  4. [Fehler] nach Neustart des Systems # module.js:340
16 Beiträge 3 Kommentatoren 3.3k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    @Bluefox:
    iobroker add admin --enabled --port 8090
    Dann erscheint unter "http://ip:8090" die Admin Seite und über die kannst du wieder alles gerade machen.
    Falls admin.0 und admin.1 existieren, dann admin.0 aktivieren und admin.1 löschen. Falls nur admin.0 existiert dann Port wieder auf 8081 ändern. `
    root@pi2:/mnt/ioBroker/iobroker.Pi2# iobroker add admin --enabled --port 8090
    This should never happens!
    create instance admin
    error: reading io-package.json Error: ENOENT, no such file or directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/io-package.json'
    • BluefoxB Offline
      BluefoxB Offline
      dann
      npm install iobroker.admin
      • derAugeD Offline
        derAugeD Offline
        derAuge
        root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker.admin
        npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
        > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
        > (node-gyp rebuild 2> builderror.log) || (exit 0)
        make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
          CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
          SOLINK_MODULE(target) Release/obj.target/bufferutil.node
          SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
          COPY Release/bufferutil.node
          CXX(target) Release/obj.target/validation/src/validation.o
          SOLINK_MODULE(target) Release/obj.target/validation.node
          SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
          COPY Release/validation.node
        make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
        > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
        make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/                      ws/build'
        make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/w                      s/build'
        iobroker.admin@0.3.23 node_modules/iobroker.admin
        ├── connect-flash@0.1.1
        ├── cookie-parser@1.3.4 (cookie-signature@1.0.6, cookie@0.1.2)
        ├── passport-local@1.0.0 (passport-strategy@1.0.0)
        ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
        ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
        ├── express-session@1.7.6 (cookie@0.1.2, utils-merge@1.0.0, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1                      )
        ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, escape-html@1.0.1, cookie@0.1.2, cookie-signature@1.0.4, range-parser@1.0.0, fresh@0.2.2, vary@0.1                      .0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, proxy-addr@1.0.1, send@0.4.3, type-is@1.2.1, accepts@1.0.7)
        ├── body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, raw-body@1.3.0, bytes@1.0.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
        ├── request@2.38.0 (json-stringify-safe@5.0.0, forever-agent@0.5.2, aws-sign2@0.5.0, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.3, form-da                      ta@0.1.4, mime-types@1.0.2, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
        └── socket.io@1.0.6 (debug@0.7.4, has-binary-data@0.1.1, socket.io-parser@2.2.0, socket.io-adapter@0.2.0, engine.io@1.3.1, socket.io-client@1.0.6)
        > iobroker add admin –enabled --port 8090
        object system.adapter.admin.1.uptime created
        object system.adapter.admin.1.memRss created
        object system.adapter.admin.1.memHeapTotal created
        object system.adapter.admin.1.memHeapUsed created
        object system.adapter.admin.1.connected created
        object system.adapter.admin.1.alive created
        object system.adapter.admin.1 created
        root@pi2:/mnt/ioBroker/iobroker.Pi2# ps -A |grep io.
         2313 ?        00:07:42 io.js-controlle
         2422 ?        00:02:17 io.history.0
         2432 ?        00:00:34 io.hm-rpc.0
         2455 ?        00:00:41 io.hm-rega.0
         2476 ?        00:02:15 io.javascript.0
         2482 ?        00:00:12 io.ping.0
         2507 ?        00:00:06 io.sayit.0
         2513 ?        00:02:25 io.web.0
         2519 ?        00:00:35 io.sonos.0
         2540 ?        00:00:10 io.hm-rpc.1
         2555 ?        00:00:08 io.node-red.0
         6990 ?        00:00:21 io.admin.1
        Das adminUI ist unter Pi2:8090 errechbar
        • derAugeD Offline
          derAugeD Offline
          derAuge
          Es sind nun beide Instanzen installiert
          der admin.0 läuft nicht
          nach Konfigurieren von :
          nach
          wird admin.0 zwar gestartet, jadoch ist die Oberfläche nicht erreichbar (Kreisel)
          • BluefoxB Offline
            BluefoxB Offline
            Es heißt, dass Port ist belegt und eine Instanz immer noch läuft und will nicht runtergehen. Das sollte vorbei sein, wenn man komplett reboot macht. Um zu prüfen ob ich recht habe, kann man:
            netstat -n -a | grep 8081
            ausführen und schauen, ob was da ist.
            • derAugeD Offline
              derAugeD Offline
              derAuge
              ;) Und täglich grüßt das Murmeltier ;)
              root@pi2:/mnt/ioBroker/iobroker.Pi2# init 6
              Nach neustart des Pi2
                  [ OK ] Starting system message bus: dbus.
                  Startion ioBroker
                  module.js:340
                      throw err;
                  Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (module.js:338:15)
                      at Function.Module._load (module.js:280:25)
                      at Function.Module.runMain (module.js:497:10)
                      at startup (node.js:119:16)
                      at node.js:935:3
                  [ OK ] Starting RPi-Monitor: rpimonitord
              :o :o :o :o :o :o
              Zur Zeit wird das NAS geprüft. dort liegt die Installation und wird vom Pi2 gemountet.
