  4. Dyson pure Hot&cool link
32 Beiträge 13 Kommentatoren 9.0k Aufrufe 11 Beobachtet
  • P Offline
    Phteven
    Hallo, ich hab es mit dieser lib hier gemacht:
    https://github.com/auchenberg/dyson-purelink
    und in einem JavaScript integriert.
    var DysonPureLink = require('../../dyson-purelink')
    createState("Dyson.On", false);
    createState("Dyson.Off", false);
    createState("Dyson.Rotation", false);
    createState("Dyson.FanSpeed", 10);
    createState("Dyson.Auto", false);
    var pureLink = new DysonPureLink("xxx@xxx.de", "xxxxxxx");
    var dyson;
    pureLink.getDevices().then(devices => {
        if(!devices)
            log('No devices found');
        else
            dyson = devices[0];
    }).catch(err => console.error(err))
    on({id: "javascript.0.Dyson.On", val: true}, function (obj)
        dyson.turnOn();
        setState("javascript.0.Dyson.On", false);
    on({id: "javascript.0.Dyson.Off", val: true}, function (obj)
        dyson.turnOff();
        setState("javascript.0.Dyson.Off", false);
    on({id: "javascript.0.Dyson.Rotation"}, function (obj)
        dyson.setRotation(obj.state.val);
    on({id: "javascript.0.Dyson.FanSpeed"}, function (obj)
        dyson.setFanSpeed(obj.state.val * 10);
    on({id: "javascript.0.Dyson.Auto"}, function (obj)
        dyson.setAuto(obj.state.val);
    /*pureLink.getDevices().then(devices => {
        if(!devices) {
            return
        // Get status
        devices[0].getTemperature().then(t => log('getTemperature', t))
        devices[0].getAirQuality().then(t => log('getAirQuality', t))
        devices[0].getRelativeHumidity().then(t => log('getRelativeHumidity', t))
        devices[0].getFanStatus().then(t => log('getFanStatus', t))
        devices[0].getFanSpeed().then(t => log('getFanSpeed', t))
        devices[0].getRotationStatus().then(t => log('getRotationStatus', t))
        devices[0].getAutoOnStatus().then(t => log('getAutoOnStatus', t))
        // Actions
        //devices[0].turnOff();
        //devices[0].setRotation(true).then(t => console.log('setRotation', t))
        //devices[0].setFanSpeed(100).then(t => console.log('setFanSpeed', t))
      Kludi
      Hallo, ich habe heute versucht den Dyson-purelink adapter von auchenberg zu installieren, aber ich bekomme immer bei der Installation die Meldung.
      "$ ./iobroker url "https://github.com/auchenberg/dyson-purelink.git"
      install https://github.com/auchenberg/dyson-purelink/tarball/master
      npm install https://github.com/auchenberg/dyson-purelink/tarball/master --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN
      notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})"
      Was muss ich machen das es funktioniert. Oder ist der Adapter schon für den aktuellen ioBroker zu alt.
      H 1 Antwort Letzte Antwort
      • K Kludi
        npm
        holgerwolf
        @Kludi
        Den Dyson kann man prima über den Umweg über den HAM Adapter steuern:
        https://forum.iobroker.net/topic/13509/aufruf-iobroker-ham-homebridge-accessory-manager-testen/240
        So sehen dann die Objekte aus:
        Holger
        • H holgerwolf
          @Kludi
          Holger
          Kludi
          schrieb am zuletzt editiert von Kludi
          @holgerwolf Danke für deine schnelle Antwort. Ich habe den HAM Adapter installiert.
          Ich bekomme nur keine Objekte.
          Was mache ich falsch?
            Kludi
            Danke noch mal für den Tipp.
            Ich habe jetzt den HAM Adapter zum laufen bekommen und ich habe es auch geschafft das die Ganzen Objekte da sind. Ich hatte noch einige Fehler im JavaScript gehabt. (ich hatte es nie gelernt)
            Jetzt habe ich alle Objekte von Dyson-purelink nur habe ich keine werte.
