  4. Adapter: Radar
Adapter: Radar
350 Beiträge 59 Kommentatoren 109.7k Aufrufe 2 Beobachtet
  • R Offline
    RappiRN
    #248
    Das hat bestimmt mit deiner Docker-Installation zu tun, da kann ich dir aber leider nicht weiterhelfen! :(
    Enrico
      sscorpio
      #249
      @sscorpio:
      Hello.
      Radar driver not see bluetooth devices.
      What i do wrong ? Help please !
      radar.0 2018-10-26 22:29:13.075 warn radar initialization finished with error SyntaxError: Unexpected token c in JSON at position 0 at Object.parse (native) at pGet.then.res (/opt/iobroker/node_modules/iobroker.radar/radar.js:820
      radar.0 2018-10-26 22:29:08.906 warn MAC addresses '00:xx:xx:xx:xx:FD' will not be scanned because no arp-scan is available!
      System CentOS 7.0
      22:32:20-root@home.angelok.ru:~# arp-scan -V
      arp-scan 1.9.2
      Copyright (C) 2005-2013 Roy Hills, NTA Monitor Ltd.
      arp-scan comes with NO WARRANTY to the extent permitted by law.
      You may redistribute copies of arp-scan under the terms of the GNU
      General Public License.
      For more information about these matters, see the file named COPYING.
      libpcap version 1.5.3 `
      i found a problem and fix them.
      everywhere where arp-scan is caused
      pExec('arp-scan -lgq –retry=7')
      i add the interface
      pExec('arp-scan --interface enp1s0 -lgq --retry=7')
      after that the script works normally
      • MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        #250
        Ich habe beide Slaves neu aufgebaut.
        Wenn ich````
        sudo hcitool lescan
        Aber die angemeldeten G-Tags kommen bei der Instanz nicht an.
        Als Rückmelddung der Instanz bekomme ich immer
        radar.0 2018-12-11 18:53:55.679 warn Adapter disconnected and stopped with true
        radar.0 2018-12-11 18:53:55.678 warn radar initialization finished with error 'No geo location data found configured in admin to calculate UWZ AREA ID!', will stop adapter!
        radar.0 2018-12-11 18:53:55.676 warn No geo location data found configured in admin to calculate UWZ AREA ID!
        radar.0 2018-12-11 18:54:17.619 debug system.adapter.admin.0: logging false
        Das gleiche auch mit Radar1, wil beide instanzen auf Slaves laufen.
        Was immer das auch heißen mag.
        Gruß,
        Mathias
        IObroker auf dem NUC als VM.
        • P Offline
          Pilotmaverick
          #251
          Hallo zusammen.
          Ich möchte gerne per Radar unsere Smartphones via Bluetooth erkennen.
          ioBroker läuft bei mir auf einem Raspberry auf dem auch die Homematic läuft. Diese ist direkt auf dem Raspberry gesteckt und wird mittels piVCCU3 gesteuert.
          Entrsprechend ist mein UART belegt und Bluetooth funktioniert nicht.
          Habe schon entsprechend der Anleitungen im Internet versucht Bluetooth auf das miniUART Interface umzulegen. Leider funktioniert es noch nicht. Hat jemand eine Idee wie ich überprüfen kann ob Bluetooth an sich schon einmal funktioniert über den miniUART?
            knx
            #252
            Moin Miteinander,
            arbeite gerade an der Anwesenheitserkennung, da ich keine Fritzbox habe benutze ich den Radar Adapter. Handy wird auch erkannt über Bluetooth und IP.
            Allerdings reagiert iobroker sehr langsam sobald ich den Adapter aktiviere, hat alle 10 Sekunden oder so denkpausen. Pausiere ich den Adapter dann hat sich das Problem erledigt und läuft wie immer.
            Als Hardware läuft ein Pi3.
            Gibt es dafür eine Lösung?
            Gruß und Gute Nacht
            • R Offline
              RappiRN
              #253
              Wie oft und wieviel Geräte fragst du denn ab?
