  4. Vis kennt keine Homematic-Geräte
    5.4k
44 Beiträge 6 Kommentatoren 7.6k Aufrufe
  • C Offline
    Communicate
    Hi, habe ne aktuelle CCU2 mit aktueller Firmware.
    Habe den rpc neu installiert und konfiguriert:
    So sieht das Log aus:
    inMem	2015-06-24 04:11:50	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435119110, from=system.adapter.admin.0, lc=1435118699
    inMem	2015-06-24 04:11:45	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435119105, from=system.adapter.admin.0, lc=1435118699
    hm-rpc-0	2015-06-24 04:10:46	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:200111","hm-rpc.0"]
    hm-rpc-0	2015-06-24 04:10:46	info	xmlrpc server is trying to listen on 192.168.178.49:200111
    hm-rpc-0	2015-06-24 04:10:45	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
    hm-rpc-0	2015-06-24 04:10:44	debug	statesDB connected
    hm-rpc-0	2015-06-24 04:10:44	debug	objectDB connected
    host-raspberrypi	2015-06-24 04:10:39	info	instance system.adapter.hm-rpc.0 started with pid 2531
    host-raspberrypi	2015-06-24 04:10:36	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
    host-raspberrypi	2015-06-24 04:10:36	info	stopInstance system.adapter.hm-rpc.0 killing pid 2530
    host-raspberrypi	2015-06-24 04:10:36	info	object change system.adapter.hm-rpc.0
    host-raspberrypi	2015-06-24 04:10:32	warn	instance system.adapter.hm-rpc.0 already running with pid 2530
    host-raspberrypi	2015-06-24 04:10:32	info	instance system.adapter.hm-rpc.0 started with pid 2530
    host-raspberrypi	2015-06-24 04:10:32	info	object change system.adapter.hm-rpc.0
    host-raspberrypi	2015-06-24 04:10:30	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
    host-raspberrypi	2015-06-24 04:10:29	info	stopInstance system.adapter.hm-rpc.0 killing pid 2529
    host-raspberrypi	2015-06-24 04:10:29	info	object change system.adapter.hm-rpc.0
    host-raspberrypi	2015-06-24 04:10:28	warn	instance system.adapter.hm-rpc.0 already running with pid 2529
    host-raspberrypi	2015-06-24 04:10:28	info	instance system.adapter.hm-rpc.0 started with pid 2529
    host-raspberrypi	2015-06-24 04:10:27	info	object change system.adapter.hm-rpc.0
    host-raspberrypi	2015-06-24 04:10:25	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
    host-raspberrypi	2015-06-24 04:10:25	info	stopInstance system.adapter.hm-rpc.0 killing pid 2528
    host-raspberrypi	2015-06-24 04:10:25	info	object change system.adapter.hm-rpc.0
    host-raspberrypi	2015-06-24 04:10:25	info	instance system.adapter.hm-rpc.0 started with pid 2528
    host-raspberrypi	2015-06-24 04:10:22	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
    host-raspberrypi	2015-06-24 04:10:22	info	stopInstance system.adapter.hm-rpc.0 killing pid 2527
    host-raspberrypi	2015-06-24 04:10:22	info	object change system.adapter.hm-rpc.0
    host-raspberrypi	2015-06-24 04:10:21	info	instance system.adapter.hm-rpc.0 started with pid 2527
    host-raspberrypi	2015-06-24 04:10:21	info	object change system.adapter.hm-rpc.0
    host-raspberrypi	2015-06-24 04:10:15	info	object change system.adapter.hm-rpc.0
    inMem	2015-06-24 04:10:05	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435119006, from=system.adapter.admin.0, lc=1435118699
    host-raspberrypi	2015-06-24 04:10:05	info	object change system.adapter.hm-rpc.0
    inMem	2015-06-24 04:09:46	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435118987, from=system.adapter.admin.0, lc=1435118699
    iobroker	2015-06-24 04:08:47	info	exit 0
    iobroker	2015-06-24 04:08:47	info	object system.adapter.hm-rpc.0 created
    host-raspberrypi	2015-06-24 04:08:47	info	object change system.adapter.hm-rpc.0
    iobroker	2015-06-24 04:08:47	info	object system.adapter.hm-rpc.0.alive created
    iobroker	2015-06-24 04:08:47	info	object system.adapter.hm-rpc.0.connected created
    iobroker	2015-06-24 04:08:47	info	object system.adapter.hm-rpc.0.memHeapUsed created
    iobroker	2015-06-24 04:08:47	info	object system.adapter.hm-rpc.0.memHeapTotal created
    iobroker	2015-06-24 04:08:47	info	object system.adapter.hm-rpc.0.memRss created
    iobroker	2015-06-24 04:08:46	info	object system.adapter.hm-rpc.0.uptime created
    iobroker	2015-06-24 04:08:46	info	object hm-rpc.0.updated created
    iobroker	2015-06-24 04:08:46	info	create instance hm-rpc
    iobroker	2015-06-24 04:08:46	info	object _design/hm-rpc created
    iobroker	2015-06-24 04:08:46	info	object hm-rpc.meta.roles created
    iobroker	2015-06-24 04:08:46	info	object hm-rpc.meta.VALUES.HM-CC-RT-DN.CLIMATECONTROL_RECEIVER.19 created
    iobroker	2015-06-24 04:08:46	info	object hm-rpc.meta.VALUES.HM-CC-RT-DN.CLIMATECONTROL_RT_RECEIVER.19 created
    iobroker	2015-06-24 04:08:46	info	object hm-rpc.meta.VALUES.HM-CC-RT-DN.CLIMATECONTROL_RT_TRANSCEIVER.19 created
