  4. [Vorstellung] Meine zweite Visualisierung
    6.4k
vistemplate
1.3k Beiträge 148 Kommentatoren 670.9k Aufrufe 157 Beobachtet
  • K Online
    K Online
    Kuddel
    #935
    @opossum und @File
    Ich hab mittlerweile die Abfrage der Versionen auf Blockly umgestellt:
    Export:
    <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="8G-t1R$2*5D,dzJ+=Z/)" x="-12" y="38">
     <field name="SCHEDULE">* * * * *</field>
     <statement name="STATEMENT">
       <block type="comment" id="Sl#pk4ynUi?qtGg$cE[g">
         <field name="COMMENT">ioBroker Version</field>
         <next>
           <block type="exec" id="!R8mB:{en(uJ^pcv:[x-">
             <mutation with_statement="true"></mutation>
             <field name="WITH_STATEMENT">TRUE</field>
             <field name="LOG"></field>
             <value name="COMMAND">
               <shadow type="text" id="v]l$N@4P}O26I3a-q-h?">
                 <field name="TEXT">iobroker version</field>
               </shadow>
             </value>
               <block type="control" id="][GYoQ$TpSK^1z+Y1)io">
                 <mutation delay_input="false"></mutation>
                 <field name="OID">javascript.0.Versionen.JS-Controller</field>
                 <value name="VALUE">
                   <block type="variables_get" id="^mDY7*B6ucov9?$`tyWW">
                     <field name="VAR" id="r$ug7+)#=~i}8RU2kgZ(" variabletype="">result</field>
                   </block>
                 </value>
               </block>
             </statement>
             <next>
               <block type="comment" id="H%;3a-me1U9t}!fx~0y~">
                 <field name="COMMENT">Node Version</field>
                 <next>
                   <block type="exec" id="*{Wr/}G!6rw|w(ts:Ubr">
                       <shadow type="text" id="1e4e9U(dN%k7nOplwh/t">
                         <field name="TEXT">node -v</field>
                       </shadow>
                     </value>
                       <block type="control" id="`vkk(uG/q|f.RsbQJ6-F">
                         <field name="OID">javascript.0.Versionen.Node</field>
                           <block type="variables_get" id=",@I94/CPiw]|fzeEmZIN">
                           </block>
                         </value>
                       </block>
                     </statement>
                     <next>
                       <block type="comment" id=":rYml-k#oiHgEwv`2(YH">
                         <field name="COMMENT">NPM Version</field>
                         <next>
                           <block type="exec" id="NsFDRm/4E?3a;yAjP2~M">
                               <shadow type="text" id="Pq@ZNpd%kQM$SihLxwc%">
                                 <field name="TEXT">npm -v</field>
                               </shadow>
                             </value>
                               <block type="control" id="Z;/822T:KaNxR6lSS-HN">
                                 <field name="OID">javascript.0.Versionen.NPM</field>
                                   <block type="variables_get" id="Ur~}G^ol^zYpeaK0SPS0">
                                   </block>
                                 </value>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </next>
       </block>
     </statement>
    </block>
    @File
    Wenn im Objekt "false" steht, heißt es nur, dass das Objekt noch nicht befüllt wurde. Ich habe immer "false" als Standard-Wert für die Erstellung des Objektes genommen.
    opossumO NegaleinN F 3 Antworten Letzte Antwort
    • D DennisMenger
      @Kuddel kannst du mir bitte einmal sagen welche Funktion genau der markierte Button in deiner Vis für eine Funktion hat? Soll der einfach die Temperatur nur 4,5 Grad runtersetzen?
      DennisMenger
      #936
      @DennisMenger sagte in [Vorstellung] Meine zweite Visualisierung:
      @Kuddel Ich schätze meine Frage hast du übersehen oder noch keine Zeit gehabt
      • D DennisMenger
        K Online
        K Online
        Kuddel
        #937
        @DennisMenger oh sorry.
        Der Button ist quasi der On/Off Button.
        Bei Homematic ist Off = 4.5 Grad. On habe ich mit 18 Grad definiert.
