  4. Installation ioBroker auf Cubietruck
    5.4k
176 Beiträge 19 Kommentatoren 51.6k Aufrufe
  • H Offline
    hobbyquaker
    hmm lass mal bitte die /etc/couchdb/default.ini sehen
      @hobbyquaker:
      hmm lass mal bitte die /etc/couchdb/default.ini sehen `
      Zu deinem vergnügen; Äh Verfügung ;-)
      ; etc/couchdb/default.ini.tpl.  Generated from default.ini.tpl.in by configure.
      ; Upgrading CouchDB will overwrite this file.
      [couchdb]
      database_dir = /var/lib/couchdb/1.2.0
      view_index_dir = /var/lib/couchdb/1.2.0
      util_driver_dir = /usr/lib/couchdb/erlang/lib/couch-1.2.0/priv/lib
      max_document_size = 4294967296 ; 4 GB
      os_process_timeout = 5000 ; 5 seconds. for view and external servers.
      max_dbs_open = 100
      delayed_commits = true ; set this to false to ensure an fsync before 201 Created is returned
      uri_file = /var/run/couchdb/couch.uri
      ; Method used to compress everything that is appended to database and view index files, except
      ; for attachments (see the attachments section). Available methods are:
      ; none         - no compression
      ; snappy       - use google snappy, a very fast compressor/decompressor
      ; deflate_[N]  - use zlib's deflate, N is the compression level which ranges from 1 (fastest,
      ;                lowest compression ratio) to 9 (slowest, highest compression ratio)
      file_compression = snappy
      [database_compaction]
      ; larger buffer sizes can originate smaller files
      doc_buffer_size = 524288 ; value in bytes
      checkpoint_after = 5242880 ; checkpoint after every N bytes were written
      [view_compaction]
      keyvalue_buffer_size = 2097152 ; value in bytes
      [httpd]
      port = 5984
      bind_address = 127.0.0.1
      authentication_handlers = {couch_httpd_oauth, oauth_authentication_handler}, {couch_httpd_auth, cookie_authentication_handler}, {couch_httpd_auth, default_authentication_handler}
      default_handler = {couch_httpd_db, handle_request}
      secure_rewrites = true
      vhost_global_handlers = _utils, _uuids, _session, _oauth, _users
      allow_jsonp = false
      ; Options for the MochiWeb HTTP server.
      ;server_options = [{backlog, 128}, {acceptor_pool_size, 16}]
      ; For more socket options, consult Erlang's module 'inet' man page.
      ;socket_options = [{recbuf, 262144}, {sndbuf, 262144}, {nodelay, true}]
      log_max_chunk_size = 1000000
      [ssl]
      port = 6984
      [log]
      file = /var/log/couchdb/couch.log
      level = info
      include_sasl = true
      [couch_httpd_auth]
      authentication_db = _users
      authentication_redirect = /_utils/session.html
      require_valid_user = false
      timeout = 600 ; number of seconds before automatic logout
      auth_cache_size = 50 ; size is number of cache entries
      allow_persistent_cookies = false ; set to true to allow persistent cookies
      [couch_httpd_oauth]
      ; If set to 'true', oauth token and consumer secrets will be looked up
      ; in the authentication database (_users). These secrets are stored in
      ; a top level property named "oauth" in user documents. Example:
      ;         "_id": "org.couchdb.user:joe",
      ;         "type": "user",
      ;         "name": "joe",
      ;         "password_sha": "fe95df1ca59a9b567bdca5cbaf8412abd6e06121",
      ;         "salt": "4e170ffeb6f34daecfd814dfb4001a73"
      ;         "roles": ["foo", "bar"],
      ;         "oauth": {
      ;             "consumer_keys": {
      ;                 "consumerKey1": "key1Secret",
      ;                 "consumerKey2": "key2Secret"
      ;             "tokens": {
      ;                 "token1": "token1Secret",
      ;                 "token2": "token2Secret"
      use_users_db = false
      [query_servers]
      javascript = /usr/bin/couchjs /usr/share/couchdb/server/main.js
      coffeescript = /usr/bin/couchjs /usr/share/couchdb/server/main-coffee.js
      ; Changing reduce_limit to false will disable reduce_limit.
      ; If you think you're hitting reduce_limit with a "good" reduce function,
      ; please let us know on the mailing list so we can fine tune the heuristic.