              • derAugeD Offline
                derAugeD Offline
                derAuge
                Das NAS-System ist sauber.
                Nun stehe ich vor der Frage: Wie kann ich herausfinden wo das Problem liegt?
                Kann ich irgend welche prüfroutinen einbauen um festzustellen warun dort etwas "zerschossen" wird?
                • BluefoxB Offline
                  BluefoxB Offline
                  Alle erste, muss du gesamte Installation zu Rpi2 holen. Und beobachten ob das Problem sich reproduziert.
                  • derAugeD Offline
                    derAugeD Offline
                    derAuge
                    @Bluefox:
                    Alle erste, muss du gesamte Installation zu Rpi2 holen. Und beobachten ob das Problem sich reproduziert. `
                    OK
                    da brauche ich aber dann etwas mehr Zeit…. Werde es testen. ;) So schnell geben wir ja nicht auf ;)
                    zur Info
                    nach einigen Updates folgendes im LOG:
                    iobroker	2015-03-26 20:18:45	info	exit 8
                    iobroker	2015-03-26 20:18:45	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                    iobroker	2015-03-26 20:18:45	error	at null._onTimeout (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/setup.js:1514:27)
                    iobroker	2015-03-26 20:18:45	error	at new ObjectsInMemServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:146:7)
                    iobroker	2015-03-26 20:18:45	error	at /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:139:9
                    iobroker	2015-03-26 20:18:45	error	at _initWebServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:958:24)
                    iobroker	2015-03-26 20:18:45	error	at Server.listen (net.js:1139:5)
                    iobroker	2015-03-26 20:18:45	error	at listen (net.js:1065:10)
                    iobroker	2015-03-26 20:18:45	error	at Server._listen2 (net.js:1043:14)
                    iobroker	2015-03-26 20:18:45	error	Error: listen EADDRINUSE at errnoException (net.js:905:11)
                    iobroker	2015-03-26 20:18:45	error	throw er; // Unhandled 'error' event ^
                    iobroker	2015-03-26 20:18:45	error	events.js:72
                    iobroker	2015-03-26 20:18:36	info	upgrade hm-rega
                    • BluefoxB Offline
                      BluefoxB Offline
                      Es läuft was auf dem System.
                      Neu starten (init 6)
                      • derAugeD Offline
                        derAugeD Offline
                        derAuge
                        @Bluefox:
                        Neu starten (init 6) `
                        ja,
                        ich hatte das System noch mal manuell gestartet.
                        Danach liefen die Adapter natürlich wieder.
                        Habe dann nach updates geschaut….
                        Gerade habe ich das "defekte" System auch noch mal (zum Test) manuell gestartet und die anstehenden Updates eingespielt.
                        • P Offline
                          pix
                          Halo,
                          könnt Ihr mir bitte noch einmal erklären, wie das funktioniert! Ich habe leider wieder das Problem:
                          2015-08-19 00:25:10.573  - info: host.Mini-Wohnzimmer.fritz.box ioBroker.js-controller version 0.7.8 js-controller starting
                          2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box Copyright (c) 2014-2015 bluefox, hobbyquaker
                          2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box hostname: Mini-Wohnzimmer.fritz.box
                          2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box ip addresses: XXXXXXXANONYMISIERTXXXXXX
                          2015-08-19 00:25:12.389  - info: inMem-states listening on port 9000
                          2015-08-19 00:25:12.801  - info: inMem-objects listening on port 9001
                          2015-08-19 00:25:12.803  - info: host.Mini-Wohnzimmer.fritz.box InMemoryDB connected
                          2015-08-19 00:25:12.818  - info: host.Mini-Wohnzimmer.fritz.box 33 instances found
                          2015-08-19 00:25:12.819  - warn: host.Mini-Wohnzimmer.fritz.box does not start any instances on this host
                          Der JS-Controler startet als einziger und dann bleibt es stehen. Ich habe bereits den obigen Weg probiert. Eine weitere Admin Instanz angeschmissen und sie läuft auch. Aber wie geht es dann weiter? amin.0 löschen hat nichts gebracht.
                          Habe bereits über Timemachine ein altes Backup von heute Mittag genutzt. Leider kein Erfolg.
