  4. [Aufruf] Plex connect testen
66 Beiträge 11 Kommentatoren 16.4k Aufrufe 5 Beobachtet
  • X Offline
    X Offline
    x-ess
    Ist das richtig so?
    undefined2019-02-04 19:57:19.365 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549306639364,"q":0,"from":"system.adapter.admin.0","lc":1549306639364}
    2019-02-04 19:57:19.366 - debug: plexconnect.0 system.adapter.admin.0: logging false
    2019-02-04 19:57:24.328 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549306644322,"q":0,"from":"system.adapter.admin.0","lc":1549306644322}
    2019-02-04 19:57:24.329 - debug: plexconnect.0 system.adapter.admin.0: logging true
    2019-02-04 19:58:31.599 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549306711598,"q":0,"from":"system.adapter.admin.0","lc":1549306711598}
    2019-02-04 19:58:31.600 - debug: plexconnect.0 system.adapter.admin.0: logging false
    2019-02-04 19:58:47.305 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549306727301,"q":0,"from":"system.adapter.admin.0","lc":1549306727301}
    2019-02-04 19:58:47.306 - debug: plexconnect.0 system.adapter.admin.0: logging true
    2019-02-04 19:59:41.876 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549306781872,"q":0,"from":"system.adapter.admin.0","lc":1549306781872}
    2019-02-04 19:59:41.878 - debug: plexconnect.0 system.adapter.admin.0: logging false
    2019-02-04 20:02:22.883 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549306942876,"q":0,"from":"system.adapter.admin.0","lc":1549306942876}
    2019-02-04 20:02:22.884 - debug: plexconnect.0 system.adapter.admin.0: logging true
    sorry bin noch nicht der Profi auf dem Gebiet..
    • EisbaeeerE Offline
      EisbaeeerE Offline
      Eisbaeeer
      Hallo x-ess
      Kein Problem. Den Adapter setzt du wie hier beschrieben auf Debug: viewtopic.php?p=135414#p135414
      Ersetzte die Suche mit plex, dann sollte da was sinnvolles rauskommen.
      Dann bitte hier posten, aber als "Code" oder "Spoiler", dann wird das hier lesbar.
      Danke.
      Kein support per PM. Bitte im Forum Fragen stellen!
      • X Offline
        X Offline
        x-ess
        2019-02-05 19:00:31.099 - debug: plexconnect.0 objectDB connected
        2019-02-05 19:00:31.177 - debug: plexconnect.0 statesDB connected
        2019-02-05 19:00:31.190 - info: plexconnect.0 States connected to redis: 127.0.0.1:6379
        2019-02-05 19:00:32.094 - info: plexconnect.0 starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.plexconnect, node: v8.15.0
        2019-02-05 19:00:32.105 - info: plexconnect.0 function ready
        2019-02-05 19:00:32.139 - info: plexconnect.0 function main
        2019-02-05 19:00:32.143 - info: plexconnect.0 Server listening on port:10000
        2019-02-05 19:00:32.144 - info: plexconnect.0 PMS:192.168.1.206
        2019-02-05 19:00:50.376 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549389650346,"q":0,"from":"system.adapter.admin.0","lc":1549389650346}
        2019-02-05 19:00:50.382 - debug: plexconnect.0 system.adapter.admin.0: logging true
        2019-02-05 19:02:08.237 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549389728235,"q":0,"from":"system.adapter.admin.0","lc":1549389728235}
        2019-02-05 19:02:08.238 - debug: plexconnect.0 system.adapter.admin.0: logging false
        2019-02-05 19:03:29.305 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549389809303,"q":0,"from":"system.adapter.admin.0","lc":1549389809303}
        2019-02-05 19:03:29.306 - debug: plexconnect.0 system.adapter.admin.0: logging true
        2019-02-05 19:04:57.887 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549389897884,"q":0,"from":"system.adapter.admin.0","lc":1549389897884}
        2019-02-05 19:04:57.889 - debug: plexconnect.0 system.adapter.admin.0: logging false
        2019-02-05 19:04:59.143 - info: host.ioBroker-RasPi object change system.adapter.plexconnect.0
        2019-02-05 19:04:59.147 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0