      [query_server_config]
      reduce_limit = true
      os_process_limit = 25
      [daemons]
      view_manager={couch_view, start_link, []}
      external_manager={couch_external_manager, start_link, []}
      query_servers={couch_query_servers, start_link, []}
      vhosts={couch_httpd_vhost, start_link, []}
      httpd={couch_httpd, start_link, []}
      stats_aggregator={couch_stats_aggregator, start, []}
      stats_collector={couch_stats_collector, start, []}
      uuids={couch_uuids, start, []}
      auth_cache={couch_auth_cache, start_link, []}
      replication_manager={couch_replication_manager, start_link, []}
      os_daemons={couch_os_daemons, start_link, []}
      compaction_daemon={couch_compaction_daemon, start_link, []}
      [httpd_global_handlers]
      / = {couch_httpd_misc_handlers, handle_welcome_req, <<"Welcome">>}
      favicon.ico = {couch_httpd_misc_handlers, handle_favicon_req, "/usr/share/couchdb/www"}
      _utils = {couch_httpd_misc_handlers, handle_utils_dir_req, "/usr/share/couchdb/www"}
      _all_dbs = {couch_httpd_misc_handlers, handle_all_dbs_req}
      _active_tasks = {couch_httpd_misc_handlers, handle_task_status_req}
      _config = {couch_httpd_misc_handlers, handle_config_req}
      _replicate = {couch_httpd_replicator, handle_req}
      _uuids = {couch_httpd_misc_handlers, handle_uuids_req}
      _restart = {couch_httpd_misc_handlers, handle_restart_req}
      _stats = {couch_httpd_stats_handlers, handle_stats_req}
      _log = {couch_httpd_misc_handlers, handle_log_req}
      _session = {couch_httpd_auth, handle_session_req}
      _oauth = {couch_httpd_oauth, handle_oauth_req}
      [httpd_db_handlers]
      _view_cleanup = {couch_httpd_db, handle_view_cleanup_req}
      _compact = {couch_httpd_db, handle_compact_req}
      _design = {couch_httpd_db, handle_design_req}
      _temp_view = {couch_httpd_view, handle_temp_view_req}
      _changes = {couch_httpd_db, handle_changes_req}
      ; The external module takes an optional argument allowing you to narrow it to a
      ; single script. Otherwise the script name is inferred from the first path section
      ; after _external's own path.
      ; _mypath = {couch_httpd_external, handle_external_req, <<"mykey">>}
      ; _external = {couch_httpd_external, handle_external_req}
      [httpd_design_handlers]
      _view = {couch_httpd_view, handle_view_req}
      _show = {couch_httpd_show, handle_doc_show_req}
      _list = {couch_httpd_show, handle_view_list_req}
      _info = {couch_httpd_db,   handle_design_info_req}
      _rewrite = {couch_httpd_rewrite, handle_rewrite_req}
      _update = {couch_httpd_show, handle_doc_update_req}
      ; enable external as an httpd handler, then link it with commands here.
      ; note, this api is still under consideration.
      ; [external]
      ; mykey = /path/to/mycommand
      ; Here you can setup commands for CouchDB to manage
      ; while it is alive. It will attempt to keep each command
      ; alive if it exits.
      ; [os_daemons]
      ; some_daemon_name = /path/to/script -with args
      [uuids]
      ; Known algorithms:
      ;   random - 128 bits of random awesome
      ;     All awesome, all the time.
      ;   sequential - monotonically increasing ids with random increments
      ;     First 26 hex characters are random. Last 6 increment in
      ;     random amounts until an overflow occurs. On overflow, the
      ;     random prefix is regenerated and the process starts over.
      ;   utc_random - Time since Jan 1, 1970 UTC with microseconds
      ;     First 14 characters are the time in hex. Last 18 are random.
      algorithm = sequential
      [stats]
      ; rate is in milliseconds
      rate = 1000
      ; sample intervals are in seconds
      samples = [0, 60, 300, 900]
      [attachments]
      compression_level = 8 ; from 1 (lowest, fastest) to 9 (highest, slowest), 0 to disable compression
      compressible_types = text/*, application/javascript, application/json, application/xml
      [replicator]
      db = _replicator
      ; Maximum replicaton retry count can be a non-negative integer or "infinity".
      max_replication_retry_count = 10
      ; More worker processes can give higher network throughput but can also
      ; imply more disk and network IO.
      worker_processes = 4
      ; With lower batch sizes checkpoints are done more frequently. Lower batch sizes
      ; also reduce the total amount of used RAM memory.
      worker_batch_size = 500
      ; Maximum number of HTTP connections per replication.
      http_connections = 20
      ; HTTP connection timeout per replication.
      ; Even for very fast/reliable networks it might need to be increased if a remote
      ; database is too busy.
      connection_timeout = 30000
      ; If a request fails, the replicator will retry it up to N times.
      retries_per_request = 10
      ; Some socket options that might boost performance in some scenarios:
      ;       {nodelay, boolean()}
      ;       {sndbuf, integer()}
      ;       {recbuf, integer()}
      ;       {priority, integer()}
      ; See the `inet` Erlang module's man page for the full list of options.
      socket_options = [{keepalive, true}, {nodelay, false}]
      ; Path to a file containing the user's certificate.
      ;cert_file = /full/path/to/server_cert.pem
      ; Path to file containing user's private PEM encoded key.
      ;key_file = /full/path/to/server_key.pem
      ; String containing the user's password. Only used if the private keyfile is password protected.
      ;password = somepassword
      ; Set to true to validate peer certificates.
      verify_ssl_certificates = false
      ; File containing a list of peer trusted certificates (in the PEM format).
