  4. Ereignisliste erzeugen
89 Beiträge 21 Kommentatoren 28.4k Aufrufe 2 Beobachtet
  • sissiwupS
    sissiwupS
    sissiwup
    um eine Ereignisliste:
    zu erzeugen, kann man folgendes Skript verwenden:
    `createState("vEreignisse","
    *   first
    var sensorsST = $('channel[state.id=*.STATE](functions=ST)').each(function(id) {
        var val = getObject(id).common.name;
        log("DeviceST=" + val);
    var sensorsVS = $('channel[state.id=*.STATE](functions=VS)').each(function(id) {
        log("DeviceVS=" + val);
    var sensorsBW = $('channel[state.id=*.MOTION](functions=BW)').each(function(id) {
        log("DeviceBW=" + val);
    var vAlarmanlage = $('state[id="hm-rega.0.3747"]').each(function(id) {
        log("Alarmanlage=" + val);
    function ereignis(text) {
        log("ereignis "+text);
        var ereignisStr = getState("vEreignisse").val;
        var ereignisArr;
        ereignisArr = ereignisStr.replace(/`
    `*   /, "").replace(/<\/li><\/ul>/, "").split("*   ");
            ereignisArr = ereignisArr.reverse();
            ereignisArr.push(text);
            ereignisArr.reverse().splice(99); // Liste auf 20 Einträge beschränken
            var str = ereignisArr.join("`
            setState("vEreignisse", "
        *   "+str+"
        function timestamp(ts) {
            var now=new Date(ts);
            var day = now.getDate();
            var month = now.getMonth() + 1;
            var year = now.getFullYear();
            var weekday = now.getDay();
            var hours = now.getHours();
            var minutes = now.getMinutes();
            var seconds = now.getSeconds();
            var day0  = ((day < 10) ? "0" : "");
            var month0  = ((month < 10) ? "0" : "");
            var hours0  = ((hours < 10) ? "0" : "");
            var minutes0  = ((minutes < 10) ? "0" : "");
            var seconds0  = ((seconds < 10) ? "0" : "");
            var output = year + "-" + month0 + month + "-" + day0 + day + " " + hours0 + hours + ":" + minutes0 + minutes + ":" + seconds0 + seconds;
            return output;
        function room(obj) {
            var devname=obj.deviceName;
            var dp = getObject(obj.id,"rooms");
            var raum=dp.enumNames;
        //    var raum="---";
            var rooms ={"ST-05" : "OG Balkontür", "ST-02" : "OG Wohnzimmer BW", "ST-03" : "EG Treppenhaustür"
              , "ST-01" : "EG Wintergarten" , "ST-04" : "EG Eingangstür"
              , "BW-01" : "UG Garage" , "BW-02" : "EG Wintergarten" , "BW-03" : "OG Wohnzimmer"
              , "VS-01" : "EG Eingangstür" , "VS-02" : "UG Eingangstür" , "VS-03" : "UG Waschküche"
              , "VS-04" : "UG Garagentor" , "VS-05" : "EG Balkontür Atrium" , "VS-06" : "EG Relaxraum"
              , "VS-07" : "OG Balkontür" , "VS-08" : "OG Dachfenster" , "VS-09" : "EG Katzen R"
              , "VS-10" : "EG Katzen L" , "VS-11" : "EG Wintergarten" , "VS-12" : "EG Wohnzimmerfenster"
              , "VS-13" : "EG Küche L" , "VS-14" : "EG Küche R" , "VS-15" : "EG Abstellkammer"
              , "VS-16" : "EG Trepphaus" , "VS-17" : "OG Gästezimmer" , "VS-18" : "OG Ankleidezimmer"
            if (devname in rooms) {
                return rooms[devname];
            return raum;
        sensorsST.on(function(obj) {
          var aktion="AUTO";
          if (obj.newState.val == 1) {
            aktion="OFF";
          var ts=timestamp(obj.newState.ts);
            ereignis(ts + " " + obj.deviceName + " " + room(obj) + " " + aktion);
        //    log("OBJ=" + JSON.stringify(obj,null,2));
        sensorsVS.on(function(obj) {
          var aktion="ZU";
            aktion="AUF";
        sensorsBW.on(function(obj) {
            ereignis(ts + " " + obj.deviceName + " " + room(obj) + " " + "Bewegung");
        vAlarmanlage.on(function(obj) {
          var aktion="Haus alles gesichert";
            aktion="im Haus/Lüften";
          if (obj.newState.val == 2) {
            aktion="OFF";
            ereignis(ts + " Alarmstatus: " + aktion);
        mit den Funktionen sensorsXX Frage ich alle Sensoren, die zu einer Gruppe gehören ab,
        bei VS = Verschluß, BW = Bewegung und ST = Statusänderung/Schalter
        mit vAlarmanlage Frage ich einen einzelnen Datenpunkt ab, hier eine Variable.