        2019-02-05 19:04:59.148 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0 killing pid 898
        2019-02-05 19:04:59.679 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 terminated with code 0 (OK)
        2019-02-05 19:05:01.674 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 started with pid 1187
        2019-02-05 19:05:04.918 - info: plexconnect.0 States connected to redis: 127.0.0.1:6379
        2019-02-05 19:05:05.234 - info: plexconnect.0 starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.plexconnect, node: v8.15.0
        2019-02-05 19:05:05.252 - info: plexconnect.0 function ready
        2019-02-05 19:05:05.274 - info: plexconnect.0 function main
        2019-02-05 19:05:05.279 - info: plexconnect.0 Server listening on port:10000
        2019-02-05 19:05:05.280 - info: plexconnect.0 PMS:192.168.1.206
        2019-02-05 19:05:43.512 - info: host.ioBroker-RasPi object change system.adapter.plexconnect.0
        2019-02-05 19:05:43.513 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0
        2019-02-05 19:05:43.514 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0 killing pid 1187
        2019-02-05 19:05:44.045 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 terminated with code 0 (OK)
        2019-02-05 19:05:46.039 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 started with pid 1254
        2019-02-05 19:05:49.403 - debug: plexconnect.0 objectDB connected
        2019-02-05 19:05:49.486 - debug: plexconnect.0 statesDB connected
        2019-02-05 19:05:49.502 - info: plexconnect.0 States connected to redis: 127.0.0.1:6379
        2019-02-05 19:05:49.822 - info: plexconnect.0 starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.plexconnect, node: v8.15.0
        2019-02-05 19:05:49.834 - info: plexconnect.0 function ready
        2019-02-05 19:05:49.864 - info: plexconnect.0 function main
        2019-02-05 19:05:49.869 - info: plexconnect.0 Server listening on port:10000
        2019-02-05 19:05:49.870 - info: plexconnect.0 PMS:192.168.1.206
        • X Offline
          X Offline
          x-ess
          2019-02-05 19:19:58.231 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549390798229,"q":0,"from":"system.adapter.admin.0","lc":1549390798229}
          2019-02-05 19:19:58.238 - debug: plexconnect.0 system.adapter.admin.0: logging false
          2019-02-05 19:20:08.196 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549390808194,"q":0,"from":"system.adapter.admin.0","lc":1549390808194}
          2019-02-05 19:20:08.197 - debug: plexconnect.0 system.adapter.admin.0: logging true
            EisbaeeerE Offline
            Eisbaeeer
            Hmm, dein Adapter startet immer wieder neu. Oder hast du das angestoßen?
            Kann es sein, dass du in das RAM Problem läufst?
            Dein iobroker läuft auf einem RPi. Beobachte mal bitte deinen RAM.
            Es läuft gerade eine Umstellung von iobroker, mit der die Adapter keinen separaten Prozess mehr starten, also weniger RAM benötigen. Nachteil ist aber, dass wenn ein Adapter ein Problem hat, es alle anderen mit auf die Bretter zieht.
            Schau mal mit top auf dem rpi, wie der RAM ausgelastet ist.
            Grüße Eisbaeeer
            • X Offline
              X Offline
              x-ess
              Danke für Deine Antwort.
              so weit ich weis stoße ich nichts an.
              Habe das mit dem Top probiert, aber für mich sieht das ok aus.
              • X Offline
                X Offline
                x-ess
                Wenn ich die IP Adresse im plex webhooks neu speichere funktioniert es sofort.
                  EisbaeeerE Offline
                  Eisbaeeer
                  Dann wird die Socket Verbindung nicht wieder hergestellt. Ich schau mir das beim nächsten Update an.
                  Gruß Eisbaeeer
                  Gesendet von meinem SM-G950F mit Tapatalk
                  • X Offline
                    X Offline
                    x-ess
                    Vielen herzlichen dank.
                    Danke für deine mühe.
