  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 135.4k Aufrufe
  • E
    E
    electric69
    #83
    @Bluefox:
    Только что проверил на новой debian `
    Может такая ошибка только после ручного удаления iobroker и потом новой установки?
    • V
      V
      vtec
      #84
      Я устанавливал с нуля, единственное отличие это версии node
      Вот что пишет при установке iobroker.js-controller:
      root@test:/opt/iobroker# npm install iobroker.js-controller
      npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
      npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
      npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
      npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
      npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      > (node-gyp rebuild 2> builderror.log) || (exit 0)
      make: Вход в каталог `/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
        COPY Release/bufferutil.node
        CXX(target) Release/obj.target/validation/src/validation.o
        SOLINK_MODULE(target) Release/obj.target/validation.node
        SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
        COPY Release/validation.node
      make: Выход из каталога `/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
      > ws@0.5.0 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      make: Вход в каталог `/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
      make: Выход из каталога `/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
      > iobroker.js-controller@0.5.15 install /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/setup.js setup first
      creating conf/iobroker.json
      fs.js:654
        return binding.mkdir(pathModule._makeLong(path),
      Error: EACCES, permission denied '/opt/iobroker/node_modules/iobroker.js-controller/lib/../../../iobroker-data/'
          at Object.fs.mkdirSync (fs.js:654:18)
          at mkpathSync (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:821:20)
          at setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:903:9)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:305:13)
          at Module._compile (module.js:456:26)
          at Object.Module._extensions..js (module.js:474:10)
          at Module.load (module.js:356:32)
          at Function.Module._load (module.js:312:12)
          at Function.Module.runMain (module.js:497:10)
          at startup (node.js:119:16)
      npm ERR! iobroker.js-controller@0.5.15 install: `node lib/setup.js setup first`
      npm ERR! Exit status 8
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.5.15 install script.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node lib/setup.js setup first
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! System Linux 3.13.0-45-generic
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller"
      npm ERR! cwd /opt/iobroker
      npm ERR! node -v v0.10.37
      npm ERR! npm -v 1.4.28
      npm ERR! code ELIFECYCLE
      npm ERR! not ok code 0</anonymous>
      • BluefoxB
        #85
        Не может создать папку 'iobroker-data' в /opt/iobroker
        дай ручками права на папку
        chmod 777 /opt/iobroker
        и вызывай:
        sudo npm install iobroker.js-controller
        А почему ты вызываешь установку iobroker.js-controller, а не iobroker ?
        • V
          V
          vtec
          #86
          @Bluefox:
          Получилось, странно, что под рутом делал и не хватило прав.
          @Bluefox:
          А почему ты вызываешь установку iobroker.js-controller, а не iobroker ? `
          Хочу попробовать подключить WebStorm и по изучать. Может созрею на написание какого нибудь драйвера :)
          • I
            I
            IZUM
            #87
            Ну если советов нет, то буду переустанавлиать линукс и пробовать ставить на чистый линукс.
            • BluefoxB
              #88
              @IZUM:
              Ну если советов нет, то буду переустанавлиать линукс и пробовать ставить на чистый линукс. `
              sudo rm -rf /opt/iobroker
              mkdir /opt/iobroker
              sudo chmod 777 /opt/iobroker
              • I
                I
                IZUM
                #89
                @Bluefox:
                @IZUM:
                mkdir /opt/iobroker
                Процесс переустановки линукс уже идет полным ходом))
                • I
                  I
                  IZUM
                  #90
                  @Bluefox:
                  @IZUM:
                  mkdir /opt/iobroker
                  после переустановки линукс, назначение прав не помогает…........
                  izum@izum-eM350:/opt/iobroker$ cd /opt
                  izum@izum-eM350:/opt$ sudo mkdir iobroker
                  izum@izum-eM350:/opt$ sudo chmod 777 /opt/iobroker
                  izum@izum-eM350:/opt$ sudo npm install iobroker
                  npm http GET https://registry.npmjs.org/iobroker
                  npm ERR! Error: failed to fetch from registry: iobroker
                  npm ERR!     at /usr/share/npm/lib/utils/npm-registry-client/get.js:139:12
                  npm ERR!     at cb (/usr/share/npm/lib/utils/npm-registry-client/request.js:31:9)
                  npm ERR!     at Request._callback (/usr/share/npm/lib/utils/npm-registry-client/request.js:136:18)
                  npm ERR!     at Request.callback (/usr/lib/nodejs/request/main.js:119:22)
                  npm ERR!     at Request. <anonymous>(/usr/lib/nodejs/request/main.js:212:58)
                  npm ERR!     at Request.emit (events.js:88:20)
                  npm ERR!     at ClientRequest. <anonymous>(/usr/lib/nodejs/request/main.js:412:12)
                  npm ERR!     at ClientRequest.emit (events.js:67:17)
                  npm ERR!     at HTTPParser.onIncoming (http.js:1261:11)
                  npm ERR!     at HTTPParser.onHeadersComplete (http.js:102:31)
                  npm ERR! You may report this log at:
                  npm ERR!     <http: bugs.debian.org/npm="">npm ERR! or use
                  npm ERR!     reportbug --attach /opt/npm-debug.log npm
                  npm ERR!
                  npm ERR! System Linux 3.13.0-32-generic
                  npm ERR! command "node" "/usr/bin/npm" "install" "iobroker"
                  npm ERR! cwd /opt
                  npm ERR! node -v v0.6.12
                  npm ERR! npm -v 1.1.4
                  npm ERR! message failed to fetch from registry: iobroker
                  npm ERR!
