  4. homee läßt sich nicht installieren
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
homee fehler-installation npm
6 Beiträge 2 Kommentatoren 381 Aufrufe 1 Beobachtet
    BLRD
    Systemdata
    Hardwaresystem: Pi3b+
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte 32 GB
    Betriebssystem: Linux Arm
    Node-Version: 10.17.0
    Nodejs-Version: 10.17.0
    NPM-Version: 6.12.1
    Installationsart: Direlt über IoBroker Adapter
    bei der Installation des homee-Adapters habe ich Probleme / Fehler.
    Siehe Log etc.:
    Wer kann hierzu helfen?
    **Platform: linux
    Architecture: arm
    CPUs: 4
    Speed: 1400 MHz
    Model: ARMv7 Processor rev 4 (v7l)
    RAM: 926 MB
    System uptime: 01:09:20
    Node.js: v10.17.0
    NPM: 6.12.1
    Disk size: 29.0 GiB
    Disk free: 22.2 GiB
    adapters count: 300
    Uptime: 01:11:48
    Active instances: 9
    $ ./iobroker add homee  --host raspiiobdr
    NPM version: 6.12.1
    npm install iobroker.homee@modified --loglevel error --production --save --prefix "/opt/iobroker" (System call)
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for iobroker.homee@modified.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-10-30T10_57_39_675Z-debug.log
    ERROR: host.raspiiobdr Cannot install iobroker.homee@modified: 1
    LOG:
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/node',
    1 verbose cli   '/usr/local/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.homee@modified',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--production',
    1 verbose cli   '--save',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker' ]
    2 info using npm@6.12.1
    3 info using node@v10.17.0
    4 verbose npm-session 6cb93a7e5919dbf5
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.homee 434ms (from cache)
    8 silly registry:manifest no matching version for iobroker.homee@modified in the cache. Forcing revalidation.
    9 http fetch GET 200 https://registry.npmjs.org/iobroker.homee 97ms
    10 silly fetchPackageMetaData error for iobroker.homee@modified No matching version found for iobroker.homee@modified.
    11 timing stage:rollbackFailedOptional Completed in 3ms
    12 timing stage:runTopLevelLifecycles Completed in 7481ms
    13 verbose type tag
    14 verbose stack iobroker.homee: No matching version found for iobroker.homee@modified.
    14 verbose stack     at pickManifest (/usr/local/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    14 verbose stack     at fetchPackument.then.packument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18)
    14 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    14 verbose stack     at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    14 verbose stack     at Promise._settlePromise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    14 verbose stack     at Promise._settlePromise0 (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    14 verbose stack     at Promise._settlePromises (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    14 verbose stack     at _drainQueueStep (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    14 verbose stack     at _drainQueue (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    14 verbose stack     at Async._drainQueues (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    14 verbose stack     at runCallback (timers.js:705:18)
    14 verbose stack     at tryOnImmediate (timers.js:676:5)
    14 verbose stack     at processImmediate (timers.js:658:5)
    15 verbose cwd /
    16 verbose Linux 4.19.75-v7+
    17 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install" "iobroker.homee@modified" "--loglevel" "error" "--production" "--save" "--prefix" "/opt/iobroker"
    18 verbose node v10.17.0
    19 verbose npm  v6.12.1
    20 error code ETARGET
    21 error notarget No matching version found for iobroker.homee@modified.
    22 error notarget In most cases you or one of your dependencies are requesting
    22 error notarget a package version that doesn't exist.
    23 verbose exit [ 1, true ]**
    Danke.
    BLRD
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    • B BLRD
      Systemdata
      NPM-Version: 6.12.1
      Siehe Log etc.:
      **Platform: linux
      Architecture: arm
      CPUs: 4
      Speed: 1400 MHz
      RAM: 926 MB
      Node.js: v10.17.0
      NPM: 6.12.1
      Disk size: 29.0 GiB
      Disk free: 22.2 GiB
      adapters count: 300
      Uptime: 01:11:48
      Active instances: 9
      NPM version: 6.12.1
      LOG:
      13 verbose type tag
      15 verbose cwd /
      Danke.
      BLRD
      GlasfaserG Offline
      GlasfaserG Offline
      @BLRD
      Warum installiert du ihn nicht über die Konsole ?
        BLRD
        Hallo Glasfaser vor 21 Stunden,
        manchmal ist man absolut dämlich.
        Vielen Dank für Dein Hinweis, über die Konsole hat es funktioniert.
        Danke.
        BLRD
        • B BLRD
          Danke.
          BLRD
          GlasfaserG Offline
          GlasfaserG Offline
          @BLRD
          Dann bitte das Thema auf [gelöst] setzen .
            BLRD
            schrieb am zuletzt editiert von BLRD
            Äh wo finde ich gelöst?
            • B BLRD
              BLRD
              @BLRD Erledigt habs gefunden! Sorry
