  4. [Aufruf] Test Shelly Adapter
shellyadapter
717 Beiträge 81 Kommentatoren 262.8k Aufrufe 30 Beobachtet
    MadTrinity
    #248
    Hi
    so wie eben im Log war es vorhin die ganze zeit in einer schleife ich hoffe das hilft weiter
    ! shelly.0 2019-01-06 19:34:34.333 info Listening for Shelly packets in the network
    ! shelly.0 2019-01-06 19:34:33.990 info Starting shelly.0 in version 2.0.4
    ! shelly.0 2019-01-06 19:34:33.937 info starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.14.0
    ! host.raspberrypi 2019-01-06 19:34:31.440 info instance system.adapter.shelly.0 started with pid 4897
    ! host.raspberrypi 2019-01-06 19:34:01.409 info Restart adapter system.adapter.shelly.0 because enabled
    ! host.raspberrypi 2019-01-06 19:34:01.407 error instance system.adapter.shelly.0 terminated with code 0 (OK)
    ! shelly.0 2019-01-06 19:34:00.981 warn Exception: TypeError: Cannot read property 'startsWith' of undefined
    ! history.0 2019-01-06 19:33:57.961 info enabled logging of shelly.0.SHSW-1#22789B#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:56.146 info enabled logging of shelly.0.SHSW-1#2276E0#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:51.978 info enabled logging of shelly.0.SHSW-1#2278D3#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:51.795 info enabled logging of shelly.0.SHSW-1#32C5F0#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:51.558 info enabled logging of shelly.0.SHSW-1#22796C#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:50.476 info enabled logging of shelly.0.SHSW-1#2273F8#1.Relay0.Switch, Alias=false
    ! shelly.0 2019-01-06 19:33:48.901 info Listening for Shelly packets in the network
    ! shelly.0 2019-01-06 19:33:48.555 info Starting shelly.0 in version 2.0.4
    ! shelly.0 2019-01-06 19:33:48.501 info starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.14.0
    ! host.raspberrypi 2019-01-06 19:33:45.967 info instance system.adapter.shelly.0 started with pid 4758
    ! host.raspberrypi 2019-01-06 19:33:15.936 info Restart adapter system.adapter.shelly.0 because enabled
    ! host.raspberrypi 2019-01-06 19:33:15.935 error instance system.adapter.shelly.0 terminated with code 0 (OK)
    ! shelly.0 2019-01-06 19:33:15.884 warn Exception: TypeError: Cannot read property 'startsWith' of undefined
    ! history.0 2019-01-06 19:33:13.192 info enabled logging of shelly.0.SHSW-1#22789B#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:10.956 info enabled logging of shelly.0.SHSW-1#2276E0#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:06.997 info enabled logging of shelly.0.SHSW-1#2278D3#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:05.251 info enabled logging of shelly.0.SHSW-1#2273F8#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:04.624 info enabled logging of shelly.0.SHSW-1#32C5F0#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:04.396 info enabled logging of shelly.0.SHSW-1#22796C#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:03.614 info enabled logging of shelly.0.SHSW-1#22F1EB#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:02.565 info enabled logging of shelly.0.SHSW-1#22FA40#1.Relay0.Switch, Alias=false
    ! history.0 2019-01-06 19:33:01.809 info enabled logging of shelly.0.SHSW-1#2275D0#1.Relay0.Switch, Alias=false
    ! shelly.0 2019-01-06 19:32:59.434 info Listening for Shelly packets in the network
    ! shelly.0 2019-01-06 19:32:59.021 info Starting shelly.0 in version 2.0.4
    ! shelly.0 2019-01-06 19:32:58.968 info starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.14.0
    ! host.raspberrypi 2019-01-06 19:32:55.986 info instance system.adapter.shelly.0 started with pid 4722
    ! host.raspberrypi 2019-01-06 19:32:25.952 info Restart adapter system.adapter.shelly.0 because enabled