                    Lg x-ess
                    • W Offline
                      W Offline
                      wizzardking
                      Vielen Dank für dieses Tool!
                      ... aber leider bekomme ich es einfach nicht zum laufen.
                      Ich wäre sehr dankbar, wenn mir einer sagen könnte, wo evtl. bei mir der Fehler liegen könnte. Vermutlich habe ich irgend was mit den Einstellungen falsch gemacht.
                      PMS
                      Plex Media Server läuft (Mit Lifetime Plexpass) auf meinem QNAP NAS mit der IP 192.168.1.214
                      Webhooks wurde aktiviert und folgendes hinzugefügt: http://192.168.1.220:10000
                      In den Einstellungen ist "Webhooks: Diese Funktion erlaubt deinem Server, Ereignisse an externe Dienste zu senden." ebenfalls aktiviert.
                      ioBroker läuft auf dem selben NAS, allerdings in einem Docker Container und hat daher eine andere IP: 192.168.1.220
                      RAM Probleme habe ich sicher nicht.
                      Die Ampel von Plexconnect ist Grün und die Logs zeigen mir keine Fehler an:
                      unter Objekte zeigt mir Plexconnect aber keine Werte an:
                      • W Offline
                        W Offline
                        wizzardking
                        Strange... aber nach Plex-Neustart gehts nun 😀
                        • W Offline
                          W Offline
                          wizzardking
                          Wie sieht es bei euch mit der Reaktionszeit aus?
                          Habe ein Script geschrieben, welches bei der Wiedergabe die Lichtwerte zwischenspeichert und alle Lampen (welche angeschalten sind) dimmt. Sobald die Wiedergabe pausiert oder beendet wird, schalten sich die Lichter auf den vorherigen Wert zurück.
                          Funktioniert soweit sehr gut, ausser das es beim Pausieren/Beenden bis 10 Sekunden dauern kann, bis sich die Lichter wieder hochschalten, bzw. bis sich der Status in Plexconnect ändert.
                          Wird der Status hier vom PMS an Plexconnect gesendet, oder fragt Plexconnect regelmässig den Status beim Plex-Server ab? Falls ersteres... Pech gehabt, da Plex ohnehin nicht auf Anfragen/Feature Requests eingeht. Falls letzteres, wäre es super, wenn der Intervall selber eingestellt werden könnte.
                          • ZefauZ Offline
                            ZefauZ Offline
                            Zefau
                            ich habe einen neuen Adapter für Plex geschrieben: ioBroker.plex.
                            Dieser nutzt die Plex API, um Server, Libraries und Settings zu laden (ohne Plex Pass). Weiterhin wird (wie im Plexconnect Adapter) der Plex Webhook (nur für Plex Pass) unterstützt, um die aktuelle Medien-Wiedergabe zu laden. Ohne Plex Pass ist es möglich mit Tautulli (Zusatzsoftware für Plex Statistiken, siehe hier) einen Webhook zu setzen und die aktuelle Wiedergabe in ioBroker zu laden.
                            Über Tests würde ich mich freuen. Einfach per SSH installieren:
                            iobroker url https://github.com/Zefau/ioBroker.plex
                            iobroker upload plex
                            Cheers,
                            Zefau
                            E 1 Antwort Letzte Antwort
                            • ZefauZ Zefau
                              Cheers,
                              Zefau
                              el_malto
                              @Zefau sagte in [Aufruf] Plex connect testen:
                              Cheers,
                              Zefau
                              Magst du dafür einen eigenen Thread anlegen? Ich würde den am WE vielleicht mal testen. Dann hat man einen eigenen Thread um sich auszutauschen.
                              • E el_malto
                                Cheers,
                                Zefau
                                ZefauZ Offline
                                ZefauZ Offline
                                Zefau
                                #66
                                @el_malto sagte in [Aufruf] Plex connect testen:
                                Jo, ist sinnig. Habe einen neuen Thread aufgemacht: https://forum.iobroker.net/topic/22027/aufruf-neuer-adapter-iobroker-plex