      ;ssl_trusted_certificates_file = /etc/ssl/certs/ca-certificates.crt
      ; Maximum peer certificate depth (must be set even if certificate validation is off).
      ssl_certificate_max_depth = 3
      [compaction_daemon]
      ; The delay, in seconds, between each check for which database and view indexes
      ; need to be compacted.
      check_interval = 300
      ; If a database or view index file is smaller then this value (in bytes),
      ; compaction will not happen. Very small files always have a very high
      ; fragmentation therefore it's not worth to compact them.
      min_file_size = 131072
      [compactions]
      ; List of compaction rules for the compaction daemon.
      ; The daemon compacts databases and their respective view groups when all the
      ; condition parameters are satisfied. Configuration can be per database or
      ; global, and it has the following format:
      ; database_name = [ {ParamName, ParamValue}, {ParamName, ParamValue}, ... ]
      ; _default = [ {ParamName, ParamValue}, {ParamName, ParamValue}, ... ]
      ; Possible parameters:
      ; * db_fragmentation - If the ratio (as an integer percentage), of the amount
      ;                      of old data (and its supporting metadata) over the database
      ;                      file size is equal to or greater then this value, this
      ;                      database compaction condition is satisfied.
      ;                      This value is computed as:
      ;                           (file_size - data_size) / file_size * 100
      ;                      The data_size and file_size values can be obtained when
      ;                      querying a database's information URI (GET /dbname/).
      ; * view_fragmentation - If the ratio (as an integer percentage), of the amount
      ;                        of old data (and its supporting metadata) over the view
      ;                        index (view group) file size is equal to or greater then
      ;                        this value, then this view index compaction condition is
      ;                        satisfied. This value is computed as:
      ;                        querying a view group's information URI
      ;                        (GET /dbname/_design/groupname/_info).
      ; * from _and_ to - The period for which a database (and its view groups) compaction
      ;                   is allowed. The value for these parameters must obey the format:
      ;                   HH:MM - HH:MM  (HH in [0..23], MM in [0..59])
      ; * strict_window - If a compaction is still running after the end of the allowed
      ;                   period, it will be canceled if this parameter is set to 'true'.
      ;                   It defaults to 'false' and it's meaningful only if the *period*
      ;                   parameter is also specified.
      ; * parallel_view_compaction - If set to 'true', the database and its views are
      ;                              compacted in parallel. This is only useful on
      ;                              certain setups, like for example when the database
      ;                              and view index directories point to different
      ;                              disks. It defaults to 'false'.
      ; Before a compaction is triggered, an estimation of how much free disk space is
      ; needed is computed. This estimation corresponds to 2 times the data size of
      ; the database or view index. When there's not enough free disk space to compact
      ; a particular database or view index, a warning message is logged.
      ; Examples:
      ; 1) [{db_fragmentation, "70%"}, {view_fragmentation, "60%"}]
      ;    The `foo` database is compacted if its fragmentation is 70% or more.
      ;    Any view index of this database is compacted only if its fragmentation
      ;    is 60% or more.
      ; 2) [{db_fragmentation, "70%"}, {view_fragmentation, "60%"}, {from, "00:00"}, {to, "04:00"}]
      ;    Similar to the preceding example but a compaction (database or view index)
      ;    is only triggered if the current time is between midnight and 4 AM.
      ; 3) [{db_fragmentation, "70%"}, {view_fragmentation, "60%"}, {from, "00:00"}, {to, "04:00"}, {strict_window, true}]
      ;    Similar to the preceding example - a compaction (database or view index)
      ;    is only triggered if the current time is between midnight and 4 AM. If at
      ;    4 AM the database or one of its views is still compacting, the compaction
      ;    process will be canceled.
      ; 4) [{db_fragmentation, "70%"}, {view_fragmentation, "60%"}, {from, "00:00"}, {to, "04:00"}, {strict_window, true}, {parallel_view_compaction, true}]
      ;    Similar to the preceding example, but a database and its views can be
      ;_default = [{db_fragmentation, "70%"}, {view_fragmentation, "60%"}, {from, "23:00"}, {to, "04:00"}]
      • H Offline
        hobbyquaker
        ah, ja, da war was:
        Änder die 127.0.0.1 mal auf 0.0.0.0, dann````
        sudo /etc/init.d/couchdb restart
          @hobbyquaker:
          ah, ja, da war was: `
          aber wohl noch nicht alles :(
          root@cubie:/opt/iobroker# /etc/init.d/couchdb restart
          [ ok ] Restarting database server: couchdb.
          root@cubie:/opt/iobroker# ./iobroker setup
          couchdb connection refused
          EDIT:
          seltsamerweise lässt sich iobroker.ctrl jetzt starten:
          root@cubie:/opt/iobroker# ./iobroker start
          Starting iobroker.ctrl daemon...
          iobroker.ctrl daemon started. PID: 24262
          nur zur Info:
          • Igor pecovnics Debian Image 2.5
          • installiert auf SD
          • das erste mal mit DHCP
            Ich habe "mal eben" den Cubie platt gemacht, neu aufgesetzt und zwei Änderungen durchgeführt.
