  4. ioBroker stürzt Ständig ab!
    3.2k
    3.1k
error log
8 Beiträge 2 Kommentatoren 803 Aufrufe 2 Beobachtet
  • Matten MattenM Offline
    Matten Matten
    ioBroker stürzt Ständig ab- Tinkerboard komplett aus.
    das ist jetzt schon das 4. mal das das system nach kurzer zeit wieder abstürzt. Was kann ich tun?
    Cannot parse /opt/iobroker/iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
    Cannot parse /opt/iobroker/iobroker-data/objects.json.bak: SyntaxError: Unexpected token  in JSON at position 13289268
    Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: SyntaxError: Unexpected token  in JSON at position 1150726
    Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json.bak: SyntaxError: Unexpected token  in JSON at position 1150653
    2019-11-15 19:19:27.385 - info: host.tinkerboard iobroker.js-controller version 1.5.14 js-controller starting
    2019-11-15 19:19:27.389 - info: host.tinkerboard Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2019-11-15 19:19:27.389 - info: host.tinkerboard hostname: tinkerboard, node: v10.16.3
    2019-11-15 19:19:27.391 - info: host.tinkerboard ip addresses: 192.168.27.38 fe80::613b:a0ba:b245:9d7b
    2019-11-15 19:19:27.497 - error: host.tinkerboard Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: SyntaxError: Unexpected token in JSON at position 1232765
    2019-11-15 19:19:27.600 - error: host.tinkerboard Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json.bak: SyntaxError: Unexpected token in JSON at position 1232780
    2019-11-15 19:19:27.617 - info: host.tinkerboard inMem-states listening on port 9000
    2019-11-15 19:19:28.772 - error: host.tinkerboard Cannot parse /opt/iobroker/iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
    2019-11-15 19:19:29.860 - error: host.tinkerboard Cannot parse /opt/iobroker/iobroker-data/objects.json.bak: SyntaxError: Unexpected end of JSON input
    2019-11-15 19:19:29.862 - info: host.tinkerboard inMem-objects listening on port 9001
    2019-11-15 19:19:29.877 - info: host.tinkerboard InMemoryDB connected
    2019-11-15 19:19:29.884 - error: uncaught exception: Cannot read property 'rows' of undefined
    2019-11-15 19:19:29.886 - error: TypeError: Cannot read property 'rows' of undefined
    at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:1239:28
    at _getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2817:13)
    at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2844:28)
    at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1869:20)
    at ObjectsInMemServer.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2840:13)
    at setMeta (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:1237:13)
    at checkHost (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:347:29)
    at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:705:17
    2019-11-15 19:19:29.889 - info: host.tinkerboard terminated
    2019-11-15 19:19:29.892 - info: iobroker _restart
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
    • dbwebD Offline
      dbwebD Offline
      dbweb
      konnte einen ähnlichen Fehler bei mir mit "npm update" beheben, vermute bei mir waren einige Dateien nach einem Stromausfall zerschossen.
      Matten MattenM 1 Antwort Letzte Antwort
      • dbwebD dbweb
        Matten Matten
        @dbweb
        hab ich alles neu installiert. das schlimme es kommt jedes mal aus dem heiteren Himmerl, das ich eine USV vor meinen systemen hab .
        bin gerade schon wieder am neu aufsetzen😰
        • dbwebD Offline
          dbwebD Offline
          dbweb
          Als das Board ist nach dem Absturz komplett aus? Klingt eher nach einem Hardwareproblem. Schon mal die Stromversorgung geprüft, anderen Trafo verwendet?
          • dbwebD Offline
            dbwebD Offline
            dbweb
            oder deine SD Karte hat nen Schaden, hatte ich bei raspis schon ein paar mal.
              Matten Matten
              das ist ein großes netzteil wo meine Raspberrymatic und noch ein pi3 drauf hängt. die anderen systeme laufen.
              • dbwebD dbweb
                Matten Matten
                schrieb am zuletzt editiert von Matten Matten
                @dbweb sagte in ioBroker stürzt Ständig ab!:
                aber zweimal innerhalb einer woche... mit 2 unterschiedlichen SDs... nee denke das eher auch nicht. ich will demnächst mit iobroker direkt auf die raspberrymatic mit nem p4 4gb ram umziehen. Ich hoffe das es dann einfach besser läuft als auf armbian und dem Tinkerboard.
                  Matten Matten
                  und schon wieder die selbe scheiße. vielleicht hat das Tinkerboard einen schuss
