  4. BLE Adapter
BLE Adapter
bluetooth setcap fehler gelb s
57 Beiträge 12 Kommentatoren 12.4k Aufrufe 10 Beobachtet
  • L Offline
    Leon111
    Hallo, beim updaten bzw. instalieren von BLE-Adapter bekomme ich die Meldungen:
    $ ./iobroker add ble --host raspberrypi
    NPM version: 6.4.1
    npm install iobroker.ble@0.7.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm
    notice created a lockfile as package-lock.json. You should commit this file.
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security/pam_appl.h>
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp
    ERR! build error
    gyp
    ERR!
    stack
    Error: make failed with exit code: 2gyp
    ERR!
    stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack at emitTwo (events.js:126:13)
    gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.14.79-v7+
    gyp ERR!
    command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v8.15.0
    gyp ERR! node-gyp -v v3.8.0
    gyp
    ERR! not ok
    node-pre-gyp
    WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    In file included from ../src/helpers.h:3:0, from ../src/node_usb.h:21,
    from ../src/transfer.cc:1:
    ../src/transfer.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Transfer_constructor(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/transfer.cc:25:12: internal compiler error: Speicherzugriffsfehler
    NAN_METHOD(Transfer_constructor) {
    ../../nan/nan.h:1413:33: note: in definition of macro ‘NAN_METHOD’
    Nan::NAN_METHOD_RETURN_TYPE name(Nan::NAN_METHOD_ARGS_TYPE info)
    Please submit a full bug report,with preprocessed source if appropriate.
    See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
    make: *** [Release/obj.target/usb_bindings/src/transfer.o] Fehler 1
    gyp
    ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack
    at emitTwo (events.js:126:13)gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    gyp ERR! System Linux 4.14.79-v7+gyp
    ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"gyp ERR! cwd /opt/iobroker/node_modules/usb
    gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
    node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
    node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
    node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.14.79-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
    node-pre-gyp ERR! node -v v8.15.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    node-pre-gyp
    node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v57-linux-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:252:95: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
    Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
    In file included from ../src/BluetoothHciSocket.cpp:8:0:
    ../node_modules/nan/nan.h:980:46: note: declared here
    NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:283:93: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::bindControl()’:../src/BluetoothHciSocket.cpp:201:6: internal compiler error: Speicherzugriffsfehler
    void BluetoothHciSocket::bindControl() {
    make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
    gyp
    ERR! build error
    gyp ERR!
    stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
    ERR! System Linux 4.14.79-v7+gyp ERR! command
    "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" "--module_name=binding" "--module_path=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    gyp
    ERR! node-gyp -v v3.8.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node --module_name=binding --module_path=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
    node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR!
    stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)node-pre-gyp ERR! System Linux 4.14.79-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    node-pre-gyp ERR! node-pre-gyp -v v0.12.0
    npm WARN JSON.parse Failed to parse jsonnpm WARN JSON.parse Unexpected token
    npm WARN JSON.parse in JSON at position 14 while parsing '{
    npm WARN JSON.parse "_argsb: [
    npm WARN JSON.parse [
    npm WARN JSON.parse {
    npm WARN JSON.parse $ "ra'
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuild
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: node-pre-gyp install --fallback-to-build
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 install: node-pre-gyp install --fallback-to-build
    host.raspberrypi install adapter ble
    got /opt/iobroker/node_modules/iobroker.ble/admin
    upload [7] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/words.js words.js application/javascript
    upload [6] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
    upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
    upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index.html index.html text/html
    upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.map build/index.map application/json
    upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
    upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
    upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
    host.raspberrypi object system.adapter.ble created
    host.raspberrypi create instance ble
    host.raspberrypi object ble.0.options.allowNewDevices created
    host.raspberrypi object ble.0.options created
    host.raspberrypi object ble.0.info.driverState created
    host.raspberrypi object ble.0.info.connection created
    host.raspberrypi object ble.0.info created
    host.raspberrypi object system.adapter.ble.0.outputCount created
    host.raspberrypi object system.adapter.ble.0.inputCount created
    host.raspberrypi object system.adapter.ble.0.uptime created
    host.raspberrypi object system.adapter.ble.0.memRss created
    host.raspberrypi object system.adapter.ble.0.memHeapTotal created
    host.raspberrypi object system.adapter.ble.0.memHeapUsed created
    host.raspberrypi object system.adapter.ble.0.cputime created
    host.raspberrypi object system.adapter.ble.0.cpu created
    host.raspberrypi object system.adapter.ble.0.connected created
    host.raspberrypi object system.adapter.ble.0.alive created
    host.raspberrypi object system.adapter.ble.0 created
    process exited with code 0
    dannach bleib der Instanz rot.
