  4. CPU Last hoch
CPU Last hoch
fehler
49 Beiträge 3 Kommentatoren 6.8k Aufrufe 2 Beobachtet
  • totocotonioT Offline
    totocotonio
    Das ist auch noch gekommen
    host.buanet-iobroker1	2019-02-24 23:03:32.086	error	instance system.adapter.history.0 terminated with code null ()
    host.buanet-iobroker1	2019-02-24 23:03:32.086	warn	instance system.adapter.history.0 terminated due to SIGABRT
    host.buanet-iobroker1	2019-02-24 23:03:32.086	error	Caught by controller[7]: 7: 0x59091f092a7
    host.buanet-iobroker1	2019-02-24 23:03:32.086	error	Caught by controller[7]: v8::internal::Runtime_SparseJoinWithSeparator(int, v8::internal::Object**, v8::internal::Isolate*) [io.history.0]
    host.buanet-iobroker1	2019-02-24 23:03:32.086	error	Caught by controller[6]: 6:
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[6]: v8::internal::Factory::NewRawTwoByteString(int, v8::internal::PretenureFlag) [io.history.0]
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[5]: 5:
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[5]: v8::internal::V8::FatalProcessOutOfMemory(char const*, bool) [io.history.0]
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[4]: 4:
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[4]: v8::Utils::ReportApiFailure(char const*, char const*) [io.history.0]
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[3]: 3:
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[3]: 0x7cff7c [io.history.0]
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[2]: 2:
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[2]: node::Abort() [io.history.0]
    host.buanet-iobroker1	2019-02-24 23:03:32.085	error	Caught by controller[1]: 1:
    host.buanet-iobroker1	2019-02-24 23:03:32.084	error	Caught by controller[0]: FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    Gruß Totocotonio
    Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
      totocotonio
      erstmal Danke an @Homoran und @wendy2702 für die Hilfe
      die Ihr mir zukommen gelassen habt.
      Ohne euch hätte ich es nicht hinbekommen-
      Mein Broker läuft im Im moment wieder soweit stabil bis auf die Meldung meines
      letzten Postes, vielleicht habt ihr da noch was für mich.
      Was habe ich gelernt:
      • Beantworte Fragen richtig
      • Wie man prozesse beendet und startet, scheint sehr wichtig zu sein.
      • Das die PID des TOP nicht die gleiche PID des Prozesses im Docker container ist 😠
      Das diese Forum Weltklasse ist 😁
      Ich hätte noch eine Frage, was passiert wenn den Broker bzw. Container noch einmal neu starte
      kann das sein das der Java Adapter nochmal sich 2 mal startet oder wie kann ich das verstehen.
      Gruß Totocotonio
      • totocotonioT totocotonio
        @totocotonio sagte in CPU Last hoch:
        Ein restart von ioBroker hilft in diesem speziellen Fall nicht
        Bei einem restart des Containers sollte es sein wie bei einem reboot eines Raspi und damit alles gut.
        Die saubere Art mit einem Code7 umzugehen ist den Prozess zu killen
        totocotonioT 1 Antwort Letzte Antwort
          totocotonio
          @Homoran Danke für Deine Hilfe.
          Kannst du mir noch was zum dem Fehler 2 Beiträge oberhalb sagen?
          Gruß Totocotonio
            leider nein - diese Meldung deutete auf einen Speicherzugriffsfehler hin, was zu der anderen Meldung passt.
            Warum und weshalb hab ich keine Ahnung
              totocotonio
              @Homoran sagte in CPU Last hoch:
              Ok.
              Das System läuft ja im Moment.
              Never change.......... ☺
              Danke nochmals für die Hilfe.
              Gruß Totocotonio
                totocotonio
                @Homoran Hi,
                ich muss den Thread noch einmal hochholen.
                Soweit läuft alles wieder Stabil.