            1.) beim ersten mal hatte ich kein apt-get update && apt-get upgrade gefahren.
            diesmal kamen 3 Pakete, u.a. openssl (!?)
            2.) habe dann DIREKT in der /opt/iobroker/package.json die Zeile mit dem node-windows gelöscht
            Anschließend erstmalig npm install –production ausgeführt.
            Ab hier lief es alles fast störungsfrei.
            Lediglich:
            npm http 200 https://registry.npmjs.org/errs/-/errs-0.2.4.tgz
            > hiredis@0.1.17 install /opt/iobroker/node_modules/hiredis
            > node-gyp rebuild
            gyp http GET http://nodejs.org/dist/v0.10.22/node-v0.10.22.tar.gz
            gyp http 200 http://nodejs.org/dist/v0.10.22/node-v0.10.22.tar.gz
            gyp ERR! build error
            gyp ERR! stack Error: not found: make
            gyp ERR! stack     at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:43:28)
            gyp ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:46:29)
            gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/which.js:57:16
            gyp ERR! stack     at Object.oncomplete (fs.js:107:15)
            gyp ERR! System Linux 3.4.101-sun7i+
            gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/hiredis
            gyp ERR! node -v v0.10.22
            gyp ERR! node-gyp -v v0.11.0
            gyp ERR! not ok
            npm http GET https://registry.npmjs.org/combined-stream
            sowie die Warnung:
            npm http 304 https://registry.npmjs.org/cryptiles
            npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
            npm WARN optional dep failed, continuing hiredis@0.1.17
            npm http 304 https://registry.npmjs.org/combined-stream
            npm http GET https://registry.npmjs.org/sntp/-/sntp-0.1.4.tgz
            npm http GET https://registry.npmjs.org/hoek/-/hoek-0.7.6.tgz
            npm http GET https://registry.npmjs.org/boom/-/boom-0.3.8.tgz
            npm http GET https://registry.npmjs.org/cryptiles/-/cryptiles-0.1.3.tgz
            npm http 200 https://registry.npmjs.org/sntp/-/sntp-0.1.4.tgz
            npm http 200 https://registry.npmjs.org/boom/-/boom-0.3.8.tgz
            npm http 200 https://registry.npmjs.org/hoek/-/hoek-0.7.6.tgz
            npm http 200 https://registry.npmjs.org/cryptiles/-/cryptiles-0.1.3.tgz
            npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
            npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
            npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
            npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})
            wake_on_lan@0.0.3 node_modules/wake_on_lan
            wobei das wohl wieder ein Problem mit der Versionsbezeichnung (0.10 ist ja weniger als 0.8) zu sein scheint
            Bei tail -f log/iobroker.log erscheint folgendes:
            root@cubie:/opt/iobroker#  tail -f log/iobroker.log
            2014-08-08 21:32:11.300  - info: ctrl ip: 192.168.2.183 fe80::f:6ff:fe01:21b0
            2014-08-08 21:32:14.089  - info: ctrl 1 instance found
            2014-08-08 21:32:14.122  - info: ctrl instance system.adapter.admin.0 started with pid 3916
            2014-08-08 21:32:19.884  - info: admin.0 starting
            2014-08-08 21:32:19.946  - info: admin.0 requesting all states
            2014-08-08 21:32:19.956  - info: admin.0 requesting all objects
            2014-08-08 21:32:19.980  - info: admin.0 http server listening on port 8080
            2014-08-08 21:32:20.117  - info: admin.0 received all objects
            2014-08-08 21:32:20.223  - info: admin.0 received all states
            2014-08-08 21:32:30.822  - info: admin.0 Cannot detect user: Cannot detect user"
            User?????
            Ich habe alles erst einmal als root gemacht - war das das mit dem pi???
            letztendlich sieht es so aus:
            Adapter kann man wohl (noch) nicht über die WebUI hinzufügen und dass da die ganze Zeit Loading steht ist auch normal?
            Unter Events wird die Liste immer länger, besteht aber im Prinzip nur aus den Zeilen:
            stateChange	system.adapter.admin.0.alive	{"val":true,"ack":true,"ts":1407527105,"lc":1407526340}
            stateChange	system.host.cubie.mem	{"val":"76","ack":true,"ts":1407527099,"lc":1407526349}
            stateChange	system.host.cubie.load	{"val":"0.45","ack":true,"ts":1407527099,"lc":1407527099}
            stateChange	system.host.cubie.alive	{"val":true,"ack":true,"ts":1407527099,"lc":1407526334}
            Ich denke, dass ist alles soweit in Ordnung und freue mich schon auf weitere Entwicklungen.