    ! host.raspberrypi 2019-01-06 19:32:25.951 error instance system.adapter.shelly.0 terminated with code 0 (OK)
    ! Caught 2019-01-06 19:32:25.951 error by controller[0]: context: 'Error parsing response. response: [{"device":{"type":"SHSW-21","mac":"CE50E35596D5","hostname":"shellyswitch-5596D5","num_outputs":2, "num_meters":1, "num_rollers":1},"w
    ! Caught 2019-01-06 19:32:25.951 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
    ! Caught 2019-01-06 19:32:25.950 error by controller[0]: at endReadableNT (stream_readable.js:1064:12)
    ! Caught 2019-01-06 19:32:25.950 error by controller[0]: at IncomingMessage.emit (events.js:208:7)
    ! Caught 2019-01-06 19:32:25.950 error by controller[0]: at emitNone (events.js:111:20)
    ! Caught 2019-01-06 19:32:25.949 error by controller[0]: at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:678:34)
    ! Caught 2019-01-06 19:32:25.949 error by controller[0]: at ConnectManager.handleEnd (/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:531:18)
    ! Caught 2019-01-06 19:32:25.949 error by controller[0]: at ConnectManager.handleResponse (/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:538:32)
    ! Caught 2019-01-06 19:32:25.949 error by controller[0]: at Object.parse (/opt/iobroker/node_modules/node-rest-client/lib/nrc-parser-manager.js:140:17)
    ! Caught 2019-01-06 19:32:25.948 error by controller[0]: at /opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:457:57
    ! Caught 2019-01-06 19:32:25.948 error by controller[0]: at exports.Client.emit (events.js:186:19)
    ! Caught 2019-01-06 19:32:25.947 error by controller[0]: { Error: Unhandled "error" event. (Error parsing response. response: [{"device":{"type":"SHSW-21","mac":"CE50E35596D5","hostname":"shellyswitch-5596D5","num_outputs":2, "num_meters"
    ! shelly.0 2019-01-06 19:32:25.907 info terminating
    ! shelly.0 2019-01-06 19:32:25.896 warn Exception: Error: Unhandled "error" event. (Error parsing response. response: [{"device":{"type":"SHSW-21","mac":"CE50E35596D5","hostname":"shellyswitch-5596D5","num_outputs":2, "num_meters":1, "num
    ! shelly.0 2019-01-06 19:32:25.869 error at _combinedTickCallback (internal/process/next_tick.js:139:11)
    ! shelly.0 2019-01-06 19:32:25.869 error at endReadableNT (_stream_readable.js:1064:12)
    ! shelly.0 2019-01-06 19:32:25.869 error at IncomingMessage.emit (events.js:208:7)
    ! shelly.0 2019-01-06 19:32:25.869 error at emitNone (events.js:111:20)
    ! shelly.0 2019-01-06 19:32:25.869 error at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:678:34)
    ! shelly.0 2019-01-06 19:32:25.869 error at ConnectManager.handleEnd (/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:531:18)
    ! shelly.0 2019-01-06 19:32:25.869 error at ConnectManager.handleResponse (/opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:538:32)
    ! shelly.0 2019-01-06 19:32:25.869 error at Object.parse (/opt/iobroker/node_modules/node-rest-client/lib/nrc-parser-manager.js:140:17)
    ! shelly.0 2019-01-06 19:32:25.869 error at /opt/iobroker/node_modules/node-rest-client/lib/node-rest-client.js:457:57
    ! shelly.0 2019-01-06 19:32:25.869 error at exports.Client.emit (events.js:186:19)
    ! shelly.0 2019-01-06 19:32:25.869 error Error: Unhandled "error" event. (Error parsing response. response: [{"device":{"type":"SHSW-21","mac":"CE50E35596D5","hostname":"shellyswitch-5596D5","num_outputs":2, "nu[/spoiler]</anonymous></anonymous>
    gruss
      danw
      #249
      Sieht eher nach nem Problem bei history aus
      It's not a Bug, it's a Feature
        MadTrinity
        #250
        habe gestern die history aufzeichnungen für die shelly´s deaktiviert, heute morgen war leider nicht die Lampe an die an sein sollte.
