  4. [gelöst]hqWidgets Dimmer läuft Amok
    5.4k
41 Beiträge 9 Kommentatoren 9.6k Aufrufe
  • L Offline
    looxer01
    Hi Bluefox,
    so, die Installation ist durchgegangen.
    Das Symptom ist allerdings noch da.
    Anbei mal das Widget. Vielleicht ist da was zu erkennen
    EDIT: irgendwie habe ich jetzt auch einige Fehler im Log. siehe unten
        ioBroker.admin
        Adapter
        Instanzen
        Objekte
        Zustände
        Ereignisse
        Gruppen
        Aufzählungen
        Hosts
        Log
        Scripte
        node-red.0
    Admin
    Log 	Log-Größe: 9.53 MB
    Zeit
    Nachricht
    host-raspberrypi	2015-08-15 17:39:27	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:39:21	error	15 Aug 17:39:21 - [error] Error: port in use
    node-red-0	2015-08-15 17:39:21	error	15 Aug 17:39:21 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:39:20	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:39:20	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:39:19	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:39:17	error	instance system.adapter.fritzbox.0 terminated with code 6 (uncaught exception)
    host-raspberrypi	2015-08-15 17:39:09	error	instance system.adapter.hue.0 terminated with code 1 ()
    hue-0	2015-08-15 17:39:09	error	{"message":"unauthorized user","type":1,"address":"/"}
    host-raspberrypi	2015-08-15 17:39:09	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:39:05	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:39:02	error	15 Aug 17:39:02 - [error] Error: port in use
    node-red-0	2015-08-15 17:39:02	error	15 Aug 17:39:02 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:39:01	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:39:00	error	instance system.adapter.b-control-em.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:54	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:45	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:44	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:43	error	instance system.adapter.fritzbox.0 terminated with code 6 (uncaught exception)
    host-raspberrypi	2015-08-15 17:38:41	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:38:41	error	15 Aug 17:38:41 - [error] Error: port in use
    node-red-0	2015-08-15 17:38:41	error	15 Aug 17:38:41 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:38:36	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:35	error	instance system.adapter.hue.0 terminated with code 1 ()
    hue-0	2015-08-15 17:38:35	error	{"message":"unauthorized user","type":1,"address":"/"}
    host-raspberrypi	2015-08-15 17:38:32	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:28	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:25	error	instance system.adapter.b-control-em.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:38:21	error	15 Aug 17:38:21 - [error] Error: port in use
    node-red-0	2015-08-15 17:38:21	error	15 Aug 17:38:21 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:38:21	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:12	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:11	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:38:09	error	instance system.adapter.fritzbox.0 terminated with code 6 (uncaught exception)
    host-raspberrypi	2015-08-15 17:38:05	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:38:03	error	15 Aug 17:38:03 - [error] Error: port in use
    node-red-0	2015-08-15 17:38:03	error	15 Aug 17:38:03 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:38:03	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:59	error	instance system.adapter.hue.0 terminated with code 1 ()
    hue-0	2015-08-15 17:37:59	error	{"message":"unauthorized user","type":1,"address":"/"}
    host-raspberrypi	2015-08-15 17:37:58	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:55	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:51	error	instance system.adapter.b-control-em.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:48	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:37:39	error	15 Aug 17:37:39 - [error] Error: port in use
    node-red-0	2015-08-15 17:37:39	error	15 Aug 17:37:39 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:37:39	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:37	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:36	error	instance system.adapter.fritzbox.0 terminated with code 6 (uncaught exception)
    host-raspberrypi	2015-08-15 17:37:29	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:25	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:21	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:21	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:37:21	error	15 Aug 17:37:21 - [error] Error: port in use