              Enrico
              • L Offline
                Latax
                #254
                Wie genau schafft man es denn das der Adapter Noble auf Windows erkennt?
                In dem Ordner C:\ioBroker\node_modules\iobroker.radar\bin\bluetoothview' ist das Programm drin. Dort kann ich es auch Händisch starten und es findet mein Telefon. Aber der Adapter sagt immer es das das Programm nicht vorhanden ist.
                Noble not available, Error: { Error: Cannot find module 'bluetooth-hci-socket' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15) at Function.Module._load (internal/m
                  dondaik
                  #255
                  ok, dann auch eine frage von mir zum adapter radar
                  seit der einrichtung von auf einem tinkerboard , mit dem neustem image, bleibt der datenpunkt "radar.0.AllUnknownIPs" und "radar.0.AllUnknownBTs" ohne inhalt ..
                  auf das warum finde ich keine antwort - der adapter ping ist mit geräten gefüllt und fping installiert.
                  ( ein reboot tut gut war auch dabei :-) )
                  wer Schreibfehler findet darf sie behalten … :-(
                  Ps: Anfänger im Bereich Tinkerboard + IOBROKER !
                  • apollon77A Offline
                    #256
                    @Latax:
                    Noble not available, Error: { Error: Cannot find module 'bluetooth-hci-socket' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15) at Function.Module._load (internal/m `
                    Komplettes log bitte. Ich dachte das sich Windows automatisch das andere genommen wird anstelle noble.
                    Gesendet vom Handy …
                      knx
                      #257
                      @RappiRN:
                      Enrico `
                      Moin,
                      alle 30 Sekunden ein Gerät zu Testzwecken :D
                      Habe allerdings mal den Thread etwas durchstöbert und irgendwo stand, dass das Wlan Modul beim Raspi wohl Probleme macht.
                      Da ich über jenes verbunden bin, dürfte wohl da das Problem liegen.
                      Leider bekomme ich den Lan Port ums verrecken nicht zum laufen, ich glaube der ist einfach defekt.
                      • R Offline
                        RappiRN
                        #258
                        Die Abfrage sollte kein Problem sein. Allerdings deine Info mit der WLAN-Verbindung könnte schon ein Hinweis auf die Ursache sein.
                        Hier im Forum wird davon abgeraten die WLAN-Verbindung zu verwenden. Is natürlich blöd, wenn du den Eindruck hast, dass deine LAN-Buchse nicht funktioniert. Woran machst du das fest?
                        Enrico
                          knx
                          #259
                          Moin Enrico,
                          mein Router vergibt dem Pi keine IP Adresse wenn er über Lan drangehängt ist, verschiedene Ports und Kabel habe ich schon probiert. Allerdings macht mich halt immer stutzig, dass die LED vom Lanport Grün blinkt, also schon eine Aktivität da ist.
                          Kann natürlich auch ein Konfigurationsproblem sein auf dem Pi, allerdings haben meine Nachforschungen keine Lösung ergeben und ich kenne mich dazu zu wenig aus:
                          ifconfig spuckt folgendes aus:
                          ! eth0: flags=4163 <up,broadcast,running,multicast>mtu 1500
                          ! inet6 …d prefixlen 64 scopeid 0x20
                          ! ether ...9 txqueuelen 1000 (Ethernet)
                          ! RX packets 0 bytes 0 (0.0 B)
                          ! RX errors 0 dropped 0 overruns 0 frame 0
                          ! TX packets 15316 bytes 2482876 (2.3 MiB)
                          ! TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
                          ! lo: flags=73 <up,loopback,running>mtu 65536
                          ! inet 127.0.0.1 netmask 255.0.0.0
                          ! inet6 ::1 prefixlen 128 scopeid 0x10 <host>loop txqueuelen 1000 (Lokale Schleife)
                          ! RX packets 348495 bytes 48502230 (46.2 MiB)
                          ! TX packets 348495 bytes 48502230 (46.2 MiB)
                          ! wlan0: flags=4163 <up,broadcast,running,multicast>mtu 1500
                          ! inet 192.168.2.109 netmask 255.255.255.0 broadcast 192.168.2.255
                          ! inet6 ...c prefixlen 64 scopeid 0x20
                          ! inet6 ...7 prefixlen 64 scopeid 0x0 <global>lobal> ether ...c txqueuelen 1000 (Ethernet)
                          ! RX packets 25579 bytes 5995047 (5.7 MiB)
                          ! TX packets 29608 bytes 13517889 (12.8 MiB)
                          ! TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0</global></up,broadcast,running,multicast></host></up,loopback,running></up,broadcast,running,multicast>
                          Die Macadressen habe ich mal rauseditiert.
