  5. Kein regexp in object trigger möglich?
8 Beiträge 4 Kommentatoren 387 Aufrufe 4 Beobachtet
  • padrinoP Offline
    padrinoP Offline
    padrino
    kann mir jemand sagen, wieso sowas nicht geht?
    der dazu erzeugte JS code:
    on({id: new RegExp(new RegExp\\('\\(rflink\\.0\\.channels\\.*\\.TEMP\\)'\\) + "|" + new RegExp\\('\\(rflink\\.0\\.channels\\.*\\.HUM\\)'\\)), change: "ne"}, function (obj) {
    Und das error log:
    javascript.0	2019-06-14 12:10:46.897	error	at TCP.onread (net.js:597:20)
    javascript.0	2019-06-14 12:10:46.897	error	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-06-14 12:10:46.897	error	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-06-14 12:10:46.897	error	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-06-14 12:10:46.897	error	at Socket.emit (events.js:211:7)
    javascript.0	2019-06-14 12:10:46.897	error	at emitOne (events.js:116:13)
    javascript.0	2019-06-14 12:10:46.896	error	at Socket._ultron.on (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:138:22)
    javascript.0	2019-06-14 12:10:46.896	error	at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:139:10)
    javascript.0	2019-06-14 12:10:46.896	error	at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:165:16)
    javascript.0	2019-06-14 12:10:46.896	error	at Receiver.getData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:330:12)
    javascript.0	2019-06-14 12:10:46.896	error	at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
    javascript.0	2019-06-14 12:10:46.896	error	at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
    javascript.0	2019-06-14 12:10:46.896	error	at WebSocket.emit (events.js:211:7)
    javascript.0	2019-06-14 12:10:46.896	error	at emitOne (events.js:116:13)
    javascript.0	2019-06-14 12:10:46.896	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
    javascript.0	2019-06-14 12:10:46.896	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
    javascript.0	2019-06-14 12:10:46.896	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-06-14 12:10:46.896	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-06-14 12:10:46.896	error	at WS.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-06-14 12:10:46.895	error	at WS.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
    javascript.0	2019-06-14 12:10:46.895	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
    javascript.0	2019-06-14 12:10:46.895	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-06-14 12:10:46.895	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-06-14 12:10:46.895	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
    javascript.0	2019-06-14 12:10:46.895	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
    javascript.0	2019-06-14 12:10:46.895	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-06-14 12:10:46.895	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-06-14 12:10:46.895	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    javascript.0	2019-06-14 12:10:46.895	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-06-14 12:10:46.895	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-06-14 12:10:46.895	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    javascript.0	2019-06-14 12:10:46.894	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    javascript.0	2019-06-14 12:10:46.889	error	at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:745:17)
    javascript.0	2019-06-14 12:10:46.888	error	at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1123:17)
    javascript.0	2019-06-14 12:10:46.888	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1070:37)
    javascript.0	2019-06-14 12:10:46.888	error	at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:878:28)
    javascript.0	2019-06-14 12:10:46.888	error	at Object.createScript (vm.js:80:10)
    javascript.0	2019-06-14 12:10:46.888	error	SyntaxError: Invalid or unexpected token
    javascript.0	2019-06-14 12:10:46.888	error	^^^^^^^
    javascript.0	2019-06-14 12:10:46.887	error	on({id: new RegExp(new RegExp\\('\\(rflink\\.0\\.channels\\.*\\.TEMP\\)'\\) + "|" + new RegExp\\('\\(rflink\\.0\\.channels\\.*\\.HUM\\)'\\)), change: "ne"}, function (obj) {
    javascript.0	2019-06-14 12:10:46.886	error	script.js.common.Skript_3_test compile failed: at script.js.common.Skript_3_test:1
    Gibt es da keinen Weg, oder wenn, dann nur ohne Blockly, als JS direkt?
    Danke. =)
    CU,
    padrino
    • padrinoP padrino
      Und das error log:
      Danke. =)
      CU,
      padrino
      dslraserD Offline
      dslraserD Offline
      dslraser
      @padrino
      mach mal nur mit einem...
      Edit: war vielleicht doch was anderes.....
      • padrinoP padrino
        Und das error log:
        Danke. =)
        CU,
        padrino
        dslraserD Offline
        dslraserD Offline
        dslraser
        @padrino
        https://forum.iobroker.net/topic/20845/wunschliste-blockly-elemente/147
        thewhoboxT 1 Antwort Letzte Antwort
        • dslraserD dslraser
          @padrino
          thewhoboxT Offline
          thewhoboxT Offline
          thewhobox
          @dslraser Hey, ich hab mir den Fehler mal angeschaut. Das liegt am Trigger-Element.
          Sobald mehr als zwei Parameter übergeben werden will er einen Regex daraus machen....
          Ein Fix wäre relativ viel arbeit.
          WOrkaround: nur einen Regex als trigger oder zwei selector elemente nehmen, beide listen zusammenfügen, neue liste als trigger nehmen.
          Meine Adapter: emby | discovery
          • padrinoP Offline
            padrinoP Offline
            padrino
            schrieb am zuletzt editiert von padrino
            @dslraser
            Cool, so
            scheint es zu gehen. :)👍
            Musste mir erstmal kurz "oder" aneignen, war dann die "|" wie vermutet. :D
            • padrinoP Offline
              padrinoP Offline
              padrino
              In meinem Fall geht es mit der oder pipe ("|") ja recht einfach zu lösen... =)
              Ist halt doof, wenn man nur Blockly kann, aber doch irgendwie freier sein möchte, oder Ideen hat, die "mehr power" benötigen... ;)
              • OliverIOO Offline
                OliverIOO Offline
                OliverIO
                zum Regex entwickeln und testen finde ich
                die Seite hervorragend
                https://regex101.com/
                Meine Adapter und Widgets
                Links im Profil
                • padrinoP Offline
                  padrinoP Offline
                  padrino
                  "gelöscht"
                  (BTW, wieso kann man bei "Werkzeuge" auch "löschen" auswählen, wenn man doch nicht die Rechte dazu hat... :D )
                  82.8k