    In den Einstalungen habe ich:
    -Gerät auswählen: 0 ( das interne Bluetooth ist aktiviert)
    RSSI Update-Intervall [ms]: 1000
    -Aktive Plugins: xiaomi
    Was mach ich falsch?
    Was fehlt noch?
    Hatte bis jetz die Version 0.5. irgendwas und es hat funktioniert
    Gerne würde ich aud die Erfahrung der Profis zurückgreifen und für Tips und Hilfe bin ich sehr dankbar
    Leon
    • L Leon111
      NPM version: 6.4.1
      npm
      gyp
      ERR! build error
      gyp
      ERR!
      stack
      ERR!
      gyp ERR!
      gyp
      ERR! not ok
      node-pre-gyp
      gyp
      ERR! build error
      gyp ERR! stack
      gyp ERR! not ok
      node-pre-gyp
      gyp
      ERR! build error
      gyp ERR!
      gyp
      node-pre-gyp ERR!
      Was fehlt noch?
      Leon
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Endlich mal jemand mit einem vollständigen Log der Installation, danke!
      Es scheint als wird bluetooth-hci-socket nicht installiert, obwohl das Modul zwingend notwendig ist. Hast du alle Abhängigkeiten vorher installiert?
      @Leon111 sagte in BLE Adapter:
      Und der Log hier wäre auch interessant, wobei ich vermute, dass bluetooth-hci-socket nicht gefunden wird.
      • L Offline
        Leon111
        Hallo, beim instalieren von den Bibliotheken kamm sowas raus:
        root@raspberrypi:~# sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
        libcap2-bin ist schon die neueste Version (1:2.25-1).
        libudev-dev ist schon die neueste Version (232-25+deb9u8).
        bluetooth ist schon die neueste Version (5.43-2+rpt2+deb9u2).
        bluez ist schon die neueste Version (5.43-2+rpt2+deb9u2).
        libbluetooth-dev ist schon die neueste Version (5.43-2+rpt2+deb9u2).
        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 8 nicht aktualisiert.
        1 nicht vollständig installiert oder entfernt.
        Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
        Möchten Sie fortfahren? [J/n]
        .....danach kamm eine liste mit allen instalierten Geräten mit IP-Nummer und dazugehörigen Adaptern:
        ein kurzer Ausschnitt:
        "stem.adapter.sonoff.0","lc":1540932395609,"expire":18509},"system.adapter.sonoff.0.connected":{"val":true,"ack":true,"ts":1541058948611,"q":0,"from":"system.adapter.sonoff.0","lc":1540932179195,"expire":23508},"system.adapter.sonoff.0.memRss":{"val":62.73,"ack":true,"ts":1541058948612,"q":0,"from":"system.adapter.sonoff.0","lc":1541058948612},"system.adapter.sonoff.0.memHeapTotal":{"val":25.03,"ack":true,"ts":1541058948618,"q":0,"from":"system.adapter.sonoff.0","lc":1541045056274},"system.adapter.sonoff.0.memHeapUsed":{"val":15.93,"ack":true,"ts":1541058948620,"q":0,"from":"system.adapter.sonoff.0","lc":1541058948620},"system.adapter.sonoff.0.uptime":{"val":485971,"ack":true,"ts":1541058948621,"q":0,"from":"system.adapter.sonoff.0","lc":1541058948621},"system.adapter.sonoff.0.inputCount":{"val":0,"ack":true,"ts":1541058948622,"q":0,"from":"system.adapter.sonoff.0","lc":1541058933614},"system.adapter.sonoff.0.outputCount":{"val":10,"ack":true,"ts":1541058948623,"q":0,"from":"system.adapter.sonoff.0","lc":1541058933614},"sonoff.0.info.connection":{"val":"Sonoff-Basic-2,Sonoff-Basic-4,Schlafzimmer-Licht,Küchenlicht,Sonoff-Basic-3,Sonoff-Basic-"
        die war sehr lang.
