  4. [gelöst]Umzug vom Pi auf Rock64-nichts geht, benötige Hilfe
    6.4k
16 Beiträge 3 Kommentatoren 1.2k Aufrufe
  • W Offline
    W Offline
    w00dy
    schrieb am zuletzt editiert von w00dy
    Hi @wendy2702,
    die IP ist unverändert.
    Hier das Log:
    root@ioBroker-Rock64:/opt/iobroker# tail -f /opt/iobroker/log/iobroker.2018-11-19.log
    2018-11-19 13:00:52.707  - error: Caught by controller[0]:     at _combinedTickCallback (internal/process/next_tick.js:83:11)
    2018-11-19 13:00:52.707  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:104:9)
    2018-11-19 13:00:52.708  - error: Caught by controller[0]:   code: 'EADDRNOTAVAIL',
    2018-11-19 13:00:52.708  - error: Caught by controller[0]:   errno: 'EADDRNOTAVAIL',
    2018-11-19 13:00:52.709  - error: Caught by controller[0]:   syscall: 'listen',
    2018-11-19 13:00:52.709  - error: Caught by controller[0]:   address: '192.168.xxx.xxx',
    2018-11-19 13:00:52.709  - error: Caught by controller[0]:   port: 2010 }
    2018-11-19 13:00:52.710  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.2 terminated with code 0 (OK)
    2018-11-19 13:00:52.710  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.2 because enabled
    2018-11-19 13:00:53.063  - info: denon.0 [CONNECT] Trying to connect to 192.168.xxx.xxx:23
    2018-11-19 13:00:56.069  - warn: denon.0 AVR unreachable, check the Network Config of your AVR
    2018-11-19 13:00:57.404  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 started with pid 8691
    2018-11-19 13:00:59.450  - info: hm-rpc.0 starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.4
    2018-11-19 13:00:59.844  - info: hm-rpc.0 binrpc server is trying to listen on 192.168.xxx.xxx:2001
    2018-11-19 13:00:59.848  - info: hm-rpc.0 binrpc client is trying to connect to 192.168.xxx.xxx:2001/ with ["xmlrpc_bin://192.168.xxx.xxx:2001","hm-rpc.0"]
    2018-11-19 13:00:59.914  - error: hm-rpc.0 uncaught exception: listen EADDRNOTAVAIL 192.168.xxx.xxx:2001
    2018-11-19 13:00:59.915  - error: hm-rpc.0 Error: listen EADDRNOTAVAIL 192.168.xxx.xxx:2001
        at Object.exports._errnoException (util.js:1020:11)
        at exports._exceptionWithHostPort (util.js:1043:20)
        at Server._listen2 (net.js:1258:19)
        at listen (net.js:1307:10)
        at net.js:1417:9
    2018-11-19 13:00:59.919  - info: hm-rpc.0 binrpc -> 192.168.xxx.xxx:2001/ init ["xmlrpc_bin://192.168.xxx.xxx:2001",""]
    2018-11-19 13:00:59.947  - info: hm-rpc.0 Connected
    2018-11-19 13:00:59.980  - info: hm-rpc.0 Disconnected
    2018-11-19 13:00:59.992  - info: hm-rpc.0 terminating
    2018-11-19 13:01:00.028  - error: Caught by controller[0]: { Error: listen EADDRNOTAVAIL 192.168.xxx.xxx:2001
    2018-11-19 13:01:00.029  - error: Caught by controller[0]:     at Object.exports._errnoException (util.js:1020:11)
    2018-11-19 13:01:00.030  - error: Caught by controller[0]:     at exports._exceptionWithHostPort (util.js:1043:20)
    2018-11-19 13:01:00.030  - error: Caught by controller[0]:     at Server._listen2 (net.js:1258:19)
    2018-11-19 13:01:00.031  - error: Caught by controller[0]:     at listen (net.js:1307:10)
    2018-11-19 13:01:00.031  - error: Caught by controller[0]:     at net.js:1417:9
    2018-11-19 13:01:00.031  - error: Caught by controller[0]:     at _combinedTickCallback (internal/process/next_tick.js:83:11)
    2018-11-19 13:01:00.032  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:104:9)
    2018-11-19 13:01:00.032  - error: Caught by controller[0]:   code: 'EADDRNOTAVAIL',
    2018-11-19 13:01:00.033  - error: Caught by controller[0]:   errno: 'EADDRNOTAVAIL',
    2018-11-19 13:01:00.034  - error: Caught by controller[0]:   syscall: 'listen',
    2018-11-19 13:01:00.034  - error: Caught by controller[0]:   address: '192.168.xxx.xxx',
    2018-11-19 13:01:00.035  - error: Caught by controller[0]:   port: 2001 }
    2018-11-19 13:01:00.035  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
    2018-11-19 13:01:00.036  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.0 because enabled
    2018-11-19 13:01:08.637  - info: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 started with pid 8704
    2018-11-19 13:01:10.535  - info: hm-rpc.1 starting. Version 1.7.8 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.14.4
    2018-11-19 13:01:11.098  - info: hm-rpc.1 binrpc server is trying to listen on 192.168.xxx.xxx:8701
    2018-11-19 13:01:11.102  - info: hm-rpc.1 binrpc client is trying to connect to 192.168.xxx.xxx:8701/ with ["xmlrpc_bin://192.168.xxx.xxx:8701","hm-rpc.1"]
    2018-11-19 13:01:11.168  - error: hm-rpc.1 uncaught exception: listen EADDRNOTAVAIL 192.168.xxx.xxx:8701
    2018-11-19 13:01:11.169  - error: hm-rpc.1 Error: listen EADDRNOTAVAIL 192.168.xxx.xxx:8701
        at net.js:1417:9
    2018-11-19 13:01:11.173  - info: hm-rpc.1 binrpc -> 192.168.xxx.xxx:8701/ init ["xmlrpc_bin://192.168.xxx.xxx:8701",""]
    2018-11-19 13:01:11.217  - info: hm-rpc.1 terminating