        Der log ist wieder voll
        ! host.raspberrypi 2019-01-07 04:58:37.886 info Restart adapter system.adapter.shelly.0 because enabled
        ! host.raspberrypi 2019-01-07 04:58:37.885 error instance system.adapter.shelly.0 terminated with code 0 (OK)
        ! shelly.0 2019-01-07 04:58:37.842 warn Exception: TypeError: Cannot read property 'startsWith' of undefined
        ! shelly.0 2019-01-07 04:58:31.603 info Listening for Shelly packets in the network
        ! shelly.0 2019-01-07 04:58:31.238 info Starting shelly.0 in version 2.0.4
        ! shelly.0 2019-01-07 04:58:31.185 info starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.14.0
        ! host.raspberrypi 2019-01-07 04:58:28.675 info instance system.adapter.shelly.0 started with pid 4271
        ! host.raspberrypi 2019-01-07 04:57:58.640 info Restart adapter system.adapter.shelly.0 because enabled
        ! host.raspberrypi 2019-01-07 04:57:58.639 error instance system.adapter.shelly.0 terminated with code 0 (OK)
        ! shelly.0 2019-01-07 04:57:58.593 warn Exception: TypeError: Cannot read property 'startsWith' of undefined
        ! shelly.0 2019-01-07 04:57:50.727 info Listening for Shelly packets in the network
        ! shelly.0 2019-01-07 04:57:50.363 info Starting shelly.0 in version 2.0.4
        ! shelly.0 2019-01-07 04:57:50.310 info starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.14.0
        ! host.raspberrypi 2019-01-07 04:57:47.853 info instance system.adapter.shelly.0 started with pid 4136
        ! host.raspberrypi 2019-01-07 04:57:17.821 info Restart adapter system.adapter.shelly.0 because enabled
        ! host.raspberrypi 2019-01-07 04:57:17.820 error instance system.adapter.shelly.0 terminated with code 0 (OK)
        ! shelly.0 2019-01-07 04:57:17.098 warn Exception: TypeError: Cannot read property 'startsWith' of undefined
        ! shelly.0 2019-01-07 04:57:10.946 info Listening for Shelly packets in the network
        ! shelly.0 2019-01-07 04:57:10.608 info Starting shelly.0 in version 2.0.4
        ! shelly.0 2019-01-07 04:57:10.553 info starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.14.0
        ! host.raspberrypi 2019-01-07 04:57:08.031 info instance system.adapter.shelly.0 started with pid 4113
        habe history ganz abgeschaltet doch der log füllt sich weiter
        noch eine Idee was das sein kann?
        So wie es scheint ist wiedermal ein Shelly aus dem Wlan geflogen, kann man irgendwo einstellen das der adapter weiterläuft auch wenn ein shelly aus dem Wlan fliegt?
        gruß
          danw
          #251
          Sieht immernoch nach history aus
          • StuebiS Offline
            StuebiS Offline
            Stuebi
            #252
            @danw:
            kannst Du den Fehler nachstellen? Wenn ja, bitte einmal für den Shelly Adapter den Debug Modus aktivieren und mir den Output schicken (der Teil wo der Fehler auftritt + ca. die 10 Meldungen davor und danach). Ich habe so eine Idee!
            Den Debug Modus aktivierst Du wie folgt: Gehe auf Instanzen, dort Experten Modus aktivieren und dann Log-Stufe auf debug stellen. Da sehr viel ausgegeben wird, kannst Du den Debug Modus anschließend wieder auf Info stellen.
            ioBroker auf Synology DS216+II im Docker Container
            • DiginixD Offline
              DiginixD Offline
              Diginix
              #253
              Ich habe seit dem letzten FW Update das Problem dass nach jedem true/false eines Relais für die reguläre Bewegung noch 1-2 true/false Wechsel folgen obwohl der Rollladen längst auf Endposition angekommen ist.
              ` > false true shelly.0 2019-01-09 20:30:04.222
              true true shelly.0 2019-01-09 20:30:02.456
              false true shelly.0 2019-01-09 20:30:02.401
              true true shelly.0 2019-01-09 20:30:02.390
              false true shelly.0 2019-01-09 20:30:02.336
              true true shelly.0 2019-01-09 20:29:52.976 `
              Das stört meine Blockly Logik und scheint ja auch eher ein Bug zu sein.
              ..:: So long! Tom ::..
              • StuebiS Offline
                StuebiS Offline
                Stuebi
                #254
                Seit dem Shelly FW Update oder Shelly ioBroker Adapter Update?
                • DiginixD Offline
                  DiginixD Offline
                  Diginix
                  #255
                  Gute Frage, was kam denn zuletzt? Installiere die Update immer am Tag der Erscheinung.
                  Kam FW 1.4.4 vor oder nach Adapter 2.0.4?
                  Obstacle Detection und Max Power Protection hatte ich schon deaktiviert weil ich dachte dass es an Schnee im Bereich des Rollladens liegen könnte. Ändert aber nichts an dem Verhalten.
                  Interessanterweise betrifft es gerade nur einen von zwei Rollläden. Ich starte den mal neu und beobachte.
                  • StuebiS Offline
                    StuebiS Offline
                    Stuebi
                    #256
                    @Diginix:
                    Das stört meine Blockly Logik und scheint ja auch eher ein Bug zu sein. `
                    Also ich habe probiert es nachzustellen, kann aber das Phänomen nicht nachvollziehen. Ich habe den Status Close/Open in der Shelly App geändert oder über die Shelly Objekte unten gesetzt
                    shelly.0.SHSW-21#xxxxxx#1.Shutter.Close
                    shelly.0.SHSW-21#xxxxxx#1.Shutter.Open
                    Den Status habe ich dann über folgende Objekte unten ermittelt. Diese sind bei mir diese aber nicht von true auf false oder umgekehrt kurz nacheinander gesprungen.
                    shelly.0.SHSW-21#xxxxxx#1.Relay0.Switch
                    shelly.0.SHSW-21#xxxxxx#1.Relay1.Switch
                    oder
                    shelly.0.SHSW-21#xxxxxx#1.Shutter.state
                    • DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #257
                      Der Fehler tritt bei mir bei genau einem Rollladen auf und dort nur beim Schließen.