                          ./iobroker update bringt das:
                          ./iobroker update
                          Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/adapter/example/io-package.json. Error: Not Found
                          update done
                          Adapter "zwave" : 0.1.0
                          Adapter "yr" : 0.1.7 , installed 0.1.7
                          Adapter "web" : 0.4.3 , installed 0.4.2 [Updateable]
                          Adapter "vis-plumb" : 0.1.5
                          Adapter "vis-metro" : 0.1.7 , installed 0.1.3 [Updateable]
                          Adapter "vis-lcars" : 0.1.6 , installed 0.1.4 [Updateable]
                          Adapter "vis-hqwidgets" : 0.1.0 , installed 0.1.0
                          Adapter "vis-colorpicker": 0.1.0 , installed 0.1.0
                          Adapter "vis-bars" : 0.0.3
                          Adapter "vis" : 0.6.12 , installed 0.6.5 [Updateable]
                          Adapter "sonos" : 0.1.6 , installed 0.1.6
                          Adapter "rickshaw" : 0.2.2 , installed 0.2.2
                          Adapter "pushover" : 0.1.1 , installed 0.1.1
                          Adapter "pushbullet" : 0.0.6 , installed 0.0.6
                          Adapter "owfs" : 0.0.2
                          Adapter "onkyo" : 0.1.9
                          Adapter "socketio" : 0.4.5
                          Adapter "simple-api" : 0.1.1 , installed 0.1.1
                          Adapter "scenes" : 0.1.2 , installed 0.0.2 [Updateable]
                          Adapter "sayit" : 0.3.11 , installed 0.3.11
                          Adapter "s7" : 0.1.8
                          Adapter "ping" : 0.1.4
                          Adapter "node-red" : 0.3.4 , installed 0.3.3 [Updateable]
                          Adapter "mqtt" : 0.2.9 , installed 0.2.9
                          Adapter "megad" : 0.1.1
                          Adapter "knx" : 0.0.1
                          Controller "js-controller" : 0.7.7 , installed 0.7.8
                          Adapter "javascript" : 0.5.4 , installed 0.5.1 [Updateable]
                          Adapter "icons-ultimate-png": 0.1.0 , installed 0.1.0
                          Adapter "icons-open-icon-library-png": 0.1.1
                          Adapter "icons-mfd-svg" : 0.1.0 , installed 0.1.0
                          Adapter "icons-mfd-png" : 0.1.0 , installed 0.1.0
                          Adapter "icons-material-svg": 0.1.0 , installed 0.1.0
                          Adapter "icons-material-png": 0.1.0 , installed 0.1.0
                          Adapter "icons-addictive-flavour-png": 0.1.0 , installed 0.1.0
                          Adapter "ical" : 1.1.1 , installed 1.0.2 [Updateable]
                          Adapter "hmm" : 0.1.1
                          Adapter "hue" : 0.4.2
                          Adapter "hm-rpc" : 0.5.2 , installed 0.5.2
                          Adapter "hm-rega" : 0.2.2 , installed 0.2.2
                          Adapter "history" : 0.1.3 , installed 0.1.3
                          Adapter "harmony" : 0.5.1
                          Adapter "fritzbox" : 0.2.1 , installed 0.2.1
                          Adapter "flot" : 0.1.1 , installed 0.1.1
                          Adapter "email" : 0.1.2
                          Adapter "dwd" : 0.1.10 , installed 0.1.9 [Updateable]
                          Adapter "cul" : 0.0.4
                          Adapter "b-control-em" : 0.1.1
                          Adapter "artnet" : 0.0.3
                          Adapter "admin" : 0.5.8 , installed 0.5.7 [Updateable]
                          Ich muss das System wohl erstmal ruhen lassen. :o
                          Pix
                          • P Offline
                            pix
                            habe jetzt mit mühevoller Handarbeit alles wieder zum Laufen bekommen. Es lief ja auf einem mac mini mit OS X.
                            Achtung! Die Einstellungen der Adapter gehen verloren (egal bei VIS oder Scenes), daher unbedingt vorher Screenshots der einzelnen Einstellungen machen (aufwendig bei ical, hm-rega, hm-rpc; bei Javascript und node-red ggf. an die zusätzlichen Module denken)
                            <list type="decimal">4. Backup des Ordner iobroker/iobroker-data (waren über 5GB wegen History Daten)
                            1. neuen Benutzer mit Adminrechten angelegt (alter Benutzer hatte sehr viele verwaiste Dateien)
                            2. ./iobroker start startet nur den js-controller (siehe oben)
                            3. ./iobroker del admin.0
                            4. ./iobroker add admin –enabled --port 8081 (danach wieder Zugriff auf Admin im Browser)
                            5. auf diese Weise jeden einzelnen Adapter erst gelöscht und dann neu angelegt und gestartet (Achtung: Bei Adaptern mit mehreren Instanzen müssen erst alle Instanzen gelöscht werden, damit die alte Reihenfolge 0,1,2,… wieder hergestellt wird)
                            6. Alle History Einstellungen sind weg. Das heißt, die Objekte müssen einzeln wieder angewählt und die gewünschte History-Log-Einstellung getätigt werden (mühsam).
                              Empfehlung: Erst hm-rp-Instanzen und dann hm-rega erneuern. Dann ggf. node-red und erst danach javascript, da viele Skripte auf die Daten aus der Homematic bzw. node-red zugreifen und sonst verrückt spielen, wenn die Objekte nicht mehr da sind.
                            Vielleicht kann es jemand brauchen, notfalls sehe ich später selbst hier nach, wenn der Fehler wieder auftaucht.
                            Pix
