  4. Node-Red mit Alexa - Dimmer
    5.8k
39 Beiträge 5 Kommentatoren 9.8k Aufrufe 1 Beobachtet
  • R Offline
    rewenode
    Ich hoffe, ich habe richtig kapiert.
    Das sollte auch ohne Blockly problemlos gehen:
    hier der flow:
    "id": "26dc88fe.708c5",
    "type": "inject",
    "z": "ca47e1d4.9f532",
    "name": "Alexa Schalte Test auf ROT",
    "topic": "",
    "payload": "{"hue":0,"saturation":1,"brightness":1}",
    "payloadType": "json",
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "x": 230,
    "y": 140,
    "wires": [
    "ad83b521.77c65",
    "7eb1492e.f3b3d8"
    "id": "86870acf.2656c",
    "type": "color-convert",
    "input": "hsv",
    "output": "rgb",
    "outputType": "array",
    "x": 190,
    "y": 300,
    "wires": [
    "a57a950f.248af8"
    "id": "ad83b521.77c65",
    "type": "change",
    "name": "{"hue":0,"saturation":1,"brightness":1} to [h,s,v]",
    "rules": [
    "t": "set",
    "p": "payload",
    "pt": "msg",
    "to": "[\t payload.hue,\t payload.saturation * 100,\t payload.brightness * 100\t]",
    "tot": "jsonata"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 300,
    "y": 220,
    "wires": [
    "86870acf.2656c",
    "a4ad7796.ecdb8"
    "id": "ccb4443d.a17ce8",
    "type": "comment",
    "name": "msg.payload ={"hue":0,"saturation":1,"brightness":1}",
    "info": "",
    "x": 940,
    "y": 140,
    "wires": []
    "id": "3e66cbf2.9da13c",
    "type": "comment",
    "name": "direct convert to rgb[r,g,b]",
    "info": "",
    "x": 830,
    "y": 300,
    "wires": []
    "id": "bd23336d.d791e8",
    "type": "comment",
    "name": "object hsv[h,s,v]",
    "info": "",
    "x": 800,
    "y": 220,
    "wires": []
    "id": "a57a950f.248af8",
    "type": "debug",
    "name": "rgb[r,g,b]",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "payload",
    "x": 600,
    "y": 300,
    "wires": []
    "id": "7eb1492e.f3b3d8",
    "type": "debug",
    "name": "{"hue":0,"saturation":1,"brightness":1}",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "x": 550,
    "y": 140,
    "wires": []
    "id": "a4ad7796.ecdb8",
    "type": "debug",
    "name": "hsv[h,s,v]",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "x": 600,
    "y": 220,
    "wires": []
     ![3999_bild_1.png](/assets/uploads/files/3999_bild_1.png)
    Am Eingang bekommt das Teil ein Oblect````
    Am Ausgang hast du ein Array````
    [r,g,b]
    Wenn das lieber ein Object sein soll, der Form:````
    {"rgb": [r,g,b]}
    ````ist eine minimale Änderung nötig.
      dondon4002
      Perfekt :D dann hab ich nur den Converter falsch benutzt :D :D danach noch nen Change to msg.payload.rgb und Alexa schaltet das ganze :-) Danke dir
      • R Offline
        rewenode
        @dondon4002:
        … Change to msg.payload.rgb `
        Exakt so :D falls nötig
          dondon4002
          Für alle die dann noch Bedarf daran haben :-)
          Ich mache es am Ende doch per Blockly denn es kommen ja noch Abfragen wie TurnOnRequest, TunOffRequest und was Alexa noch alles so bietet.