            Danke für eure Arbeit
              Hallo nochmal,
              ich habe gerade ein Update mit git pull versucht und bekomme folgende Meldung:
              root@cubie:/opt/iobroker# git pull
              Updating ae52e20..17d3583
              error: Your local changes to the following files would be overwritten by merge:
                      package.json
              Please, commit your changes or stash them before you can merge.
              Aborting
              Ich nehme an, dass es sich hier um die WIN Parameter handelt und ihr die jetzt ebenfalls geändert habt.
              Wie kann ich das überschreiben akzeptieren?
              Außerdem habe ich wegen der Fehlermeldung make installiert und den Ordner node_modules gelöscht und anschließend npm install –production gestartet.
              jetzt bekomme ich folgende Fehlermeldung:
              npm http 304 https://registry.npmjs.org/eyes
              > node-gyp rebuild
              make: Entering directory `/opt/iobroker/node_modules/hiredis/build'
                CC(target) Release/obj.target/hiredis/deps/hiredis/hiredis.o
              make: cc: Command not found
              make: *** [Release/obj.target/hiredis/deps/hiredis/hiredis.o] Error 127
              make: Leaving directory `/opt/iobroker/node_modules/hiredis/build'
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
              gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
              gyp ERR! not ok
              npm http GET https://registry.npmjs.org/follow
                da ihr anscheinend Tag und Nacht an dem Projekt arbeitet :shock: habe ich den CT nochmals neu aufgesetzt.
                Folgende Änderungen:
                • User Cubie angelegt und unter diesem gearbeitet
                • make installiert
                trotzdem kam bei npm immer noch folgende Fehlermeldung:
                > node-gyp rebuild
                gyp ERR! not ok
                npm http GET https://registry.npmjs.org/mime
                Lief alles soweit durch, das Webinterface hat jetzt auch Daten, lediglich der nachträglich installierte hm-rega-Adapter war erst nach einem couchdb restart zu sehen.
                Dazu kam allerdings im log folgende Fehlermeldung:
                cubie@cubie:/opt/iobroker$ tail -f log/iobroker.log
                2014-08-10 14:49:28.902  - info: admin.0 requesting all states
                2014-08-10 14:49:28.911  - info: admin.0 requesting all objects
                2014-08-10 14:49:28.944  - info: admin.0 http server listening on port 8080
                2014-08-10 14:49:29.134  - info: admin.0 received all objects
                2014-08-10 14:49:29.205  - info: admin.0 received all states
                2014-08-10 14:51:49.693  - info: ctrl object change system.adapter.hm-rega.0
                2014-08-10 14:51:49.719  - info: ctrl instance system.adapter.hm-rega.0 started with pid 4203
                2014-08-10 14:51:55.567  - info: hm-rega.0 starting
                2014-08-10 14:51:55.584  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                2014-08-10 14:53:00.232  - error: hm-rega.0 CCU 172.16.23.3 unreachable
                Hier muss wohl die IP-Adresse der CCU rein - aber wie?
                Ein Zugriff auf die Datenbank per Futon (http://192.168.xxx.yyy:5984/_utils/) klappt leider nicht.
                Ansonsten mal wieder eine Super Arbeit.
                • H Offline
                  hobbyquaker
                  @Homoran:
                  Ein Zugriff auf die Datenbank per Futon (http://192.168.xxx.yyy:5984/_utils/) klappt leider nicht. `
                  Tausche mal in der Datei /etc/couchdb/local.ini folgende Zeile
                  ;bind_address = 127.0.0.1
                  gegen diese Zeile aus:
                  bind_address = 0.0.0.0
                  und starte dann CouchDB neu:
                  @Homoran:
                  Hier muss wohl die IP-Adresse der CCU rein - aber wie? `
                  Es gibt noch keine Adapter-Settings Seiten, Du kannst das entweder via Futon im Objekt hm-rpc.0 (am besten in Futon oben rechts View System/Instance auswählen) oder über das Admin-UI im Reiter Instances machen (dort die Adapter-Instanz markieren und dann unten links auf den kleinen bearbeiten-Button)
                    Hallo HQ,
                    @hobbyquaker:
                    Es gibt noch keine Adapter-Settings Seiten, … `
                    um Himmels Willen, das war mir doch klar, ich wollte nur eine Erklärung für die fehlermeldung haben :oops:
                    EDIT:
                    mit der 0.0.0.0 klappt es!
                    ! Das ändern der bind-adress hat leider nicht geholfen :(
                    ! die IP ist doch die des Cubie, oder hat die CouchDB eine eigene IP?
                    Ich hatte beim Versuch des couchDB restart noch den Befehl vom Anlegen des rega-Adapters im Zwischenspeicher - jetzt habe ich 3 davon ;-)
                    allerdings sieht es unter instances so aus:
                    Was mir sonst noch aufgefallen ist, ist der Speicherverbrauch:
                    Sind das 71% ? Bei 2 GB Memory vom Cubie ist das aber doch heftig, oder?