                          • wendy2702W Online
                            wendy2702W Online
                            #260
                            Vielleicht versuchst du mal dem PI eine feste IP zu geben:
                            https://www.elektronik-kompendium.de/si … 912151.htm
                              Shaky79
                              #261
                              bekomme den Radar irgendwie auch nicht zum laufen. Außer Ping funktioniert eigentlich nichts.
                              Arp-Scan meckert
                              2018-12-29 12:27:52.200  - [33mwarn[39m: radar.0 MAC addresses '[b]XY:YCF:XY:XY:XY:XY' will not be scanned because no arp-scan is available!
                              Ist aber installiert und ich meine mich zu erinnern, dass zumindest das mal geklappt hat.
                              Wenn ich es versuche noch einmal zu installieren, sagt er mir, dass es schon vorhanden ist.
                              Noble meckert schon die ganze Zeit
                              `2018-12-29 18:42:43.730  - [33mwarn[39m: radar.0 Noble not available, Error: { Error: Cannot find module '../build/Release/binding.node'     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)     at Function.Module._load (internal/modules/cjs/loader.js:507:25)     at Module.require (internal/modules/cjs/loader.js:637:17)     at require (internal/modules/cjs/helpers.js:22:18)     at Object. <anonymous>(/opt/iobroker/node_modules/noble/node_modules/bluetooth-hci-socket/lib/native.js:3:15)     at Module._compile (internal/modules/cjs/loader.js:689:30)     at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)     at Module.load (internal/modules/cjs/loader.js:599:32)     at tryModuleLoad (internal/modules/cjs/loader.js:538:12)     at Function.Module._load (internal/modules/cjs/loader.js:530:3) code: 'MODULE_NOT_FOUND' }[/code]</anonymous>`
                              Hab auch schon versucht noble zu deinstallieren und neu zu installieren. Leider ohne tausend Fehlermeldungen nicht möglich. Auch bei der Version von @abandonware/noble klappt die Installation nicht.
                              Hat einer einen Tipp bzw. ähnliches Problem gehabt?
                                srkonus
                                #262
                                ich habe Radar laut dieser Anleitung: https://homematic-guru.de/homematic-blu … serkennung eingerichtet und als Skript abgespeichert. Leider kommen da jetzt ein paar Fragen bei mir auf:
                                1. Kann ich mehr als ein Script parallel laufen lassen?
                                2. Wie kann ich eine Variable (in dem Fall "anwesenheit") in einem anderen Script nutzen?
                                3. Wie teste ich das am Besten...wahrscheinlich mit Pushpullet, oder?
                                Habe versucht eine Pushpullet Nachricht einzubauen, ist das so richtig?
                                if (obj.newState.val > 0) { setState(anwesenheit,true);
                                        sendTo("pushbullet.0", "send", {
                                       "message": 'Mann im Haus'
                                Entschuldigt meine DAU Fragen ;)
                                srkonus
                                  knx
                                  #263
                                  @wendy2702:
                                  https://www.elektronik-kompendium.de/si … 912151.htm `
                                  habe ich mal gemacht und jetzt andere Probleme. Habe das Thema mal ausgelagert, damit der Thread hier nicht "zugemüllt" wird.
                                  viewtopic.php?f=34&t=20104
                                  Danke und schönen Abend noch miteinander.