              "platforms": [
                  "platform": "DysonPlatform",
                  "name": "DysonPlatform",
                  "email": "xxxxxxx@xxx.de",
                  "password": "xxxx",
                  "country": "DE",
                  "accessories": [
                      "ip": "192.168.178.53",
                      "displayName": "Dyson-PureCool",
                      "serialNumber": "DYSON-xxx-EU-xxxxxxxx-xxx",
                      "password": "xxxx"
            Was muss ich noch machen das ich meine Werte habe?
            Gruß Kludi
            • H Offline
              holgerwolf
              schrieb am zuletzt editiert von holgerwolf
              So sehen meine Einstellunge aus:
                "platforms": [
                    "email": "xx@xx.com",
                    "password": "xyz",
                    "country": "DE",
                    "accessories": [
                        "ip": "192.168.178.152",
                        "displayName": "Dyson-Wohnzimmer",
                        "serialNumber": "DYSON-NN2-EU-xxxx-475",
                        "password": "xyz"
                "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                "accessories": []
              Ich denke es liegt am Polling Wert....
              • H holgerwolf
                  "platforms": [
                      "password": "xyz",
                      "country": "DE",
                      "accessories": [
                          "password": "xyz"
                  "accessories": []
                Kludi
                @holgerwolf Danke ich habe dein JavaScript übernommen.
                Leider bleibt der HAM-Adapter nicht Grün wechselt immer wieder hin und her.
                Wenn ich das richtig in den Log's verstanden habe hat der mit meinem Zugangsdaten Probleme.
                host.tinkerboard	2019-06-09 20:00:24.313	error	instance system.adapter.ham.0 terminated with code 0 (OK)
                host.tinkerboard	2019-06-09 20:00:24.313	error	Caught by controller[4]: at Socket.emit (events.js:211:7) code: 4 }
                host.tinkerboard	2019-06-09 20:00:24.313	error	Caught by controller[4]: at emitOne (events.js:116:13)
                host.tinkerboard	2019-06-09 20:00:24.313	error	Caught by controller[4]: at Socket.ondata (_stream_readable.js:639:20)
                host.tinkerboard	2019-06-09 20:00:24.313	error	Caught by controller[4]: at Writable.write (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[4]: at writeOrBuffer (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[4]: at doWrite (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[4]: at Writable.writable._write (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:271:5)
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[4]: at work (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:261:12)
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[4]: at MqttClient._handlePacket (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:319:12)
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[4]: at MqttClient._handleConnack (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:877:15)
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[4]: { Error: Connection refused: Bad username or password
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[3]: HAP Warning: Characteristic 000000BF-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 000000B7-0000-1000-8000-0026BB765291. Adding anyway.
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[2]: [2019-6-9 20:00:22] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-dyson-link' since we already loaded the same plugin from '/opt/iobroker/node_modules/io
                host.tinkerboard	2019-06-09 20:00:24.312	error	Caught by controller[1]: [2019-6-9 20:00:22] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                host.tinkerboard	2019-06-09 20:00:24.311	error	Caught by controller[0]: [2019-6-9 20:00:21] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                ham.0	2019-06-09 20:00:24.269	error	uncaught exception: Connection refused: Bad username or password
                host.tinkerboard	2019-06-09 19:59:50.182	error	instance system.adapter.ham.0 terminated with code 0 (OK)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at Socket.emit (events.js:211:7) code: 4 }
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at emitOne (events.js:116:13)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at Socket.ondata (_stream_readable.js:639:20)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at Writable.write (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at writeOrBuffer (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at doWrite (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at Writable.writable._write (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:271:5)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at work (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:261:12)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at MqttClient._handlePacket (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:319:12)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: at MqttClient._handleConnack (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:877:15)
                Caught	2019-06-09 19:59:50.182	error	by controller[4]: { Error: Connection refused: Bad username or password
                Caught	2019-06-09 19:59:50.182	error	by controller[3]: HAP Warning: Characteristic 000000BF-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 000000B7-0000-1000-8000-0026BB765291. Adding anyway.