    iobroker	2015-06-24 04:08:46	info	object hm-rpc.meta.VALUES.HM-CC-RT-DN.MAINTENANCE.19 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-RT-DN.REMOTECONTROL_RECEIVER.19 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-RT-DN.WEATHER_RECEIVER.19 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-RT-DN.WINDOW_SWITCH_RECEIVER.19 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.CLIMATECONTROL_REGULATOR.14 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.CLIMATECONTROL_REGULATOR.15 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.MAINTENANCE.14 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.MAINTENANCE.15 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.WEATHER.14 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.WEATHER.15 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.WINDOW_SWITCH_RECEIVER.14 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-TC.WINDOW_SWITCH_RECEIVER.15 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-VD.CLIMATECONTROL_VENT_DRIVE.8 created
    iobroker	2015-06-24 04:08:45	info	object hm-rpc.meta.VALUES.HM-CC-VD.MAINTENANCE.8 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Bl1-FM.BLIND.1 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Bl1-FM.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Dim1L-CV.DIMMER.15 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Dim1L-CV.MAINTENANCE.15 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Dim1L-Pl.DIMMER.15 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Dim1L-Pl.MAINTENANCE.15 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Dim1TPBU-FM.DIMMER.10 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Dim1TPBU-FM.MAINTENANCE.10 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Dim1TPBU-FM.VIRTUAL_DIMMER.10 created
    iobroker	2015-06-24 04:08:44	info	object hm-rpc.meta.VALUES.HM-LC-Sw1-FM.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:43	info	object hm-rpc.meta.VALUES.HM-LC-Sw1-FM.SWITCH.1 created
    iobroker	2015-06-24 04:08:43	info	object hm-rpc.meta.VALUES.HM-LC-Sw1-Pl.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:43	info	object hm-rpc.meta.VALUES.HM-LC-Sw1-Pl.SENSOR.1 created
    iobroker	2015-06-24 04:08:43	info	object hm-rpc.meta.VALUES.HM-LC-Sw2-FM.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:43	info	object hm-rpc.meta.VALUES.HM-LC-Sw2-FM.SWITCH.1 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-LC-Sw4-PCB.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-LC-Sw4-PCB.SWITCH.1 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-PBI-4-FM.KEY.9 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-PBI-4-FM.MAINTENANCE.9 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-RC-12-B.KEY.8 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-RC-12-B.MAINTENANCE.8 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-RC-P1.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-RC-P1.SHUTTER_CONTACT.1 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-RCV-50.MAINTENANCE.6 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-RCV-50.VIRTUAL_KEY.6 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-SCI-3-FM.MAINTENANCE.9 created
    iobroker	2015-06-24 04:08:42	info	object hm-rpc.meta.VALUES.HM-SCI-3-FM.SHUTTER_CONTACT.9 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-RHS.MAINTENANCE.12 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-RHS.ROTARY_HANDLE_SENSOR.12 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SC-2.MAINTENANCE.15 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SC-2.SHUTTER_CONTACT.15 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SC.MAINTENANCE.15 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SC.SHUTTER_CONTACT.15 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SD-Team.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SD-Team.SMOKE_DETECTOR_TEAM.1 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SD.MAINTENANCE.8 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sec-SD.SMOKE_DETECTOR.8 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sen-EP.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:41	info	object hm-rpc.meta.VALUES.HM-Sen-EP.SENSOR.1 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-Sen-MDIR-SM.MAINTENANCE.7 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-Sen-MDIR-SM.MAINTENANCE.9 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-Sen-MDIR-SM.MOTION_DETECTOR.7 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-Sen-MDIR-SM.MOTION_DETECTOR.9 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-Sen-RD-O.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-Sen-RD-O.RAINDETECTOR_HEAT.1 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-Sen-RD-O.RAINDETECTOR.1 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-WDS10-TH-O.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-WDS10-TH-O.WEATHER.1 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-WDS40-TH-I.MAINTENANCE.5 created
    iobroker	2015-06-24 04:08:40	info	object hm-rpc.meta.VALUES.HM-WDS40-TH-I.WEATHER.5 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HM-WS550STH-I.MAINTENANCE.1 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HM-WS550STH-I.WEATHER.1 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-IO-12-Sw7-DR.KEY.11 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-IO-12-Sw7-DR.MAINTENANCE.11 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-IO-12-Sw7-DR.SWITCH.11 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-LC-Dim1L-DR.DIMMER.11 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-LC-Dim1L-DR.KEY.11 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-LC-Dim1L-DR.MAINTENANCE.11 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-LC-Sw2-DR.KEY.12 created