        danach kamm so eine meldung:
        SyntaxError: EOF while scanning triple-quoted string literal
        Sorry: ValueError: source code string cannot contain null bytes
        dpkg: Fehler beim Bearbeiten des Paketes python3.5 (--configure):
        Unterprozess installiertes post-installation-Skript gab den Fehlerwert 1 zurück
        Fehler traten auf beim Bearbeiten von:
        python3.5
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        W: Operation wurde unterbrochen, bevor sie beendet werden konnte.
        root@raspberrypi:~#
        Es wurde also nichts instaliert und dem entsprechen ist der BLE-Adapter immer nochauf rot.
        Eine Idee was ich da noch machen kann?
        • L Leon111
          die war sehr lang.
          python3.5
          root@raspberrypi:~#
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @Leon111
          Das Sonoff-Zeug hat mit BLE nix zu tun. Ich kann mir auch gerade nicht erklären, warum das ausgegeben werden sollte, wenn du auf der Konsole etwas mit apt-get installierst?!
          Wenn der BLE-Adapter rot ist, dann steht auch im ioBroker-Log etwas in rot mit Präfix ble.0. Die Info bräuchte ich um zu helfen.
          • Lenny.CBL Offline
            Lenny.CBL Offline
            Lenny.CB
            scheinbar gibt es was neues von Xiaomi. Ist ein BT- Hygro/Temp/Uhr-Modul mit E-Ink Display.
            Gefällt mir ausgesprochen gut, da jetzt auch mit Uhr.
            Link zu Aliexspress
            Hat den schon wer? Funktioniert der bereits mit dem Ble-Adapter?
            • Lenny.CBL Lenny.CB
              Link zu Aliexspress
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @Lenny-CB sagte in BLE Adapter:
              Ich vermute nicht, dazu brauche ich die Mac-Adress-Präfixe. Außer die sind unverändert.
              Lenny.CBL 2 Antworten Letzte Antwort
              • AlCalzoneA AlCalzone
                Lenny.CBL Offline
                Lenny.CBL Offline
                Lenny.CB
                @AlCalzone sagte in BLE Adapter:
                Einer ist grade auf dem Weg zu mir. Wenn er da ist, kann ich dir das benötigte schicken... :-)
                  Lenny.CBL Offline
                  Lenny.CBL Offline
                  Lenny.CB
                  schrieb am zuletzt editiert von Lenny.CB
                  heut kam das gute Stück. @AlCalzone willst mal schauen ob du das intergrieren kannst? 😀
                  wenn ich beim ble-Adapter neue Devices erlaube kommt Folgendes:
                  value vom "fe95" ist "70205b04ba613081c8593f09041002d500"
                  die App nRF Connect habe ich auch, falls du da was brauchst.
                  AlCalzoneA E 2 Antworten Letzte Antwort
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    0.7.3 ist auf NPM :)
                    Lenny.CBL 1 Antwort Letzte Antwort
                      Lenny.CBL Offline
                      Lenny.CBL Offline
                      Lenny.CB
                      @AlCalzone vielen Dank schon mal!
                      schaut erst einmal gut aus.
                      Wie bekommt man raus was da noch alles kommt? Batterie und Uhr wäre gut. Uhr eigentlich nur zum stellen.
                      im nRF Connect wird noch ne Menge mehr angezeigt, leider kann ich es nicht zuordnen.
                      Gibts ne Doku wie man sowas "entschlüsselt"?
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        Als Advertisement oder Characteristics? Letzteres benötigt eine aktive Verbindung, die der Adapter derzeit nicht unterstützt.
