  4. Node-Red
  5. Node Red: Zeit Badfenster offen
    6.6k
20 Beiträge 3 Kommentatoren 5.2k Aufrufe 4 Beobachtet
  • R Offline
    rewenode
    schrieb am zuletzt editiert von rewenode
    Ist eine etwas verkorkste Object structure.
    Du kannst aber einfach change-nodes nehmen und das ganze mit einem kleinen JSONata Ausdruck machen.
    hier der Flow:
            "id": "d62d0d87.9561f8",
            "type": "inject",
            "z": "ce726243.5a5778",
            "name": "",
            "topic": "",
            "payload": "{\"values\":{\"heating_temperature\":0,\"warmwater_temperature\":51,\"heating_operation_mode\":0,\"warmwater_operation_mode\":0,\"heating_operation_mode_string\":\"Automatik\",\"warmwater_operation_mode_string\":\"Automatik\",\"heating_curve_end_point\":46,\"heating_curve_parallel_offset\":20,\"deltaHeatingReduction\":0,\"heatSourcedefrostAirThreshold\":7,\"hotWaterTemperatureHysteresis\":3,\"returnTemperatureHysteresis\":2,\"heatSourcedefrostAirEnd\":6,\"temperature_hot_water_target\":52,\"cooling_operation_mode\":0,\"cooling_release_temperature\":20,\"thresholdTemperatureSetBack\":-20,\"cooling_inlet_temp\":20,\"hotWaterCircPumpDeaerate\":\"off\",\"heatingLimit\":1,\"thresholdHeatingLimit\":14,\"cooling_start_after_hours\":120,\"cooling_stop_after_hours\":120,\"typeSerial\":\"2509/22-83\",\"returnTemperatureTargetMin\":15}}",
            "payloadType": "json",
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "x": 160,
            "y": 100,
            "wires": [
                    "94a117c0.f92528",
                    "5ae32f5d.bd16d8"
            "id": "918f1b7f.3aa788",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "x": 790,
            "y": 100,
            "wires": []
            "id": "94a117c0.f92528",
            "type": "change",
            "name": "heating_temperature",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "{\t   \"heating_temperature\": payload.values.heating_temperature\t}",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 440,
            "y": 100,
            "wires": [
                    "918f1b7f.3aa788"
            "id": "eb70ea5a.6e6738",
            "type": "comment",
            "name": "und so weiter",
            "info": "",
            "x": 410,
            "y": 180,
            "wires": []
            "id": "5ae32f5d.bd16d8",
            "type": "change",
            "name": "warmwater_temperature",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "{\t   \"warmwater_temperature\": payload.values.warmwater_temperature\t}",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 450,
            "y": 140,
            "wires": [
                    "d8070b65.88a4b"
            "id": "d8070b65.88a4b",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "x": 790,
            "y": 140,
            "wires": []
            "id": "124c73d6.4623ac",
            "type": "comment",
            "name": "payload.values - object",
            "info": "",
            "x": 160,
            "y": 60,
            "wires": []
    Ersetze dann einfach deine function-nodes durch die change-nodes.
    Homer.J.H 1 Antwort Letzte Antwort
    • R rewenode
      hier der Flow:
              "type": "inject",
              "name": "",
              "topic": "",
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "x": 160,
              "y": 100,
              "wires": [
                      "94a117c0.f92528",
                      "5ae32f5d.bd16d8"
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "x": 790,
              "y": 100,
              "wires": []
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 440,
              "y": 100,
              "wires": [
                      "918f1b7f.3aa788"
              "type": "comment",
              "info": "",
              "x": 410,
              "y": 180,
              "wires": []
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "jsonata"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 450,
              "y": 140,
              "wires": [
                      "d8070b65.88a4b"
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "x": 790,
              "y": 140,
              "wires": []
              "type": "comment",
              "info": "",
              "x": 160,
              "y": 60,
              "wires": []
      Homer.J.H Offline
      Homer.J.H Offline
      Homer.J.
      @rewenode Lässt sich leider nicht importieren.
      R 1 Antwort Letzte Antwort
      • Homer.J.H Homer.J.
        rewenode
        @Homer-J Sollte jetzt gehen. Der Export muss wohl in Code-Tags stehen.
        • R rewenode
          Homer.J.H Offline
          Homer.J.H Offline
          Homer.J.
          @rewenode Steht jetzt das im Debug.Screenshot_2019-11-27 Node-RED 192 168 178 33.png
            rewenode
            Wie genau hast du den change-node konfiguriert?
            • R rewenode
              Homer.J.H Offline
              Homer.J.H Offline
              Homer.J.
              schrieb am zuletzt editiert von Homer.J.
              @rewenode im Debug wir der Wert jetzt eingetragen aber nicht in die variable die ich im Java angelegt habe
              als was müssen diese angelegt sein als String. ?Screenshot_2019-11-27 Node-RED 192 168 178 33.png
                rewenode
                @Homer-J Dazu kann ich nichts sagen. Dazu müsste ich wissen, wie genau dein nachfolgender ioBroker-In node die Daten haben will. Name/Path/Type
                • R rewenode
                  Homer.J.H Offline
                  Homer.J.H Offline
                  Homer.J.
                  @rewenode hab mal einen anderen Knoten vom iobroker genommen jetzt geht es danke dir.
                  R 2 Antworten Letzte Antwort
                    rewenode
                    @Homer-J Alles klar 👍
                    Feierabend ;-)
                      rewenode
                      @Homer-J Der Vollständigkeit halber. So gehts auch mit deinen function-nodes:
                      return {"payload": {"heating_temperature": msg.payload.values.heating_temperature}};
                      • H Offline
                        HomeSweetHome
                        schrieb am zuletzt editiert von HomeSweetHome
                        danke für die Antwort. Zurück nochmal zum Badfenster.
                        Wo bekomme ich die Zeit her, bzw. die steckt doch nicht in msg.payload.lc oder?
                        Habe ich noch nicht ganz verstanden.
                        Beim Schließen wird die Funktion immer hier beendet "if (typeof flow.get("FensterAufStart") === "undefined") return false;" und Debug Node noch dahinter wird nicht "stimuliert"
                        Wo ist mein Denkfehler?
                        Gruß HomeSweetHome
                        • H HomeSweetHome
                          Gruß HomeSweetHome
                          rewenode
                          @HomeSweetHome sagte in Node Red: Zeit Badfenster offen:
                          genau. Ist die Unix-Zeit. Die Umrechnung in Sekunden geschieht dann hier:
                          // (gespeicherte UNIX Zeit in ms - aktuelle Zeit in ms) / 1000 = Differenz in Sekunden
                          ... Math.floor((msg.payload.lc - flow.get("FensterAufStart"))/1000)
                          Dass passiert, wenn die Flow-Variable "FensterAufStart" noch nicht angelegt ist, was wiederum dann der Fall ist, wenn beim ersten feuern des ioBroker-in-nodes das Fender schließt. Weil die Variable ja beim Öffnen angelegt wird.
                          Kann es sein, dass dein ioBroker-In-Node nicht auf Object steht?2019-12-01_16-43-22.png