        Darüber kann ich somit das Thermostat und den Heizkörper an- bzw ausschalten
        • K Kuddel
          DennisMenger
          #938
          @Kuddel Ah ok … danke dir. Mich hatte gewundert, dass in den Objekten der Wert 4.5 dann rot unterlegt war. Bei mir kann ich nicht weniger als 5 Grad einstellen, daher ist 4.5 Grad dann halt aus.
          • K Kuddel
            @opossum und @File
            Export:
                 <next>
                       </shadow>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                     <next>
                         <next>
                               </shadow>
                             </value>
                                   </block>
                                 </value>
                               </block>
                             </statement>
                             <next>
                                 <next>
                                       </shadow>
                                     </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
            </block>
            @File
            opossumO Offline
            opossumO Offline
            opossum
            #939
            Hallo, @Kuddel
            @Kuddel sagte in [Vorstellung] Meine zweite Visualisierung:
            @opossum und @File
            danke Dir, das hat es bei mir gebracht, jetzt werden die DP wieder sauber gefüllt.
            https://www.schlepper-petersdorf.de
            • K Kuddel
              @opossum und @File
              Export:
                   <next>
                         </shadow>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                       <next>
                           <next>
                                 </shadow>
                               </value>
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                               <next>
                                   <next>
                                         </shadow>
                                       </value>
                                             </block>
                                           </value>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </statement>
              </block>
              @File
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #940
              Hi Kuddel!
              Ich verwende auch dein Blockly.
              Aber es werden bei mir nicht alle DP befüllt.
              ° Fixer ---> iob fix
              • NegaleinN Negalein
                Hi Kuddel!
                K Online
                K Online
                Kuddel
                #941
                @Negalein das liegt daran, dass ich NodeJS im Blockly nicht abfrage
                • K Kuddel
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #942
                  Ok, hab ich ganz übersehen.
                  Aber der JS-Controller bleibt noch immer leer.
                  • opossumO Offline
                    opossumO Offline
                    opossum
                    schrieb am zuletzt editiert von opossum
                    #943
                    Hallo, @Negalein ,
                    hast Du das Blockly von oben genommen? Da habe ich etwas ergänzt.
                    EDIT: Kuddel war schneller 😀
                      <variables>
                        <variable id="r$ug7+)#=~i}8RU2kgZ(" type="">result</variable>
                      </variables>
                      <block id="8G-t1R$2*5D,dzJ+=Z/)" type="schedule" x="-12" y="38">
                        <field name="SCHEDULE">0 * * * *</field>
                          <block id="Sl#pk4ynUi?qtGg$cE[g" type="comment">
                            <next>
                              <block id="!R8mB:{en(uJ^pcv:[x-" type="exec">
                                  <shadow id="v]l$N@4P}O26I3a-q-h?" type="text">
                                  </shadow>
                                </value>
                                  <block id="][GYoQ$TpSK^1z+Y1)io" type="control">
                                      <block id="^mDY7*B6ucov9?$`tyWW" type="variables_get">
                                        <field id="r$ug7+)#=~i}8RU2kgZ(" name="VAR" variabletype="">result</field>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                  <block id="H%;3a-me1U9t}!fx~0y~" type="comment">
                                    <next>
                                      <block id="*{Wr/}G!6rw|w(ts:Ubr" type="exec">
                                          <shadow id="1e4e9U(dN%k7nOplwh/t" type="text">
                                          </shadow>
                                        </value>
                                          <block id="`vkk(uG/q|f.RsbQJ6-F" type="control">
                                              <block id=",@I94/CPiw]|fzeEmZIN" type="variables_get">
                                              </block>
                                            </value>
                                          </block>
                                        </statement>
                                        <next>
                                          <block id=":rYml-k#oiHgEwv`2(YH" type="comment">
                                            <next>
                                              <block id="NsFDRm/4E?3a;yAjP2~M" type="exec">
                                                  <shadow id="Pq@ZNpd%kQM$SihLxwc%" type="text">
                                                  </shadow>
                                                </value>
                                                  <block id="Z;/822T:KaNxR6lSS-HN" type="control">
                                                      <block id="Ur~}G^ol^zYpeaK0SPS0" type="variables_get">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                                <next>
                                                  <block id="_VHco8o-RQ%}k1^}(Jv9" type="comment">
                                                    <field name="COMMENT">NODEJS Version</field>
                                                    <next>
                                                      <block id="e(R]V[00Lw|/XxZ6jMF|" type="exec">
                                                          <shadow id="}IaR=aRj??^,}JP(X!Y." type="text">
                                                            <field name="TEXT">nodejs -v</field>
                                                          </shadow>
                                                        </value>
                                                          <block id="G;4.63b:Q0I1]np?7V!}" type="control">
