  4. Node Red - warn UnhandledPromiseRejectionWarning:
warn
2 Beiträge 2 Kommentatoren 539 Aufrufe 1 Beobachtet
  • F Offline
    fisch
    schrieb am zuletzt editiert von fisch
    Kann mir hier jemand was zu dieser Warnung sagen? Muss ich hier aktiv werden oder ignorieren?
    [code]node-red.0	2019-08-05 21:26:05.978	warn	(node:24583) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which
    node-red.0	2019-08-05 21:26:05.977	warn	(node:24583) UnhandledPromiseRejectionWarning: Error: timeout at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/iobroker-data/node-red/node_modules/@enocean-js/serialport-sender/src/serialport-
    node-red.0	2019-08-05 21:26:05.893	warn	(node:24583) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which
    node-red.0	2019-08-05 21:26:05.893	warn	(node:24583) UnhandledPromiseRejectionWarning: Error: timeout at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/iobroker-data/node-red/node_modules/@enocean-js/serialport-sender/src/serialport-
    node-red.0	2019-08-05 21:26:05.809	warn	(node:24583) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which
    node-red.0	2019-08-05 21:26:05.809	warn	(node:24583) UnhandledPromiseRejectionWarning: Error: timeout at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/iobroker-data/node-red/node_modules/@enocean-js/serialport-sender/src/serialport-
    node-red.0	2019-08-05 21:26:05.730	warn	(node:24583) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which
    node-red.0	2019-08-05 21:26:05.728	warn	(node:24583) UnhandledPromiseRejectionWarning: Error: timeout at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/iobroker-data/node-red/node_modules/@enocean-js/serialport-sender/src/serialport-
    node-red.0	2019-08-05 21:26:05.703	warn	(node:24583) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which
    node-red.0	2019-08-05 21:26:05.699	warn	(node:24583) UnhandledPromiseRejectionWarning: Error: timeout at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/iobroker-data/node-red/node_modules/@enocean-js/serialport-sender/src/serialport-
    admin.0	2019-08-05 21:25:44.255	info	successful connection to socket.io from ::ffff:192.168.178.27[/code]
    • V Offline
      V Offline
      valbuz
      Habe dasselbe Problem. Gibt's da schon eine Lösung?
      2xProxmox auf NUC
      E3DC 13kWh Speicher via RCSP an ioBroker