    node-red-0	2015-08-15 17:37:21	error	15 Aug 17:37:21 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:37:20	error	instance system.adapter.hue.0 terminated with code 1 ()
    hue-0	2015-08-15 17:37:20	error	{"message":"unauthorized user","type":1,"address":"/"}
    host-raspberrypi	2015-08-15 17:37:16	error	instance system.adapter.b-control-em.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:15	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:07	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:04	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:37:02	error	instance system.adapter.fritzbox.0 terminated with code 6 (uncaught exception)
    node-red-0	2015-08-15 17:37:01	error	15 Aug 17:37:01 - [error] Error: port in use
    node-red-0	2015-08-15 17:37:01	error	15 Aug 17:37:01 - [error] Unable to listen on http://127.0.0.1:1880/
    node-red-0	2015-08-15 17:36:00	error	15 Aug 17:36:00 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:36:57	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:45	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:44	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:43	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:41	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:41	error	instance system.adapter.hue.0 terminated with code 1 ()
    hue-0	2015-08-15 17:36:41	error	{"message":"unauthorized user","type":1,"address":"/"}
    host-raspberrypi	2015-08-15 17:36:41	error	instance system.adapter.b-control-em.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:36:40	error	15 Aug 17:36:40 - [error] Error: port in use
    node-red-0	2015-08-15 17:36:40	error	15 Aug 17:36:40 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:36:34	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:30	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:28	error	instance system.adapter.fritzbox.0 terminated with code 6 (uncaught exception)
    host-raspberrypi	2015-08-15 17:36:23	error	instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:36:19	error	15 Aug 17:36:19 - [error] Error: port in use
    node-red-0	2015-08-15 17:36:19	error	15 Aug 17:36:19 - [error] Unable to listen on http://127.0.0.1:1880/
    host-raspberrypi	2015-08-15 17:36:13	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:08	error	instance system.adapter.sonos.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:07	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:05	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:05	error	instance system.adapter.b-control-em.0 terminated with code 7 (Adapter already running)
    host-raspberrypi	2015-08-15 17:36:04	error	instance system.adapter.hue.0 terminated with code 1 ()
    hue-0	2015-08-15 17:36:04	error	{"message":"unauthorized user","type":1,"address":"/"}
    host-raspberrypi	2015-08-15 17:36:02	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    node-red-0	2015-08-15 17:36:00	error	15 Aug 17:36:00 - [error] Error: port in use
    [{"tpl":"tplHqDimmer","data":{"visibility-cond":"==","visibility-val":1,"oid":"hm-rpc.0.JEQ0199306.1.LEVEL","unit":"%","min":"0","max":"100","digits":"0","is_comma":"true","iconName":"img/bulb_off.png","btIconWidth":"32","offsetAuto":true,"leftOffset":"27","topOffset":"55","circleWidth":"25","showValue":true,"timeAsInterval":true,"infoLeftFontSize":"12","infoFontRightSize":"12","alwaysShow":false,"oid-working":"","name":"Licht WZ Esstisch Dimmer","filterkey":"Licht"},"style":{"left":"679px","top":"135px","width":"35px","height":"33px","z-index":"8","border-radius":"16px"},"widgetSet":"hqwidgets"}]
    dann der Code von hqwidget.html (scheint noch der alte zu sein?)
    [/orange]
    • BluefoxB Offline
      BluefoxB Offline
      Starte deine Kiste neu. Du hast 2 Instanzen von ioBroker am laufen.
      • L Offline
        looxer01
        ups - jap. habe jetzt neu gestartet und das Log ist sauber.
        Aber das Problem mit dem Widget ist noch da.
        Kann ich noch was machen ? Ich würde nur sehr ungern iobroker neu installieren.
        • BluefoxB Offline
          BluefoxB Offline
          Welche Version zeigt bei dir vis-hqwidgets?
          • L Offline
            looxer01
            Admin zeigt 0.1.1
            • BluefoxB Offline
              BluefoxB Offline
              Wenn du tatsächlich neueste js-controller hast, dann sollte bei dir 100% das funktionieren:
              iobroker upload vis-hqwidgets
              Danach versuche cache zu löschen.
