  4. [Fehler] "does not start any instances on this host"
6 Beiträge 2 Kommentatoren 3.9k Aufrufe
  • P Offline
    pix
    ich habe heute die Updates Controller und Ping gemacht. Ich habe dann (auch wenn nicht nötig) iobroker neu gestartet````
    ./iobroker restart
    leider erscheint jetzt nur noch diese Fehlermeldung:
    `2015-04-15 11:14:59.850  - [32minfo[39m: host.MacMini-Ethernet.fritz.box received SIGTERM
    2015-04-15 11:14:59.857  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated
    2015-04-15 11:15:00.853  - [32minfo[39m: host.MacMini-Ethernet.fritz.box received SIGTERM
    2015-04-15 11:15:04.609  - [32minfo[39m: info
    2015-04-15 11:15:04.612  - [32minfo[39m: host.MacMini-Ethernet.fritz.box ioBroker.js-controller version 0.5.15 js-controller starting
    2015-04-15 11:15:04.612  - [32minfo[39m: host.MacMini-Ethernet.fritz.box Copyright (c) 2014 bluefox, hobbyquaker
    2015-04-15 11:15:04.612  - [32minfo[39m: host.MacMini-Ethernet.fritz.box hostname: MacMini-Ethernet.fritz.box
    2015-04-15 11:15:04.612  - [32minfo[39m: host.MacMini-Ethernet.fritz.box ip addresses: ANONYMISIERT
    2015-04-15 11:15:04.668  - [32minfo[39m: inMem-states listening on port 9000
    2015-04-15 11:15:04.726  - [32minfo[39m: inMem-objects listening on port 9001
    2015-04-15 11:15:04.727  - [32minfo[39m: host.MacMini-Ethernet.fritz.box InMemoryDB connected
    2015-04-15 11:15:04.732  - [32minfo[39m: host.MacMini-Ethernet.fritz.box 19 instances found
    2015-04-15 11:15:04.733  - [33mwarn[39m: host.MacMini-Ethernet.fritz.box does not start any instances on this host[/code]`
    Was kann ich tun?
    Pix
    • P Offline
      pix
      Hier mal die Update Liste:
      ./iobroker update
      Cannot get version of "virtual".
      Cannot get version of "geofency".
      update done
      Adapter    "zwave"         : 0.1.0
      Adapter    "yr"            : 0.1.5    , installed 0.1.5
      Adapter    "web"           : 0.2.6    , installed 0.2.6
      Adapter    "vis"           : 0.2.11   , installed 0.2.11
      Adapter    "virtual"
      Adapter    "sonos"         : 0.1.6
      Adapter    "rickshaw"      : 0.2.2    , installed 0.2.2
      Adapter    "pushover"      : 0.1.0    , installed 0.1.0
      Adapter    "onkyo"         : 0.1.0
      Adapter    "telnet"        : 0.0.0
      Adapter    "socketio"      : 0.2.3
      Adapter    "simple-api"    : 0.0.4    , installed 0.0.4
      Adapter    "sayit"         : 0.3.6    , installed 0.3.6
      Adapter    "ping"          : 0.1.4    , installed 0.1.4
      Adapter    "node-red"      : 0.1.9
      Adapter    "mqtt"          : 0.1.7
      Adapter    "mobile"        : 0.0.2    , installed 0.0.2
      Adapter    "legacy"        : 0.1.12   , installed 0.1.12
      Adapter    "knx"           : 0.0.1
      Controller "js-controller" : 0.5.15   , installed 0.5.15
      Adapter    "javascript"    : 0.3.0    , installed 0.3.0
      Adapter    "ical"          : 0.1.0    , installed 0.1.0
      Adapter    "hmm"           : 0.0.17
      Adapter    "hue"           : 0.2.0
      Adapter    "hm-rpc"        : 0.4.0    , installed 0.4.0
      Adapter    "hm-rega"       : 0.2.1    , installed 0.2.1
      Adapter    "history"       : 0.1.3    , installed 0.1.3
      Adapter    "highcharts"    : 0.0.0
      Adapter    "graphite"      : 0.1.0
      Adapter    "geofency"
      Adapter    "example"       : 0.1.1    , installed 0.1.1
      Adapter    "email"         : 0.1.0    , installed 0.1.0
      Adapter    "dwd"           : 0.1.7    , installed 0.1.7
      Adapter    "cul"           : 0.0.2
      Adapter    "b-control-em"  : 0.1.1
      Adapter    "artnet"        : 0.0.3
      Adapter    "admin"         : 0.3.27   , installed 0.3.27
      Ich würde ja nochmal drüberinstallieren, möchte aber auf gar keinen Fall meine Scripts verlieren.