        Im unteren Bereich des Skriptes muss zu jeder Funktion eine *.on Funktion dazu erstellt werden.
        Diese kann je nach Geräteart die Ausgabe umformulieren.
        UPDATE: Angepasst an neue Timestamps!
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
    • F
      F
      Fitti
      Hallo Sissiwup,
      vielen Dank für die Wissensteilung. Kann man immer benötigen.
      Wofür hast Du es entwickelt, was machst Du damit dann?
      Viele Grüße,
      Fitti
      "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
      Plural von Status ist auch Status!
      • P
        P
        pix
        kannst du evtl. audioconcept http://forum.iobroker.org/viewtopic.php?f=21&t=1289#p10621 weiterhelfen? Ich bin jetzt ein paar Tage weg und er benötigt Unterstützung bei der Ereignisliste.
        Pix
        • ruhr70R
          ruhr70R
          ruhr70
          @Fitti:
          Wofür hast Du es entwickelt, was machst Du damit dann? `
          Um "wichtige" Ereignisse des Tages in einer Liste darzustellen, die dann in Vis mit eingebunden ist.
          Ich lasse mir z.B. u.a. folgende Punkte anzeigen:
          • Anwesenheiten
          • Haustür geöffnet
          • Internetausfall / neue IP-Adresse
          • Anrufe in Abewesenheit
          • Änderungen von Logikschaltern (Logik ein/aus)
          • Änderung von diversen Variablen
          Die letzten 30 Ereignisse werden in einer Liste in VIS dargestellt.
          • H
            H
            HKF8770
            Ich hat das Skript kopiert, doch komme ich nicht ganz klar was ich hier dann neu anlegen muss. Ich verstehe es so dass ich für jedes Aktor den ich abfragen möchte eine eigenen .on Bereich erstellen muss. Verstehe ich das richtig? Isr es der untere Bereich den ich für jeden Aktor anlegen muss? Wenn ja muss ich dann sensorBW gegen den namen des Aktors tauschen?
            var ts=timestamp(obj.newState.ts*1000);
            Freddy
            • sissiwupS
              sissiwupS
              sissiwup
              es gehört immer ein oberer Bereich, wo du die Geräte/Sensoren auswählst, die du überwachen willst.
              Mit dem "on" definierst du, was passieren soll, wenn die Änderung eintritt, die du überwachst.
              MfG
              Sissi
              • H
                H
                HKF8770
                Läuft soweit doch habe ich folgende Frage:
                Habe eine Abfrage der Temperaturen definiert, welche auch geht
                var sensorsTemp = $('channel[state.id=*.TEMPERATURE]').each(function(id) {
                    log("===> Ereignisliste Temperatur=" + val);
                der untere Teil ist wie folgt:
                sensorsTemp.on(function(obj) {
                  if (obj.newState.val > -100) {
                    ereignis(ts + " " + obj.deviceName + " " + room(obj) + " " + "Grad");
                Ich möchte abr die Gradzahl mit einbinden, wie frag ich die ab?
                var val = getObject(id).common.name gibt ja den Manen das Sensors.
                wie heist dass wenn ich den Wert möchte??
                getObject(id).????????
                Bin für jeden Tipp dankbar
                Freddy
                • paul53P
                  paul53P
                  @HKF8770:
                  wie heist dass wenn ich den Wert möchte?? `
                  innerhalb der callback-Funktion von on(function(obj) {…})
                  var wert = obj.newState.val;
                  sonst
                  var wert = getState(id).val;
                  Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                  • H
                    H
                    HKF8770
                    Supper…danke.
                    getObject(id).common.name gibt mir ja den Namen des Gerätes wieder. Wie bekomme ich den namen des Kanals?
                    Freddy
                    • H
                      H
                      HKF8770
                      Habe ein Problem mit den functions.
                      Ich habe die Kanäle entsprechend manuell über "Aufzählung" hinzugefügt und zuvor die Kategorie Licht angelegt
                      Wenn ich (functions=Licht) weg lasse geht alles.
                          var sensorsLicht = $('channel[state.id=*.STATE]').each(function(id) {  //(functions=Licht)
                          log("===> Ereignisliste Licht=" + val);
                      möchte ich nach STATE und Functions selektieren gehts nicht mehr.
