  4. Nach Neuinstall keine Weboberfläche
    2.8k
    4.9k
    4.1k
44 Beiträge 10 Kommentatoren 13.9k Aufrufe
    mctom
    Hi zusammen,
    ich hänge mich auch mal dran.
    Habe das gleiche Probleme.
    sudo ps -A | grep io
    Habe ich auch ausprobiert und bekomme:
       10 ?        00:00:00 migration/0
       11 ?        00:00:00 migration/1
       15 ?        00:00:00 migration/2
       19 ?        00:00:00 migration/3
       30 ?        00:00:00 bioset
       34 ?        00:00:00 rpciod
       37 ?        00:00:00 nfsiod
       49 ?        00:00:00 DWC Notificatio
     2584 ?        00:00:02 io.js-controlle
    Können wir noch etwas testen für die Fehlersuche ?
    Michael
    • BluefoxB Offline
      BluefoxB Offline
      @mctom:
      Hi zusammen,
      Michael `
      Also admin läuft nicht.
      Was passiert bei:
      cd /opt/iobroker
      iobroker add admin –enabled --port 8091
        krissi
        Hallo Bluefox
        root@bananapi:/opt/iobroker# iobroker add admin --enabled --port 8091
        host.bananapi install adapter admin
        got /opt/iobroker/node_modules/iobroker.admin/admin
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:278
                        if (objs.rows.length) {
        TypeError: Cannot read property 'rows' of undefined
            at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:278:25)
            at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:29    5:6)
            at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js    :220:12)
            at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modu    les/component-bind/index.js:21:15)
            at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_mod    ules/component-emitter/index.js:134:20)
            at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager    .js:301:8)
            at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modu    les/component-bind/index.js:21:15)
            at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_mod    ules/component-emitter/index.js:134:20)
            at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/sock    et.io-parser/index.js:247:12)
            at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js    :291:16)
        root@bananapi:/opt/iobroker# root@bananapi:/opt/iobroker# iobroker add admin --enabled --port 8091
        -bash: root@bananapi:/opt/iobroker#:</anonymous></anonymous></anonymous>
        ` > root@bananapi:/opt/iobroker# sudo ps -A | grep io
        9 ? 00:00:00 migration/0
        10 ? 00:00:00 migration/1
        20 ? 00:00:00 bioset
        25 ? 00:00:00 rpciod
        29 ? 00:00:00 nfsiod
        30 ? 00:00:00 cifsiod
        69 ? 00:00:00 bioset
        8267 ? 00:00:02 io.js-controlle
        root@bananapi:/opt/iobroker# `
        ioBroker in VM (unraid) / CCU2 für IP FB-Heizungssteuerung raspi3 / 3x Echo Dot / IKEA Tradfri / zigBee mit Conbee II
          mctom
          gleiches bild bei mir…
          host.ioBrokerLIVE install adapter admin
              at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
              at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
              at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
              at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
              at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
              at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
              at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)</anonymous></anonymous></anonymous>
            Sebbo
            Gibt es schon einen Workaround für unser Problem?
            Gruß Sebbo
            • BluefoxB Offline
              BluefoxB Offline
              Danke. Es war tatsächlich ein Fehler drin.
              Es gibt jetzt zwei Möglichkeiten:
              • alles löschen und neu installieren.
              • oder updaten:
              cd /opt/iobroker
              iobroker stop
              npm install iobroker.js-controller
              iobroker setup
              iobroker add admin
              iobroker start
                Sebbo
                was soll ich sagen, läuft… Vielen Dank!
                Gruß Sebbo
                  Sebbo
                  VIS lässt sich allerdings auch nicht installieren.
                  $ ./iobroker add vis
                  host.raspberrypi install adapter visnpm install –production --prefix "/opt/iobroker/node_modules/iobroker.vis" (System call)
                  npm
                  WARN cannot run in wd
                  iobroker.vis@0.6.12 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.vis)
                  npm
                  iobroker.vis@0.6.12 node node_modules/grunt/lib/grunt prepublish (wd=/opt/iobroker/node_modules/iobroker.vis)
                  got /opt/iobroker/node_modules/iobroker.vis/admin
                  upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                  upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                  • BluefoxB Offline
                    BluefoxB Offline
                    @Sebbo:
                    npm
                    npm
                    upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html `
                    Rechte. (wd ist Working Directory)
                    cd /opt/iobroker
                    sudo chmod 777 * -R
                    sudo iobroker add vis
                      krissi
                      Ich glaub ich geb es erst mal auf bis es wieder läuft. ich hab jetzt komplett neu installiert (inkl. dem Update), gleiches Ergebniss. Vieleicht mach ich ja auch noch irgendwo einen Fehler. Ich wüsste aber nicht wo. Mehr als das aus der Anleitung kopieren kann ich auch nicht. :(
                        Hast du die rechte gesetzt, so wie bluefox es gepostet hat?
