  4. Icon sets
    5.5k
Icon sets
23 Beiträge 9 Kommentatoren 12.3k Aufrufe
    Hallo Bluefox,
    ich habe in der Konsole folgende Meldung bekommen:
    ! npm http 200 https://registry.npmjs.org/iobroker.icons-addictive-flavour-png/-/iobroker.icons-addictive-flavour-png-0.1.0.tgz npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/body-parser requires qs@'2.2.4' but will load npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/qs, npm WARN unmet dependency which is version 2.2.3 npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/expres/node_modules/connect/node_modules/body-parser requires raw-body@'1.3.0' but will load npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/raw-body, npm WARN unmet dependency which is version 1.3.2 npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/cookie-parser requires cookie-signature@'1.0.6' but will load npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/cookie-signature, npm WARN unmet dependency which is version 1.0.5 npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/serve-static requires send@'0.9.3' but will load npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/send, npm WARN unmet dependency which is version 0.9.2 !
    Im heutigen log sehe ich diese Fehlermeldungen nicht!
    • BluefoxB Offline
      BluefoxB Offline
      Falls jemand gutes Iconset kennt, kann ich denn auch anbinden. Muss aber passende Lizenz haben.
        mctom
        die Installation lief bei mir sauber durch.
        In der Adapter Übersicht werden die Icons auch angezeigt.
        In VIS kann ich Sie leider nicht auswählen, da ich auf diesen Ordner nicht zugreifen kann.
        Mach ich hier etwas falsch ?
        Michael
        • BluefoxB Offline
          BluefoxB Offline
          @mctom:
          filename="2015-05-25 14_01_13-ioBroker.vis.png" index="0">~~
          Michael `
          Welche hast du installiert?
          • F Offline
            Fugazzy
            Stimmt, die werden auch bei mir nicht angezeigt - egal welche installiert sind
            Gruss Lutz
              mctom
              Ich habe die mfd svg installiert.
              • BluefoxB Offline
                BluefoxB Offline
                Ok. Ein Schritt fehlt noch.
                Nachdem als "npm install …" ausgeführt ist. Muss man in admin auf "Update" drücken und dann die neue Adapter-Instanzen erzeugen.
                  mctom
                  Danke für den Hinweis.
                  Hat alles funktioniert.
                    SchuetzeSchulz
                    Bei mir werden nach npm install iobroker.icons-mfd-png und klicken auf "Update" keine Icons in der Adapterübersicht angezeigt :(
                      Hast du auf den button "Instanz hinzufügen" = (+) geklickt?
                        SchuetzeSchulz
                        Kann ich ja erst nicht, weil bei mir in der Adapter-Liste die Icons wie im Screenshot von Bluefox gar nicht auftauchen.
                        Auch nach Dienstneustart nicht…
                        • BluefoxB Offline
                          BluefoxB Offline
                          In welchem Verzeichnis hast du "npm install …" geschrieben?
                            SchuetzeSchulz
                            Im Installationsverzeichnis C:\ioBroker. Aber es passiert auch nicht viel, siehe Screenshot:
                            • BluefoxB Offline
                              BluefoxB Offline
                              @SchuetzeSchulz:
                              filename="Unbenannt.png" index="0">~~ `
                              Passiert nicht viel, weil alles schon da ist.
                              Hast du Verzeichnis C:\ioBroker\node_modules\iobroker.icons-mfd-png und auch io-package.json dadrin?
                                Wenn schon alles da ist kommt Fehlermeldung, dass diese Adapter keine mehrfachinstanzen zulässt.
                                Zumindest auf Linux.
                                Gesendet von meinem Cynus T7 mit Tapatalk
                                  SchuetzeSchulz
                                  @Bluefox:
                                  Hast du Verzeichnis C:\ioBroker\node_modules\iobroker.icons-mfd-png und auch io-package.json dadrin? `
                                  Hallo Bluefox,
                                  ja, der Ordner iobroker.icons-mfd-png ist vorhanden, die JSON ist auch drin.
                                  Habe jetzt alles nochmal manuell gelöscht und neu installiert, nun erscheinen die Icons.
                                  Hat sich also erledigt.
                                  Vielen Dank für die Hilfe.
                                  • Alex1808A Offline
                                    Alex1808A Offline
                                    Alex1808
                                    Bei icons-addatctive-flavour, kategorie "Social Media" werden icons nicht richtig erkannt, Rest ist ok.. :?
                                    ![](</s><URL url=)http://i.imgur.com/0invaN1.png" />
                                    • F Offline
                                      Fitti
                                      wo ist denn bitte dieser "Dateimanager"? Weder in der Anleitung noch in diesem Forum darüber was gefunden, wie man den wo startet.
                                      Danke euch.
                                      Fitti
                                      "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
                                      Plural von Status ist auch Status!
                                        Dieser Dateimanager öffnet sich, wenn du in der rechten Einstellungssidebar des Widgets auf den button gehst, wo du ein icon aussuchen kannst.
                                        Der Punkt heißt z.b. "Aktivbild".
                                        Bin nicht am PC, kann daher keinen Screenshot machen.
                                        Gesendet von meinem LIFETAB_S785X mit Tapatalk
                                        ~~![](</s><URL url=)<link_text text="http://images.tapatalk-cdn.com/15/07/19 ... db3bc6.jpg">http://images.tapatalk-cdn.com/15/07/19/7eebfb64f80a2ae261daf1e794db3bc6.jpg</link_text>" />
                                        Klappt notfalls auch mit dem tablet, wenn man noch ein paar apps nach lädt~~
                                        • F Offline
                                          Fitti
                                          Okay - Danke. Solch ein Widget hatte ich noch nicht probiert.