                        Screenshot vielleicht? ;)
                          Lenny.CBL Offline
                          Lenny.CBL Offline
                          Lenny.CB
                          @AlCalzone
                          hatte ich schon geahnt, dass das nicht so einfach wird.
                          Sind jede Mengen Characteristics drin.
                          nRF Connect, 2019-05-04
                          LYWSD02 (3F:59:C8:81:30:61)
                          V 09:57:40.327 Connecting to 3F:59:C8:81:30:61...
                          D 09:57:40.328 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M or LE 2M)
                          D 09:57:42.859 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
                          I 09:57:42.859 Connected to 3F:59:C8:81:30:61
                          D 09:57:42.932 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
                          V 09:57:42.933 Discovering services...
                          D 09:57:42.933 gatt.discoverServices()
                          I 09:57:43.506 Connection parameters updated (interval: 35.0ms, latency: 0, timeout: 3000ms)
                          I 09:57:43.823 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
                          D 09:57:44.694 [Callback] Services discovered with status: 0
                          I 09:57:44.695 Services discovered
                          V 09:57:44.736 Generic Access (0x1800)
                          • Device Name [R] (0x2A00)
                          • Appearance [R] (0x2A01)
                            Generic Attribute (0x1801)
                          • Service Changed [I R] (0x2A05)
                            Client Characteristic Configuration (0x2902)
                            Device Information (0x180A)
                          • Manufacturer Name String [R] (0x2A29)
                          • Model Number String [R] (0x2A24)
                          • Serial Number String [R] (0x2A25)
                          • Hardware Revision String [R] (0x2A27)
                          • Firmware Revision String [R] (0x2A26)
                          • Software Revision String [R] (0x2A28)
                          • System ID [R] (0x2A23)
                            Unknown Service (0000fef5-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [R W] (8082caa8-41a6-4021-91c6-56f9b954cc34)
                          • Unknown Characteristic [R W] (724249f0-5ec3-4b5f-8804-42345af08651)
                          • Unknown Characteristic [R] (6c53db25-47a1-45fe-a022-7c92fb334fd4)
                          • Unknown Characteristic [R W] (9d84b9a3-000c-49d8-9183-855b673fda31)
                          • Unknown Characteristic [R W WNR] (457871e8-d516-4ca1-9116-57d0b17b9cb2)
                          • Unknown Characteristic [N R] (5f78df94-798c-46f5-990a-b3eb6a065c88)
                          • Unknown Characteristic [R] (64b4e8b5-0de5-401b-a21d-acc8db3b913a)
                          • Unknown Characteristic [R] (42c3dfdd-77be-4d9c-8454-8f875267fb3b)
                          • Unknown Characteristic [R] (b7de1eea-823d-43bb-a3af-c4903dfce23c)
                            Unknown Service (ebe0ccb0-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [R W] (ebe0ccb7-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [R] (ebe0ccb9-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [R W] (ebe0ccba-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [R] (ebe0ccbb-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [N R] (ebe0ccbc-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [R W] (ebe0ccbe-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [N R] (ebe0ccc1-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [W] (ebe0ccc2-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [R W] (ebe0ccc3-7a0a-4b0c-8a1a-6ff2997da3a6)
                          • Unknown Characteristic [R] (ebe0ccc4-7a0a-4b0c-8a1a-6ff2997da3a6)
                            Unknown Service (2b43ccc0-2506-415c-a16c-e4cc5f52ef78)
                          • Unknown Characteristic [R] (2b43ccc1-2506-415c-a16c-e4cc5f52ef78)
                          • Unknown Characteristic [N W WNR] (2b43ccc2-2506-415c-a16c-e4cc5f52ef78)
                          • Unknown Characteristic [W WNR] (2b43ccc3-2506-415c-a16c-e4cc5f52ef78)
                          • Unknown Characteristic [W WNR] (2b43ccc4-2506-415c-a16c-e4cc5f52ef78)
                            Unknown Service (aaaaaaa0-aaaa-aaaa-aaaa-aaaaaaaaaaaa)
                          • Unknown Characteristic [R W WNR] (aaaaaaa1-aaaa-aaaa-aaaa-aaaaaaaaaaaa)
                            Unknown Service (fafafa00-fafa-fafa-fafa-fafafafafafa)
                          • Unknown Characteristic [R W] (fafafa01-fafa-fafa-fafa-fafafafafafa)
