  4. Node-Red mit Alexa - Dimmer
    5.8k
39 Beiträge 5 Kommentatoren 9.8k Aufrufe 1 Beobachtet
    dondon4002
    Perfekt :D dann hab ich nur den Converter falsch benutzt :D :D danach noch nen Change to msg.payload.rgb und Alexa schaltet das ganze :-) Danke dir
    • R Offline
      rewenode
      @dondon4002:
      … Change to msg.payload.rgb `
      Exakt so :D falls nötig
        dondon4002
        Für alle die dann noch Bedarf daran haben :-)
        Ich mache es am Ende doch per Blockly denn es kommen ja noch Abfragen wie TurnOnRequest, TunOffRequest und was Alexa noch alles so bietet.
        "id": "6a18e5be.c9abdc",
        "type": "Blockly",
        "z": "9433ac39.c5756",
        "language": "en",
        "func": "if ((msg['command']) == 'SetColorRequest') {\n msg['payload'] = [(msg['payload']['hue']), (msg['payload']['saturation']) * 100, (msg['payload']['brightness']) * 100];\n return [msg, null];\n} else if ((msg['command']) == 'TurnOffRequest') {\n msg['payload'] = false;\n return [null, msg];\n} else if ((msg['command']) == 'TurnOnRequest') {\n msg['payload'] = true;\n return [null, msg];\n}\n",
        "workspaceXml": "<xml xmlns="&quot;http://www.w3.org/1999/xhtml\&quot;"><block id="&quot;OegDmw1SSX]D=Pa(8G75&quot;" type="&quot;controls_if&quot;" x="&quot;-2037&quot;" y="&quot;-387&quot;"><mutation elseif="&quot;2&quot;"></mutation><value name="&quot;IF0&quot;"><block id="&quot;GconiS<value name="&quot;IF0&quot;"ihVrBvHEiKZu&quot;" type="&quot;logic_compare&quot;"><field name="&quot;OP&quot;">EQ</field><value name="&quot;A&quot;"><block id="&quot;qfEv5p}Q.6(4bAAhVY)t&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;8Rf40:s+-(Iix/~rpXuB&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;3K$0p{%[oP^XO:,{IhsI&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">command</field></shadow></value></block></value><value name="&quot;B&quot;"><block id="&quot;Gu~Z4BXhmh4D%LOE{4s-&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">SetColorRequest</field></block></value></block></value><statement name="&quot;DO0&quot;"><block id="&quot;Wz6Dr1k2)tZbJ[+?V+j{&quot;" type="&quot;node_object_set&quot;"><value name="&quot;object_field&quot;"><shadow id="&quot;N7nV^CQPdk8cxV}?9mWX&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;cZ6WgGkQ{3ya8z~VBE3\&quot;" type="\&quot;text\&quot;"><field name="\&quot;TEXT\&quot;">payload</field></shadow></value><value name="\&quot;value_field\&quot;"><shadow id="\&quot;sk?O05P5ma_5vqc{!#)&quot;" type="&quot;text&quot;"></shadow><block id="&quot;Md|@A(]N!kq$=b3)[SH!&quot;" type="&quot;lists_create_with&quot;"><mutation items="&quot;3&quot;"></mutation><value name="&quot;ADD0&quot;"><block id="&quot;tu7-Qe3u+zsXsItw[,yY&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;4WDpncvt3q4gpN@S@MfM&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;@d+[0zA[c(D{jmlYd^%O&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">payload.hue</field></shadow></value></block></value><value name="&quot;ADD1&quot;"><block id="&quot;!Q#d8F/fCDqPNsm,6Z+&quot;" type="&quot;math_arithmetic&quot;"><field name="&quot;OP&quot;">MULTIPLY</field><value name="&quot;A&quot;"><shadow id="&quot;bNOGt$4!S%VQ?:vfS1V.&quot;" type="&quot;math_number&quot;"><field name="&quot;NUM&quot;">1</field></shadow><block id="&quot;cl:38kKKmak%V3E!m2}T&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;8+vu8BKKc)fZo;rSk0[D&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;FzE=$C.cumV)e3g*!;0\&quot;" type="\&quot;text\&quot;"><field name="\&quot;TEXT\&quot;">payload.saturation</field></shadow></value></block></value><value name="\&quot;B\&quot;"><shadow id="\&quot;p$RJ=}@6=xX[Ekbiqfn^\&quot;" type="\&quot;math_number\&quot;"><field name="\&quot;NUM\&quot;">100</field></shadow></value></block></value><value name="\&quot;ADD2\&quot;"><block id="\&quot;K[@!p?t]Y]0YY,I]]Y=3\&quot;" type="\&quot;math_arithmetic\&quot;"><field name="\&quot;OP\&quot;">MULTIPLY</field><value