              • L Offline
                looxer01
                nicht ganz. Ich sehe 0.77 installiert und eigentlich sollte 0.78 verfügbar sein ?
                allerdings gibt es keinen update button bei mir. nach ./iobroker upgrade auch nicht
                • BluefoxB Offline
                  BluefoxB Offline
                  Ist doch 0.7.8 installiert. ;)
                  0.7.8 ist noch nicht freigegeben. Man kann die nicht über admin installieren.
                  • L Offline
                    looxer01
                    …oooh mann, hast natürlich recht. habe ich irgendwie andersherum gelesen.
                    aber leider.... :(
                    gleiches Symptom; der Dimmer flackert irgendwie zufällig zwischen 1% und 100%
                    • L Offline
                      looxer01
                      Ich habe es jetzt auch nochmal mit einem anderen Dimmer (Steckdosendimmer) versucht.
                      Gleicher Effekt.
                      und so sieht es dann im log aus:
                      2015-08-16 11:30:11.413  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:12.274  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.01}] FLOAT
                      2015-08-16 11:30:12.644  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:13.586  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.21}] FLOAT
                      2015-08-16 11:30:13.949  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:14.909  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.4}] FLOAT
                      2015-08-16 11:30:15.282  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:16.244  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.52}] FLOAT
                      2015-08-16 11:30:16.666  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:17.609  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.6}] FLOAT
                      2015-08-16 11:30:18.008  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:18.990  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.7}] FLOAT
                      2015-08-16 11:30:19.341  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:20.360  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.76}] FLOAT
                      2015-08-16 11:30:20.692  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:21.676  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.81}] FLOAT
                      2015-08-16 11:30:21.996  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:22.987  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.85}] FLOAT
                      2015-08-16 11:30:23.297  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:24.286  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.88}] FLOAT
                      2015-08-16 11:30:24.628  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":1}] FLOAT
                      2015-08-16 11:30:25.675  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.91}] FLOAT
                      2015-08-16 11:30:26.157  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.99}] FLOAT
                      2015-08-16 11:30:27.158  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.92}] FLOAT
                      2015-08-16 11:30:27.245  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.95}] FLOAT
                      2015-08-16 11:30:28.245  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.78}] FLOAT
                      2015-08-16 11:30:28.568  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.95}] FLOAT
                      2015-08-16 11:30:29.560  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.82}] FLOAT
                      2015-08-16 11:30:30.168  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.91}] FLOAT
                      2015-08-16 11:30:31.008  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.7}] FLOAT
                      2015-08-16 11:30:31.454  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.91}] FLOAT
                      2015-08-16 11:30:32.407  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.72}] FLOAT
                      2015-08-16 11:30:32.764  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.91}] FLOAT
                      2015-08-16 11:30:33.746  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.76}] FLOAT
                      2015-08-16 11:30:34.086  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.91}] FLOAT
                      2015-08-16 11:30:35.086  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.79}] FLOAT
                      2015-08-16 11:30:35.458  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.91}] FLOAT
                      2015-08-16 11:30:36.451  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.8}] FLOAT
                      2015-08-16 11:30:36.813  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.91}] FLOAT
                      2015-08-16 11:30:37.792  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.89}] FLOAT
                      2015-08-16 11:30:38.124  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.01}] FLOAT
                      2015-08-16 11:30:39.188  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.71}] FLOAT
                      2015-08-16 11:30:39.730  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.02}] FLOAT
                      2015-08-16 11:30:40.719  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.71}] FLOAT
                      2015-08-16 11:30:41.280  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.03}] FLOAT
                      2015-08-16 11:30:42.269  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.71}] FLOAT
                      2015-08-16 11:30:42.603  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.04}] FLOAT
                      2015-08-16 11:30:43.569  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.57}] FLOAT