                      An der Konfiguration hat sich nie etwas geändert. Dennoch ist es bei jedem Schließen egal aus welchem Ausgangslevel reproduzierbar.
                      Ich habe nun im Skript ein Delay damit erst nach 1Sek wieder true/false gültig ist. Im Log und History Adapter landen die sinnlosen Schaltmomente weiterhin. Aber meine Zeitmessung für die Bewegungszeit wird so wieder sauber gemessen.
                      K.a. wieso weshalb warum der Shelly2 diese sinnlosen Schaltevents auslöst.
                      • MatzebhvM Offline
                        MatzebhvM Offline
                        Matzebhv
                        #258
                        Moin,
                        habe heute einen Shelly bekommen und daher gleich mal den Adapter in Betrieb genommen. Soweit scheint alles sauber zu laufen, aber:
                        Das Ding liegt gerade ausgebaut neben mir. Da können die Werte so ja nicht stimmen. :D
                        Adapter habe ich schon neu gestartet, ist immer noch online.
                        Matze
                        • StuebiS Offline
                          StuebiS Offline
                          Stuebi
                          #259
                          @Matzebhv:
                          Moin,
                          Matze `
                          Das ist auch so gewollt. Beispiel: switch = true und WLAN fällt aus. Soll jetzt ioBroker den Wert auf true oder false setzen?
                          Nur der Status online wird angepaßt. Leider dauert das eine gewisse Zeit. Hängt mit dem CoAP Protokoll zusammen.
                          • MatzebhvM Offline
                            MatzebhvM Offline
                            Matzebhv
                            #260
                            Moin,
                            ja klar, ich meinte auch den Onlinestatus und die angezeigte Verbindungsqualität. Das Gerät lag 2 Stunden hier rum, wann merkt der Adapter das denn?
                            Matze
                              Mr.X
                              #261
                              Die Shellys und der Adapter scheinen sich zur Eierlegenden Wollmilchsau zu entwickeln.
                              Ich werde auf den Zug mit aufspringen und hoffentlich irgendwann mein defragmentiertes Haus auf ein System umrüsten.
                              Laufen die alle auch ohne Probleme, wenn man LED Beleuchtung hat? Meine jetzt normale LED Birnen, etc..
                              Da gab ja mit HM auch anfangs Probleme, oder?
                              Kann man die auch irgendwie dimmen?
                              • Daniel_ND Offline
                                Daniel_ND Offline
                                Daniel_N
                                #262
                                LEDs sind kein Problem solange kein trafo mit dran hängt… durch hohe einschaltströme bei trafos kann(muss nicht) der shelly abrauchen. Habe bisher ohne Probleme e27 gu10 Spots und eine energiesparleuchte eingebunden...
                                Gesendet von meinem SM-G950F mit Tapatalk
                                  Mr.X
                                  #263
                                  Supi, danke.
                                  Habe soeben einen Shelly 1 und 2 zum ausprobieren bestellt.
                                  Aber sind erst ab dem 25.Jan wieder lieferbar.
                                  Denkt ihr die können evtl irgendwann eine Dimmfunktion per SW update bringen?
                                  Kann man am Schalter nach wie vor ganz klassisch schalten, wenn es mal kein Wlan gibt?
                                  • DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #264
                                    Shelly1+2 sind reine Relais, damit kann man nur 0 oder 1 (an/aus) schalten. Dimmen kann man damit imho nicht. Auch nicht per Software Update.
                                    Auch ohne WLAN kann man weiterhin per manuellem Schalter die Rollläden/Geräte/Lichter schalten.
                                      danw
                                      #265
                                      Dimmer soll noch kommen.
                                      Shelly 1 mit Power Management ist angekündigt.
                                        Mr.X
                                        #266
                                        Danke an alle für die Infos, und sorry, dass ich diesen Thread hier so hijacke.
                                        Woher bekommt man Infos über neue Produkte?
                                        Habe vorhin Shelly angeschrieben, ob die noch irgendwie vorhaben die Shelly Smokes wirklich smart zu machen, und sie untereinander connecten.
                                          danw
                                          #267
                                          Über die Facebook Gruppe wird aktiv kommuniziert
                                          StuebiS 1 Antwort Letzte Antwort