                         var sensorsLicht = $('channel[state.id=*.STATE](functions=Licht)').each(function(id) {  //(functions=Licht)
                      Ich hab schon LIcht oder licht probiert aber es kommt kein Ergebnis.
                      QWie gesagt lass ich es weg bekomme ich einen Eintrag so dass das Skript ja funktioniert.
                      Was mach ich falsch / übersehe ich?
                      Freddy
                      • paul53P
                        paul53P
                        @HKF8770:
                        Wenn ich (functions=Licht) weg lasse geht alles. `
                        Hast Du es mal mit (functions=licht) versucht ?
                        • H
                          H
                          HKF8770
                          geht leider weder noch….Mach ich irgendwo nen Fehler?
                          Ich lege die funtions auf dem Reiter "Aufzählunbgen" manuell an. unter enum.funtions mit dem + lege ich die Unterkategorie an die ja im Skript auch abgefragt wird. Dann in der Unterkategorie ganz rechts über das Buch ergänze ich die entsprechenden Datenpunkte. z.B.xxxxxx.state oder xxxxxx.motion, immer das was ich abfragen möchte.
                          Das ist so doch richtig, oder?
                          Freddy
                          • H
                            H
                            HKF8770
                            Hab Lösung gefunden.
                            • alle functions manuell gelöscht (Papierkorb rechts)
                            • Adapter hm-rega neu synchronisiert
                            Dachte wenn ich Änderungen an edn Gewerken der CCU2 mache wird dies mit iobrokler synchronisiert, wenn ich hm-rega neu starte….dem ist aber wohl nicht so. Erst nachdem ich alle functions gelöscht hatte und neu synchronisiert hatte, war dies identisch zu der CCU2.
                            Freddy
                            • S
                              S
                              stephan61
                              Hallo
                              seit gestern ( update io Broker )stimmt die zeit in der Ereignisliste nicht mit der richtigen Zeit überein
                              ![](<ATTACHMENT 516_ereignisliste.jpg )~~[attachment=0]~~ereignisliste.JPG[/attachment]" />
                              mus am dem Script etwas geändert werden ?
                              Gruß Stephan
                              • P
                                P
                                pix
                                da ioBroker jetzt mit Millisekunden umgehen kann, brauchst du im Skript nicht mehr umzurechnen. Das heißt, überall wo im Code der Timestamp mit eintausend multipliziert wird, kürzt du die Multiplikation weg ("*1000").
                                zB hier````
                                Um den Code noch mehr zu vereinfachen, kannst du den Timestmp auch direkt an die ereignis-Funktion übergeben und gleich ganz die Variable ts weglassen:
                                ereignis(obj.state.ts + " Alarmstatus: " + aktion);
                                Wenn dir das alles zuviel ist, änderst du in der function timestamp die zweite Zeile in
                                var now=new Date(ts/1000);
                                Geht, ist aber nicht so schön.
                                Pix
                                • sissiwupS
                                  sissiwupS
                                  sissiwup
                                  hab es oben angepasst. Geht jetzt mit neuen TimeStamps
                                  MfG
                                  Sissi
                                  • BluefoxB
                                    Vielleicht wird so was interessant.
                                    Alle events werden aus dem history/sql Adapter gelesen.
                                    `/* Read events from history adapter.
                                       Define the list of IDs, that must be shown.
                                       Additionally for every ID the display name and number of events can be defined.