                      2015-08-16 11:30:43.947  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.07}] FLOAT
                      2015-08-16 11:30:44.901  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.49}] FLOAT
                      2015-08-16 11:30:45.271  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.08}] FLOAT
                      2015-08-16 11:30:46.203  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.41}] FLOAT
                      2015-08-16 11:30:46.874  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.09}] FLOAT
                      2015-08-16 11:30:47.856  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.39}] FLOAT
                      2015-08-16 11:30:48.273  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.1}] FLOAT
                      2015-08-16 11:30:49.239  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.33}] FLOAT
                      2015-08-16 11:30:49.627  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.11}] FLOAT
                      2015-08-16 11:30:50.631  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.28}] FLOAT
                      2015-08-16 11:30:51.117  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.12}] FLOAT
                      2015-08-16 11:30:52.088  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.19}] FLOAT
                      2015-08-16 11:30:52.493  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.86}] FLOAT
                      2015-08-16 11:30:53.457  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.33}] FLOAT
                      2015-08-16 11:30:53.897  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.86}] FLOAT
                      2015-08-16 11:30:54.870  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.38}] FLOAT
                      2015-08-16 11:30:55.273  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.86}] FLOAT
                      2015-08-16 11:30:56.231  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.82}] FLOAT
                      2015-08-16 11:30:56.648  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:30:57.633  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.68}] FLOAT
                      2015-08-16 11:30:58.043  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:30:58.948  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.57}] FLOAT
                      2015-08-16 11:30:59.431  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:00.392  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.55}] FLOAT
                      2015-08-16 11:31:00.790  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:01.755  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.47}] FLOAT
                      2015-08-16 11:31:02.091  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:03.114  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.4}] FLOAT
                      2015-08-16 11:31:03.481  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:04.446  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.34}] FLOAT
                      2015-08-16 11:31:04.794  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:05.819  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.3}] FLOAT
                      2015-08-16 11:31:06.180  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:07.115  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.27}] FLOAT
                      2015-08-16 11:31:07.522  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:08.511  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.25}] FLOAT
                      2015-08-16 11:31:08.934  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.14}] FLOAT
                      2015-08-16 11:31:09.906  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.23}] FLOAT
                      2015-08-16 11:31:10.414  - info: hm-rpc.0 setValue ["JEQ0199306:1","LEVEL",{"explicitDouble":0.01}] FLOAT
                      mitterweile tritt es jetzt auch mit DashUI auf. Das war noch nie der Fall.
                      Ausschalten geht auch nur noch mit dem Dimmer selber, mit langem Tastendruck.
                      und dann habe ich noch gesehen, dass wir nicht die einzigen sind:
                      http://forum.iobroker.com/viewtopic.php … f807#p9154
                      aber das Thema scheint dort nicht gelöst worden zu sein.
                      • E Offline
                        elmar
                        So, nach ein wenig Funkstille bin ich jetzt nochmal dazu gekommen zu testen: Ergebnis vorweg: Kein Amoklauf mehr, aber immer noch kein korrektes Verhalten
                        Versionen:
                        root@heimatpi:/opt/iobroker# iobroker list adapters
                        system.adapter.admin                   : admin       - 0.5.9
                        system.adapter.history                 : history     - 0.1.3
                        system.adapter.web                     : web         - 0.4.3
                        system.adapter.rickshaw                : rickshaw    - 0.2.2
                        system.adapter.onkyo                   : onkyo       - 0.1.9
                        system.adapter.hm-rpc                  : hm-rpc      - 0.5.2
                        system.adapter.vis                     : vis         - 0.6.13
                        system.adapter.vis-hqwidgets           : vis-hqwidgets - 0.1.1
                        system.adapter.vis-bars                : vis-bars    - 0.1.0
                        system.adapter.hm-rega                 : hm-rega     - 0.2.2
                        Wie ich die Version von js-controller herausbekomme ist mir nicht ganz klar. Ich habe aber direkt vor diesem Test auf den jeweils neuesten master von github geupdatet (vis/hqwidgets/js-controller)
                        Verhalten bei Switch:
                        1. Switch aus (in diesem Fall Steckdose)