    iobroker	2015-06-24 04:08:39	info	object hm-rpc.meta.VALUES.HMW-LC-Sw2-DR.MAINTENANCE.12 created
    iobroker	2015-06-24 04:08:38	info	object hm-rpc.meta.VALUES.HMW-LC-Sw2-DR.SWITCH.12 created
    iobroker	2015-06-24 04:08:38	info	object hm-rpc.meta.VALUES.HMW-RCV-50.MAINTENANCE.3 created
    iobroker	2015-06-24 04:08:38	info	object hm-rpc.meta.VALUES.HMW-RCV-50.VIRTUAL_KEY.3 created
    iobroker	2015-06-24 04:08:38	info	object system.adapter.hm-rpc created
    iobroker	2015-06-24 04:08:38	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
    iobroker	2015-06-24 04:08:38	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/13_hm-ws550sth-i_thumb.png icons/13_hm-ws550sth-i_thumb.png image/png
    iobroker	2015-06-24 04:08:38	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/14_hm-sec-key_thumb.png icons/14_hm-sec-key_thumb.png image/png
    iobroker	2015-06-24 04:08:38	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/15_hm-sec-win_thumb.png icons/15_hm-sec-win_thumb.png image/png
    iobroker	2015-06-24 04:08:38	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/16_hm-sec-sc_thumb.png icons/16_hm-sec-sc_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/17_hm-sec-rhs_thumb.png icons/17_hm-sec-rhs_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/18_hm-rc-4_thumb.png icons/18_hm-rc-4_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/19_hm-rc-12_thumb.png icons/19_hm-rc-12_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/20_hm-rc-19_thumb.png icons/20_hm-rc-19_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/21_hm-rc-p1_thumb.png icons/21_hm-rc-p1_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/22_hm-rc-sec3-b_thumb.png icons/22_hm-rc-sec3-b_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/23_hm-rc-key3-b_thumb.png icons/23_hm-rc-key3-b_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/24_hm-cen-3-1_thumb.png icons/24_hm-cen-3-1_thumb.png image/png
    iobroker	2015-06-24 04:08:37	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/25_hm-em-cmm_thumb.png icons/25_hm-em-cmm_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/26_hmw-lc-sw2-dr_thumb.png icons/26_hmw-lc-sw2-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/27_hmw-lc-bl1-dr_thumb.png icons/27_hmw-lc-bl1-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/28_hmw-lc-dim1l-dr_thumb.png icons/28_hmw-lc-dim1l-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/29_hmw-io-4-fm_thumb.png icons/29_hmw-io-4-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/2_hm-lc-dim1l-cv_thumb.png icons/2_hm-lc-dim1l-cv_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/30_hmw-io-12-sw7-dr_thumb.png icons/30_hmw-io-12-sw7-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/31_hmw-wse-sm_thumb.png icons/31_hmw-wse-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/32_hmw-wsth-sm_thumb.png icons/32_hmw-wsth-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:36	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/33_hmw-sec-tr-fm_thumb.png icons/33_hmw-sec-tr-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/34_hmw-sys-tm_thumb.png icons/34_hmw-sys-tm_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/35_hmw-sys-tm-dr_thumb.png icons/35_hmw-sys-tm-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/36_hmw-sys-ps7-dr_thumb.png icons/36_hmw-sys-ps7-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/38_hm-pbi-4-fm_thumb.png icons/38_hm-pbi-4-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/39_hm-swi-3-fm_thumb.png icons/39_hm-swi-3-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/3_hm-lc-sw4-sm_thumb.png icons/3_hm-lc-sw4-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/42_hm-cc-tc_thumb.png icons/42_hm-cc-tc_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/43_hm-cc-vd_thumb.png icons/43_hm-cc-vd_thumb.png image/png
    iobroker	2015-06-24 04:08:35	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/44_hm-em-ccm_thumb.png icons/44_hm-em-ccm_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/45_hm-lc-dim2l-sm_thumb.png icons/45_hm-lc-dim2l-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/46_hm-lc-sw4-pcb_thumb.png icons/46_hm-lc-sw4-pcb_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/47_hm-sec-tis_thumb.png icons/47_hm-sec-tis_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/48_hm-sen-ep_thumb.png icons/48_hm-sen-ep_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/49_hm-sec-wds_thumb.png icons/49_hm-sec-wds_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/4_hm-lc-sw1-fm_thumb.png icons/4_hm-lc-sw1-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/50_hm-sec-mdir_thumb.png icons/50_hm-sec-mdir_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/51_hm-sec-sd_thumb.png icons/51_hm-sec-sd_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/52_hm-sec-sd-team_thumb.png icons/52_hm-sec-sd-team_thumb.png image/png
