  4. Zigbee-Adapter
Zigbee-Adapter
xiaomizigbee-adapterzigbee-stick
12 Beiträge 4 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • MathiasJM Offline
    MathiasJM Offline
    MathiasJ
    schrieb am zuletzt editiert von MathiasJ
    Zigbee-Adapter läßt sich in meiner neuen IObroker-Installation nicht hinzufügen:
    code_Fertig mit Fehler: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
    $ ./iobroker add zigbee  --host iobroker-rock64
    NPM version: 6.4.1
    npm install iobroker.zigbee@0.9.2 --production --save --prefix "/opt/iobroker" (System call)
    Traceback (most recent call last):  File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
        import gyp
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 8, in <module>
        import gyp.input
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>
        from compiler.ast import Const
    ImportError: No module named compiler.ast
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.4.132-1072-rockchip-ayufan-ga1d27dba5a2e
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    gyp ERR! node -v v8.15.1
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    prebuild-install
     WARN install No prebuilt binaries found (target=8.15.1 runtime=node arch=arm64 libc= platform=linux)
        import gyp  File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 8, in <module>
        import gyp.input
    gyp
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    gyp ERR! stack
         at emitTwo (events.js:126:13)gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp
     ERR! System Linux 4.4.132-1072-rockchip-ayufan-ga1d27dba5a2egyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    gyp ERR! node -v v8.15.1gyp ERR! node-gyp -v v3.8.0
    gyp
    ERR! not ok
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 (node_modules/diskusage):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 install: `node-gyp rebuild`
    npm
     WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm ERR! @serialport/bindings@2.0.7 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR! Exit status 1
    npm ERR! npm ERR! Failed at the @serialport/bindings@2.0.7 install script.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-03-06T15_11_06_002Z-debug.log
    host.iobroker-rock64 create instance zigbee
    ERROR: host.iobroker-rock64 error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
    ERROR: process exited with code 20text
    Gruß,
    Mathias
    IObroker auf dem NUC als VM.
    • arteckA Offline
      arteckA Offline
      arteck
      mach mal auf der console aus dem /opt/iobroker
      npm install https://github.com/arteck/ioBroker.zigbee
      • MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        Dankeschön, hat auch nichts gebracht.
        ich weiß aber woran es lag.
        Es war wohl eine falsche Python-Version installiert.
        @Alcalzone war so frei, mir deshalb zu helfen.
        da ich IObroker sowieso neu aufsetzen mußte, habe ich gleich die richtige Version mit installiert.
        Nun lief der Test erfolgreich, ein paar Router habe auch geflasht.
        Jetzt heißt es warten, bis der Kühlkörper hier ist, damit ich den Rock64 in den regulären Betrieb nehmen kann,
        ganz ohne Multihost.
        Gruß,
        Mathias
          Smarthome WEG3
          schrieb am zuletzt editiert von Smarthome WEG3
          hallo ich habe diesen Fehler bei Zigbee Adapter
          instance system.adapter.zigbee.0 terminated with code 1 ()
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Module._compile (module.js:653:30)
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd/lib/components/controller.js:23:16)
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at require (internal/module.js:11:18)
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Module.require (module.js:597:17)
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Module.load (module.js:566:32)
          host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
          host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd/lib/config/nv_start_options.js:5:22)
          host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: TypeError: Cannot read property 'nvItemIdsUint8' of undefined
          host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: ^
          host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: NVID8 = ZSC.SAPI.nvItemIdsUint8,
          host.raspberrypi 2019-03-08 16:03:00.676 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd/lib/config/nv_start_options.js:5
          Kannst du mir Weiterhelfen??
          MathiasJM 1 Antwort Letzte Antwort
          • S Smarthome WEG3
            MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            Und ich kann keine Geräte anlernen.
            Es kommt immer die gleiche Meldung:
            Error...timeout 10000ms......??undefinied
            Mathias
            • MathiasJM MathiasJ
              Mathias
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @MathiasJ
              Welche Geräte ?
              Wenn xiaomi Sensoren - hälst du sie währen des pairings “wach” ?
              A.
              • MathiasJM Offline
                MathiasJM Offline
                MathiasJ
                Ich lerne sie so an, als ob ich sie am Gateway anlernen würde.
                Also 3 mal Taste drücken, warten.....
                Ach da fällt mir ein, kann man auch einen Router an einem Router anlernen?
                Gruß,
                Mathias
                  Gruß,
                  Mathias
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @MathiasJ
                  Bei mir persönlich funktioniert das anlernen am besten am coordinator - prinzipiell sollte es auch an einem roter gehen.
                  Nun zum anmelden - leider hast du meine Frage nach der Art der Geräte nicht beantwortet - deswegen nur der link mit der Anweisung zum anlernen von Geräten: link - das anlernen am Stick geht anders als an der xiaomi Bridge. Auf der Seite werden verschiedene Geräte und die dazu gehörigen Hinweise zum pairen aufgelistet.
                  A.
                  P.s. nicht wundern das diese Seite von zigbee2mqtt ist - iobroker.zigbee benutzt den gleichen Unterbau, deswegen gelten die gleichen Regeln.
                  • MathiasJM Offline
                    MathiasJM Offline
                    MathiasJ
                    Danke erst mal.
                    Nein der Link wundert mich nicht.
                    Von der Seite habe ich auch die Firmware.
                    Ich habe nur Aqara Sensoren, die ich nach dieser Anleitung versucht habe, anzulernen.
                    Dann die Meldung.
                    Teilweise wird auch nur bis auf 0 runtergezählt. Aber es passiert nichts.
                    Was mich wundert, ein wireless Switch ließ sich problemlos einbinden.
                    Dann gingen die Probleme los. Im Moment ist ein Gerät angelernt.
                    Gruß,
                    Mathias
                    P.S. ich habe:
                    5 Bewegungsmelder,
                    4 wireless Switches,
                    2 Beschleunigungssensoren
                    1 Wassersensor
                    2 Temperatursensoren
                    4 MIJA Rauchmelder
                      Danke erst mal.
                      Dann die Meldung.
                      Gruß,
                      Mathias
                      P.S. ich habe:
                      5 Bewegungsmelder,
                      1 Wassersensor
                      4 MIJA Rauchmelder
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @MathiasJ
                      Ich bekomme meine Sensoren eigentlich immer Geparde, wenn ich sie während des pairings regelmäßig alle 1-2 sekunden triggered, I.e. kurz auf den Knopf drücke mit dem ich sie in den pairing mode bekomme.
                      A.
                      • MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        Das werde ich heute dann versuchen.
                        Wenn ich das Teil ganz nah zum coordinator bringe, ist das ja kein Problem.
                        Ich will aber von Gaeway zum Stick wechseln.
                        Da sind sie teilweise schon eingebaut
                        Das ist mein Problem
                          MathiasJM Offline
                          MathiasJM Offline
                          MathiasJ
                          also,
                          Zigbee kann ich mit dem CC2531 vergessen!
                          ich habe da gefühlte 1000 Abbrüche,
                          Router bringen da nicht wirklich was.
                          ich versuche mein Glück mit dem CC2530 als Coordinator, einen weiteren als Router.
                          Zuerst habe ich alles wieder auf dem Gateway angelernt, damit es überhaupt läuft.
                          Gruß,
                          Mathias
