  4. [gelöst] Cannot install iobroker.javascript@4.3.1
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
update
7 Beiträge 2 Kommentatoren 1.4k Aufrufe 2 Beobachtet
    skokarl
    schrieb am zuletzt editiert von skokarl
    das Update auf 4.3.0 lief problemlos .... jetzt das hier :
    host.iobroker Cannot install iobroker.javascript@4.3.1: 243
    host.iobroker 2019-10-18 15:35:10.978 info iobroker exit 25
    host.iobroker 2019-10-18 15:35:09.964 error iobroker host.iobroker Cannot install iobroker.javascript@4.3.1: 243
    host.iobroker 2019-10-18 15:35:09.941 info iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-10-18T13_35_09_852Z-debug.log
    host.iobroker 2019-10-18 15:35:09.940 info iobroker
    host.iobroker 2019-10-18 15:35:09.841 info iobroker ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believ
    host.iobroker 2019-10-18 15:35:09.840 info iobroker npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroke
    host.iobroker 2019-10-18 15:35:09.839 info iobroker path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/nodenpm ERR! code EACCESnpm ERR! errno -13npm ERR! syscall access
    host.iobroker 2019-10-18 15:35:09.837 info iobroker npm ERR!
    host.iobroker 2019-10-18 15:34:40.989 info iobroker npm install iobroker.javascript@4.3.1 --loglevel error --production --save --prefix "/opt/iobroker" (System call)
    host.iobroker 2019-10-18 15:34:40.987 info iobroker NPM version: 6.9.0
    host.iobroker 2019-10-18 15:34:40.528 info iobroker Update javascript from @4.3.0 to @4.3.1
    host.iobroker 2019-10-18 15:34:39.296 info iobroker upgrade javascript
    • BBTownB Offline
      BBTownB Offline
      BBTown
      schrieb am zuletzt editiert von BBTown
      Du solltest mal den fixer (erneut?) rüber laufen lassen ... das klingt nach einem Berechtigungsproblem
      PS:
      Bitte stelle Logs in "Code Tags"
        skokarl
        Fixer wäre aber sehr komisch, da 4.3.0 einwandfrei durchlief.
        BBTownB 1 Antwort Letzte Antwort
        • S skokarl
          BBTownB Offline
          BBTownB Offline
          BBTown
          @skokarl sagte in Cannot install iobroker.javascript@4.3.1: 243:
          Ich kann dir nicht sagen wann der Fixer Sinn macht oder gar notwendig ist, aber in deinem Log lese ich "permission denied", das ist für mich recht eindeutig
          • BBTownB BBTown
            skokarl
            @BBTown
            ja, ich hab das auch gesehen, aber Sinn macht es für mich nicht nicht.
            Ich probier es mal mit dem Fixer
              skokarl
              so, jetzt gings .....ganz ganz komisch,
              naja, waren auch ne Menge System Updates in letzter Zeit, irgendwer hat da was durcheinander
              gewirbelt.
              • S skokarl
                gewirbelt.
                BBTownB Offline
                BBTownB Offline
                BBTown
                @skokarl setzt Du noch ein [gelöst] in die Überschrift deines ersten Beitrages?!