                                    dondaik
                                    #264
                                    ich hänge es mal hier an:
                                    ggf hat ja einer eine erklärung:
                                    basis: aktuelles Tinker-Board image mit BT ergänzungen nach der Doku für radar… / ...BT-onboard und einem BT-Logitech USB-Adapter
                                    dann erhalte ich - ohne(!) neustart des boards:
                                    und nun wird das board neu gestartet …. die BT - Geärte werden nicht mehr "gescannt"
                                      dondaik
                                      #265
                                      und nun … weiter nach root > poweroff ... tinker board aus
                                      also neustart tinker, dann:
                                      • tinker startet
                                      • radar scannt kein BT und IP
                                      • auf linuxebene alles gut
                                      dann
                                      root > iobroker start all
                                      root -> iobroker start
                                      iobroker controller daemon started . PID: 7568
                                      in iobroker
                                      radar stoppen
                                      radar starten
                                      -- > BT und IP werden in RADAR wieder gescannt ....
                                      so, in 52 minuten ist 2019 - prost neujahr an alle
                                      und nun .. 9 stunden später - der BT adapter scannt nicht mehr
                                      • L Offline
                                        Latax
                                        #266
                                        @apollon77:
                                        @Latax:
                                        Gesendet vom Handy … `
                                        radar.0
                                        2019-01-01 14:45:14.363
                                        info
                                        Adapter initialization finished!
                                        radar.0
                                        2019-01-01 14:45:14.155
                                        info
                                        ScanAll: From all 2 devices dedected 2 are whoHere: Anna, Lars
                                        history.0
                                        2019-01-01 14:45:14.134
                                        info
                                        enabled logging of radar.0.Lars.here, Alias=false
                                        history.0
                                        2019-01-01 14:45:14.097
                                        info
                                        enabled logging of radar.0.Anna.here, Alias=false
                                        radar.0
                                        2019-01-01 14:45:13.461
                                        info
                                        UWZ found the following (changed) warnings: No warnings
                                        radar.0
                                        2019-01-01 14:45:13.237
                                        info
                                        radar set use of noble(false), fping(false), doMac(false), doHci(false), doBtv(true) and doUwz(UWZDE29643,1800,0,de,false).
                                        radar.0
                                        info
                                        radar adapter initialized 2 devices, ExternalNetwork = 300.
                                        radar.0
                                        2019-01-01 14:45:11.520
                                        info
                                        Init item Lars with { name: 'Lars', ip: '192.168.2.61', macs: '', bluetooth: '34:2D:0D:FF:66:0C', id: 'Lars', hasBT: true, printer: false, hasECB: false, hasIP: true, rip: '192.168.
                                        radar.0
                                        2019-01-01 14:45:11.469
                                        info
                                        Init item Anna with { name: 'Anna', ip: '192.168.2.60', macs: '', bluetooth: '68:5A:CF:22:98:C9', id: 'Anna', hasBT: true, printer: false, hasECB: false, hasIP: true, rip: '192.168.
                                        radar.0
                                        2019-01-01 14:45:11.103
                                        info
                                        BT Bin Dir = 'C:\ioBroker\node_modules\iobroker.radar\bin\bluetoothview'
                                        radar.0
                                        info
                                        radar set to scan every 30 sec and printers every 500 scans.
                                        radar.0
                                        warn
                                        radar.0
                                        2019-01-01 14:45:10.569
                                        info
                                        starting. Version 1.1.3 in C:/ioBroker/node_modules/iobroker.radar, node: v10.11.0
                                        So sieht es aus wenn ich den Adapter starte.
                                        • C Offline
                                          CandyMan
                                          #267
                                          bin neu bei der Thematik. Und habe 2 Gigaset G-Tag an laufen ein Roter und ein Grüner wie man in Log auch sieht.
                                          In Einsatz hab ich den Verbauten Bluetooth von PI3 sowie Bluetooth Stick wegen der Reichweite. ein hcitool lescan zeigt mir auch die beiden G-Tags an.
                                          Eingetragen sind Sie auch in Radar leider stellt sich der Wert btHere nicht auf true und bleibt auf false was ist hier falsch das er den Wert nicht ändernt?