                        2. Switch über vis hqwidget anschalten
                        3. Logfile zeigt zwei Log Einträge
                        2015-09-13 11:10:12.459  - info: hm-rpc.0 setValue ["JEQ0463281:1","STATE",true] BOOL
                        2015-09-13 11:10:12.469  - info: hm-rpc.0 setValue ["JEQ0463281:1","STATE",true] BOOL
                        Verhalten bei Schalter UP Dose identisch
                        2015-09-13 11:19:50.740  - info: hm-rpc.0 setValue ["JEQ0033148:1","STATE",true] BOOL
                        2015-09-13 11:19:50.744  - info: hm-rpc.0 setValue ["JEQ0033148:1","STATE",true] BOOL
                        Verhalten bei Steckdosendimmer
                        1. Dimmer ist aus
                        2. Mit der Maus 75% einstellen
                        Logfile zeigt folgendes
                        2015-09-13 11:20:56.333  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2015-09-13 11:20:56.340  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2015-09-13 11:21:12.630  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.75}] FLOAT
                        2015-09-13 11:21:12.636  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.75}] FLOAT
                        2015-09-13 11:21:13.732  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.4}] FLOAT
                        2015-09-13 11:21:13.736  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.4}] FLOAT
                        2015-09-13 11:21:14.345  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.75}] FLOAT
                        2015-09-13 11:21:14.357  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.75}] FLOAT
                        2015-09-13 11:21:15.598  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.62}] FLOAT
                        2015-09-13 11:21:15.607  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.62}] FLOAT
                        2015-09-13 11:21:16.488  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.75}] FLOAT
                        2015-09-13 11:21:16.497  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.75}] FLOAT
                        2015-09-13 11:21:17.437  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.7}] FLOAT
                        2015-09-13 11:21:17.441  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.7}] FLOAT
                        2015-09-13 11:21:17.774  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.74}] FLOAT
                        2015-09-13 11:21:17.782  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.74}] FLOAT
                        2015-09-13 11:21:18.745  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.73}] FLOAT
                        2015-09-13 11:21:18.753  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.73}] FLOAT
                        2015-09-13 11:21:19.031  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.74}] FLOAT
                        2015-09-13 11:21:19.035  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.74}] FLOAT
                        2015-09-13 11:21:19.999  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.74}] FLOAT
                        2015-09-13 11:21:20.008  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.74}] FLOAT
                        Auch hier kommt jedes Event zweimal. Erstens überrascht mich, dass der Dimmer zuerst auf 0 gesetzt wird. Dann wird im zweiten Schritt die tatsächlich erwünschten 75% gesendet. Und dann fängt er sich langsam "einzuschwingen" bzw. asymptotisch zu nähern.
                        Alternativlogeinträge bei einfachem Klick auf den Dimmer:
                        2015-09-13 11:23:46.440  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2015-09-13 11:23:46.458  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0}] FLOAT
                        2015-09-13 11:23:48.523  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":1}] FLOAT
                        2015-09-13 11:23:48.535  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":1}] FLOAT
                        2015-09-13 11:23:49.532  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.55}] FLOAT
                        2015-09-13 11:23:49.542  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.55}] FLOAT
                        2015-09-13 11:23:50.142  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":1}] FLOAT
                        2015-09-13 11:23:50.149  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":1}] FLOAT
                        2015-09-13 11:23:51.148  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.83}] FLOAT
                        2015-09-13 11:23:51.155  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.83}] FLOAT
                        2015-09-13 11:23:51.399  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.97}] FLOAT
                        2015-09-13 11:23:51.406  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.97}] FLOAT
                        2015-09-13 11:23:52.407  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.93}] FLOAT
                        2015-09-13 11:23:52.421  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.93}] FLOAT
                        2015-09-13 11:23:52.658  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.97}] FLOAT
                        2015-09-13 11:23:52.665  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.97}] FLOAT
                        2015-09-13 11:23:53.663  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.97}] FLOAT
                        2015-09-13 11:23:53.675  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.97}] FLOAT
                        Bei UP Dimmer identisches Verhalten.
                        Getestet mit jeweils aktuellem Internet Explorer/Firefox/Chrome auf Windows 8.1 mit aktuellem Patch Level. Sowie Safari unter aktuellem iOS.
