  3. Entwicklung
  4. [Neuer Adapter] hue-extended
adapter
441 Beiträge 32 Kommentatoren 142.2k Aufrufe 31 Beobachtet
    @Zefau Das Hochkomma ist mir hier beim Einfügen passiert - war natürlich beim command mit dabei.
    Die warn-Meldung bei 'level' ist jetzt weg, doch beim Setzen von '_rgb' mittels
     {"transitiontime":4,"_rgb":"250,10,250","level":100}
    erhalte ich folgende Fehlermeldungen:
    2019-08-31 10:17:13.922 - error: hue-extended.0 uncaught exception: rgb is not defined
    2019-08-31 10:17:13.924 - error: hue-extended.0 ReferenceError: rgb is not defined
    at Adapter. (/opt/iobroker/node_modules/iobroker.hue-extended/hue-extended.js:227:77)
    at Adapter.emit (events.js:198:13)
    at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3710:38)
    at runCallback (timers.js:705:18)
    at tryOnImmediate (timers.js:676:5)
    at processImmediate (timers.js:658:5)
    2019-08-31 10:17:13.925 - info: hue-extended.0 Adapter stopped und unloaded.
    2019-08-31 10:17:13.972 - error: Caught by controller[0]: ReferenceError: rgb is not defined
    2019-08-31 10:17:13.972 - error: Caught by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.hue-extended/hue-extended.js:227:77)
    2019-08-31 10:17:13.972 - error: Caught by controller[0]: at Adapter.emit (events.js:198:13)
    2019-08-31 10:17:13.972 - error: Caught by controller[0]: at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3710:38)
    2019-08-31 10:17:13.972 - error: Caught by controller[0]: at runCallback (timers.js:705:18)
    2019-08-31 10:17:13.972 - error: Caught by controller[0]: at tryOnImmediate (timers.js:676:5)
    2019-08-31 10:17:13.972 - error: Caught by controller[0]: at processImmediate (timers.js:658:5)
    2019-08-31 10:17:13.973 - error: host.iobroker instance system.adapter.hue-extended.0 terminated with code 0 (OK)
    Wenn man den Unterstrich weglässt, kommt natürlich:
    2019-08-31 10:21:42.383 - warn: hue-extended.0 Error setting /groups/3/action/rgb: parameter, rgb, not available
    2019-08-31 10:21:42.385 - warn: hue-extended.0 Error setting /groups/3/action: body contains invalid json
    ZefauZ Offline
    ZefauZ Offline
    Zefau
    #178
    @Dr-Bakterius Da war noch ein Fehler in der Umrechnung für nicht Philips Leuchtmittel. Probier bitte nochmal, sollte nun funktionieren.
    Dr. BakteriusD 1 Antwort Letzte Antwort
    • ZefauZ Zefau
      Dr. BakteriusD Offline
      Dr. Bakterius
      #179
      @Zefau Sorry, nein.
      2019-09-01 15:56:51.949 - error: hue-extended.0 uncaught exception: Cannot read property '0' of null
      2019-09-01 15:56:51.950 - error: hue-extended.0 TypeError: Cannot read property '0' of null
      at Object.convertRGBtoXY (/opt/iobroker/node_modules/iobroker.hue-extended/lib/hueColor.js:231:38)
      at Adapter. (/opt/iobroker/node_modules/iobroker.hue-extended/hue-extended.js:227:62)
      2019-09-01 15:56:51.951 - info: hue-extended.0 Adapter stopped und unloaded.
      2019-09-01 15:56:51.984 - error: Caught by controller[0]: TypeError: Cannot read property '0' of null
      2019-09-01 15:56:51.985 - error: Caught by controller[0]: at Object.convertRGBtoXY (/opt/iobroker/node_modules/iobroker.hue-extended/lib/hueColor.js:231:38)
      2019-09-01 15:56:51.985 - error: Caught by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.hue-extended/hue-extended.js:227:62)
      2019-09-01 15:56:51.985 - error: Caught by controller[0]: at Adapter.emit (events.js:198:13)
      2019-09-01 15:56:51.985 - error: Caught by controller[0]: at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3710:38)
      2019-09-01 15:56:51.985 - error: Caught by controller[0]: at runCallback (timers.js:705:18)
      2019-09-01 15:56:51.985 - error: Caught by controller[0]: at tryOnImmediate (timers.js:676:5)
      2019-09-01 15:56:51.985 - error: Caught by controller[0]: at processImmediate (timers.js:658:5)
      2019-09-01 15:56:51.985 - error: host.iobroker instance system.adapter.hue-extended.0 terminated with code 0 (OK)
        @Zefau Sorry, nein.