                    EDIT2:
                    Habe eben einen Wert von 84 gehabt, top gibt folgendes aus:
                    KiB Mem:   2047968 total,   323968 used,  1724000 free,    11604 buffers
                    Das sind etwa 16%; dann sind das wohl 84% free Memory ;-)
                    Jetzt aber bitte keine operative Hektik, das sind nur Hinweise, keine Kritik!!!
                    EDIT:
                    WOWWWW!!!
                    Habe jetzt alle(?) Datenpunkte von meiner CCU - Wahnsinn; und das mit den mehreren rega-Adaptern deutet ja wohl darauf hin, dass mehrere CCUs abgefragt werden können!
                    Na da bin ich ja mal gespannt!!! :!: :!:
                      Hallo HQ, Hallo Bluefox,
                      Zur Info:
                      Habe eben mal einen git pull gemacht.
                      danach einen:
                      2014-08-10 20:56:37.857  - info: hm-rega.0 deleted 0 variables
                      2014-08-10 20:56:57.795  - error: hm-rega.1 CCU 172.16.23.3 unreachable
                      2014-08-10 20:57:03.234  - error: hm-rega.2 CCU 172.16.23.3 unreachable
                      2014-08-10 22:36:57.059  - error: hm-rega.0 post request error: connect EHOSTUNREACH
                      2014-08-10 22:37:09.294  - error: ctrl instance system.adapter.hm-rega.0 terminated with code 8
                      2014-08-10 22:37:39.337  - info: ctrl instance system.adapter.hm-rega.0 started with pid 2645
                      2014-08-10 22:37:42.503  - info: hm-rega.0 starting
                      2014-08-10 22:37:42.519  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                      2014-08-10 22:37:44.001  - info: hm-rega.0 ReGaHSS 192.168.2.166 up
                      2014-08-10 22:37:44.034  - error: hm-rega.0 post request error: connect ECONNREFUSED
                      Habe jetzt anscheinend wirklich fast alles unter objects, nachdem da bis jetzt nur die Programme und Variablen waren.
                      Unter states sind auch jetzt nur Programme und Variablen.
                      Schlaft ihr eigentlich irgenwann einmal?
                        Hallo ihr fleißigen Bienchen ;-)
                        im Moment hacke ich mich ein wenig durch das Programm.
                        Ich weiß, dass es noch lange nicht fertig ist - das wäre ja auch zu schön, wenn man so etwas in wenigen Wochen hinbekommen könnte.
                        Wollt ihr trotzdem schon Infos haben, über etwas, was mir auffällt? (muss ja nichts zu bedeuten haben)
                        • BluefoxB Offline
                          BluefoxB Offline
                          @Homoran:
                          Rainer `
                          Natürlich. Roadmap muss auch gepflegt werden :D
                            Hallo Bluefox,
                            wie gesagt, ich weiß nicht, ob es relevant ist.
                            Nachdem ich erst irrtümlich 3x den rega-Adapter aktiviert habe, habe ich dann den hm.rega.0 mit meinem produktiven cubie verknüpft und den hm.rega.1 mit meinem Test BananaPi (RaspBian 3.0 für BananaPi). Dort habe ich testweise einen neuen Wandthermostat angelernt.
                            • Die Variable 0950 wird in beiden Fällen aber unterschiedlich dargestellt:
                              Das gleiche gilt für die var 1235
                            • Bei den instances wird bei den apatern hm.rega.1 und hm.rega.2
                              144_iobroker_instances.jpg in der Spalte enabled etwas angezeigt, das m.E da nicht hingehört.
                            • bei einem reboot des Raspi / Cubie / Banana startet iobroker nicht von selbst
                              belmondo2001
                              ich komme leider nicht weiter .
                              Beim Setup bekomme ich diese Meldung :
                              root@cubieez:/opt/iobroker# ./iobroker setup
                              Per Web kann ich auf die Webseite der couchdb zugreifen.
                              Die Änderungen von 127.0.0.1 auf 0.0.0.0 habe ich auch durchgeführt.
                              Starte ich node controller.js kommt auch eine Meldung mit Database connect
                              root@cubieez:/opt/iobroker# node controller.js
                              2014-08-16 09:21:47.775 - info: ioBroker.nodejs version 0.0.14
                              2014-08-16 09:21:47.899 - info: copyright 2014 hobbyquaker, bluefox
                              2014-08-16 09:21:47.905 - info: io.controller starting
                              2014-08-16 09:21:47.912 - info: controller ip: 192.168.100.120 2001:XXXX:XXXX:XXXX::120 fe80::1:9ff:fe81:XXXX
                              2014-08-16 09:21:53.630 - info: controller couchdb connected
                              2014-08-16 09:21:54.490 - error: controller _design/system missing - call node iobroker.js setup
                              Vielleicht hat ja jemand einen Tipp für mich.
                              mfg.
                              Jürgen
                                Hallo HQ und BF
                                Nachdem ihr wieder so fleißig wart, habe ich heute wieder ein git pull gezogen.