                        Kurioserweise sind die ersten drei Logwerte immer identisch 1, 0,57, 1 und dann geht es in Richtung 0,8x und schwingt sich in Richtung 0,9x ein
                        Zweites beobachtetes Kuriosum: Wenn zwei Browserfenster geöffnet sind, dann läuft wieder alles Amok. Auch wenn ein Browser auf iOS und der andere auf Windows läuft.
                        • E Offline
                          elmar
                          Der Vollständigkeit halber sollte ich vielleicht noch erwähnen, dass es sich um einen Laptop mit Touchscreen handelt. Die Touch Funktionalität ist jedoch in der Registry abgeklemmt.
                          • E Offline
                            elmar
                            Nach weiterem probieren komme ich zu dem Schluss, dass das Problem grundsätzlich im ioBroker zu suchen ist. Es hat nichts mit den hqwidgets zu tun.
                            1. Beobachtung: Das Verhalten mit den jqui Widget dimmer ctrl ist absolut identisch
                            2. Beobachtung: Es wird total seltsam, wenn man ein lichtsteuerndes Programm auf der CCU aufruft
                            1. In Vis einen Button einfügen
                            2. Object ID auf das ProgramExecute setzen
                            3. "value" auf "true"
                            4. Den Button in der vis anklicken
                            5. Jetzt laufen alle Lampen, die über das Programm angesteuert werden Amok
                            Logfile zeigt folgendes (kurzer Ausschnitt)
                            2015-09-13 17:23:37.572  - error: hm-rpc.0 Error: You are sending too fast
                            2015-09-13 17:23:37.611  - info: hm-rpc.0 setValue ["JEQ0193658:1","LEVEL",{"explicitDouble":0.08}] FLOAT
                            2015-09-13 17:23:38.188  - info: hm-rpc.0 setValue ["JEQ0193658:1","LEVEL",{"explicitDouble":0.09}] FLOAT
                            2015-09-13 17:23:38.226  - info: hm-rpc.0 setValue ["JEQ0193658:1","LEVEL",{"explicitDouble":0.09}] FLOAT
                            2015-09-13 17:23:38.463  - info: hm-rpc.0 setValue ["JEQ0200241:1","LEVEL",{"explicitDouble":0.12}] FLOAT
                            2015-09-13 17:23:38.471  - info: hm-rpc.0 setValue ["JEQ0200241:1","LEVEL",{"explicitDouble":0.12}] FLOAT
                            2015-09-13 17:23:38.474  - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.12] FLOAT
                            2015-09-13 17:23:38.475  - error: hm-rpc.0 Error: You are sending too fast
                            2015-09-13 17:23:39.196  - info: hm-rpc.0 setValue ["JEQ0193658:1","LEVEL",{"explicitDouble":0.09}] FLOAT
                            2015-09-13 17:23:39.282  - info: hm-rpc.0 setValue ["JEQ0193658:1","LEVEL",{"explicitDouble":0.09}] FLOAT
                            2015-09-13 17:23:39.392  - info: hm-rpc.0 setValue ["JEQ0200292:1","LEVEL",{"explicitDouble":0.02}] FLOAT
                            2015-09-13 17:23:39.395  - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.02] FLOAT
                            2015-09-13 17:23:39.397  - error: hm-rpc.0 Error: You are sending too fast
                            2015-09-13 17:23:39.956  - info: hm-rpc.0 setValue ["IEQ0544749:1","LEVEL",{"explicitDouble":0.03}] FLOAT
                            2015-09-13 17:23:39.971  - info: hm-rpc.0 setValue ["IEQ0544749:1","LEVEL",{"explicitDouble":0.03}] FLOAT
                            2015-09-13 17:23:40.063  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.02}] FLOAT
                            2015-09-13 17:23:40.113  - info: hm-rpc.0 setValue ["IEQ0092302:1","LEVEL",{"explicitDouble":0.02}] FLOAT
                            2015-09-13 17:23:40.115  - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.02] FLOAT
                            2015-09-13 17:23:40.117  - error: hm-rpc.0 Error: You are sending too fast
                            2015-09-13 17:23:40.921  - info: hm-rpc.0 setValue ["IEQ0544749:1","LEVEL",{"explicitDouble":0.3}] FLOAT