        ZefauZ Offline
        ZefauZ Offline
        Zefau
        #180
        @Dr-Bakterius Sehr merkwürdig, bei mir funktioniert's. Was hast du beim RGB Wert eingetragen? Hab nochmal auf Github aktualisiert, probier gerne nochmal.
        • ZefauZ Zefau
          Dr. Bakterius
          #181
          @Zefau Wie oben beschrieben:
          Mit der neuen Version geht es jetzt ohne Fehler. Allerdings wird der RGB nicht auf 250/10/250, sondern auf 255/8/255 gesetzt. Aber das wird wohl der Konvertierung geschuldet sein. Allerdings dauert es ein bis drei Sekunden bis Befehle umgesetzt werden (Pull-Zeit?). Die Rückmeldung geänderter Werte ist auch unterschiedlich. Zum Beispiel wird bei mir 'xy' innerhalb der vorgegebenen Pull-Zeit aktualisiert, doch bis sich der RGB ändert, dauert es erheblich länger. Nur eine Feststellung - danke für deine Arbeit!
            ZefauZ Offline
            ZefauZ Offline
            Zefau
            #182
            @Dr-Bakterius
            1. Ja, die ungenauen Werte begründen sich in der Umrechnung. Kannst du nochmal die aktuelle Version von Github probieren? Ggf. ist die Umrechnung damit etwas präziser.
            2. Die Umsetzung der Befehle dauert in den Standardeinstellungen 3 Sekunden. Diesen Wert kannst du in den Adapter-Einstellungen anpassen (ggf. nochmal iobroker upload hue-extendedausführen, damit du die aktuellen Adapter-Einstellungen siehst)
            3. Die Aktualisierung von RGB sollte ebenfalls sofort erfolgen. Ich werde das mal bei mir beobachten.
            • G Offline
              gst666
              #183
              Bei mir gibt es leider auch ein Problem. Wenn ich eine Szene aktivieren will (also den Trigger unter Action auslöse) erhalte ich immer Fehlermeldungen:
              Error setting /lights/LightScene-4_1FbpfnZI6O1ksvo/state: resource, /lights/LightScene-4_1FbpfnZI6O1ksvo/state, not available
              Habt ihr das Problem auch.
              Trotzdem schon mal ein dickes Lob an den Entwickler. Wenn der Adapter fertig ist, brauche ich nicht mehr mein eigenes gefrickle für die Szenen verwenden.
              ZefauZ 2 Antworten Letzte Antwort
                Schrubbel
                #184
                Moin Moin,
                nun habe ich mich auch mal an diesen Adapter gewagt nachdem mich der Hue-Adapter in den Wahnsinn treibt.
                So viel schonmal vorweg: In Verbindung mit Node-Red und KNX läuft er auf Anhieb wie er soll! =)
                Allerdings vermisse ich den Datenpunkt "level" (Also den Prozentwert der Helligkeit von 0-100%).
                Oder habe ich da was übersehen?
                Wäre sehr schön wenn man den auch noch implementieren könnte.
                Vielen Dank!!!
                • S Schrubbel
                  Moin Moin,
                  Vielen Dank!!!
                  ZefauZ Offline
                  ZefauZ Offline
                  Zefau
                  #185
                  @Schrubbel sagte in [Neuer Adapter] hue-extended:
                  Den Datenpunkt gibt es sowohl bei groups als auch bei lights.
                  • XsevX Offline
                    XsevX Offline
                    Xsev
                    #186
                    Ich bin heute auf den neuen Adapter umgestiegen von dem Hue Bridge Adapter. Ich nutze die Bridge ja nur für meine 3 Philips Outdoor Motion Sensoren.
                    Als erstes muss ich gleich positiv anmerken, der erste Adapter, der out of the box problemlos mit meinen 3 Bewegungsmeldern inkl Lichtsensoren und Temperaturen umgehen kann und diese auch perfekt in einzelne Verzeichnisse in den Objekten einpflegt!
                    Auf den ersten Blick scheint alles super zu laufen. Vielen Dank für die Arbeit!!
                    • ZefauZ Zefau
                      Schrubbel
                      #187
                      @Zefau
                      Merkwürdig, ich habe überall nur den Punkt "bri" mit Werten zwischen 0 und 254.