      • P Offline
        pix
        Okay, für alle, die mal vor dem gleichen Problem stehen:
        Ich habe jetzt die Installation gelöscht und sie mit OS X Time Machine wiederhergestellt. Der ioBroker Controller läßt sich starten, die Webseite öffnet sich nicht.
        Also muss ich jetzt ioBroker auf dem normalen Weg neu installieren und dann nach und nach versuchen, die alten Einstellungen aus Backups wiederherzustellen. Bei VIS hatte das ja schonmal geklappt.
        Pix
        • derAugeD Offline
          derAugeD Offline
          derAuge
          Hallo pix,
          wenn das Admin-Interface nicht geht schau mal hier http://forum.iobroker.org/viewtopic.php … =557#p3831 ob es dir hilft
          derAuge
          • P Offline
            pix
            Hallo derAuge,
            danke für den Tipp. Ich habe einen anderen, steinigen Weg eingeschlagen. Der Webserver war ja gar nicht erreichbar, keine Instanz wurde geladen (siehe Threadtitel). Deshalb habe ich mich zu einem kompletten Neuaufbau entschieden und vorher ein Backup gemacht.
            ./iobroker backup
            Das Installieren von ioBroker, Laden und Einstellen der Adapter dauert nicht länger als 20 Minuten und ist kein Beinbruch. Mir ging es um die mittlerweile 20 Skripte. Die sollten keinesfalls verloren gehen.
            Da ich nicht weiß, wo im Backup (das ja nach dem Absturz angefertigt wurde) der Fehler lag, wurden nur die Skripte aus dem Backup (backup.json) wiederhergestellt. Sie liegen im Dateisystem in der Datei objects.json. Diese Datei wird natürlich auch regelmäßig mit TimeMachine gesichert.
            Doch die Wiederherstellung aus beiden Backups ist gleich aufwendig. In der __objects.json-__Datei mit 1,3Mio Zeichen hab ich die Skripte gesucht und kopiert. Es sind Anführungzeichen (") mit (") ersetzt und Zeilenumbrüche mit (\n). Die Anführungszeichen konnte ich leicht mit dem Texteditor ersetzen, die Zeilenumbrüche aber per Hand. Und das dauert. Jetzt habe ich http://forum.iobroker.org/viewtopic.php?f=23&t=445&p=3170&hilit=schmerzen#p3170, jedes Skript auch offline auf der Festplatte zu sichern.
            Ist es möglich, die Backupfunktion aus Admin zu steuern (Häufigkeit Zielort, evtl. Umfang, ggf. Restore) ?
            Pix
            • derAugeD Offline
              derAugeD Offline
              derAuge
              Das mit dem backup habe ich auch schon mal angesprochen. Ich habe es noch nicht geschafft (am Testsystem) ein backup zu machen…. System neu aufgesetzt und backup wieder zurück zu spielen.
              Vorschlag: Hier sollte es Adapter ein backup und ein restore geben.
              Bei einem restore auf ein neu aufgesetztes System sollten dann ach die noch nicht installierten Adapter automatisch installiert werden
              Gesendet von meinem BLOOM mit Tapatalk