                Bis auf diese Meldungen im LOG.:
                Was kann denn das sein.
                javascript.0	2019-03-01 16:30:04.935	info	script.js.common.Telefonie_und_Telegramm.Anrufmonitor_7878: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status":
                javascript.0	2019-03-01 16:30:04.904	error	at Object.<anonymous> (script.js.common.Heizung_und_Klimasteuerung.Luftfeuchtigkeit_mit_zeit:633:5)
                javascript.0	2019-03-01 16:30:04.904	error	at main (script.js.common.Heizung_und_Klimasteuerung.Luftfeuchtigkeit_mit_zeit:622:9)
                javascript.0	2019-03-01 16:30:04.904	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.903	info	script.js.common.Heizung_und_Klimasteuerung.Luftfeuchtigkeit_mit_zeit: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298
                javascript.0	2019-03-01 16:30:04.903	error	at Object.<anonymous> (script.js.common.Heizung_und_Klimasteuerung.Luftfeuchtigkeit_mit_zeit:379:5)
                javascript.0	2019-03-01 16:30:04.903	error	at main (script.js.common.Heizung_und_Klimasteuerung.Luftfeuchtigkeit_mit_zeit:622:9)
                javascript.0	2019-03-01 16:30:04.903	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.903	error	at Object.<anonymous> (script.js.common.Türen_und_Fenster.rolladen_abends_zu_kopie_zum_testen(1):633:5)
                javascript.0	2019-03-01 16:30:04.903	error	at main (script.js.common.Türen_und_Fenster.rolladen_abends_zu_kopie_zum_testen(1):622:9)
                javascript.0	2019-03-01 16:30:04.903	info	script.js.common.Türen_und_Fenster.rolladen_abends_zu_kopie_zum_testen(1): url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.4198961
                javascript.0	2019-03-01 16:30:04.903	error	at Object.<anonymous> (script.js.common.Türen_und_Fenster.rolladen_abends_zu_kopie_zum_testen(1):379:5)
                javascript.0	2019-03-01 16:30:04.903	error	at Object.<anonymous> (script.js.common.Heizung_und_Klimasteuerung.UVIndexColor:633:5)
                javascript.0	2019-03-01 16:30:04.903	error	at main (script.js.common.Heizung_und_Klimasteuerung.UVIndexColor:622:9)
                javascript.0	2019-03-01 16:30:04.903	info	script.js.common.Heizung_und_Klimasteuerung.UVIndexColor: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.8911743
                javascript.0	2019-03-01 16:30:04.903	error	at Object.<anonymous> (script.js.common.Heizung_und_Klimasteuerung.UVIndexColor:379:5)
                javascript.0	2019-03-01 16:30:04.902	error	at main (script.js.common.Heizung_und_Klimasteuerung.UVIndexColor:622:9)
                javascript.0	2019-03-01 16:30:04.902	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.902	info	script.js.common.Heizung_und_Klimasteuerung.UVIndexColor: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.8911743
                javascript.0	2019-03-01 16:30:04.539	error	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:633:5)
                javascript.0	2019-03-01 16:30:04.539	error	at main (script.js.common.Service.Stromverbrauch:622:9)
                javascript.0	2019-03-01 16:30:04.539	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.539	info	script.js.common.Service.Stromverbrauch: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.89117431640625&waypoints
                javascript.0	2019-03-01 16:30:04.539	error	at Object.<anonymous> (script.js.common.Service.Stromverbrauch:379:5)
                javascript.0	2019-03-01 16:30:04.536	error	at main (script.js.common.Service.Stromverbrauch:622:9)
                javascript.0	2019-03-01 16:30:04.536	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.536	info	script.js.common.Service.Stromverbrauch: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.89117431640625&waypoints
                javascript.0	2019-03-01 16:30:04.536	info	script.js.common.Türen_und_Fenster.rollo_hoch_bei_Tür_öffnen: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.522	info	script.js.common.Türen_und_Fenster.rollo_hoch_bei_Tür_öffnen: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status
                javascript.0	2019-03-01 16:30:04.522	info	script.js.common.Türen_und_Fenster.rollo_hoch_bei_Tür_öffnen: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.522	error	at Object.<anonymous> (script.js.common.Telefonie_und_Telegramm.Telegramm_Button:633:5)
                javascript.0	2019-03-01 16:30:04.522	error	at main (script.js.common.Telefonie_und_Telegramm.Telegramm_Button:622:9)
                javascript.0	2019-03-01 16:30:04.522	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.522	info	script.js.common.Telefonie_und_Telegramm.Telegramm_Button: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.891174