                                          Als Image nutze ich das von ioBroker von 4.1.19
                                          Hier noch das Log:
                                          radar.0 2019-01-06 15:57:45.796 debug Noble found unknown BT's: {}, unknown IP's: [object Object]
                                          radar.0 2019-01-06 15:57:45.758 debug RED={ name: 'RED', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:1A', id: 'RED', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: false,
                                          radar.0 2019-01-06 15:57:45.738 debug GREEN={ name: 'GREEN', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:14', id: 'GREEN', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: fal
                                          radar.0 2019-01-06 15:57:45.635 debug Noble= Noble { initialized: true, address: 'b8:27:eb:f6:d1:92', _state: 'unauthorized', _bindings: NobleBindings { _state: 'unauthorized', _addresses: {}, _addresseTypes: {}
                                          radar.0 2019-01-06 15:57:45.634 debug Would now start scan for devices! printerCount=4
                                          radar.0 2019-01-06 15:57:20.019 debug system.adapter.admin.0: logging true
                                          radar.0 2019-01-06 15:56:45.829 debug Noble found unknown BT's: {}, unknown IP's: [object Object]
                                          radar.0 2019-01-06 15:56:45.740 debug RED={ name: 'RED', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:1A', id: 'RED', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: false,
                                          radar.0 2019-01-06 15:56:45.712 debug GREEN={ name: 'GREEN', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:14', id: 'GREEN', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: fa
                                          radar.0 2019-01-06 15:56:45.610 debug Noble= Noble { initialized: true, address: 'b8:27:eb:f6:d1:92', _state: 'unauthorized', _bindings: NobleBindings { _state: 'unauthorized', _addresses: {}, _addresseTypes: {
                                          radar.0 2019-01-06 15:56:45.592 debug Would now start scan for devices! printerCount=3
                                          radar.0 2019-01-06 15:56:29.946 debug system.adapter.admin.0: logging false
                                          radar.0 2019-01-06 15:55:45.771 debug Noble found unknown BT's: {}, unknown IP's: [object Object]
                                          radar.0 2019-01-06 15:55:45.726 debug RED={ name: 'RED', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:1A', id: 'RED', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: false,
                                          radar.0 2019-01-06 15:55:45.693 debug GREEN={ name: 'GREEN', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:14', id: 'GREEN', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: fa
                                          radar.0 2019-01-06 15:55:45.589 debug Noble= Noble { initialized: true, address: 'b8:27:eb:f6:d1:92', _state: 'unauthorized', _bindings: NobleBindings { _state: 'unauthorized', _addresses: {}, _addresseTypes: {
                                          radar.0 2019-01-06 15:55:45.571 debug Would now start scan for devices! printerCount=2
                                          radar.0 2019-01-06 15:54:45.751 debug Noble found unknown BT's: {}, unknown IP's: [object Object]
                                          radar.0 2019-01-06 15:54:45.701 debug RED={ name: 'RED', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:1A', id: 'RED', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: false,
                                          radar.0 2019-01-06 15:54:45.672 debug GREEN={ name: 'GREEN', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:14', id: 'GREEN', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: fa
                                          radar.0 2019-01-06 15:54:45.569 debug Noble= Noble { initialized: true, address: 'b8:27:eb:f6:d1:92', _state: 'unauthorized', _bindings: NobleBindings { _state: 'unauthorized', _addresses: {}, _addresseTypes: {
                                          radar.0 2019-01-06 15:54:45.549 debug Would now start scan for devices! printerCount=1
                                          radar.0 2019-01-06 15:54:39.487 debug system.adapter.admin.0: logging true
                                          radar.0 2019-01-06 15:54:18.742 debug system.adapter.admin.0: logging false
                                          radar.0 2019-01-06 15:53:46.058 info Adapter initialization finished!