                                Anschließend kamen wieder jede Menge Fehlermeldungen
                                -> ioBroker stop - couchDB restart - iobroker start
                                Waren schon weniger Fehlermeldungen.
                                u.a. Verbindungsfehler zu rega.0 mit IP xxx.xxx…..
                                Ups.. Bin mit der lxccu (rega.0) vom Cubie auf den RasPi umgezogen - also in der CouchDB die IP geändert
                                Anschließend sicherheitshalber wieder -> ioBroker stop - couchDB restart - iobroker start
                                gleiche Fehlermeldung - sicherheitshalber in Futon nachgesehen - alles korrekt übernommen.
                                Das ganze Spiel 2x - Es blieb so.
                                Dann reboot vom ioBroker-Cubie
                                Jetzt war die IP von rega.0 korrekt
                                Trotzdem noch:
                                2014-08-17 11:42:32.486  - info: admin.0 received all objects
                                2014-08-17 11:42:31.354  - info: hm-rega.0 starting
                                2014-08-17 11:42:33.964  - error: pmessage TypeError: Cannot read property 'io' of null
                                2014-08-17 11:42:31.409  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                                2014-08-17 11:42:34.135  - info: hm-rega.0 ReGaHSS 192.168.xxx.yyy up
                                2014-08-17 11:42:34.206  - info: hm-rega.0 time difference local-ccu 0s
                                2014-08-17 11:42:34.385  - info: hm-rega.0 added/updated 5 favorites to enum.favorites
                                2014-08-17 11:42:34.981  - info: controller instance system.adapter.hm-rega.2 started with pid 2535
                                2014-08-17 11:42:35.361  - error: controller instance system.adapter.admin.0 terminated with code 8
                                2014-08-17 11:42:35.625  - info: hm-rega.0 added/updated 11 functions to enum.functions
                                Später jede Menge Warnungen mit:
                                2014-08-17 11:42:57.260  - warn: hm-rega.0 setObject 3851.ProgramExecute (type=state) property common.role missing!
                                2014-08-17 11:42:57.277  - warn: hm-rega.0 setObject 3851.Active (type=state) property common.role missing!
                                2014-08-17 11:42:57.320  - warn: hm-rega.0 setObject 3971.ProgramExecute (type=state) property common.role missing!
                                2014-08-17 11:42:57.328  - warn: hm-rega.0 setObject 3971.Active (type=state) property common.role missing!
                                2014-08-17 11:42:57.340  - warn: hm-rega.0 setObject 4090.ProgramExecute (type=state) property common.role missing!
                                Und zum Schluss noch nicht endend wollende Errors:
                                2014-08-17 11:43:56.970  - error: pmessage TypeError: Cannot read property 'io' of null
                                2014-08-17 11:43:56.984  - error: pmessage TypeError: Cannot read property 'io' of null
                                2014-08-17 11:43:56.993  - error: pmessage TypeError: Cannot read property 'io' of null
                                2014-08-17 11:43:56.999  - error: pmessage TypeError: Cannot read property 'io' of null
                                Und auf das WebUI vom ioBroker komme ich nicht mehr.
                                Ich hatte mal zum Spielen den Port geändert auf 8383 - lt. Futon ist er da auch noch aber weder mit 8080 noch 8383 komme ich drauf
                                • EisbaeeerE Offline
                                  EisbaeeerE Offline
                                  Eisbaeeer
                                  ich weiss, frühes Stadium. Ich hatte ein wenig Zeit und wollte ioBroker parallel zu CCU.IO installieren. Wo passe ich den HTTP Port von ioBroker an?
                                  Ich möchte meinen jetzigen ccu.io port mit 8080 nicht ändern.
                                  Gruß Eisbaeeer
                                  Kein support per PM. Bitte im Forum Fragen stellen!
                                    Ich hab es so gemacht:
                                    http://forum.iobroker.org/viewtopic.php?f=8&t=211#p743
                                    nur seit dem heutigen git pull komm ich nicht mehr drauf :(
                                      EisbaeeerE Offline
                                      Eisbaeeer
                                      Danke für den Link. Ich hatte es mal gelesen und dann nicht mehr gefunden. Ich warte noch ab, bis die beiden mal einen Tag Ihre Finger von der Tastatur lassen.
                                      Ich wollte mich in die Adapter mal einlesen, um ein wenig zu verstehen, wie ich dann meine CCU.IO Adapter anpassen muss. Aber das hat noch Zeit. Erstmal muss das ganze reifen ;-)
                                      Gruß Eisbaeeer
                                      Gesendet von meinem iPad mit Tapatalk
                                        @ Eisbaeeer
                                        ich glaube denen sind die Finger an der Tastatur bereits angewachsen ;-)
                                        alle paar Stunden gibt's was neues.
                                        @HQ und BF: aktueller Status (Antwort nicht nötig, außer ich soll was testen!):
                                        So habe ich gerade wieder ein neuen git pull gemacht.
                                        nach reboot kam dann nur noch eine Fehlermeldung:
                                        Starting ioBroker controller daemon...