name="\&quot;A\&quot;"><shadow id="\&quot;12luhGJPp}BppnOnCd]t\&quot;" type="\&quot;math_number\&quot;"><field name="\&quot;NUM\&quot;">1</field></shadow><block id="\&quot;hu/B]c6@]lE@cn^qMa!I\&quot;" type="\&quot;node_object_get\&quot;"><mutation action="\&quot;GET\&quot;"></mutation><field name="\&quot;action\&quot;">GET</field><value name="\&quot;object\&quot;"><shadow id="\&quot;$2{@U|#45m9O#sYMG_HL\&quot;" type="\&quot;node_msg\&quot;"></shadow></value><value name="\&quot;field_name\&quot;"><shadow id="\&quot;9q^k;%a@6pz!wwSL[S\&quot;" type="\&quot;text\&quot;"><field name="\&quot;TEXT\&quot;">payload.brightness</field></shadow></value></block></value><value name="\&quot;B\&quot;"><shadow id="\&quot;H7P5:v+4jC%4eNSZg1b3\&quot;" type="\&quot;math_number\&quot;"><field name="\&quot;NUM\&quot;">100</field></shadow></value></block></value></block></value><next><block id="\&quot;dj6-iR8:4O-+v*!D~,M-\&quot;" type="\&quot;node_return_message\&quot;"><field name="\&quot;OUTPUT_NR\&quot;">1</field><value name="\&quot;MESSAGE_INPUT\&quot;"><shadow id="\&quot;!e8R2#N8Jdu(EAVQ{|&quot;" type="&quot;node_msg&quot;"></shadow></value></block></next></block></statement><value name="&quot;IF1&quot;"><block id="&quot;Gt#y.gqIL,qm)]{hhHC&quot;" type="&quot;logic_compare&quot;"><field name="&quot;OP&quot;">EQ</field><value name="&quot;A&quot;"><block id="&quot;N6$q19G#S0_xYH%PxSEI&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;x(P(iAF[acHUJa%K1WW0&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;401Ct:?6f$=h/.@%JFf=&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">command</field></shadow></value></block></value><value name="&quot;B&quot;"><block id="&quot;E:%o.01_qWbolte})n[}&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">TurnOffRequest</field></block></value></block></value><statement name="&quot;DO1&quot;"><block id="&quot;6=mvJ%:D4qf|CDFfAg[z&quot;" type="&quot;node_object_set&quot;"><value name="&quot;object_field&quot;"><shadow id="&quot;ABbAcS^Mj_]u:G0bmbxl&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;to=(u!-hoz(ZB|X@F7;&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">payload</field></shadow></value><value name="&quot;value_field&quot;"><shadow id="&quot;6?#earD4R8~?M5_1Y1va&quot;" type="&quot;text&quot;"></shadow><block id="&quot;gSN[vp0Vp@iiKOCKXZxO&quot;" type="&quot;logic_boolean&quot;"><field name="&quot;BOOL&quot;">FALSE</field></block></value><next><block id="&quot;8Lt@[lrf:,v#bz#My!,~&quot;" type="&quot;node_return_message&quot;"><field name="&quot;OUTPUT_NR&quot;">2</field><value name="&quot;MESSAGE_INPUT&quot;"><shadow id="&quot;ac^):!N/SuXK+m#l6G{e&quot;" type="&quot;node_msg&quot;"></shadow></value></block></next></block></statement><value name="&quot;IF2&quot;"><block id="&quot;:%iB^77hKA%5#Y]m3(KI&quot;" type="&quot;logic_compare&quot;"><field name="&quot;OP&quot;">EQ</field><value name="&quot;A&quot;"><block id="&quot;bZZ%2UXkY4qB_Fmae68&quot;" type="&quot;node_object_get&quot;"><mutation action="&quot;GET&quot;"></mutation><field name="&quot;action&quot;">GET</field><value name="&quot;object&quot;"><shadow id="&quot;O;dMHWtpMY{zN1](^WQa&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;C0O}w0bo=c,,_#.[I9Gf&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">command</field></shadow></value></block></value><value name="&quot;B&quot;"><block id="&quot;e5e|,AqRBMdDQ|~s?uv9&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">TurnOnRequest</field></block></value></block></value><statement name="&quot;DO2&quot;"><block id="&quot;|DY5/yaj[#aVyjA:qNS&quot;" type="&quot;node_object_set&quot;"><value name="&quot;object_field&quot;"><shadow id="&quot;ee@E0k_unaE#!Ss=xdAB&quot;" type="&quot;node_msg&quot;"></shadow></value><value name="&quot;field_name&quot;"><shadow id="&quot;h]@6ikfpmr#ni-9FWDmN&quot;" type="&quot;text&quot;"><field name="&quot;TEXT&quot;">payload</field></shadow></value><value name="&quot;value_field&quot;"><shadow id="&quot;6?#earD4R8~?M5_1Y1va&quot;" type="&quot;text&quot;"></shadow><block id="&quot;c3@@`D0S$O}J_N]-B5lf&quot;" type="&quot;logic_boolean&quot;"><field name="&quot;BOOL&quot;">TRUE</field></block></value><next><block id="&quot;%R}_.z4(NfAy?#=Gv44&quot;" type="&quot;node_return_message&quot;"><field name="&quot;OUTPUT_NR&quot;">2</field><value name="&quot;MESSAGE_INPUT&quot;"><shadow id="&quot;}z$f11Tsy#/HuS(JG_Z&quot;" type="&quot;node_msg&quot;"></shadow></value></block></next></block></statement></block></xml>",
