<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zigbee-Adapter]]></title><description><![CDATA[<p dir="auto">Zigbee-Adapter läßt sich in meiner neuen IObroker-Installation nicht hinzufügen:</p>
<pre><code>code_Fertig mit Fehler: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
$ ./iobroker add zigbee  --host iobroker-rock64
NPM version: 6.4.1
npm install iobroker.zigbee@0.9.2 --production --save --prefix "/opt/iobroker" (System call)
Traceback (most recent call last):  File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in &lt;module&gt;
    import gyp
  File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 8, in &lt;module&gt;
    import gyp.input
  File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in &lt;module&gt;
    from compiler.ast import Const
ImportError: No module named compiler.ast
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
gyp ERR! stack     at emitTwo (events.js:126:13)
gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
gyp ERR! System Linux 4.4.132-1072-rockchip-ayufan-ga1d27dba5a2e
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /opt/iobroker/node_modules/diskusage
gyp ERR! node -v v8.15.1
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
prebuild-install
 WARN install No prebuilt binaries found (target=8.15.1 runtime=node arch=arm64 libc= platform=linux)
    import gyp  File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 8, in &lt;module&gt;
    import gyp.input
gyp
gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
gyp ERR! stack
     at emitTwo (events.js:126:13)gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
gyp
 ERR! System Linux 4.4.132-1072-rockchip-ayufan-ga1d27dba5a2egyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
gyp ERR! node -v v8.15.1gyp ERR! node-gyp -v v3.8.0
gyp
ERR! not ok
npm
 WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 (node_modules/diskusage):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 install: `node-gyp rebuild`
npm
 WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
npm
 ERR! code ELIFECYCLEnpm ERR! errno 1
npm ERR! @serialport/bindings@2.0.7 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR! Exit status 1
npm ERR! npm ERR! Failed at the @serialport/bindings@2.0.7 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-03-06T15_11_06_002Z-debug.log
host.iobroker-rock64 create instance zigbee
ERROR: host.iobroker-rock64 error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
ERROR: process exited with code 20text
</code></pre>
<p dir="auto">Gruß,<br />
Mathias</p>
]]></description><link>https://forum.iobroker.net/topic/20668/zigbee-adapter</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 13:04:29 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/20668.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Mar 2019 15:25:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zigbee-Adapter on Sat, 23 Mar 2019 08:34:27 GMT]]></title><description><![CDATA[<p dir="auto">also,<br />
Zigbee kann ich mit dem CC2531 vergessen!<br />
ich habe da gefühlte 1000 Abbrüche,<br />
Router bringen da nicht wirklich was.<br />
ich versuche mein Glück mit dem CC2530 als Coordinator, einen weiteren als Router.<br />
Zuerst habe ich alles wieder auf dem Gateway angelernt, damit es überhaupt läuft.</p>
Mathias</p>
]]></description><link>https://forum.iobroker.net/post/245587</link><guid isPermaLink="true">https://forum.iobroker.net/post/245587</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Sat, 23 Mar 2019 08:34:27 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Sat, 09 Mar 2019 00:27:31 GMT]]></title><description><![CDATA[<p dir="auto">Das werde ich heute dann versuchen.<br />
Wenn ich das Teil ganz nah zum coordinator bringe, ist das ja kein Problem.<br />
Ich will aber von Gaeway zum Stick wechseln.<br />
Da sind sie teilweise schon eingebaut<br />
Das ist mein Problem</p>
]]></description><link>https://forum.iobroker.net/post/238355</link><guid isPermaLink="true">https://forum.iobroker.net/post/238355</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Sat, 09 Mar 2019 00:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 22:49:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathiasj" aria-label="Profile: MathiasJ">@<bdi>MathiasJ</bdi></a><br />
Ich bekomme meine Sensoren eigentlich immer Geparde, wenn ich sie während des pairings regelmäßig alle 1-2 sekunden triggered, I.e. kurz auf den Knopf drücke mit dem ich sie in den pairing mode bekomme.</p>
<p dir="auto">A.</p>
]]></description><link>https://forum.iobroker.net/post/238340</link><guid isPermaLink="true">https://forum.iobroker.net/post/238340</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Fri, 08 Mar 2019 22:49:06 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 20:10:35 GMT]]></title><description><![CDATA[<p dir="auto">Danke erst mal.<br />
Nein der Link wundert mich nicht.<br />
Von der Seite habe ich auch die Firmware.<br />
Ich habe nur Aqara Sensoren, die ich nach dieser Anleitung versucht habe, anzulernen.<br />
Dann die Meldung.<br />
Teilweise wird auch nur bis auf 0 runtergezählt. Aber es passiert nichts.<br />
Was mich wundert, ein wireless Switch ließ sich problemlos einbinden.<br />
Dann gingen die Probleme los. Im Moment ist ein Gerät angelernt.<br />
Gruß,<br />
Mathias<br />
P.S. ich habe:<br />
5 Bewegungsmelder,<br />
4 wireless Switches,<br />
2 Beschleunigungssensoren<br />
1 Wassersensor<br />
2 Temperatursensoren<br />
4 MIJA Rauchmelder</p>