                            Unknown Service (0000fe95-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [N W] (00000001-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [R] (00000002-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [R] (00000004-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [N W] (00000005-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [W] (00000010-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [R W] (00000013-0000-1000-8000-00805f9b34fb)
                          • Unknown Characteristic [R] (00000014-0000-1000-8000-00805f9b34fb)
                            Unknown Descriptor (fafafa01-fafa-fafa-fafa-fafafafafafa)
                            D 09:57:44.737 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
                            D 09:57:44.738 gatt.setCharacteristicNotification(5f78df94-798c-46f5-990a-b3eb6a065c88, true)
                            D 09:57:44.739 gatt.setCharacteristicNotification(ebe0ccbc-7a0a-4b0c-8a1a-6ff2997da3a6, true)
                            D 09:57:44.740 gatt.setCharacteristicNotification(ebe0ccc1-7a0a-4b0c-8a1a-6ff2997da3a6, true)
                            D 09:57:44.742 gatt.setCharacteristicNotification(2b43ccc2-2506-415c-a16c-e4cc5f52ef78, true)
                            D 09:57:44.744 gatt.setCharacteristicNotification(00000001-0000-1000-8000-00805f9b34fb, true)
                            D 09:57:44.746 gatt.setCharacteristicNotification(00000005-0000-1000-8000-00805f9b34fb, true)
                            I 09:57:44.814 Connection parameters updated (interval: 35.0ms, latency: 0, timeout: 3000ms)
                          Nur mal so, wie kann ich sehen was da übermittelt wird?
                          Sonst noch kurz zum Display:
                          • cooles Teil, schaut sehr wertig aus
                          • zeigt mit dem Adapter Temp/Hum/RSSI an
                          • Uhr kommt nur aus der APP (kann nicht gestellt werden - jedenfalls noch nicht raus bekommen wie)
                          • Gerät kann man nur bei Serverauswahl "China" hinzu fügen
                          • Uhr geht eine Stunde nach. Vermutlich wegen "China-Server"
                            @AlCalzone
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            Keine Ahnung 🤷
                              adarof
                              Hallo
                              Meine LED Panels scheinen mir auch BLE zu machen. Dump von nRF Connect unten.
                              Gäbe es eine Möglichkeit die im BLE-Adapter auch bekannt zu machen?
                              Ich könnte dann ja erstmal nur lesen (wenn ich rausbekomme, wie die READ-Services zu dekodieren sind - ich denke dadrüber bekomme ich die RGB Werte sowie Helligkeitswerte) und später vielleicht durch ausprobieren auch die WRITE-Services (auch wenn der Adapter gerade noch garkein Write unterstützt).
                              Gruss -
                              telink_mesh1 (A4:C1:38:28:A4:0D)
                              V	07:56:30.372	Connecting to A4:C1:38:28:A4:0D...
                              D	07:56:30.373	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) (hidden)
                              D	07:56:30.765	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
                              I	07:56:30.766	Connected to A4:C1:38:28:A4:0D
                              D	07:56:30.788	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
                              V	07:56:30.834	Discovering services...
                              D	07:56:30.834	gatt.discoverServices()
                              D	07:56:31.613	[Callback] Services discovered with status: 0
                              I	07:56:31.613	Services discovered
                              V	07:56:31.645	Generic Access (0x1800)
                              - Device Name [R] (0x2A00)
                               Characteristic User Description (0x2901)
                              - Appearance [R] (0x2A01)
                              - Firmware Revision String [R] (0x2A26)
                              - Manufacturer Name String [R] (0x2A29)
                              - Model Number String [R] (0x2A24)
                              - Hardware Revision String [R] (0x2A27)
                              Unknown Service (00010203-0405-0607-0809-0a0b0c0d1910)
                              - Unknown Characteristic [N R W] (00010203-0405-0607-0809-0a0b0c0d1911)
                              - Unknown Characteristic [R W WNR] (00010203-0405-0607-0809-0a0b0c0d1912)
                              - Unknown Characteristic [R WNR] (00010203-0405-0607-0809-0a0b0c0d1913)
                              - Unknown Characteristic [R W] (00010203-0405-0607-0809-0a0b0c0d1914)
                              V	07:56:54.271	Beginning reliable write...