                            2015-09-13 17:23:40.926  - info: hm-rpc.0 setValue ["IEQ0544749:1","LEVEL",{"explicitDouble":0.3}] FLOAT
                            2015-09-13 17:23:41.058  - info: hm-rpc.0 setValue ["IEQ0544749:1","LEVEL",{"explicitDouble":0.1}] FLOAT
                            2015-09-13 17:23:41.061  - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.1] FLOAT
                            2015-09-13 17:23:41.062  - error: hm-rpc.0 Error: You are sending too fast
                            2015-09-13 17:23:41.065  - info: hm-rpc.0 setValue ["IEQ0544749:1","LEVEL",{"explicitDouble":0.1}] FLOAT
                            Was mich total irritiert. Das Programm läuft ja auf der CCU … aber trotzdem wird im Logfile "setValue" geloggt. Wenn ich das Programm auf der CCU ausführe, dann werden die Werte in vis korrekt dargestellt. Das Logfile bleibt aber komplett leer.
                              Ich weiß nicht wann genau, aber eben ist eine neue vis version gekommen.
                              Ich hatte eine neue Installation gemacht, unmittelbar danach war ein update da. jetzt 0.6.14.
                              @elmar:
                              Wie ich die Version von js-controller herausbekomme ist mir nicht ganz klar. `
                              steht im Reiter "hosts"
                              • E Offline
                                elmar
                                Jo, die ist bei mir auch neu … Installation läuft
                                Derweil js-controller: 0.7.11
                                Update fertig ...
                                Update von vis auf 0.6.14 bringt allerdings keine Änderung im beschriebenen Verhalten
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  hqWidgets sind nicht in vis sondern in "vis-hqWidgets" und die sind gerade upgedated. Allerdings, weil ich das Verhalten nicht reproduzieren kann, es konnte nur durch Zufall kommen, dass Fehler gefixt ist.
                                  Ich habe da was geändert.
                                  • E Offline
                                    elmar
                                    Habe gerade Admin und hqwidgets aktualisiert … allerdings keine Veränderung des Verhaltens.
                                    Ich habe bei mir 2 hm-rpc Instanzen .0 für rfd und .1 für wired ... da ja jeder Klick 2x gesendet wird habe ich die wired Instanz mal ausgeschaltet und danach auch den iobroker durchgestartet ... aber auch das hat das Verhalten nicht verändert.
                                    Ich glaube immer noch, dass das Verhalten irgendwo anders verursacht wird und nicht in den hqwidgets begründet ist.
                                    Bei mir ist das Verhalten absolut reproduzierbar. Es tritt sowohl auf meinem Windows Entwicklungssystem auf, als auch auf dem gestern frisch aufgesetzten RPI 2. Meine Vermutung geht in die Richtung, dass auf Grund zweier RPC Instanzen die Calls zweimal gemacht werden und das zu einem kuriosen Schaukeleffekt kommt.
                                    Ich werde mal in Ruhe versuchen das lokal zu debuggen ... muss aber zugeben, dass ich vor 10 Jahren mal aktiver Java Entwickler war und das node.js Geraffel für mich noch "Neuland" ist ;-)
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      Frage ich anders: gibt es noch jemand (ausser mir), der hqWidgets/dimmer benutz und es läuft?
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        Ich habe eine Vermutung, woher so ein Verhalten kommen konnte.
                                        Passiert das nur beim aktivierten hm-rpc?
                                          Brati
                                          ich kann das Problem bestätigen. Ich habe ioBroker installiert und das war mein 1. Versuch mit Widgets. Daher dachte ich an einen Fehler vor dem Bildschirm.
                                          Mit dem Metro Style Slider klappt es aber ohne Probleme. Ein UP Dimmer wurde angesprochen.
                                          Brati