          "id": "6a18e5be.c9abdc",
          "type": "Blockly",
          "z": "9433ac39.c5756",
          "language": "en",
          "func": "if ((msg['command']) == 'SetColorRequest') {\n msg['payload'] = [(msg['payload']['hue']), (msg['payload']['saturation']) * 100, (msg['payload']['brightness']) * 100];\n return [msg, null];\n} else if ((msg['command']) == 'TurnOffRequest') {\n msg['payload'] = false;\n return [null, msg];\n} else if ((msg['command']) == 'TurnOnRequest') {\n msg['payload'] = true;\n return [null, msg];\n}\n",
          "workspaceXml": "<xml xmlns="&quot;http://www.w3.org/1999/xhtml\&quot;"><block id="&quot;OegDmw1SSX]D=Pa(8G75&quot;" type="&quot;controls_if&quot;" x="&quot;-2037&quot;" y="&quot;-387&quot;"><mutation elseif="&quot;2&quot;"></mutation><value name="&quot;IF0&quot;"><block id="&quot;GconiS<value name="&quot;IF0&quot;"ihVrBvHEiKZu&quot;" type="&quot;logic_compare&quot;"><field name="&quot;OP&quot;">EQ</field><value name="&quot;A&quot;"><block id="&quot;qfEv5p}Q.6(4bAAhVY)t&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;8Rf40:s+-(Iix/~rpXuB&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;3K$0p{%[oP^XO:,{IhsI&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">command</field></shadow></value></block></value><value name="&quot;B&quot;"><block id="&quot;Gu~Z4BXhmh4D%LOE{4s-&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">SetColorRequest</field></block></value></block></value><statement name="&quot;DO0&quot;"><block id="&quot;Wz6Dr1k2)tZbJ[+?V+j{&quot;" type="&quot;node_object_set&quot;"><value name="&quot;object_field&quot;"><shadow id="&quot;N7nV^CQPdk8cxV}?9mWX&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;cZ6WgGkQ{3ya8z~VBE3\&quot;" type="\&quot;text\&quot;"><field name="\&quot;TEXT\&quot;">payload</field></shadow></value><value name="\&quot;value_field\&quot;"><shadow id="\&quot;sk?O05P5ma_5vqc{!#)&quot;" type="&quot;text&quot;"></shadow><block id="&quot;Md|@A(]N!kq$=b3)[SH!&quot;" type="&quot;lists_create_with&quot;"><mutation items="&quot;3&quot;"></mutation><value name="&quot;ADD0&quot;"><block id="&quot;tu7-Qe3u+zsXsItw[,yY&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;4WDpncvt3q4gpN@S@MfM&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;@d+[0zA[c(D{jmlYd^%O&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">payload.hue</field></shadow></value></block></value><value name="&quot;ADD1&quot;"><block id="&quot;!Q#d8F/fCDqPNsm,6Z+&quot;" type="&quot;math_arithmetic&quot;"><field name="&quot;OP&quot;">MULTIPLY</field><value name="&quot;A&quot;"><shadow id="&quot;bNOGt$4!S%VQ?:vfS1V.&quot;" type="&quot;math_number&quot;"><field name="&quot;NUM&quot;">1</field></shadow><block id="&quot;cl:38kKKmak%V3E!m2}T&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;8+vu8BKKc)fZo;rSk0[D&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;FzE=$C.cumV)e3g*!;0\&quot;" type="\&quot;text\&quot;"><field name="\&quot;TEXT\&quot;">payload.saturation</field></shadow></value></block></value><value name="\&quot;B\&quot;"><shadow id="\&quot;p$RJ=}@6=xX[Ekbiqfn^\&quot;" type="\&quot;math_number\&quot;"><field name="\&quot;NUM\&quot;">100</field></shadow></value></block></value><value name="\&quot;ADD2\&quot;"><block id="\&quot;K[@!p?t]Y]0YY,I]]Y=3\&quot;" type="\&quot;math_arithmetic\&quot;"><field name="\&quot;OP\&quot;">MULTIPLY</field><value name="\&quot;A\&quot;"><shadow id="\&quot;12luhGJPp}BppnOnCd]t\&quot;" type="\&quot;math_number\&quot;"><field name="\&quot;NUM\&quot;">1</field></shadow><block id="\&quot;hu/B]c6@]lE@cn^qMa!I\&quot;" type="\&quot;node_object_get\&quot;"><mutation action="\&quot;GET\&quot;"></mutation><field name="\&quot;action\&quot;">GET</field><value name="\&quot;object\&quot;"><shadow