                              D	07:56:54.271	gatt.beginReliableWrite()
                              V	07:57:06.019	Reading remote RSSI...
                              D	07:57:06.019	gatt.readRemoteRssi()
                              I	07:57:06.042	Remote RSSI received: -69 dBm
                              V	07:57:09.808	Reading all characteristics...
                              V	07:57:09.809	Reading characteristic 00002a00-0000-1000-8000-00805f9b34fb
                              D	07:57:09.809	gatt.readCharacteristic(00002a00-0000-1000-8000-00805f9b34fb)
                              I	07:57:09.869	Read Response received from 00002a00-0000-1000-8000-00805f9b34fb, value: (0x) 54-65-6C-69-6E-6B-20-74-4C-69-67-68-74-00
                              A	07:57:09.869	"Telink tLight " received
                              V	07:57:09.888	Reading characteristic 00002a01-0000-1000-8000-00805f9b34fb
                              D	07:57:09.888	gatt.readCharacteristic(00002a01-0000-1000-8000-00805f9b34fb)
                              I	07:57:09.953	Read Response received from 00002a01-0000-1000-8000-00805f9b34fb, value: (0x) 00-00
                              A	07:57:09.953	"[0] Unknown" received
                              V	07:57:09.973	Reading characteristic 00002a26-0000-1000-8000-00805f9b34fb
                              D	07:57:09.973	gatt.readCharacteristic(00002a26-0000-1000-8000-00805f9b34fb)
                              I	07:57:10.143	Read Response received from 00002a26-0000-1000-8000-00805f9b34fb, value: (0x) 56-31-2E-36-00-00-00-00-00-00-00-00
                              A	07:57:10.143	"V1.6        " received
                              V	07:57:10.160	Reading characteristic 00002a29-0000-1000-8000-00805f9b34fb
                              D	07:57:10.160	gatt.readCharacteristic(00002a29-0000-1000-8000-00805f9b34fb)
                              I	07:57:10.262	Read Response received from 00002a29-0000-1000-8000-00805f9b34fb, value: (0x) 74-65-6C-69-6E-6B-5F-6D-65-73-68-31-00
                              A	07:57:10.262	"telink_mesh1 " received
                              V	07:57:10.275	Reading characteristic 00002a24-0000-1000-8000-00805f9b34fb
                              D	07:57:10.275	gatt.readCharacteristic(00002a24-0000-1000-8000-00805f9b34fb)
                              I	07:57:10.342	Read Response received from 00002a24-0000-1000-8000-00805f9b34fb, value: (0x) 6D-6F-64-65-6C-20-69-64-20-31-32-33-00
                              A	07:57:10.342	"model id 123 " received
                              V	07:57:10.358	Reading characteristic 00002a27-0000-1000-8000-00805f9b34fb
                              D	07:57:10.358	gatt.readCharacteristic(00002a27-0000-1000-8000-00805f9b34fb)
                              I	07:57:10.422	Read Response received from 00002a27-0000-1000-8000-00805f9b34fb, value: (0x) 22-22-22-22, """"""
                              A	07:57:10.422	"""""" received
                              V	07:57:10.435	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1911
                              D	07:57:10.435	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1911)
                              I	07:57:10.544	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1911, value: (0x) 00
                              A	07:57:10.544	"(0x) 00" received
                              V	07:57:10.566	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1912
                              D	07:57:10.566	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1912)
                              I	07:57:10.622	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1912, value: (0x) 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                              A	07:57:10.622	"(0x) 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00" received
                              V	07:57:10.648	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1913
                              D	07:57:10.648	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1913)
                              I	07:57:10.743	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1913, value: (0x) E0-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
                              A	07:57:10.743	"(0x) E0-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00" received
