  4. BLE und Radar2 rot
    1.0k
    6.1k
BLE und Radar2 rot
bluetoothble adapterradar2radar adapterradar2 adapter
24 Beiträge 2 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • MathiasJM Offline
    MathiasJM Offline
    MathiasJ
    schrieb am zuletzt editiert von MathiasJ
    Hier die Fehler.....
    t import Const
    ImportError: No module named compiler.ast
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.4.132-1072-rockchip-ayufan-ga1d27dba5a2e
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/deasync
    gyp ERR! node -v v8.15.1
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    Build failed
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! deasync@0.1.14 install: `node ./build.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the deasync@0.1.14 install script.
    npm ERR!     /home/rock64/.npm/_logs/2019-03-06T15_19_26_939Z-debug.log
    Mir vergeht langsam die Lust........
    nun werde ich die nächste Baustelle hier posten.......
    Gruß,
    Mathias
    IObroker auf dem NUC als VM.
    • MathiasJM MathiasJ
      t import Const
      gyp ERR! not ok
      Build failed
      npm ERR! errno 1
      npm ERR!
      Gruß,
      Mathias
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @MathiasJ Das scheint mir oben abgeschnitten. Ist das wirklich alles?
      • MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        Ja, das sind alle Fehler.
        Davor kamen Warnungen.
        Gruß,
        Mathias
        • MathiasJM Offline
          MathiasJM Offline
          MathiasJ
          Soll ich vllt ein anderes OS installieren?
          Mit dem Neuaufbau habe ich ja schon meine Erhafrung. Ich könnte von srmbian nach Ubuntu 18.04 für Rock64 wechseln.
          Vllt gehts dann.
          Mathias
          • AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            In Zukunft wäre der komplette Output interessant, zumal die Meldung mittem im Wort abgeschnitten scheint. In deinem Fall scheint das Problem an einer falschen Python-Variante zu liegen.
            apt-get install python-dev
            und dann die Reparaturinstallation von BLE nochmal probieren - das gleiche könnte für Radar2 nötig sein.
            • MathiasJM Offline
              MathiasJM Offline
              MathiasJ
              Reperaturinstallation?
              Du meinst, den Adapter kpl. neu installieren?
                AlCalzoneA Offline
                AlCalzone
                Nee das selbe wie oben:
                @AlCalzone sagte in BLE und Radar2 rot:
                Gehe mal in den Ordner /opt/iobroker/node_modules/iobroker.ble und führe npm install aus. Sollten hierbei Fehler auftreten, bitte posten.
                • MathiasJM Offline
                  MathiasJM Offline
                  MathiasJ
                  so, jetzt ist wenigstens Radar2 grün.
                  BLE wird heruntergefahren, wie vorher.
                  Ich habe keine Fehlermeldungen bei der Reperaturinstallation von Radar2 und BLE.
                  Nur steige ich da irgendwie nicht durch:
                  USB-Dongle auf Bus2-Gerät2
                  USB-Dongle auf Bus3-Gerät2,
                  Was gebe ich jetzt in die Adapter ein?
                  Edit
                  es werde alle G-Tags erkannt.
                  Nur BLE spinnt herum und Zigbee läßt sich auch nicht installieren.
                  Edit2
                  Radar2 ist alle paar Sekunden offline.
                  Im Log bekomme ich die Meldung:
                  host.iobroker-rock64	2019-03-06 18:00:06.258	info	Restart adapter system.adapter.radar2.0 because enabled
                  host.iobroker-rock64	2019-03-06 18:00:06.257	error	instance system.adapter.radar2.0 terminated with code 7 (Adapter already running)
                  ich werde IObroker morgen neu aufsetzen, dieses mal mit Ubuntu 18.04 für Rock64.
                  Vllt habe ich da mehr Glück. es läuft bei dieser Installation zu vel schief.
                  Gruß,
                  Mathias
                  AlCalzoneA 2 Antworten Letzte Antwort
                    Edit
                    Edit2
                    Gruß,
                    Mathias
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @MathiasJ sagte in BLE und Radar2 rot:
                    Steht irgendwas im Log?
                      Edit
                      Edit2
                      Gruß,
                      Mathias
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      Kein Grund direkt neu aufzusetzen - da läuft noch ein Adapter-Prozess, den ioBroker nicht beendet bekommt. Starte die Kiste mal sauber neu.
                      Bzgl. BLE: Bitte mal von Github aktualisieren, dann sehen wir vllt auch warum der nicht startet.
                      MathiasJM 1 Antwort Letzte Antwort
                      • AlCalzoneA AlCalzone
                        MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        Ich bin Dir noch etwas schuldig:
                        Hier erst mal der Log vom BLE:
                        host.iobroker-rock64	2019-03-06 18:02:43.167	error	instance system.adapter.ble.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                        Mehr kommt leider nicht, bis ich BLE neu gestartet habe.