                      Ich bin grade mal meine Leuchten durchgegangen und tatsächlich ist "level" nur bei der Original Hue RGBW E27 zu finden.
                      Sonst habe ich noch Hue White, Hue Ambience, diverse Tradfri Leuchten und zwei Innr E14.
                      Woran kann das liegen?
                      • S Schrubbel
                        @Zefau
                        ZefauZ Offline
                        ZefauZ Offline
                        Zefau
                        #188
                        @Schrubbel liegt dann am Adapter. Ich schaue und ändere es heute Abend.
                        • G gst666
                          ZefauZ Offline
                          ZefauZ Offline
                          Zefau
                          #189
                          @gst666 Wie führst du die LightScene mit deinem Skript aus?
                          • G gst666
                            ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            #190
                            @gst666 sagte in [Neuer Adapter] hue-extended:
                            Ich weiß leider nicht, wie ich das Ausführen von LightScene implementieren kann. Es funktioniert wohl nur GroupScene?
                            • sigi234S Online
                              sigi234S Online
                              #191
                              Update V 0.8.0 geht nicht, Adapter bleibt auf 0.7.0
                              Vielleicht nur ein Anzeige Problem, aber der Adapterstatus bleibt auf aktualisierbar.
                              Log: process exited with code 0
                              SpegeliS 1 Antwort Letzte Antwort
                              • sigi234S sigi234
                                SpegeliS Offline
                                SpegeliS Offline
                                Spegeli
                                #192
                                @sigi234 sagte in [Neuer Adapter] hue-extended:
                                Jo den Fehler kann ich bestätigen ^^
                                • SpegeliS Spegeli
                                  ZefauZ Offline
                                  ZefauZ Offline
                                  Zefau
                                  #193
                                  @Spegeli @sigi234 sollte mit v0.8.1 behoben sein.
                                  • S Schrubbel
                                    @Zefau
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    #194
                                    sollte mit v0.8.0 bzw. v0.8.1 nun behoben sein. Alle Leuchten sollten nun .level haben.
                                    • cashC Offline
                                      cashC Offline
                                      cash
                                      #195
                                      Habe nun auch den Adapter mal installiert da der andere Hue Adapter seit gestern mit vielen Fehlermeldungen zickt. Hier scheint erstmal alles ok. Dafür schonmal vielen Dank. Sollte es die nächsten Tagen ruhig im Log bleiben ist dir meine Spende sicher.
                                      Zwei Sachen hätte ich noch. Zum einen haben die Gruppen bzw Lichter eine Zahl vorangestellt was ja nicht verkehrt ist aber sofern man mehr als 9 hat ist die Sortierung halt nur suboptimal da die 12 vor der 2 logischerweise ist. Wäre es nicht möglich mit 01 zu beginnen? Oder besser noch die Zahl ans Ende stellen meine Lichter haben eigentlich am Anfang immer den Raumnamen und da ich nicht alle Lampen für einen Raum zu gleichen Zeit gekauft habe habe ich jetzt unter 1 etwas dann viel tiefer unter 9 und dann wieder irgendwas mit 15...
                                      Das zweite sind die Szenen die heißen irgendwie z. B. 'abenddämmerung.GroupScene-10_mFrqg40AYUIo8QE'
                                      Ok ohne die 10 wüßte ich nicht zu welcher Gruppe die Szene gehört, da ich für fast jeden Raum die selben Szenen habe. Aber wäre es nicht stattdessen möglich die Szene 'Abenddämmerung.04Garten' zu nennen. Man könnte ja das 'mFrqg40AYUIo8QE' in ein sep. Feld packen. Das wird man eigentlich ja auch nur sehr selten brauchen.
                                      Nutze derzeit die 0.62 da ich die 0.7 leider nicht auswählen kann.
                                      Auf jeden Fall nochmal vielen Dank für diesen Adapter und auch für den Nuki Adapter den ich bald vermutlich auch nutzen werde wenn denn mal mein neuer Türzylinder kommen würde :-)
                                      ZefauZ 3 Antworten Letzte Antwort
                                      • ZefauZ Zefau
                                        sigi234S Online
                                        sigi234S Online
                                        #196
                                        @Zefau sagte in [Neuer Adapter] hue-extended:
                                        Ja, Danke.
                                        • ZefauZ Zefau
                                          Schrubbel
                                          #197
                                          @Zefau said in [Neuer Adapter] hue-extended:
                                          Jawoll sieht gut aus. Vielen Dank! =)