    iobroker	2015-06-24 04:08:34	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/53_hm-sen-mdir-sm_thumb.png icons/53_hm-sen-mdir-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/54_hm-lc-ddc1-pcb_thumb.png icons/54_hm-lc-ddc1-pcb_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/54_lc-ddc1-pcb_thumb.png icons/54_lc-ddc1-pcb_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/54a_lc-ddc1_thumb.png icons/54a_lc-ddc1_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/55_hm-sec-sfa-sm_thumb.png icons/55_hm-sec-sfa-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/56_hmw-sen-sc-12-dr_thumb.png icons/56_hmw-sen-sc-12-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/57_hm-cc-scd_thumb.png icons/57_hm-cc-scd_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/58_hmw-sen-sc-12-fm_thumb.png icons/58_hmw-sen-sc-12-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/59_hmw-io-12-fm_thumb.png icons/59_hmw-io-12-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:33	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/5_hm-lc-sw2-fm_thumb.png icons/5_hm-lc-sw2-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/60_hm-ou-cf-pl_thumb.png icons/60_hm-ou-cf-pl_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/61_hm-lc-bi1-pb-fm_thumb.png icons/61_hm-lc-bi1-pb-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/61_hm-lc-bl1-pb-fm_thumb.png icons/61_hm-lc-bl1-pb-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/64_hm-lc-dim2T-sm_thumb.png icons/64_hm-lc-dim2T-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/65_hm-lc-dim1t-fm_thumb.png icons/65_hm-lc-dim1t-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/66_hm-lc-dim1t-cv_thumb.png icons/66_hm-lc-dim1t-cv_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/67_hm-sci-3-fm_thumb.png icons/67_hm-sci-3-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/68_hm-lc-sw4-dr_thumb.png icons/68_hm-lc-sw4-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:32	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/69_hm-lc-sw2-dr_thumb.png icons/69_hm-lc-sw2-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/6_hm-lc-bl1-sm_thumb.png icons/6_hm-lc-bl1-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/70_hm-pb-4dis-wm_thumb.png icons/70_hm-pb-4dis-wm_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/71_hmw-io-12-sw14-dr_thumb.png icons/71_hmw-io-12-sw14-dr_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/72_hm-rc-brc-h_thumb.png icons/72_hm-rc-brc-h_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/73_hm-atent_thumb.png icons/73_hm-atent_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/75_hm-pb-2-wm55_thumb.png icons/75_hm-pb-2-wm55_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/76_hm-lc-sw4-wm_thumb.png icons/76_hm-lc-sw4-wm_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/77_hm-lc-sw1-ba-pcb_thumb.png icons/77_hm-lc-sw1-ba-pcb_thumb.png image/png
    iobroker	2015-06-24 04:08:31	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/78_hm-ou-led16_thumb.png icons/78_hm-ou-led16_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/7_hm-lc-bl1-fm_thumb.png icons/7_hm-lc-bl1-fm_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/80_hm-sen-mdir-o_thumb.png icons/80_hm-sen-mdir-o_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/81_hm-dis-td-t_thumb.png icons/81_hm-dis-td-t_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/82_hm-sen-wa-od_thumb.png icons/82_hm-sen-wa-od_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/83_hm-cc-rt-dn_thumb.png icons/83_hm-cc-rt-dn_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/84_hm-rc-4-2_thumb.png icons/84_hm-rc-4-2_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/85_hm-rc-key4-2_thumb.png icons/85_hm-rc-key4-2_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/86_hm-pb-6-wm55_thumb.png icons/86_hm-pb-6-wm55_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/86_hm-rc-sec4-2_thumb.png icons/86_hm-rc-sec4-2_thumb.png image/png
    iobroker	2015-06-24 04:08:30	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/87_hm-sen-rd-o_thumb.png icons/87_hm-sen-rd-o_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/88_hm-lc-sw4-ba-pcb_thumb.png icons/88_hm-lc-sw4-ba-pcb_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/8_hm-lc-sw1-sm_thumb.png icons/8_hm-lc-sw1-sm_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/9_hm-ws550-us_thumb.png icons/9_hm-ws550-us_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/CCU2_thumb.png icons/CCU2_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/IP65_G201_thumb.png icons/IP65_G201_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/OM55_DimmerSwitch_thumb.png icons/OM55_DimmerSwitch_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/PushButton-2ch-wm_thumb.png icons/PushButton-2ch-wm_thumb.png image/png
    iobroker	2015-06-24 04:08:29	info	upload hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/PushButton-4ch-wm_thumb.png icons/PushButton-4ch-wm_thumb.png
    Wirkliche Besserung hat das aber leider nicht gebracht .