]]></description><link>https://forum.iobroker.net/post/238279</link><guid isPermaLink="true">https://forum.iobroker.net/post/238279</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Fri, 08 Mar 2019 20:10:35 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 19:38:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathiasj" aria-label="Profile: MathiasJ">@<bdi>MathiasJ</bdi></a><br />
Bei mir persönlich funktioniert das anlernen am besten am coordinator - prinzipiell sollte es auch an einem roter gehen.</p>
<p dir="auto">Nun zum anmelden - leider hast du meine Frage nach der Art der Geräte nicht beantwortet - deswegen nur der link mit der Anweisung zum anlernen von Geräten: <a href="https://www.zigbee2mqtt.io/getting_started/pairing_devices.html" rel="nofollow ugc">link</a> - das anlernen am Stick geht anders als an der xiaomi Bridge. Auf der Seite werden verschiedene Geräte und die dazu gehörigen Hinweise zum pairen aufgelistet.</p>
<p dir="auto">A.<br />
P.s. nicht wundern das diese Seite von zigbee2mqtt ist - iobroker.zigbee benutzt den gleichen Unterbau, deswegen gelten die gleichen Regeln.</p>
]]></description><link>https://forum.iobroker.net/post/238270</link><guid isPermaLink="true">https://forum.iobroker.net/post/238270</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Fri, 08 Mar 2019 19:38:57 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 18:57:37 GMT]]></title><description><![CDATA[<p dir="auto">Ich lerne sie so an, als ob ich sie am Gateway anlernen würde.<br />
Also 3 mal Taste drücken, warten.....<br />
Ach da fällt mir ein, kann man auch einen Router an einem Router anlernen?<br />
Gruß,<br />
Mathias</p>
]]></description><link>https://forum.iobroker.net/post/238251</link><guid isPermaLink="true">https://forum.iobroker.net/post/238251</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Fri, 08 Mar 2019 18:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 18:48:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathiasj" aria-label="Profile: MathiasJ">@<bdi>MathiasJ</bdi></a><br />
Welche Geräte ?<br />
Wenn xiaomi Sensoren - hälst du sie währen des pairings “wach” ?</p>
]]></description><link>https://forum.iobroker.net/post/238245</link><guid isPermaLink="true">https://forum.iobroker.net/post/238245</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Fri, 08 Mar 2019 18:48:25 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 18:44:01 GMT]]></title><description><![CDATA[<p dir="auto">Und ich kann keine Geräte anlernen.<br />
Es kommt immer die gleiche Meldung:<br />
Error...timeout 10000ms......??undefinied<br />
Gruß<br />
Mathias</p>
]]></description><link>https://forum.iobroker.net/post/238243</link><guid isPermaLink="true">https://forum.iobroker.net/post/238243</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Fri, 08 Mar 2019 18:44:01 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 17:16:58 GMT]]></title><description><![CDATA[<p dir="auto">hallo ich habe diesen Fehler bei Zigbee Adapter</p>
<pre><code>
instance system.adapter.zigbee.0 terminated with code 1 ()
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Module._compile (module.js:653:30)
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd/lib/components/controller.js:23:16)
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at require (internal/module.js:11:18)
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Module.require (module.js:597:17)
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Module.load (module.js:566:32)
host.raspberrypi 2019-03-08 16:03:00.679 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd/lib/config/nv_start_options.js:5:22)
host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: TypeError: Cannot read property 'nvItemIdsUint8' of undefined
host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: ^
host.raspberrypi 2019-03-08 16:03:00.678 error Caught by controller[0]: NVID8 = ZSC.SAPI.nvItemIdsUint8,
host.raspberrypi 2019-03-08 16:03:00.676 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd/lib/config/nv_start_options.js:5
</code></pre>
<p dir="auto">Kannst du mir Weiterhelfen??</p>
]]></description><link>https://forum.iobroker.net/post/238137</link><guid isPermaLink="true">https://forum.iobroker.net/post/238137</guid><dc:creator><![CDATA[Smarthome WEG3]]></dc:creator><pubDate>Fri, 08 Mar 2019 17:16:58 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 08:26:34 GMT]]></title><description><![CDATA[<p dir="auto">Dankeschön, hat auch nichts gebracht.<br />
ich weiß aber woran es lag.<br />
Es war wohl eine falsche Python-Version installiert.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/alcalzone" aria-label="Profile: Alcalzone">@<bdi>Alcalzone</bdi></a> war so frei, mir deshalb zu helfen.<br />
da ich IObroker sowieso neu aufsetzen mußte, habe ich gleich die richtige Version mit installiert.</p>
<p dir="auto">Nun lief der Test erfolgreich, ein paar Router habe auch geflasht.<br />
Jetzt heißt es warten, bis der Kühlkörper hier ist, damit ich den Rock64 in den regulären Betrieb nehmen kann,<br />
ganz ohne Multihost.</p>
Mathias</p>
]]></description><link>https://forum.iobroker.net/post/237920</link><guid isPermaLink="true">https://forum.iobroker.net/post/237920</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Fri, 08 Mar 2019 08:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee-Adapter on Fri, 08 Mar 2019 06:52:09 GMT]]></title><description><![CDATA[<p dir="auto">mach mal auf der console aus dem /opt/iobroker</p>
<pre><code>npm install https://github.com/arteck/ioBroker.zigbee
</code></pre>
]]></description><link>https://forum.iobroker.net/post/237892</link><guid isPermaLink="true">https://forum.iobroker.net/post/237892</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Fri, 08 Mar 2019 06:52:09 GMT</pubDate></item></channel></rss>
