  4. [Vorstellung] Meine zweite Visualisierung
    6.4k
vistemplate
1.3k Beiträge 148 Kommentatoren 671.0k Aufrufe 157 Beobachtet
  • K Kuddel
    @opossum und @File
    Ich hab mittlerweile die Abfrage der Versionen auf Blockly umgestellt:
    Export:
    <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="8G-t1R$2*5D,dzJ+=Z/)" x="-12" y="38">
     <field name="SCHEDULE">* * * * *</field>
     <statement name="STATEMENT">
       <block type="comment" id="Sl#pk4ynUi?qtGg$cE[g">
         <field name="COMMENT">ioBroker Version</field>
         <next>
           <block type="exec" id="!R8mB:{en(uJ^pcv:[x-">
             <mutation with_statement="true"></mutation>
             <field name="WITH_STATEMENT">TRUE</field>
             <field name="LOG"></field>
             <value name="COMMAND">
               <shadow type="text" id="v]l$N@4P}O26I3a-q-h?">
                 <field name="TEXT">iobroker version</field>
               </shadow>
             </value>
               <block type="control" id="][GYoQ$TpSK^1z+Y1)io">
                 <mutation delay_input="false"></mutation>
                 <field name="OID">javascript.0.Versionen.JS-Controller</field>
                 <value name="VALUE">
                   <block type="variables_get" id="^mDY7*B6ucov9?$`tyWW">
                     <field name="VAR" id="r$ug7+)#=~i}8RU2kgZ(" variabletype="">result</field>
                   </block>
                 </value>
               </block>
             </statement>
             <next>
               <block type="comment" id="H%;3a-me1U9t}!fx~0y~">
                 <field name="COMMENT">Node Version</field>
                 <next>
                   <block type="exec" id="*{Wr/}G!6rw|w(ts:Ubr">
                       <shadow type="text" id="1e4e9U(dN%k7nOplwh/t">
                         <field name="TEXT">node -v</field>
                       </shadow>
                     </value>
                       <block type="control" id="`vkk(uG/q|f.RsbQJ6-F">
                         <field name="OID">javascript.0.Versionen.Node</field>
                           <block type="variables_get" id=",@I94/CPiw]|fzeEmZIN">
                           </block>
                         </value>
                       </block>
                     </statement>
                     <next>
                       <block type="comment" id=":rYml-k#oiHgEwv`2(YH">
                         <field name="COMMENT">NPM Version</field>
                         <next>
                           <block type="exec" id="NsFDRm/4E?3a;yAjP2~M">
                               <shadow type="text" id="Pq@ZNpd%kQM$SihLxwc%">
                                 <field name="TEXT">npm -v</field>
                               </shadow>
                             </value>
                               <block type="control" id="Z;/822T:KaNxR6lSS-HN">
                                 <field name="OID">javascript.0.Versionen.NPM</field>
                                   <block type="variables_get" id="Ur~}G^ol^zYpeaK0SPS0">
                                   </block>
                                 </value>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
     </statement>
    </block>
    @File
    Wenn im Objekt "false" steht, heißt es nur, dass das Objekt noch nicht befüllt wurde. Ich habe immer "false" als Standard-Wert für die Erstellung des Objektes genommen.
    File
    #946
    @Kuddel
    Danke für die rasche Hilfe, musste nur noch exec-Kommandos aktivieren.
    LG
    Philipp
    • Uli977U Offline
      Uli977U Offline
      Uli977
      #947
      Hallo @Kuddel !
      Ich brauche mal deine Hilfe...
      /adapter/daswetter/icons/tiempo-weather/galeria1/22.png
      Das habe ich gar nicht, sondern nur bis 19
      Wie kann es sein dass nach Icon 22 gefragt wird?
      Was kann ich da machen?
      Danke dir für deine Hilfe.
      • Uli977U Uli977
        Hallo @Kuddel !
        GlasfaserG Offline
        GlasfaserG Offline
        #948
        @Uli977 sagte in [Vorstellung] Meine zweite Visualisierung:
        Du bist leider hier falsch , das ist von @sigi234
        Der Fehler ist bekannt , bitte hier weiter lesen !!!
        Projekt WetterView von sigi234
        Uli977U 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          Uli977U Offline
          Uli977U Offline
          Uli977
          #949
          @Glasfaser Da hast du recht :-)
          • Uli977U Uli977
            GlasfaserG Offline
            GlasfaserG Offline
            #950
            @Uli977
              djsirius
              #951
              @Kuddel kannst du mir sagen, wie du z.b. die Uptime von der CCU abrufst?