    Aber: Nach der Installation ist die CCU2 jetzt ermstmal nicht erreichbar. Vermutlich arbeitet Sie jetzt irgendwelche Anfragen von rpc ab, die sie auslasten. Aber sehen kann ich nichts.
    • Y Offline
      Y Offline
      ykuendig
      Bei mir war das so, dass wenn die CCU2 am Bus nicht mehr reagiert hat, dann hat das Web-Gui zwar normal funktioniert.
      Wenn ich ich aber auf der Seite Einstellungen - Systemsteuerung den Knopf Zentralen Wartung geklickt habe ist der Bildschirm nur grau geworden und, nichts geschah. Dann musste ich die CCU2 am Stecker booten.
      Gruss Yves
      • BluefoxB Offline
        BluefoxB Offline
        Was ist das?
        > info xmlrpc -> 192.168.178.101:2001 init ["[http://192.168.178.49](http://192.168.178.49):~~[color=#FF0000]~~200111","hm-rpc.0"]
        • C Offline
          Communicate
          Den Port habe ich nicht erfasst. Ist das ein Bug? Wo kann ich das einstellen?
          • Y Offline
            Y Offline
            ykuendig
            Bei der Instanz des 'hm-rpc' auf diesen kleinen Notizblock klicken.
            Gruss Yves
            • BluefoxB Offline
              BluefoxB Offline
              Das ist ein Zeichen, dass es schon 2 andere hm-rpc Instanzen auf dem Rechner laufen. (Und ein Bug bei getPort :lol: )
              Kannst du dein Rechner neu starten?
              • C Offline
                Communicate
                Hmm. Da steht aber eigentlich Port 2001. So wie auf dem Screenshot in einen meiner vorherigen posts. Ich habe da auch nichts verändert.
                Hast du noch ne idee?
                • C Offline
                  Communicate
                  Neustart mache Ich heute abend. Bis später :-)
                  • C Offline
                    Communicate
                    So, Neustart durchgeführt.
                    Jetzt kann ich weder das Admin noch das bis webinterdace mehr aufrufen. Per ssh komme ich aber ohne Probleme auf den raspi. Was kann ich tun!
                    1917_sonos_ger_te_in_verbindung_mit_alexa_und_iobroker_steuern.docx
                    • BluefoxB Offline
                      BluefoxB Offline
                      @Communicate:
                      Jetzt kann ich weder das Admin noch das bis webinterdace mehr aufrufen. Per ssh komme ich aber ohne Probleme auf den raspi. Was kann ich tun! `
                      Checken ob ioBroker überhaupt läuft:
                      ps -A | grep io
                      • C Offline
                        Communicate
                        das kommt daraus:
                        pi@raspberrypi ~ $ ps -A | grep io
                           17 ?        00:00:00 bioset
                           20 ?        00:00:00 rpciod
                           23 ?        00:00:00 nfsiod
                           35 ?        00:00:00 DWC Notificatio
                         2048 ?        00:00:52 io.js-controlle
                         2191 ?        00:00:51 io.admin.0
                         2309 ?        00:00:15 io.web.0
                         2356 ?        00:01:49 io.hm-rega.0
                         2357 ?        00:00:10 io.hm-rpc.0
                        EDIT:
                        Ein Versuch iobroker zu starten sagt folgendes:
                        pi@raspberrypi /opt/iobroker $ sudo ./iobroker start
                        ioBroker controller daemon already running. PID: 2048
                        • C Offline
                          Communicate
                          Update:
                          Jetzt kann ich Admin wieder aufrufen, warum auch immer…
                          So sieht jetzt das Log aus:
                          hm-rega-0	2015-06-24 17:56:17	warn	Pending request for more than 54675000 ms
                          hm-rega-0	2015-06-24 17:56:16	warn	Pending request for more than 54650000 ms
                          hm-rega-0	2015-06-24 17:56:16	warn	Pending request for more than 54625000 ms
                          hm-rega-0	2015-06-24 17:56:15	warn	Pending request for more than 54600000 ms
                          hm-rega-0	2015-06-24 17:56:14	warn	Pending request for more than 54575000 ms
                          hm-rega-0	2015-06-24 17:56:14	warn	Pending request for more than 54550000 ms
                          hm-rega-0	2015-06-24 17:56:13	warn	Pending request for more than 54525000 ms
                          hm-rega-0	2015-06-24 17:56:13	warn	Pending request for more than 54500000 ms
                          hm-rega-0	2015-06-24 17:56:12	warn	Pending request for more than 54475000 ms
                          hm-rega-0	2015-06-24 17:56:11	warn	Pending request for more than 54450000 ms
                          hm-rpc-0	2015-06-24 17:56:11	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:20011","hm-rpc.0"]