                                    var historyInstance = 'sql.0'; // can be history adapter too
                                    // ofcourse all IDs must be enabled for history
                                    var states = {
                                        "javascript.0.graph.minutes"/*graph.minutes*/:      { name: 'Minutes', count: 15},
                                        "system.adapter.admin.0.memRss"/*admin.0.memRss*/ : { name: 'Memory'}
                                    var timeout = null; // de-bounce
                                    // create variable, where the list will be stored
                                    createState('eventList', '', function () {
                                        //first execute
                                        readAllEvents();
                                    function publishEvents(events) {
                                        // AS HTML
                                        /*var table = '';
                                        for (var e = 0; e < events.length; e++) {
                                            table += '';
                                        table += '
                                    | ' + formatDate(events[e].time, 'hh:mm:ss.sss') + ' | ' + states[events[e].id].name + ' | ' + events[e].val + ' |
                                        // as JSON
                                           events[e].time = formatDate(events[e].time, 'hh:mm:ss.sss');
                                           events[e].id   = states[events[e].id].name || events[e].id;
                                        setState('eventList', JSON.stringify(events), true);
                                    function readOneId(id, number, events, cb) {
                                        var end = new Date().getTime();
                                        sendTo(historyInstance, 'getHistory', {
                                            options: {
                                                end:        end,
                                                aggregate: 'none',
                                                count:      number || 10
                                        }, function (result) {
                                            if (result.result) {
                                                for (var i = 0; i < result.result.length; i++) {
                                                    events.push({id: id, time: result.result[i].ts, val: result.result[i].val});
                                            cb();
                                    // read events for all IDs
                                    function readAllEvents() {
                                        timeout = null;
                                        var ready = 0;
                                        var events = [];
                                        for (var id in states) {
                                            ready++;
                                            readOneId(id, 10, events, function () {
                                                if (!--ready) {
                                                    events.sort(function (a, b) {
                                                        if (a.time < b.time) return 1;
                                                        if (a.time > b.time) return -1;
                                                        return 0;
                                                    publishEvents(events);
                                    // subscribe on all changes
                                        on(id, function () {
                                            if (timeout) return;
                                            // de-bounce creation
                                            timeout = setTimeout(readAllEvents, 500);
                                     ![48_2016-05-25_23_51_20-edit_vis.png](/assets/uploads/files/48_2016-05-25_23_51_20-edit_vis.png)
                                    Widget:
                                    >! ~~[spoiler]~~`~~[code]~~[{"tpl":"tplTableBody","data":{"visibility-cond":"==","visibility-val":1,"static_value":"","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-oid":"javascript.0.eventList","colCount":"3","colName1":"Time","colWidth1":"60px","colAttr1":"time","table_oid":"javascript.0.eventList","colName2":"Event","colWidth2":"80px","colAttr2":"id","colName3":"Value","colWidth3":"60px","colAttr3":"val","hide_header":false,"class":""},"style":{"left":"760px","top":"315px","width":"332px","height":"200px"},"widgetSet":"basic"}][/code]`[/spoiler][/i][/i]
                                    • C
                                      C
                                      ChristianF
                                      Ich danke ebenfalls sehr für dieses Script, ist eine tolle Sache !
                                      Allerdings habe ich mit diesem Abschnitt so meine Probleme:
                                      Wie muss ich das an meine Räume anpassen? Was muss dort genau stehen? Ich bin ein bisschen lost..
                                      Danke!
                                      Viele grüße
                                      Christian
                                      • P
                                        P
                                        pix
                                        Wenn ich das richtig sehe, ist das eine etwas unglückliche Textformatierung, die dir Probleme macht.
                                        var rooms = {
                                            "ST-05": "OG Balkontür",
                                            "ST-02": "OG Wohnzimmer BW",
                                            "ST-03": "EG Treppenhaustür",
                                            "ST-01": "EG Wintergarten",
                                            "ST-04": "EG Eingangstür",
                                            "BW-01": "UG Garage",
                                            "BW-02": "EG Wintergarten",
                                            "BW-03": "OG Wohnzimmer",
                                            "VS-01": "EG Eingangstür",
                                            "VS-02": "UG Eingangstür",
                                            "VS-03": "UG Waschküche",
                                            "VS-04": "UG Garagentor",
                                            "VS-05": "EG Balkontür Atrium",
                                            "VS-06": "EG Relaxraum",
                                            "VS-07": "OG Balkontür",
                                            "VS-08": "OG Dachfenster",
                                            "VS-09": "EG Katzen R",
                                            "VS-10": "EG Katzen L",
                                            "VS-11": "EG Wintergarten",
                                            "VS-12": "EG Wohnzimmerfenster",
                                            "VS-13": "EG Küche L",
                                            "VS-14": "EG Küche R",
                                            "VS-15": "EG Abstellkammer",
                                            "VS-16": "EG Trepphaus",
                                            "VS-17": "OG Gästezimmer",
                                            "VS-18": "OG Ankleidezimmer"
                                        Wenn du dir nun die Ausgabe ansiehst: 261_bildschirmfoto_202015-09-06_20um_2020.46.22.png Es sind also nur Bezeichnungen.
                                        Das Skript lauscht auf deine Sensoren an anderer Stelle:
                                        Es lauscht in den Gewerken ST, BW, VS (vermute BW= Bewegungsmelder, VS= Verschluss, ST ???), ob die angegebenen Datenpunkte sich ändern. Dazu wird auf die REGA-Variable Alarmanlage gelauscht.
                                        Pix
                                        • M
                                          M
                                          michihorn
                                          @ruhr70:
                                          @Fitti:
                                          • Anwesenheiten
                                          • Haustür geöffnet
                                          Die letzten 30 Ereignisse werden in einer Liste in VIS dargestellt. `
                                          Hallo
                                          wie realisierst Du denn Internetausfall?
                                          Michael
                                          84.2k