                                                            <field name="OID">javascript.0.Versionen.NodeJS</field>
                                                              <block id="BrlBksXsDJLiI+4MI!Y-" type="variables_get">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </statement>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </xml>
                    NegaleinN H 2 Antworten Letzte Antwort
                    • opossumO opossum
                      Hallo, @Negalein ,
                        <variables>
                        </variables>
                              <next>
                                    </shadow>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                      <next>
                                            </shadow>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                              <next>
                                                    </shadow>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                      <next>
                                                            </shadow>
                                                          </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </xml>
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #944
                      @opossum sagte in [Vorstellung] Meine zweite Visualisierung:
                      Danke, hab NodeJS auch schon ergänzt gehabt! :)
                      Aber der JS-Controller wird mir nicht befüllt. :(
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #945
                        @Negalein sagte in [Vorstellung] Meine zweite Visualisierung:
                        Gehe mal in die Docker Konsole ....
                        iobroker stop
                        pkill io
                        curl -sL https://iobroker.net/fix.sh | bash -
                        iobroker start
                        • K Kuddel
                          @opossum und @File
                          Export:
                               <next>
                                     </shadow>
                                   </value>
                                         </block>
                                       </value>
                                     </block>
                                   </statement>
                                   <next>
                                       <next>
                                             </shadow>
                                           </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </statement>
                                           <next>
                                               <next>
                                                     </shadow>
                                                   </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                          </block>
                          @File
                          File
                          #946
                          @Kuddel
                          Danke für die rasche Hilfe, musste nur noch exec-Kommandos aktivieren.
                          LG
                          Philipp
                          • Uli977U Offline
                            Uli977U Offline
                            Uli977
                            #947
                            Hallo @Kuddel !
                            Ich brauche mal deine Hilfe...
                            /adapter/daswetter/icons/tiempo-weather/galeria1/22.png
                            Das habe ich gar nicht, sondern nur bis 19
                            Wie kann es sein dass nach Icon 22 gefragt wird?
                            Was kann ich da machen?
                            Danke dir für deine Hilfe.
                            • Uli977U Uli977
                              Hallo @Kuddel !
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #948
                              @Uli977 sagte in [Vorstellung] Meine zweite Visualisierung:
                              Du bist leider hier falsch , das ist von @sigi234
                              Der Fehler ist bekannt , bitte hier weiter lesen !!!
                              Projekt WetterView von sigi234
                              Uli977U 1 Antwort Letzte Antwort
                              • GlasfaserG Glasfaser
                                Uli977U Offline
                                Uli977U Offline
                                Uli977
                                #949
                                @Glasfaser Da hast du recht :-)
                                • Uli977U Uli977
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  #950
                                  @Uli977
                                    djsirius
                                    #951
                                    @Kuddel kannst du mir sagen, wie du z.b. die Uptime von der CCU abrufst?
                                    Vielen Dank!
                                    djsirius
                                    • D djsirius
                                      Vielen Dank!
                                      K Online
                                      K Online
                                      Kuddel
                                      #952
                                      @djsirius ich frage die Uptime per SSH ab und rechne die Sekunden dann um.
                                      Voraussetzung ist, dass der public SSH Key auf der CCU liegt.
                                      Der Befehle lautet:
                                      ssh root@192.168.4.5 uptime | awk '{print $3_$4_$5}'
                                      192.168.4.5 = CCU2
                                      Hier das komplette Skript inkl. Umrechnung (Blockly Export):
                                      uptime_ccu.txt
                                        djsirius
                                        #953
                                        Erstmal vielen Dank!
                                        @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                                        public SSH Key
                                        wo bekomme ich den her?
                                        djsirius
                                        • D djsirius
                                          public SSH Key
                                          K Online
                                          K Online
                                          Kuddel
                                          #954
                                          @djsirius Anleitung
                                          O 1 Antwort Letzte Antwort