                              V	07:57:10.755	Reading characteristic 00010203-0405-0607-0809-0a0b0c0d1914
                              D	07:57:10.755	gatt.readCharacteristic(00010203-0405-0607-0809-0a0b0c0d1914)
                              I	07:57:10.822	Read Response received from 00010203-0405-0607-0809-0a0b0c0d1914, value: (0x) 00-72-B4-14-60-83-FE-C3-5A-4D-A8-5D-CB-2D-1A-88-BF
                              A	07:57:10.822	"(0x) 00-72-B4-14-60-83-FE-C3-5A-4D-A8-5D-CB-2D-1A-88-BF" received
                              V	07:57:10.835	10 characteristics read
                              D	07:58:43.455	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
                              E	07:58:43.460	Error 8 (0x8): GATT CONN TIMEOUT
                              I	07:58:43.460	Disconnected
                              D	07:58:43.650	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
                              • C Offline
                                Cliff
                                Hallo und Moin,
                                ich hadere schon länger mit dem BLE- Adapter, bzw. der Funktionalität.
                                Installiert ist BLE in der aktuellsten Version. Der Adapter ist grün, meldet 'Powered' und so weit alles OK.
                                Leider erkennt er mein Flower- Care nicht. Per App, bzw. mit nRF ist das Gerät sofort zu entdecken.
                                Um es ganz verrückt zu machen: Der Adapter hat das Gerät EINMALIG erkannt, die Objekte angelegt und mit Daten gefüllt. Seither ist schweigen im Walde, bzw. ich bekomme keine Daten mehr...
                                • C Cliff
                                  Hallo und Moin,
                                  Jan1
                                  @Cliff
                                  Auf was läuft Dein IOBroker? Bei mir kackt ab und an mal das BT Modul meines BeeLink ab und da hilft einmal runter fahren und spannungsfrei, danach ist das BT Modul wieder online und der BLE Adapter läuft. Die Sensoren dürfen auch nicht über BT mit der APP verbunden sein, sonst gibts auch Probleme.
                                  • C Offline
                                    Cliff
                                    schrieb am zuletzt editiert von Cliff
                                    hatte ich vergessen zu schreiben:
                                    Es läuft auf einem Rock64.
                                    Andere Devices werden wie verrückt erkannt (Allerdings dann nur RSSI).
                                    Habe schon mehrere Bluetooth Dongle probiert. Ohne Änderung.
                                    Wie schon geschrieben:
                                    Der Adapter läuft grundsätzlich ohne Probleme (Grün und so...).
                                    In wie fern nicht mit der App verbunden?
                                    ich verwende Flower Care. Der Sensor ist nicht mit dem Handy gekoppelt. Die App im Regelfall geschlossen.
                                    • C Cliff
                                      Jan1
                                      @Cliff
                                      Hm, welche FW Version läuft denn auf dem Sensor? Da die ja aber auch schon mal funktioniert hatten, dürfte es daran aber auch nicht liegen.
                                      Hast Du ne grafische Oberfläche für Dein Linux? Wenn ich Probleme habe, geh ich auf den BeeLink unter Debian Buster direkt rein und schau ob unter BT mein Adapter noch erkannt wird, wenn dem nicht so ist, ist mein Workaround das was ich oben geschrieben hatte.
                                      Sonst fällt mir dazu nichts mehr ein.
                                      • C Offline
                                        Cliff
                                        Firmware ist die Aktuellste (3.2.1).
                                        Der Flowercare Sensor wird z.B. von nRf sofort erkannt.
                                        Habe leider nur Armbian drauf laufen.
                                        Der Bluetoothadapter wird einwandfrei vom System erkannt (HciTool/ Adapter ist ja auch 'grün').
                                        • C Cliff
                                          Jan1
                                          @Cliff
                                          Aber in Reichweite sind die Sensoren? Bei mir sind 6m schon grenzwertig.