        "outputs": 2,
        "name": "",
        "x": 390,
        "y": 1320,
        "wires": [
        "aeec5dac.065a9"
        "7bd5f7d8.5e0f58"
        "id": "7bd5f7d8.5e0f58",
        "type": "hue-light",
        "name": "Lampe_Buero_LedStrip",
        "bridge": "d5d520c8.c3118",
        "lightid": "9",
        "colornamer": true,
        "x": 960,
        "y": 1330,
        "wires": [
        "id": "8259bb25.207dc8",
        "type": "alexa-home",
        "conf": "b91f3657.228818",
        "device": "43026",
        "acknoledge": true,
        "name": "Test",
        "topic": "",
        "x": 240,
        "y": 1320,
        "wires": [
        "6a18e5be.c9abdc"
        "id": "aeec5dac.065a9",
        "type": "color-convert",
        "input": "hsv",
        "output": "rgb",
        "outputType": "array",
        "x": 570,
        "y": 1290,
        "wires": [
        "84d8358e.688908"
        "id": "84d8358e.688908",
        "type": "change",
        "name": "-> Converter ->",
        "rules": [
        "t": "move",
        "p": "payload",
        "pt": "msg",
        "to": "payload.rgb",
        "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 740,
        "y": 1290,
        "wires": [
        "7bd5f7d8.5e0f58"
        "id": "d5d520c8.c3118",
        "type": "hue-bridge",
        "z": "",
        "name": "Philips hue",
        "bridge": "1.2.3.103",
        "key": "*****",
        "interval": "1000"
        "id": "b91f3657.228818",
        "type": "alexa-home-conf",
        "z": "",
        "username": "
        return [msg, null];
        return [null, msg];
        return [null, msg];
        • R Offline
          rewenode
          Nur zu, im Prinzip weist du ja jetzt wie es geht ;-)
            Blackeye
            ich habe ein Problem mit der Range des Dimmers. Der Dimmer möchte 0-100 und Alexa 0-1.
            Hier ist mein "Flow" der HomeKit Dimmer kommt da anschl. auch noch dran….
            [{"id":"40e9814d.216b7","type":"change","z":"e742a326.057cb","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"100","tot":"num"},{"t":"set","p":"payload","pt":"msg","to":"bri","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":507.4999694824219,"y":218.33334922790527,"wires":[["286a0677.93840a"]]}]
            • R Offline
              rewenode
              @Blackeye:
              ich habe ein Problem mit der Range des Dimmers. Der Dimmer möchte 0-100 und Alexa 0-1. `
              Was heisst Alexa 0-1 ? Alexa liefert dir einen Wert von 0-1 und der soll nach 0-100 umgesetzt werden?
                Blackeye
                genau so…..
                • R Offline
                  rewenode
                  @Blackeye:
                  genau so….. `
                  Na wie wäre es, wenn du den von Alexa kommenden Wert 0-1 einfach mit 100 multiplizierst ?
                    Blackeye
                    ja auf die Idee bin ich auch gekommen, finde nur nirgendwo wie ich das mache.
                    Lars
                    • R Offline
                      rewenode
                      Sollte so gehen:
                      • F Offline
                        Frank_y
                        Range-node (Standard)
                        • R Offline
                          rewenode
                          @Frank_y:
                          Range-node (Standard) `
                          Klar geht das. Der Sinn will sich mir aber nicht erschließen, wo er den change doch schon drin hat;-)