                Caught	2019-06-09 19:59:50.181	error	by controller[2]: [2019-6-9 19:59:48] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-dyson-link' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker
                Caught	2019-06-09 19:59:50.181	error	by controller[1]: [2019-6-9 19:59:47] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                Caught	2019-06-09 19:59:50.181	error	by controller[0]: [2019-6-9 19:59:47] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                ham.0	2019-06-09 19:59:50.145	error	at Socket.emit (events.js:211:7)
                ham.0	2019-06-09 19:59:50.145	error	at emitOne (events.js:116:13)
                ham.0	2019-06-09 19:59:50.145	error	at Socket.ondata (_stream_readable.js:639:20)
                ham.0	2019-06-09 19:59:50.145	error	at Writable.write (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                ham.0	2019-06-09 19:59:50.145	error	at writeOrBuffer (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                ham.0	2019-06-09 19:59:50.145	error	at doWrite (/opt/iobroker/node_modules/iobroker.ham/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                ham.0	2019-06-09 19:59:50.145	error	at Writable.writable._write (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:271:5)
                ham.0	2019-06-09 19:59:50.145	error	at work (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:261:12)
                ham.0	2019-06-09 19:59:50.145	error	at MqttClient._handlePacket (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:319:12)
                ham.0	2019-06-09 19:59:50.145	error	at MqttClient._handleConnack (/opt/iobroker/node_modules/iobroker.ham/node_modules/mqtt/lib/client.js:877:15)
                ham.0	2019-06-09 19:59:50.145	error	Error: Connection refused: Bad username or password
                ham.0	2019-06-09 19:59:50.145	error	uncaught exception: Connection refused: Bad username or password
                Aber meine Zugangsdaten stimmen, sonnst hätte ich ja auch mit der Dyson app. Probleme.
                Ich danke dir noch mal das du dir das anschaust.
                Gruß Kludi
                • H Offline
                  holgerwolf
                  Vielleicht weil das ein wenig verwirrend ist. Oben in Kombi mit der E-Mail Adresse muss das PW aus dem Dyson Web Login rein. Unten bei der Seriennummer das WLAN PW vom Dyson. Das vom Aufkleber.
                  Gruss
                  Holger
                    Kludi
                    @holgerwolf Das ist ja interessant darauf wehre ich nie drauf gekommen. Das Password vom Aufkleber zu nehmen.
                    Super jetzt habe ich werte, hat ein bissen gedauert bis er die anzeigt.
                    Ich denke das liegt am Polling.
                    Aber ich kann daraus nicht steuern oder habe ich immer noch ein Fehler? 🙈
                    Gruß Kludi
                      Kludi
                      Doch geht ich kann alles machen! Danke für die Super Hilfe ☺
                      Kludi
                      • H holgerwolf
                        Gruss
                        Holger
                        Kludi
                        @holgerwolf Sorry ich muss dich noch mal stören.
                        Kann das sein wenn der Lüfter auf Auto seht, dass man dann keine neuen Werte bekommt und auch nicht eingreifen bzw. steuern kann?
                        Gruß Kludi
                        • K Kludi
                          Gruß Kludi
                          holgerwolf
                          @Kludi
                          Bei mir geht das. Ich kann mich aber auch erinnern, das es eine Einstellung in der App gibt um im Automatikmode Strom zu sparen. Irgendwas mit dauernde Luftmessung oder so. Das habe ich aus und vielleicht schaltet das auch das WLAN ab?
                          Holger
                          R 1 Antwort Letzte Antwort
                          • H holgerwolf
                            @Kludi
                            Holger
                            RobertM
                            @holgerwolf
                            Hallo, ich hab's mach deiner Anleitung hinbekommen meinen Dyson zu steuern.
                            Wie hadt du deine VIS dazu gebastelt?