                javascript.0	2019-03-01 16:30:04.522	info	script.js.common.Service.bewegungsmelder_sendet_telegram: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.522	info	script.js.common.Service.bewegungsmelder_sendet_telegram: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status":"O
                javascript.0	2019-03-01 16:30:04.521	info	script.js.common.Service.bewegungsmelder_sendet_telegram: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status":"O
                javascript.0	2019-03-01 16:30:04.521	error	at Object.<anonymous> (script.js.common.Telefonie_und_Telegramm.Telegramm_Button:379:5)
                javascript.0	2019-03-01 16:30:04.521	error	at main (script.js.common.Telefonie_und_Telegramm.Telegramm_Button:622:9)
                javascript.0	2019-03-01 16:30:04.521	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.521	info	script.js.common.Telefonie_und_Telegramm.Telegramm_Button: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.891174
                javascript.0	2019-03-01 16:30:04.521	info	script.js.common.Meine_Fragen.Alexa_Radio_an_Bluetooth: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.521	info	script.js.common.Meine_Fragen.Alexa_Radio_an_Bluetooth: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status":"OK"
                javascript.0	2019-03-01 16:30:04.521	info	script.js.common.Sicherheit.Alarmanlage_Überwachung_Hüllschutz_: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.519	info	script.js.common.Sicherheit.Alarmanlage_Überwachung_Hüllschutz_: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_sta
                javascript.0	2019-03-01 16:30:04.516	info	script.js.common.Service.Servicemeldung_der_ccu: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.516	info	script.js.common.Service.Servicemeldung_der_ccu: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt":["street_address"]},{"geocoder_status":"OK","place
                javascript.0	2019-03-01 16:30:04.516	info	script.js.common.test.Mi_bewegungsmelder_licht_war_an: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.516	info	script.js.common.test.Mi_bewegungsmelder_licht_war_an: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status":"OK",
                javascript.0	2019-03-01 16:30:04.516	info	script.js.common.Sicherheit.Ausgelöster_RM_sendet_Telegramm: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.512	info	script.js.common.Sicherheit.Ausgelöster_RM_sendet_Telegramm: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status"
                javascript.0	2019-03-01 16:30:04.512	info	script.js.common.Sicherheit.Alarmanlage_Überwachung_Hüllschutz_: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.512	info	script.js.common.Sicherheit.Alarmanlage_Überwachung_Hüllschutz_: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_sta
                javascript.0	2019-03-01 16:30:04.512	info	script.js.common.Meine_Fragen.Alexa_Radio_an_Bluetooth: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.512	info	script.js.common.Meine_Fragen.Alexa_Radio_an_Bluetooth: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status":"OK"
                javascript.0	2019-03-01 16:30:04.512	info	script.js.common.Service.Servicemeldung_der_ccu: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.503	info	script.js.common.Service.Servicemeldung_der_ccu: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status":"OK","place
                javascript.0	2019-03-01 16:30:04.503	info	script.js.common.Sicherheit.Ausgelöster_RM_sendet_Telegramm: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.502	info	script.js.common.Sicherheit.Ausgelöster_RM_sendet_Telegramm: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"Schlüssel entfernt","types":["street_address"]},{"geocoder_status"
                javascript.0	2019-03-01 16:30:04.502	info	script.js.common.test.Mi_bewegungsmelder_licht_war_an: Anzahl Wegepunkte: 22
                javascript.0	2019-03-01 16:30:04.501	info	script.js.common.test.Mi_bewegungsmelder_licht_war_an: json:{"geocoded_waypoints":[{"geocoder_status":"OK","place_id":"","types":["street_address"]},{"geocoder_status":"OK",
                javascript.0	2019-03-01 16:30:04.500	error	at Object.<anonymous> (script.js.common.Telefonie_und_Telegramm.Anrufmonitor_7878:633:5)
                javascript.0	2019-03-01 16:30:04.500	error	at main (script.js.common.Telefonie_und_Telegramm.Anrufmonitor_7878:622:9)
                javascript.0	2019-03-01 16:30:04.498	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.498	info	script.js.common.Telefonie_und_Telegramm.Anrufmonitor_7878: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.89117