              Vielen Dank!
              djsirius
              • D djsirius
                Vielen Dank!
                K Online
                K Online
                Kuddel
                #952
                @djsirius ich frage die Uptime per SSH ab und rechne die Sekunden dann um.
                Voraussetzung ist, dass der public SSH Key auf der CCU liegt.
                Der Befehle lautet:
                ssh root@192.168.4.5 uptime | awk '{print $3_$4_$5}'
                192.168.4.5 = CCU2
                Hier das komplette Skript inkl. Umrechnung (Blockly Export):
                uptime_ccu.txt
                  djsirius
                  #953
                  Erstmal vielen Dank!
                  @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                  public SSH Key
                  wo bekomme ich den her?
                  djsirius
                  • D djsirius
                    public SSH Key
                    K Online
                    K Online
                    Kuddel
                    #954
                    @djsirius Anleitung
                    O 1 Antwort Letzte Antwort
                    • K Kuddel
                      @djsirius Anleitung
                      O Online
                      O Online
                      Oli
                      schrieb am zuletzt editiert von Oli
                      #955
                      @Kuddel
                      ich verwende folgendes Powershellscript von dir um Daten von meinem Windows 10 Rechner abzufragen:
                      #Dieses Skript übergibt die aktuelle Laufzeit in Sekunden an den ioBroker
                      #Das Skript läuft im Hintergrund und liegt im Autostart
                      cls
                      sleep 30
                      #Warteschleife wenn ioBroker nicht erreichbar ist
                      while(!(Test-Connection 192.168.2.120)){sleep 1}
                      #Dauerschleife
                      while($env:COMPUTERNAME -eq "Win10") {
                        #Uptime Windows 10
                        $wmio = Get-WmiObject win32_operatingsystem -ComputerName 'Oliver-Boehm'
                        $LocalTime = [management.managementDateTimeConverter]::ToDateTime($wmio.localdatetime)
                        $LastBootUptime = [management.managementDateTimeConverter]::ToDateTime($wmio.lastbootuptime)
                        $timespan = $localTime - $lastBootUptime
                        $sekunden = $timespan.TotalSeconds
                        Invoke-WebRequest -Uri http://192.168.2.120:8087/set/javascript.0.Ressourcen.pc.uptime_raw?value=$sekunden | Out-Null
                        #FreeSpace C in GB
                        $freespace_c = Get-WmiObject Win32_LogicalDisk -Filter "DeviceID='C:'" | Foreach-Object {$_.FreeSpace}
                        $freespace_c = $freespace_c / 1024 / 1024 / 1024
                        $freespace_c = [math]::Round($freespace_c,2)
                        Invoke-WebRequest -Uri http://192.168.2.120:8087/set/javascript.0.Ressourcen.pc.win10_c_freespace?value=$freespace_c | Out-Null
                        #FreeSpace D in GB
                        $freespace_d = Get-WmiObject Win32_LogicalDisk -Filter "DeviceID='D:'" | Foreach-Object {$_.FreeSpace}
                        $freespace_d = $freespace_d / 1024 / 1024 / 1024
                        $freespace_d = [math]::Round($freespace_d,2)
                        Invoke-WebRequest -Uri http://192.168.2.120:8087/set/javascript.0.Ressourcen.pc.win10_d_freespace?value=$freespace_d | Out-Null
                        #FreeSpace F in GB
                        $freespace_f = Get-WmiObject Win32_LogicalDisk -Filter "DeviceID='F:'" | Foreach-Object {$_.FreeSpace}
                        $freespace_f = $freespace_f / 1024 / 1024 / 1024
                        $freespace_f = [math]::Round($freespace_f,2)
                        Invoke-WebRequest -Uri http://192.168.2.120:8087/set/javascript.0.Ressourcen.pc.win10_f_freespace?value=$freespace_f | Out-Null
                        #CPU Auslastung
                        $cpu = Get-WmiObject win32_processor | select LoadPercentage
                        $cpu = $cpu.LoadPercentage
                        Invoke-WebRequest -Uri http://192.168.2.120:8087/set/javascript.0.Ressourcen.pc.win10_cpu_usage?value=$cpu | Out-Null
                        #RAM Auslastung
                        $ram =  Get-Ciminstance Win32_OperatingSystem
                        $ram = $ram.FreePhysicalMemory
                        $ram = $ram / 1024
                        $ram = 4096 - $ram
                        $ram = $ram / 4096
                        $ram = $ram * 100
                        $ram = [math]::Round($ram,0)
                        Invoke-WebRequest -Uri http://192.168.2.120:8087/set/javascript.0.Ressourcen.pc.win10_ram_usage?value=$ram | Out-Null
                      Wenn ich jetzt das Script in der Powershell ISE starte, läuft es ohne Fehlermeldung durch, es werden jedoch keine Daten im ioBroker eingetragen.