                        Gesendet von meinem LIFETAB_S785X mit Tapatalk
                        2352_wemos_iobroker_wemos.txt
                        2352_skript_iobroker.txt
                          Sebbo
                          @Bluefox:
                          @Sebbo:
                          npm
                          npm
                          cd /opt/iobroker
                          sudo chmod 777 * -R
                          Ok, danke. Ich bekomme aber leider danach die selbe Fehlermeldung. :shock:
                          Gruß Sebbo
                          Edit: Hab jetzt nochmal komplett neu installiert. Aber Vis lässt sich noch immer nicht installieren. Es bleibt hängen, und mehr passiert nicht:
                          npm install iobroker.vis --production --prefix "/opt/iobroker/node_modules" (System call)
                          npm
                           http GET https://registry.npmjs.org/iobroker.vis
                          npm
                           http 200 https://registry.npmjs.org/iobroker.vis
                          npm
                           http GET https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-0.6.13.tgz
                          npm
                           http
                           200
                          327_datenpunkte_anlegen.js
                          327_wemos_iobroker_wemos.c
                            krissi
                            Sonst läuft das aber? Welches Image hast Du genommen und wie hast Du genau installiert? Kannst du das bitte mal auflisten? Ich probier das dann noch mal, wenn ich Glück habe läuft es dann auch bei mir.
                              Sebbo
                              Ich habe einen Raspi2 mit 2015-05-05-raspbian-wheezy und alles genau nach Installationsanleitung auf iobroker.net.
                              Gruß, Sebbo
                                Bruzze
                                Hallo Zusammen,
                                ich wollte mich für den Tip/Fix bedanken. Alles läuft und jetzt starte ich mal mein ioBroker Projekt.
                                Besten Dank an die Community
                                B.
                                Raspi 4/8 [Buster], pivCCU 3.67.10 (Homematic, wenige HMIP), ioBroker (Node 16.19, NPM 9.2.0), Redmatic, Homebridge, diverse Tasmota's, Sonoff's, Shellys (Total ca. 120 Geräte)
                                  Sebbo
                                  Geht denn dein Vis auch?
                                  Ich währe froh ich hätte nicht neuinstalliert. Leider lässt sich das Vis bei mir nicht installieren.
                                  Gruß Sebbo
                                    krissi
                                    Ich bin ja dann doch hartnäckig!!! Zum gefühlten 84sten mal neu installiert!!! Jetzt hab ich schon mal die Weboberfläche :) Danke an Bluefox und Rainer für den Support!!! Ich bleib da jetzt am Ball und probier das weiter. Dann erst mal gute Nacht und einen guten Start in die neue Woche!!! :P
                                      krissi
                                      Moin. Es läuft mittlerweile soweit alles prima. Ein Problem habe ich allerdings noch. Wenn ich bei der Installation dem Cubi eine feste ip zuweise und dann iobroker installiere, bekomme ich keine Verbindung zur Weboberfläche. Ohne feste ip geht das wunderbar. Mach ich da noch einen Denk- oder Konfigfehler? Ich stelle die ip in der /etc/network/interfaces ein.
                                        Um herauszubekommen ob es an der Einstellung liegt, müsstest du sie hier posten.
                                        Ersatzweise kannst du versuchen die vergebene IP vom PC anzupingen, oder versuchen mit putty auf den cubie zu gelangen und von dort sus einen ping an deinen Router oder an 8.8.8.8 zu schicken.
                                        Kommst du dann gar nicht an den cubie ran, ist die einstellung definitiv falsch. Dann brauchen wir die settings.
                                        Gesendet von meinem Cynus T7 mit Tapatalk
                                          krissi
                                          Ok, hab ich mich etwas unverständlich ausgedrückt. :) Wenn ich dem Cubi eine feste ip verpasse geht nur der Broker nicht. Ich komme mit putty drauf und sonst funktioniert auch alles! Ich komm halt nur nicht auf die Weboberfläche und iobroker verhält sich so wie am Anfang von dem Thema. Lass ich die ip per dhcp zuweisen geht alles.
