  4. Fehler bei der Installation vom SQL Adapter
    1.0k
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
adapter sql fehler
8 Beiträge 3 Kommentatoren 1.0k Aufrufe 1 Beobachtet
  • Amnesia1211A Offline
    Amnesia1211
    schrieb am zuletzt editiert von Amnesia1211
    Hallo liebe Iobroker Gemeinde,
    leider habe ich einen Fehler bei der Installation des SQL Adapters und weiß leider auch keine Abhilfe.
    Vielleicht hat ja einer von euch eine Idee.
    iobroker läuft auf Synology (Docker) Version 2.0.0
    Fertig mit Fehler: host.iobroker Cannot install sql
    $ ./iobroker add sql  --host iobroker
    NPM version: 6.4.1
    npm install iobroker.sql --production --save --prefix "/opt/iobroker" (System call)
    gyp
     WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/8.14.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/mmmagic/.node-gyp"
    gyp
     WARN install got an error, rolling back install
    gyp WARN
    gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/mmmagic/.node-gyp'
    gyp ERR! System Linux 3.10.105gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd
     /opt/iobroker/node_modules/mmmagicgyp ERR! node -v v8.14.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm
     ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! mmmagic@0.5.3 install: `node-gyp rebuild`npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the mmmagic@0.5.3 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-06-06T20_28_50_353Z-debug.log
    host.iobroker install adapter sql
    NPM version: 6.4.1
    gyp
    gyp
    gyp
     WARN install got an error, rolling back installgyp ERR! configure error
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mmmagic
    gyp ERR! not ok
    npm
    npm ERR! code ELIFECYCLEnpm ERR! errno 1
    npm
    npm ERR!
    npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-06-06T20_29_37_206Z-debug.log
    NPM version: 6.4.1
    gyp
    gyp WARN install got an error, rolling back install
    gyp ERR!
     node -v v8.14.0gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm
    npm
    npm ERR!
    npm ERR!
    npm ERR!     /root/.npm/_logs/2019-06-06T20_30_24_236Z-debug.log
    ERROR: host.iobroker Cannot install sql
    ERROR: process exited with code 13
    Man muss nicht alles wissen, nur wissen wo es steht.
    Fragen schadet aber auch nicht :spock-hand:
      Amnesia1211
      Wirklich keiner eine Idee? Würde gerne die SQL Datenbank für das loggen nutzen.
      • Amnesia1211A Amnesia1211
        HomoranH Offline
        HomoranH Offline
        @Amnesia1211
        Hast du Mal im Forum nach fehlender Berechtigung und Behebung davon gesucht?
        Die in diesem Rahmen übliche Frage:
        Wann und wie würde ioBroker installiert?
        Amnesia1211A 1 Antwort Letzte Antwort
          @Amnesia1211
          Amnesia1211
          @Homoran sagte in Fehler bei der Installation vom SQL Adapter:
          Berechtigung
          Ja habe schon mal gesucht aber nichts gefunden :-(
          Wann ich iobroker installiert habe weiß ich nicht mehr genau, denke vor 3 Wochen.
          Wie hatte ich oben schon erwähnt, es läuft auf einer Synology DS RS818+ über Docker,
          der link ist hier https://hub.docker.com/r/buanet/iobroker/ die Version ist 2.0.0
          Andere Adapter lassen sich normal installieren. Was der Unterschied zum SQL Adapter sind kann ich mir nicht erklären.
          HomoranH NegaleinN 2 Antworten Letzte Antwort
            Berechtigung
            HomoranH Offline
            HomoranH Offline
            @Amnesia1211
            Sorry, das mit dem Docker habe ich überlesen. Aber genau da eird das Problem luegen. Leider kenne ich mich damit überhaupt nicht aus.
              Berechtigung
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              @Amnesia1211 sagte in Fehler bei der Installation vom SQL Adapter:
              Hast du hier schon mal gefragt?
              Ich glaube @andre hat mal was zwecks SQL geschrieben.
              ° Fixer ---> iob fix
              • NegaleinN Negalein
                Amnesia1211
                @Negalein
                Nein habe ich nicht gemacht, werde ich aber jetzt im Anschluss tun danke gute Idee :-)
                  Amnesia1211
                  Also...
                  Mir wurde geraten die Docker Version auf 3.0 upzudaten, was ich dann nach einigen Problemen auch hin bekommen habe.
                  Der SQL Adapter läuft auf der Version 3.0, zudem wurde mir gesagt das ich ein Rechte Problem mit der Version 2.0 habe und deswegen die Installation
                  des SQL Adapters nicht klappt.