                      Wenn ich jedoch jede Zeile einzeln mit der F8 abspiele, werden die an ioBroker weitergereicht.
                      Weißt du vielleicht , woran das liegen könnte?
                      Edit: Hat sich erledigt, habe den Fehler gefunden!!
                      Oliver
                      • O Oli
                        @Kuddel
                        cls
                        sleep 30
                        #Dauerschleife
                          #Uptime Windows 10
                          #FreeSpace C in GB
                          #FreeSpace D in GB
                          #FreeSpace F in GB
                          #CPU Auslastung
                          #RAM Auslastung
                          $ram = $ram / 1024
                          $ram = 4096 - $ram
                          $ram = $ram / 4096
                          $ram = $ram * 100
                        DennisMenger
                        #956
                        @Oli welchen Fehler hast du denn gefunden? Das wäre vielleicht hilfreich für andere?
                          DennisMenger
                          #957
                          @Kuddel
                          Ich würde jetzt gerne die View der Lampen anpassen. Im groben habe ich das auch hinbekommen. Allerdings zeigt er mir nicht alle Widgets an. Die beiden Rahmen, die hinter den Widgets liegen, sind aktuell eigentlich ausgeblendet/inaktiv.
                          Kannst oder jemand anderes helfen?
                          • D DennisMenger
                            K Online
                            K Online
                            Kuddel
                            #958
                            @DennisMenger ich vermute er hat den fehler in Zeile 11 gefunden
                            Da muss der Name des Clients rein, auf dem das Skript läuft. Win10 heißt mein Client
                            • D DennisMenger
                              @Kuddel
                              K Online
                              K Online
                              Kuddel
                              #959
                              @DennisMenger check mal den z-index, vllt. liegen die Widgets hinter den Rahmen
                              GlasfaserG D 2 Antworten Letzte Antwort
                              • K Kuddel
                                GlasfaserG Offline
                                GlasfaserG Offline
                                #960
                                @DennisMenger
                                Klapp mal das Menue auf , dann kannst du die Widgets einzeln anwählen !
                                • K Kuddel
                                  DennisMenger
                                  #961
                                  @Kuddel z-index des widgets 20, der des Rahmens 10. Wie bei allen anderen Lampen auch. Außerdem sind eigentlich die beiden Rahmen über Inaktiv(locked) deaktiviert. Dafür ist doch die Funktion oder?
                                    @DennisMenger
                                    DennisMenger
                                    #962
                                    @Glasfaser das habe ich gefunden und weiß wie ich an die Widgets, die im Hintergrund liegen, rankomme.
                                    PS: ioBroker läuft aktuell auf einem Windows-System
                                    • K Kuddel
                                      O Online
                                      O Online
                                      Oli
                                      #963
                                      @Kuddel , @DennisMenger
                                      stimmt genau, ewig gesucht woran es liegt und als ich es gepostet hatte viel es mir auf.
                                      Powershell ist nicht mein Freund :-)
                                      Eine Frage hätte ich aber noch, ich habe ja eine Aufgabe auf dem Windowsrechner erstellt, dass dieses Script bei der Anmeldung am PC startet.
                                      Ist es jetzt sinnvoll in dieser Aufgabe auch die regelmäßige Wiederholung mit aufzunehmen, oder sollte ich eine neue Aufgabe erstellen?
                                      Oliver
                                      • O Oli
                                        K Online
                                        K Online
                                        Kuddel
                                        #964
                                        @Oli das Skript selber läuft doch in einer Endlosschleife.
                                        Daher muss es nicht nochmal gestartet werden
                                        • D DennisMenger
                                          DennisMenger
                                          #965
                                          @DennisMenger sagte in [Vorstellung] Meine zweite Visualisierung:
                                          @Kuddel noch eine Idee?