                                        ioBroker controller daemon started. PID: 2374
                                        2014-08-17 14:37:26.740  - info: controller instance system.adapter.hm-rega.0 started with pid 2450
                                        2014-08-17 14:37:30.017  - info: admin.0 starting
                                        2014-08-17 14:37:30.176  - error: admin.0 port missing
                                        2014-08-17 14:37:30.207  - error: controller instance system.adapter.admin.0 terminated with code 1
                                        2014-08-17 14:37:30.728  - info: controller instance system.adapter.hm-rega.1 started with pid 2461
                                        2014-08-17 14:37:30.487  - info: hm-rega.0 starting
                                        2014-08-17 14:37:30.504  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                                        2014-08-17 14:37:32.562  - info: hm-rega.0 ReGaHSS 192.168.xxx.yyy up
                                        2014-08-17 14:37:32.637  - info: hm-rega.0 time difference local-ccu 1s
                                        2014-08-17 14:37:32.807  - info: hm-rega.0 added/updated 5 favorites to enum.favorites
                                        2014-08-17 14:37:33.603  - info: hm-rega.0 added/updated 11 functions to enum.functions
                                        2014-08-17 14:37:34.502  - info: hm-rega.0 added/updated 15 rooms to enum.rooms
                                        2014-08-17 14:37:34.756  - info: controller instance system.adapter.hm-rega.2 started with pid 2464
                                        2014-08-17 14:37:35.699  - info: hm-rega.0 extend hm-rpc.0.KEQ0120652 {"common":{"name":"3_fach_01"}}
                                        2014-08-17 14:37:36.172  - info: hm-rega.1 starting
                                        2014-08-17 14:37:36.223  - info: hm-rega.1 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                                        2014-08-17 14:37:39.247  - info: hm-rega.1 ReGaHSS 192.168.xxx.zzz up
                                        2014-08-17 14:37:39.379  - info: hm-rega.1 time difference local-ccu 0s
                                        2014-08-17 14:37:39.583  - info: hm-rega.1 added/updated 0 favorites to enum.favorites
                                        2014-08-17 14:37:35.711  - info: hm-rega.0 extend hm-rpc.0.KEQ0120652:0 {"common":{"name":"3_fach_01:0"}}
                                        Leider hängt sich dann nach dem download (oder wie das auch immer funktioniert) der Programme und Variablen von rega.o und rega1 anscheinend die gesamte iobroker weg.
                                        Aus dem log (tail…..) komme ich nicht mehr mit CTRL-C heraus. ich muss die Verbindung von putty beenden und neu aufbauen.
                                        ohne Port natürlich nach wie vor keine Möglichkeit auf das WebUI zu kommen :(
                                          Nach dem heutigen git pull war immer noch die Fehlermeldung "admin.0 port missing und der damit verbundene Versuch alle 20-30sec. den Adapter neu zu starten da.
                                          Auch eine Rücksetzung des Ports auf 8080 half nicht.
                                          ich habe daraufhin versucht den adapter mit ./iobroker del admin.0 zu löschen - was anscheinend auch geklappt hat.
                                          Der Versuch den Adapter mit ./iobroker add admin –enabled neu zu installieren endete mit der Meldung:
                                          root@cubie:/opt/iobroker# ./iobroker add admin --enabled
                                          module.js:340
                                              throw err;
                                          Error: Cannot find module 'mime'
                                              at Function.Module._resolveFilename (module.js:338:15)
                                              at Function.Module._load (module.js:280:25)
                                              at Module.require (module.js:364:17)
                                              at require (module.js:380:17)
                                              at Object. <anonymous>(/opt/iobroker/setup.js:96:25)
                                              at Module._compile (module.js:456:26)
                                              at Object.Module._extensions..js (module.js:474:10)
                                              at Module.load (module.js:356:32)
                                              at Function.Module._load (module.js:312:12)
                                              at Module.require (module.js:364:17)</anonymous>
                                          auch ein Versuch mit ./iobroker del admin (ohne.0) zu löschen ergab zwar die Löschung von weiteren 4 objects von admin, die Fehlermeldung mein Versuch der neuinstallation war jedoch die gleiche.
                                          PS ich denke ich werde mal eine neue Komplettinstallation machen - oder?
                                          EDIT:
                                          neue Komplettinstallation - sieht ja ganz anders aus; Da kommt man ja mit dem Testen gar nicht nach - was ihr da ständig neu einbaut;
                                          Bei der Installation nur die Warnhinweise wegen der Versionsnummern von node;
                                          bei iobroker update gab es eine Fehlermeldung, dass ein Ordner nicht existiert, war leider aus dem Zwischenspeicher weg;
                                          Habe jetzt admin, 2x rega und 2x rpc.
                                          Habe alle (?) Datenpunkte auch die live-Punkte
                                          Habe dann noch den legacy adapter installiert - immer mit code 8 beendet - und hat das gesamte ioBroker abgeschossen - wieder deinstalliert
                                          SPITZE!!