                  npm ERR! Additional logging details can be found in:
                  npm ERR!     /opt/npm-debug.log
                  npm not ok</http:></anonymous></anonymous>
                  • V
                    V
                    vtec
                    #91
                    Попробуй так, что напишет
                    cd /opt/iobroker
                    • E
                      E
                      electric69
                      #92
                      @IZUM:
                      Устанавливать надо в /opt/iobroker, а не в /opt
                      З.Ы. Вообще код какой то странный))
                      Уже находишься в izum@izum-eM350:/opt/iobroker$
                      но при этом переходишь в cd /opt
                      потом создаешь уже существующую директорию sudo mkdir iobroker
                      Разбиритесь что куда скопировать, перейти, установить…
                      • I
                        I
                        IZUM
                        #93
                        @electric69:
                        @IZUM:
                        Разбиритесь что куда скопировать, перейти, установить… `
                        Находясь в /opt/iobroker я удалял до этого папку iobroker , по этому возвращался в /opt/ ;)
                        • I
                          I
                          IZUM
                          #94
                          @vtec:
                          cd /opt/iobroker
                          izum@izum-eM350:/opt/iobroker$ sudo npm cache clean
                          izum@izum-eM350:/opt/iobroker$ sudo npm install iobroker.js-controller
                          npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
                          npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
                          npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
                          npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
                          npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
                          npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
                          > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
                          > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
                          sh: 1: node: not found
                          npm WARN This failure might be due to the use of legacy binary "node"
                          npm WARN For further explanations, please read
                          /usr/share/doc/nodejs/README.Debian
                          npm ERR! Exit status 127
                          npm ERR!
                          npm ERR! System Linux 3.16.0-23-generic
                          npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller"
                          npm ERR! node -v v0.10.25
                          npm ERR! npm -v 1.4.21
                          npm ERR!
                          npm ERR!     /opt/iobroker/npm-debug.log
                          • BluefoxB
                            #95
                            node.js не доступен по команде "node"
                            Что происходит если в консоли написать?
                            izum@izum-eM350:/opt$ node
                            • I
                              I
                              IZUM
                              #96
                              @Bluefox:
                              izum@izum-eM350:~$ izum@izum-eM350:/opt$ node
                              bash: izum@izum-eM350:/opt$: Нет такого файла или каталога
                              izum@izum-eM350:~$ /opt$ node
                              bash: /opt$: Нет такого файла или каталога
                              izum@izum-eM350:~$
                              • V
                                V
                                vtec
                                #97
                                Создай ссылку на "node" с помощью команды "sudo ln -s /usr/bin/nodejs /usr/bin/node"
                                • I
                                  I
                                  IZUM
                                  #98
                                  @vtec:
                                  Создай ссылку на "node" с помощью команды "sudo ln -s /usr/bin/nodejs /usr/bin/node" `
                                  make: вход в каталог «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build»
                                  make: выход из каталога «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build»
                                  make: вход в каталог «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build»
                                  make: выход из каталога «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build»
                                  object system.certificates created
                                  object system.repositories created
                                  object system.config created
                                  object enum.rooms created
                                  object system.group.user created
                                  object system.group.administrator created
                                  object _design/system created
                                  object system.user.admin created
                                  object system.meta.uuid created
                                  install adapter admin
                                  object system.adapter.admin created
                                  create instance admin
                                  object system.adapter.admin.0.uptime created
                                  object system.adapter.admin.0.memRss created
                                  object system.adapter.admin.0.memHeapTotal created
                                  object system.adapter.admin.0.memHeapUsed created
                                  object system.adapter.admin.0.connected created
                                  object system.adapter.admin.0.alive created
                                  object system.adapter.admin.0 created
                                  iobroker.js-controller@0.5.15 node_modules/iobroker.js-controller
                                  ├── daemonize2@0.4.2
                                  ├── mime@1.2.11
                                  ├── node-schedule@0.1.13
                                  ├── ncp@0.6.0
                                  ├── node.extend@1.0.10 (is@0.3.0)
                                  ├── adm-zip@0.4.7
                                  ├── yargs@1.2.6 (minimist@0.1.0)
                                  ├── request@2.38.0 (json-stringify-safe@5.0.0, forever-agent@0.5.2, aws-sign2@0.5.0, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.3, mime-types@1.0.2, form-data@0.1.4, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
                                  ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
                                  ├── socket.io@1.2.1 (debug@0.7.4, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.2, engine.io@1.4.3)
                                  ├── winston@0.7.3 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, colors@0.6.2, async@0.2.10, pkginfo@0.3.0, request@2.16.6)
                                  ├── socket.io-client@1.2.1 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.5, parseuri@0.0.2, socket.io-parser@2.2.2, engine.io-client@1.4.3)
                                  └── npm@2.3.0
                                  Вроде ошибок нет ,но http://localhost:8081/ не открывается.
                                  • BluefoxB
                                    #99
                                    node iobroker start
                                    • I
                                      I
                                      IZUM
                                      #100
                                      @Bluefox:
                                      node iobroker start
                                      izum@izum-eM350:/opt/iobroker$ node iobroker start
                                      /opt/iobroker/iobroker:1
                                      (function (exports, require, module, __filename, __dirname) { node node_module
                                      SyntaxError: Unexpected identifier
                                          at Module._compile (module.js:439:25)
                                          at node.js:902:3
                                      izum@izum-eM350:~$ node iobroker start
                                      /home/izum/iobroker:1
                                          at node.js:902:3
                                      izum@izum-eM350:~$ node --version
                                      v0.10.25
                                      • BluefoxB
                                        #101
                                        node /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js start
                                        • I
                                          I
                                          IZUM
                                          #102
                                          @Bluefox:
                                          node /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js start `
                                          Ура, все завелось! Спасибо вам за ваше терпение и отзывчивость))
                                          84.3k