                            • R RobertM
                              @holgerwolf
                              holgerwolf
                              @RobertM
                              Nix großartiges:
                              Oben die Geschwindigkeit per Popup:
                              Unten einfacher Schalter für das Schwenken.
                              • P Offline
                                Phteven
                                Dumme Frage, aber über welches Objekt steuert man denn beim HAM Adapter den Speed? "Rotation Speed" scheint bei mir die Geschwindigkeit für das Schwenken zu sein...
                                • P Offline
                                  Phteven
                                  Korrigiere, jetzt nach dem Update auf die neuste Version klappt das auch bei mir :)
                                  • NewpicselN Offline
                                    NewpicselN Offline
                                    Newpicsel
                                    schrieb am zuletzt editiert von Newpicsel
                                    Moin, kann mir einer sagen wie und womit was genau angesteuert werden muss/kann?
                                    bin hier etwas am verzweifeln! 😵
                                    habe den Dyson Pure Cool (Modell 438 (nicht der link!))
                                    An/Aus fuktioniert mit "setze Activ auf (false oder true)",
                                    Lüftergeschwindigkeit funktioniert mit "setze Rotation-Speed (Wert 10-100)",
                                    Nachtmodus funktioniert mit "setze Night-Mode On (false oder true)",
                                    Das wars auch schon was ich momentan gesteuert bekomme,
                                    den Auto Modus kann ich zB. nicht mit "setze Auto On (false oder true)" steuern, ob true oder false, bei mir ändert sich nichts am Gerät,
                                    würde gerne noch die Drehung aktivieren, aber entweder versuche ich es mit dem falschen Objekt oder benutze falsche Werte,
                                    gleiches mit der Position des Lüfters.
                                    Edit: die schaltung des Luftstromes, von vorne oder hinten, würde ich auch gerne steuern 😬
                                    Ich wäre für Hilfe sehr dankbar
                                    • NewpicselN Newpicsel
                                      Kludi
                                      @Newpicsel
                                      Das selbe problem habe ich auch.
                                      Sobalt der Dyson Pure Cool auf Auto seht kann man den nicht mehr über den HAM Adapter steuern. Ich habe leider für dich keine lösung.
                                      Ich hoffe immer noch das jemand den Dyson Adapter wieder an leben bringt.
                                      Gruß Kludi
                                        bjoernson
                                        Ich habe nun auch mein Dyson Pure Cool (TP02, älteres Modell) versucht in iobroker einzubinden.
                                        Leider habe ich auch das Problem, dass ich den Auto-Modus nicht per HAM Adapter steuern kann. Als Notlösung werde ich hier auf meine Logitech Harmony zurückgreifen, wo ich den Modus per Infrarot schalten kann. Leider habe ich damit noch keine bidirektionale Steuerung. Ich weiß also nicht, in welchem Modus sich das Gerät derzeit befindet. Einziger Hinweis wäre die Rotation, welche sich im Auto-Modus bei mir immer auf 50% befindet.
                                        Ist es bei euch auch so, dass es für den Datenpunkte Airquality nur zwei Werte gibt? Bei mir scheint "5" für gute Luftqualität zu stehen und alles was schlechter ist wird nur als "2" ausgegeben?
                                        NewpicselN 1 Antwort Letzte Antwort
                                        • B bjoernson
                                          NewpicselN Offline
                                          NewpicselN Offline
                                          Newpicsel
                                          @bjoernson
                                          Moin, Automodus ist leider wirklich ein Problem und genau diese Einstellung finde ich persönlich ziemlich wichtig, per IR habe ich es auch versucht, allerdings klappt dies auch nicht sehr zuverlässig in meinem Fall, da die Schnittstelle am Gerät stark eingeschränkt ist und durch Drehung zum Teil schwer zu erreichen ist.
                                          Zu den Werten für die Luftqualität, bei mir klappt das sehr gut, hier steht der Wert 1 für sehr gute Luft und der Wert 5 für sehr schlechte, diese werden auch normal von 1-5 durchgeschaltet.