id="\&quot;$2{@U|#45m9O#sYMG_HL\&quot;" type="\&quot;node_msg\&quot;"></shadow></value><value name="\&quot;field_name\&quot;"><shadow id="\&quot;9q^k;%a@6pz!wwSL[S\&quot;" type="\&quot;text\&quot;"><field name="\&quot;TEXT\&quot;">payload.brightness</field></shadow></value></block></value><value name="\&quot;B\&quot;"><shadow id="\&quot;H7P5:v+4jC%4eNSZg1b3\&quot;" type="\&quot;math_number\&quot;"><field name="\&quot;NUM\&quot;">100</field></shadow></value></block></value></block></value><next><block id="\&quot;dj6-iR8:4O-+v*!D~,M-\&quot;" type="\&quot;node_return_message\&quot;"><field name="\&quot;OUTPUT_NR\&quot;">1</field><value name="\&quot;MESSAGE_INPUT\&quot;"><shadow id="\&quot;!e8R2#N8Jdu(EAVQ{|&quot;" type="&quot;node_msg&quot;"></shadow></value></block></next></block></statement><value name="&quot;IF1&quot;"><block id="&quot;Gt#y.gqIL,qm)]{hhHC&quot;" type="&quot;logic_compare&quot;"><field name="&quot;OP&quot;">EQ</field><value name="&quot;A&quot;"><block id="&quot;N6$q19G#S0_xYH%PxSEI&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;x(P(iAF[acHUJa%K1WW0&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;401Ct:?6f$=h/.@%JFf=&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">command</field></shadow></value></block></value><value name="&quot;B&quot;"><block id="&quot;E:%o.01_qWbolte})n[}&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">TurnOffRequest</field></block></value></block></value><statement name="&quot;DO1&quot;"><block id="&quot;6=mvJ%:D4qf|CDFfAg[z&quot;" type="&quot;node_object_set&quot;"><value name="&quot;object_field&quot;"><shadow id="&quot;ABbAcS^Mj_]u:G0bmbxl&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;to=(u!-hoz(ZB|X@F7;&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">payload</field></shadow></value><value name="&quot;value_field&quot;"><shadow id="&quot;6?#earD4R8~?M5_1Y1va&quot;" type="&quot;text&quot;"></shadow><block id="&quot;gSN[vp0Vp@iiKOCKXZxO&quot;" type="&quot;logic_boolean&quot;"><field name="&quot;BOOL&quot;">FALSE</field></block></value><next><block id="&quot;8Lt@[lrf:,v#bz#My!,~&quot;" type="&quot;node_return_message&quot;"><field name="&quot;OUTPUT_NR&quot;">2</field><value name="&quot;MESSAGE_INPUT&quot;"><shadow id="&quot;ac^):!N/SuXK+m#l6G{e&quot;" type="&quot;node_msg&quot;"></shadow></value></block></next></block></statement><value name="&quot;IF2&quot;"><block id="&quot;:%iB^77hKA%5#Y]m3(KI&quot;" type="&quot;logic_compare&quot;"><field name="&quot;OP&quot;">EQ</field><value name="&quot;A&quot;"><block id="&quot;bZZ%2UXkY4qB_Fmae68&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;O;dMHWtpMY{zN1](^WQa&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;C0O}w0bo=c,,_#.[I9Gf&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">command</field></shadow></value></block></value><value name="&quot;B&quot;"><block id="&quot;e5e|,AqRBMdDQ|~s?uv9&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">TurnOnRequest</field></block></value></block></value><statement name="&quot;DO2&quot;"><block id="&quot;|DY5/yaj[#aVyjA:qNS&quot;" type="&quot;node_object_set&quot;"><value name="&quot;object_field&quot;"><shadow id="&quot;ee@E0k_unaE#!Ss=xdAB&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;h]@6ikfpmr#ni-9FWDmN&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">payload</field></shadow></value><value name="&quot;value_field&quot;"><shadow id="&quot;6?#earD4R8~?M5_1Y1va&quot;" type="&quot;text&quot;"></shadow><block id="&quot;c3@@`D0S$O}J_N]-B5lf&quot;" type="&quot;logic_boolean&quot;"><field name="&quot;BOOL&quot;">TRUE</field></block></value><next><block id="&quot;%R}_.z4(NfAy?#=Gv44&quot;" type="&quot;node_return_message&quot;"><field name="&quot;OUTPUT_NR&quot;">2</field><value name="&quot;MESSAGE_INPUT&quot;"><shadow id="&quot;}z$f11Tsy#/HuS(JG_Z&quot;" type="&quot;node_msg&quot;"></shadow></value></block></next></block></statement></block></xml>",