                javascript.0	2019-03-01 16:30:04.498	error	at Object.<anonymous> (script.js.common.Telefonie_und_Telegramm.Anrufmonitor_7878:379:5)
                javascript.0	2019-03-01 16:30:04.498	error	at main (script.js.common.Telefonie_und_Telegramm.Anrufmonitor_7878:622:9)
                javascript.0	2019-03-01 16:30:04.497	info	script.js.common.Telefonie_und_Telegramm.Anrufmonitor_7878: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.89117
                ical.1	2019-03-01 16:30:04.403	info	processing URL: Restmüll https://calendar.google.com/calendar/ical/Schlüssel entfernt .ical
                javascript.0	2019-03-01 16:30:04.307	error	at Object.<anonymous> (script.js.common.Türen_und_Fenster.rollo_hoch_bei_Tür_öffnen:633:5)
                javascript.0	2019-03-01 16:30:04.307	error	at main (script.js.common.Türen_und_Fenster.rollo_hoch_bei_Tür_öffnen:622:9)
                javascript.0	2019-03-01 16:30:04.307	error	Error in callback: ReferenceError: isTimeInRange is not defined
                javascript.0	2019-03-01 16:30:04.307	info	script.js.common.Türen_und_Fenster.rollo_hoch_bei_Tür_öffnen: url: https://maps.googleapis.com/maps/api/directions/json?origin=49.43189410000001,6.842155400000024&waypoints=via:49.41989615298593,6.891
                javascript.0	2019-03-01 16:30:04.307	error	at Object.<anonymous> (script.js.common.Türen_und_Fenster.rollo_hoch_bei_Tür_öffnen:379:5)
                Gruß Totocotonio
                  @Homoran Hi,
                  @totocotonio
                  Bitte keine persönlichen Daten posten - ich weiß nicht ob ich alle Schlüssel in deinem log entfernt habe und ob das alles auch Schlüssel waren
                    @Homoran Hi,
                    @totocotonio sagte in [Gelöst]CPU Last hoch:
                    Zeile 633
                    Zeichen Nummer 5
                    Sieh da mal nach
                      Zeile 633
                      Zeichen Nummer 5
                      Sieh da mal nach
                      totocotonio
                      schrieb am zuletzt editiert von totocotonio
                      @Homoran Ok danke das mit dem schlüssel wusste ich nicht
                      wie mache ich das.
                      Das ist zB. nur ein kleines Blockly mit 32 zeilen 😕
                      var Grenzwert, cnt, Intervall;
                      Grenzwert = 62;
                      on({id: "hm-rpc.0.NEQxxxxxx.1.HUMIDITY"/*Raumthermostat Badezimmer.HUMIDITY*/, change: "ne"}, function (obj) {
                        var value = obj.state.val;
                        console.log((obj.state ? obj.state.val : ""));
                        if (compareTime('07:00', '22:00', "between", null) && getState("hm-rpc.0.OEQ0xxxx.1.STATE").val == false && (obj.state ? obj.state.val : "") >= Grenzwert && (obj.oldState ? obj.oldState.val : "") < Grenzwert) {
                          console.log('Grenzwert überschritten bei geschlossenem Fenster');
                          setState("alexa2.0.Echo-Devices.G090Lxxxx0LT7.Commands.speak-volume"/*Volume to use for speak commands*/, 80);
                          setStateDelayed("alexa2.0.Echo-Devices.G090xxxxxxxT7.Commands.speak"/*speak*/, 'Luftfeuchtigkeit im Bad zu hoch bitte das Fenster öffnen ', 3000, false);
                          setState("alexa2.0.Echo-Devices.G090xxxxxxxLT7.Commands.speak-volume"/*Volume to use for speak commands*/, 70);
                          cnt = 0;
                          Intervall = setInterval(function () {
                            setState("alexa2.0.Echo-Devices.Gx.Commands.speak-volume"/*Volume to use for speak commands*/, 100);
                            setStateDelayed("alexa2.0.Echo-Devices.G090LxxxxxxLT7.Commands.speak"/*speak*/, 'Luftfeuchtigkeit im Bad zu hoch bitte das Fenster öffnen ', 3000, false);
                            setState("alexa2.0.Echo-Devices.Gx.Commands.speak-volume"/*Volume to use for speak commands*/, 70);
                            cnt = (typeof cnt == 'number' ? cnt : 0) + 1;
                            if (cnt >= 3) {
                              (function () {if (Intervall) {clearInterval(Intervall); Intervall = null;}})();
                          }, 240000);
                      on({id: "hm-rpc.0.OEQ0xxxxxx.1.STATE"/*Fenster Badezimmer TFK.STATE*/, val: true}, function (obj) {
                      Gruß Totocotonio
                        totocotonio
                        @Homoran Hi, hast Du mal geschaut was es sein könnte.
                        Gruß Totocotonio