                        Keine 10 Sekunden später kommt die gleiche Meldung usw.
                        Ach ja, Deine Antwort hat sich mit meiner überschnitten. ich habe in Edit2 noch was gepostet.
                        BLE im Terminal oder im Admin neu installieren? Github geht ja auch im Admin.
                        Ich habe nur an einer Neuinstallation des Systems gedacht, weil wir nicht wissen, was sonst noch falsch läuft.
                        Gruß,
                        Mathias
                          Gruß,
                          Mathias
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          Admin bitte.
                          Kannst aber nicht sicher sein, dass du alle Probleme schon gefunden hast ;)
                          • MathiasJM Offline
                            MathiasJM Offline
                            MathiasJ
                            BLE und weitere Adapter im Admin über Github neu installiert, weil die Config-Seite bei anderen Adaptern nicht da war.
                            Nun sind sie da.
                            BLE wird immer noch heruntergefahren und wartet darauf, daß sie von mir neu gestartet wurde. bringt nur nochts. nach ein par sekunden wird BLE wieder heruntergefahren usw.
                            Hier ist der Log der Installation:
                             npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev
                            npm ERR! code EACCES
                            npm ERR! errno -13
                            npm ERR! syscall access
                            npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev'
                            npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev'
                            npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev\'',
                            npm ERR!   errno: -13,
                            npm ERR!   code: 'EACCES',
                            npm ERR!   syscall: 'access',
                            npm ERR!   path: '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/node_modules/abbrev' }
                            npm ERR!
                            npm ERR! The operation was rejected by your operating system.
                            npm ERR! It is likely you do not have the permissions to access this file as the current user
                            npm ERR!
                            npm ERR! If you believe this might be a permissions issue, please double-check the
                            npm ERR! permissions of the file and its containing directories, or try running
                            npm ERR! the command again as root/Administrator (though this is not recommended).
                            Der Adapter wurde erfolgreich installiert. Vllt deinstalliere ich die Instanz, mache einen Neustart und installiere sie mal neu?
                            Radar2 läuft jetzt durch, seit dem ich die Kiste neu gestartet habe.
                              Nun sind sie da.
                              npm ERR! errno -13
                              npm ERR!
                              npm ERR!
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @MathiasJ Ja da fehlt das Bluetooth-Modul, das wegen fehlendem Schreibzugriff nicht installiert werden kann. Bist du auf der Kommandozeile üblicherweise als root unterwegs oder als ein anderer User? Falls ersteres, könnte
                              chown -R iobroker:iobroker /opt/iobroker
                              helfen.
                              • MathiasJM Offline
                                MathiasJM Offline
                                MathiasJ
                                danke.....
                                ich muß IObroker komplett neu aufsetzen.
                                Ich wollte gerade die SD-karte sichern.
                                Jetzt ist IObroker gar nicht mehr erreichbar.
                                Also von vorne.... 😢
                                • MathiasJM Offline
                                  MathiasJM Offline
                                  MathiasJ
                                  so.....
                                  nachdem ich alles neu aufgesetzt und USB-Dongles getauscht habe
                                  BLE läuft........
                                  Radar2 läuft.......
                                  Er war nicht nur ein Software- sondern auch ein Hardwareproblem :(
                                  Einer der beiden Dongles wurde nicht erkannt. um genau zu sein der Logilink.
                                  Jetzt laufen beide Adapter mit Speedlink Dongles.
                                  Vielen lieben Dank, @AlCalzone
                                  Gruß,
                                  Mathias
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Yay! 👏
                                      Yay! 👏
                                      MathiasJM Offline
                                      MathiasJM Offline
                                      MathiasJ
                                      @AlCalzone hat auch lange genug gedauert.........
                                      Nochmals:
                                      Dankeschön!!!
                                      bleibt nur noch eine Frage:
                                      Wenn ich alle Objekte von BLE lösche, holt sich BLE dann alles neu?
                                      Ich möchte sicher gehen, daß auch alles erkannt wurde. Die Objekte kommen vom Backup.
                                      Gruß,
                                      Mathias
                                        Nochmals:
                                        Dankeschön!!!
                                        Gruß,
                                        Mathias
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        BLE schreibt grundsätzlich erst mal alles auf, was es hört. Also ruhig löschen, das kann nur etwas Zeit in Anspruch nehmen bis alle Daten wieder da sind.
                                          MathiasJM Offline
                                          MathiasJM Offline
                                          MathiasJ
                                          dankeschön,
                                          wird dann gemacht.
                                          ich habe ihn erst mal heruntergefahren und warte auf ein emmc2USB-Adapter und Kühlkörper.
                                          In der Zwischenzeit schreibe ich alles auf, was ich so wissen muß.