                          hm-rpc-0	2015-06-24 17:56:11	info	xmlrpc server is trying to listen on 192.168.178.49:20011
                          hm-rega-0	2015-06-24 17:56:11	warn	Pending request for more than 54425000 ms
                          hm-rega-0	2015-06-24 17:56:10	warn	Pending request for more than 54400000 ms
                          hm-rpc-0	2015-06-24 17:56:10	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                          hm-rega-0	2015-06-24 17:56:10	warn	Pending request for more than 54375000 ms
                          hm-rpc-0	2015-06-24 17:56:09	debug	statesDB connected
                          hm-rpc-0	2015-06-24 17:56:09	debug	objectDB connected
                          hm-rega-0	2015-06-24 17:56:09	warn	Pending request for more than 54350000 ms
                          hm-rega-0	2015-06-24 17:56:08	warn	Pending request for more than 54325000 ms
                          hm-rega-0	2015-06-24 17:56:08	warn	Pending request for more than 54300000 ms
                          hm-rega-0	2015-06-24 17:56:07	warn	Pending request for more than 54275000 ms
                          hm-rega-0	2015-06-24 17:56:06	warn	Pending request for more than 54250000 ms
                          hm-rega-0	2015-06-24 17:56:06	warn	Pending request for more than 54225000 ms
                          hm-rega-0	2015-06-24 17:56:05	warn	Pending request for more than 54200000 ms
                          hm-rega-0	2015-06-24 17:56:05	warn	Pending request for more than 54175000 ms
                          hm-rega-0	2015-06-24 17:56:04	warn	Pending request for more than 54150000 ms
                          hm-rega-0	2015-06-24 17:56:03	warn	Pending request for more than 54125000 ms
                          host-raspberrypi	2015-06-24 17:56:03	info	instance system.adapter.hm-rpc.0 started with pid 2459
                          host-raspberrypi	2015-06-24 17:56:03	info	object change system.adapter.hm-rpc.0
                          hm-rega-0	2015-06-24 17:56:03	warn	Pending request for more than 54100000 ms
                          host-raspberrypi	2015-06-24 17:51:05	info	instance system.adapter.hm-rpc.0 started with pid 2454
                          host-raspberrypi	2015-06-24 17:51:05	info	object change system.adapter.hm-rpc.0
                          hm-rega-0	2015-06-24 17:51:05	warn	Pending request for more than 42525000 ms
                          hm-rega-0	2015-06-24 17:51:05	warn	Pending request for more than 42500000 ms
                          hm-rega-0	2015-06-24 17:51:04	warn	Pending request for more than 42475000 ms
                          hm-rega-0	2015-06-24 17:51:03	warn	Pending request for more than 42450000 ms
                          hm-rega-0	2015-06-24 17:51:03	warn	Pending request for more than 42425000 ms
                          hm-rega-0	2015-06-24 17:51:02	warn	Pending request for more than 42400000 ms
                          hm-rega-0	2015-06-24 17:51:01	warn	Pending request for more than 42375000 ms
                          hm-rega-0	2015-06-24 17:51:01	warn	Pending request for more than 42350000 ms
                          hm-rega-0	2015-06-24 17:51:00	warn	Pending request for more than 42325000 ms
                          hm-rega-0	2015-06-24 17:50:59	warn	Pending request for more than 42300000 ms
                          hm-rega-0	2015-06-24 17:50:59	warn	Pending request for more than 42275000 ms
                          hm-rega-0	2015-06-24 17:50:58	warn	Pending request for more than 42250000 ms
                          hm-rega-0	2015-06-24 17:50:57	warn	Pending request for more than 42225000 ms
                          hm-rega-0	2015-06-24 17:50:57	warn	Pending request for more than 42200000 ms
                          hm-rega-0	2015-06-24 17:50:56	warn	Pending request for more than 42175000 ms
                          hm-rega-0	2015-06-24 17:50:55	warn	Pending request for more than 42150000 ms
                          hm-rega-0	2015-06-24 17:50:55	warn	Pending request for more than 42125000 ms
                          hm-rega-0	2015-06-24 17:50:54	warn	Pending request for more than 42100000 ms
                          hm-rpc-0	2015-06-24 17:50:53	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:2001",""]
                          host-raspberrypi	2015-06-24 17:50:53	info	stopInstance system.adapter.hm-rpc.0 killing pid 2357
                          host-raspberrypi	2015-06-24 17:50:53	info	object change system.adapter.hm-rpc.0
                            @Communicate:
                            das kommt daraus:
                            EDIT:
                            Das ist klar; das wurde dir ja auch schon oben gesagt:
                            somit läuft der controller, außerdem hm-rpc, hm-rega und der web-Adapter.