          "outputs": 2,
          "name": "",
          "x": 390,
          "y": 1320,
          "wires": [
          "aeec5dac.065a9"
          "7bd5f7d8.5e0f58"
          "id": "7bd5f7d8.5e0f58",
          "type": "hue-light",
          "name": "Lampe_Buero_LedStrip",
          "bridge": "d5d520c8.c3118",
          "lightid": "9",
          "colornamer": true,
          "x": 960,
          "y": 1330,
          "wires": [
          "id": "8259bb25.207dc8",
          "type": "alexa-home",
          "conf": "b91f3657.228818",
          "device": "43026",
          "acknoledge": true,
          "name": "Test",
          "topic": "",
          "x": 240,
          "y": 1320,
          "wires": [
          "6a18e5be.c9abdc"
          "id": "aeec5dac.065a9",
          "input": "hsv",
          "output": "rgb",
          "x": 570,
          "y": 1290,
          "wires": [
          "84d8358e.688908"
          "id": "84d8358e.688908",
          "type": "change",
          "name": "-> Converter ->",
          "rules": [
          "t": "move",
          "p": "payload",
          "pt": "msg",
          "to": "payload.rgb",
          "tot": "msg"
          "action": "",
          "property": "",
          "from": "",
          "to": "",
          "reg": false,
          "x": 740,
          "y": 1290,
          "wires": [
          "7bd5f7d8.5e0f58"
          "id": "d5d520c8.c3118",
          "type": "hue-bridge",
          "z": "",
          "name": "Philips hue",
          "bridge": "1.2.3.103",
          "key": "*****",
          "interval": "1000"
          "id": "b91f3657.228818",
          "type": "alexa-home-conf",
          "z": "",
          "username": "
          return [msg, null];
          return [null, msg];
          return [null, msg];
          • R Offline
            rewenode
            Nur zu, im Prinzip weist du ja jetzt wie es geht ;-)
              Blackeye
              ich habe ein Problem mit der Range des Dimmers. Der Dimmer möchte 0-100 und Alexa 0-1.
              Hier ist mein "Flow" der HomeKit Dimmer kommt da anschl. auch noch dran….
              [{"id":"40e9814d.216b7","type":"change","z":"e742a326.057cb","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"100","tot":"num"},{"t":"set","p":"payload","pt":"msg","to":"bri","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":507.4999694824219,"y":218.33334922790527,"wires":[["286a0677.93840a"]]}]
              • R Offline
                rewenode
                @Blackeye:
                ich habe ein Problem mit der Range des Dimmers. Der Dimmer möchte 0-100 und Alexa 0-1. `
                Was heisst Alexa 0-1 ? Alexa liefert dir einen Wert von 0-1 und der soll nach 0-100 umgesetzt werden?
                  Blackeye
                  genau so…..
                  • R Offline
                    rewenode
                    @Blackeye:
                    genau so….. `
                    Na wie wäre es, wenn du den von Alexa kommenden Wert 0-1 einfach mit 100 multiplizierst ?
                      Blackeye
                      ja auf die Idee bin ich auch gekommen, finde nur nirgendwo wie ich das mache.
                      Lars
                      • R Offline
                        rewenode
                        Sollte so gehen:
                        • F Offline
                          Frank_y
                          Range-node (Standard)
                          • R Offline
                            rewenode
                            @Frank_y:
                            Range-node (Standard) `
                            Klar geht das. Der Sinn will sich mir aber nicht erschließen, wo er den change doch schon drin hat;-)
