Zahl, der hat aber keine Angabe welche Zahl ? Wie soll man den dann schalten ?