                            Was hattest du da gemacht?
                            Am rpc-Adapter wurde etwas geändert,
                            • C Offline
                              Communicate
                              ` > Was hattest du da gemacht?
                              CODE: ALLES AUSWÄHLEN
                              Am rpc-Adapter wurde etwas geändert, `
                              Den RPC Adapter einmal aus und dann wieder an gemacht…
                              Hier mal das log nach einem Neustart mit anschliessendem Start der RPC Instanz (aber ohne Init, CheckInit, etc.):
                              hm-rpc-0	2015-06-24 18:06:53	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              hm-rpc-0	2015-06-24 18:06:52	debug	statesDB connected
                              hm-rpc-0	2015-06-24 18:06:52	debug	objectDB connected
                              host-raspberrypi	2015-06-24 18:06:48	warn	instance system.adapter.hm-rpc.0 already running with pid 2412
                              host-raspberrypi	2015-06-24 18:06:47	info	instance system.adapter.hm-rpc.0 started with pid 2412
                              host-raspberrypi	2015-06-24 18:06:46	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:06:45	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
                              host-raspberrypi	2015-06-24 18:06:45	info	stopInstance system.adapter.hm-rpc.0 killing pid 2411
                              host-raspberrypi	2015-06-24 18:06:45	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:06:43	warn	instance system.adapter.hm-rpc.0 already running with pid 2411
                              host-raspberrypi	2015-06-24 18:06:40	info	instance system.adapter.hm-rpc.0 started with pid 2411
                              host-raspberrypi	2015-06-24 18:06:40	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
                              host-raspberrypi	2015-06-24 18:06:40	info	stopInstance system.adapter.hm-rpc.0 killing pid 2410
                              host-raspberrypi	2015-06-24 18:06:40	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:06:39	info	instance system.adapter.hm-rpc.0 started with pid 2410
                              host-raspberrypi	2015-06-24 18:06:39	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:06:38	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
                              host-raspberrypi	2015-06-24 18:06:38	info	stopInstance system.adapter.hm-rpc.0 killing pid 2409
                              host-raspberrypi	2015-06-24 18:06:38	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:06:36	info	instance system.adapter.hm-rpc.0 started with pid 2409
                              host-raspberrypi	2015-06-24 18:06:36	info	object change system.adapter.hm-rpc.0
                              Und dann hier das Log, nachdem ich Init? aktiviert habe:
                              hm-rpc-0	2015-06-24 18:09:10	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:2001","hm-rpc.0"]
                              hm-rpc-0	2015-06-24 18:09:10	info	xmlrpc server is trying to listen on 192.168.178.49:2001
                              hm-rpc-0	2015-06-24 18:09:09	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              hm-rpc-0	2015-06-24 18:09:08	debug	statesDB connected
                              hm-rpc-0	2015-06-24 18:09:08	debug	objectDB connected
                              host-raspberrypi	2015-06-24 18:09:02	warn	instance system.adapter.hm-rpc.0 already running with pid 2417
                              host-raspberrypi	2015-06-24 18:09:02	info	instance system.adapter.hm-rpc.0 started with pid 2417
                              host-raspberrypi	2015-06-24 18:09:02	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:09:00	info	stopInstance system.adapter.hm-rpc.0 killing pid 2412
                              host-raspberrypi	2015-06-24 18:09:00	info	object change system.adapter.hm-rpc.0
                              inMem	2015-06-24 18:08:52	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435169332, from=system.adapter.admin.0, lc=1435169162
                              und hier nachdem ich Init aktiviert habe:
                              hm-rpc-0	2015-06-24 18:11:56	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:20011","hm-rpc.0"]
                              hm-rpc-0	2015-06-24 18:11:56	info	xmlrpc server is trying to listen on 192.168.178.49:20011
                              hm-rpc-0	2015-06-24 18:11:55	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              hm-rpc-0	2015-06-24 18:11:54	debug	statesDB connected
                              hm-rpc-0	2015-06-24 18:11:54	debug	objectDB connected
                              host-raspberrypi	2015-06-24 18:11:49	info	instance system.adapter.hm-rpc.0 started with pid 2427
                              host-raspberrypi	2015-06-24 18:10:55	info	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
                              hm-rpc-0	2015-06-24 18:10:55	error	already running
                              hm-rpc-0	2015-06-24 18:10:54	debug	statesDB connected
                              hm-rpc-0	2015-06-24 18:10:54	debug	objectDB connected
                              host-raspberrypi	2015-06-24 18:10:48	info	instance system.adapter.hm-rpc.0 started with pid 2422
                              host-raspberrypi	2015-06-24 18:10:46	info	stopInstance system.adapter.hm-rpc.0 killing pid 2417