                                          radar.0 2019-01-06 15:53:45.893 debug Make State AllUnknownIPs and set value to ''{}''
                                          radar.0 2019-01-06 15:53:45.808 debug Make State AllUnknownBTs and set value to ''{}''
                                          radar.0 2019-01-06 15:53:45.807 debug Noble found unknown BT's: {}, unknown IP's: [object Object]
                                          radar.0 2019-01-06 15:53:45.798 debug Make State whoHere and set value to ''''
                                          radar.0 2019-01-06 15:53:45.785 debug Make State allHere and set value to ''''
                                          radar.0 2019-01-06 15:53:45.773 debug Make State countHere and set value to '0'
                                          radar.0 2019-01-06 15:53:45.772 info ScanAll: From all 0 devices dedected 0 are whoHere:
                                          radar.0 2019-01-06 15:53:45.760 debug Make State RED.btHere and set value to 'false'
                                          radar.0 2019-01-06 15:53:45.747 debug Make State RED.here and set value to 'false'
                                          radar.0 2019-01-06 15:53:45.731 debug Make State RED.count and set value to '-11'
                                          radar.0 2019-01-06 15:53:45.730 debug RED={ name: 'RED', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:1A', id: 'RED', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: false,
                                          radar.0 2019-01-06 15:53:45.716 debug Make State GREEN.btHere and set value to 'false'
                                          radar.0 2019-01-06 15:53:45.703 debug Make State GREEN.here and set value to 'false'
                                          radar.0 2019-01-06 15:53:45.678 debug Make State GREEN.count and set value to '-11'
                                          radar.0 2019-01-06 15:53:45.678 debug GREEN={ name: 'GREEN', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:14', id: 'GREEN', hasBT: true, printer: '', hasECB: '', hasIP: '', btHere: false, ipHere: false, anwesend: fa
                                          radar.0 2019-01-06 15:53:45.670 debug Make State UWZ_Warning and set value to ''No warnings''
                                          radar.0 2019-01-06 15:53:45.670 info UWZ found the following (changed) warnings: No warnings
                                          radar.0 2019-01-06 15:53:45.563 debug Noble= Noble { initialized: false, address: 'unknown', _state: 'unknown', _bindings: NobleBindings { _state: null, _addresses: {}, _addresseTypes: {}, _connectable: {}
                                          radar.0 2019-01-06 15:53:45.551 debug Would now start scan for devices! Would also scan for printer ink now!
                                          radar.0 2019-01-06 15:53:45.548 info radar set use of noble(true), fping(true), doMac(false), doHci(true), doBtv(false) and doUwz(UWZDE12489,1800,0,de,false).
                                          radar.0 2019-01-06 15:53:45.547 info radar adapter initialized 2 devices, ExternalNetwork = 300.
                                          radar.0 2019-01-06 15:53:44.292 debug Make State ExternalNetwork.status and set value to '2'
                                          radar.0 2019-01-06 15:53:44.247 debug Make State ExternalNetwork.IP4 and set value to ''88.130.98.162''
                                          radar.0 2019-01-06 15:53:44.245 debug Same IP address 88.130.98.162
                                          radar.0 2019-01-06 15:53:43.717 info Init item RED with { name: 'RED', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:1A', id: 'RED', hasBT: true, printer: '', hasECB: '', hasIP: '' }
                                          radar.0 2019-01-06 15:53:43.664 info Init item GREEN with { name: 'GREEN', ip: '', macs: '', bluetooth: '7C:2F:80:AD:B9:14', id: 'GREEN', hasBT: true, printer: '', hasECB: '', hasIP: '' }
                                          radar.0 2019-01-06 15:53:40.582 debug system.adapter.admin.0: logging true
                                          radar.0 2019-01-06 15:53:38.426 info BT Bin Dir = '/opt/iobroker/node_modules/iobroker.radar\bin\bluetoothview'
                                          radar.0 2019-01-06 15:53:38.426 info radar set to scan every 60 sec and printers every 500 scans.
                                          radar.0 2019-01-06 15:53:38.339 info starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v8.15.0
                                          radar.0 2019-01-06 15:53:38.222 debug statesDB connected
                                          radar.0 2019-01-06 15:53:38.139 debug objectDB connected
                                          EDIT: Problem gelöst einfach mal ioBroker neugestartet.