                              host-raspberrypi	2015-06-24 18:10:46	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:09:00	info	instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
                              inMem	2015-06-24 18:10:46	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435169446, from=system.adapter.admin.0, lc=1435169162
                              hm-rpc-0	2015-06-24 18:10:46	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:2001",""]
                              Und hier nachdem ich "Initiiere Geräte neu" aktiviert habe:
                              hm-rpc-0	2015-06-24 18:13:49	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:200111","hm-rpc.0"]
                              hm-rpc-0	2015-06-24 18:13:49	info	xmlrpc server is trying to listen on 192.168.178.49:200111
                              hm-rpc-0	2015-06-24 18:13:48	info	starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                              hm-rpc-0	2015-06-24 18:13:47	debug	statesDB connected
                              hm-rpc-0	2015-06-24 18:13:47	debug	objectDB connected
                              host-raspberrypi	2015-06-24 18:13:41	info	instance system.adapter.hm-rpc.0 started with pid 2438
                              host-raspberrypi	2015-06-24 18:13:39	info	instance system.adapter.hm-rpc.0 terminated with code 143 ()
                              host-raspberrypi	2015-06-24 18:13:38	info	stopInstance system.adapter.hm-rpc.0 killing pid 2437
                              host-raspberrypi	2015-06-24 18:13:38	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:13:37	info	instance system.adapter.hm-rpc.0 started with pid 2437
                              host-raspberrypi	2015-06-24 18:13:37	info	object change system.adapter.hm-rpc.0
                              host-raspberrypi	2015-06-24 18:13:07	info	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
                              hm-rpc-0	2015-06-24 18:13:07	error	already running
                              hm-rpc-0	2015-06-24 18:13:06	debug	statesDB connected
                              hm-rpc-0	2015-06-24 18:13:06	debug	objectDB connected
                              host-raspberrypi	2015-06-24 18:13:01	info	instance system.adapter.hm-rpc.0 started with pid 2432
                              inMem	2015-06-24 18:12:58	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435169579, from=system.adapter.admin.0, lc=1435169162
                              hm-rpc-0	2015-06-24 18:12:58	info	xmlrpc -> 192.168.178.101:2001 init ["http://192.168.178.49:2001",""]
                              host-raspberrypi	2015-06-24 18:12:58	info	stopInstance system.adapter.hm-rpc.0 killing pid 2427
                              host-raspberrypi	2015-06-24 18:12:58	info	object change system.adapter.hm-rpc.0
                              inMem	2015-06-24 18:12:50	debug	message *.logging system.adapter.admin.0.logging val=true, ack=true, ts=1435169571, from=system.adapter.admin.0, lc=1435169162
                              ein ps -A | grep io ergibt:
                              ` > pi@raspberrypi ~ $ ps -A | grep io
                              2051 ? 00:00:32 io.js-controlle
                              2118 ? 00:00:35 io.admin.0
                              2252 ? 00:00:12 io.web.0
                              2363 ? 00:00:11 io.hm-rega.0
                              2417 ? 00:00:07 io.hm-rpc.0
                              2427 ? 00:00:06 io.hm-rpc.0
                              2438 ? 00:00:06 io.hm-rpc.0 `
                                Jetzt laufen drei rpc Instanzen und dier alte Fehler ist wieder das:
                                • C Offline
                                  Communicate
                                  Haltet mich für total bekloppt, aber nachdem ich die CCU2 neugestartet habe, geht es jetzt. Komisch :roll:
                                  Einziger Fehler, der aber nicht so schlimm ist:
                                  Wenn ich bei den Instanzen auf VIS klicke ruft er "undefined://192.168.178.49:8082/vis/edit.html auf statt http:// …
                                    @Communicate:
                                    Haltet mich für total bekloppt, aber nachdem ich die CCU2 neugestartet habe, geht es jetzt. Komisch `
                                    Hoffentlich war es das, immerhin meldete sich iobroker, dass er seit zigtausend ms auf eine Reaktion der CCU wartet.
                                    @Communicate:
                                    Wenn ich bei den Instanzen auf VIS klicke ruft er "undefined://192.168.178.49:8082/vis/edit.html auf statt http:// … `
                                    der bug ist bekannt.
                                    • Y Offline
                                      Y Offline
                                      ykuendig
                                      Die 'pending requests' sind ein Problem, welches wir im Zusammenhang mit Tests des iobroker.occ Adapters festgestellt hatten. Das war auch dort ein Zeichen, dass die CCU zerschossen war. Hast Du auch occ installiert?
                                      Das andere Problem sind die zum hängenden Instanzen. Ich habe das manchmal bei Javascript und versuche da noch die Zusammenhänge zu verstehen. Aber hilft nur entweder einzeln abschiessen mit kill oder reboot…
                                      144_tradfri.txt
                                      Gruss Yves