    2018-11-19 13:01:11.256  - error: Caught by controller[0]: { Error: listen EADDRNOTAVAIL 192.168.xxx.xxx:8701
    2018-11-19 13:01:11.257  - error: Caught by controller[0]:     at Object.exports._errnoException (util.js:1020:11)
    2018-11-19 13:01:11.258  - error: Caught by controller[0]:     at exports._exceptionWithHostPort (util.js:1043:20)
    2018-11-19 13:01:11.258  - error: Caught by controller[0]:     at Server._listen2 (net.js:1258:19)
    2018-11-19 13:01:11.259  - error: Caught by controller[0]:     at listen (net.js:1307:10)
    2018-11-19 13:01:11.259  - error: Caught by controller[0]:     at net.js:1417:9
    2018-11-19 13:01:11.259  - error: Caught by controller[0]:     at _combinedTickCallback (internal/process/next_tick.js:83:11)
    2018-11-19 13:01:11.260  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:104:9)
    2018-11-19 13:01:11.260  - error: Caught by controller[0]:   code: 'EADDRNOTAVAIL',
    2018-11-19 13:01:11.261  - error: Caught by controller[0]:   errno: 'EADDRNOTAVAIL',
    2018-11-19 13:01:11.261  - error: Caught by controller[0]:   syscall: 'listen',
    2018-11-19 13:01:11.261  - error: Caught by controller[0]:   address: '192.168.xxx.xxx',
    2018-11-19 13:01:11.262  - error: Caught by controller[0]:   port: 8701 }
    2018-11-19 13:01:11.262  - error: host.ioBroker-Rock64 instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
    2018-11-19 13:01:11.263  - info: host.ioBroker-Rock64 Restart adapter system.adapter.hm-rpc.1 because enabled
    2018-11-19 13:01:14.409  - error: rpi2.0 No Value found for cpu_voltage
    2018-11-19 13:01:14.410  - error: rpi2.0 No Value found for mem_arm
    2018-11-19 13:01:14.411  - error: rpi2.0 No Value found for mem_gpu
    2018-11-19 13:01:14.420  - error: rpi2.0 Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
    /dev/mmcblk1p1  30341564 2211472  27790520   8% /
    /1024
    2018-11-19 13:01:14.422  - error: rpi2.0 Cannot evaluate: Filesystem     1K-blocks    Used Available Use% Mounted on
    /1024
    ^C
    @paul53 - berichtigt, meinte natürlich das vom 11.12.2017 ;)
    Viele Grüße
    w00dy
    • wendy2702W Offline
      wendy2702W Offline
      iobroker list instances
      node -v
      npm -v
      Sind die Versionen gleich mit der vom PI ?
      Warum kann der Rock deine CCU nicht erreichen?
      Warum kannst du````
      reinstall.sh
      • paul53P Offline
        @Hicks:
        vom Pi3 auf einen Rock64 umzuziehen. `
        Welche Version von Node.js und NPM läuft auf dem Pi3 ?
        @Hicks:
        Dafür nutze ich das fertige Image vom 11.12.2017. `
        Das verwendet Node.js 6.12.2 und NPM 3.x.
        • W Offline
          W Offline
          w00dy
          Hier die Augabe von " iobroker list instances":
          ` > root@ioBroker-Rock64:/opt/iobroker# iobroker list instances
          system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0 : backitup - enabled
          system.adapter.broadlink2.0 : broadlink2 - enabled
          system.adapter.cloud.0 : cloud - enabled
          system.adapter.denon.0 : denon - enabled
          system.adapter.discovery.0 : discovery - enabled
          system.adapter.email.0 : email - enabled
          system.adapter.flot.0 : flot - enabled
          system.adapter.fritzdect.0 : fritzdect - enabled
          system.adapter.history.0 : history - enabled
          system.adapter.hm-rega.0 : hm-rega - enabled
          system.adapter.hm-rpc.0 : hm-rpc - enabled, port: 0
          system.adapter.hm-rpc.1 : hm-rpc - enabled, port: 0
          system.adapter.hm-rpc.2 : hm-rpc - enabled, port: 0
          system.adapter.ical.0 : ical - enabled
          system.adapter.icons-icons8.0 : icons-icons8 - enabled
          system.adapter.icons-mfd-png.0 : icons-mfd-png - enabled
          system.adapter.javascript.0 : javascript - enabled
          system.adapter.mobile.0 : mobile - enabled
          system.adapter.modbus.0 : modbus - enabled
          system.adapter.mqtt.0 : mqtt - enabled, port: 1886
          system.adapter.ping.0 : ping - enabled
          system.adapter.radar.0 : radar - enabled
          system.adapter.rpi2.0 : rpi2 - enabled
          system.adapter.sayit.0 : sayit - enabled, port: 0
          system.adapter.scenes.0 : scenes - enabled
          system.adapter.sonoff.0 : sonoff - enabled, port: 1883, bind: 0.0.0.0
          system.adapter.vis-bars.0 : vis-bars - enabled
          system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges - enabled
          system.adapter.vis-colorpicker.0 : vis-colorpicker - enabled
          system.adapter.vis-fancyswitch.0 : vis-fancyswitch - enabled
          system.adapter.vis-history.0 : vis-history - enabled
          system.adapter.vis-hqwidgets.0 : vis-hqwidgets - enabled
          system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd - enabled
          system.adapter.vis-justgage.0 : vis-justgage - enabled
          system.adapter.vis-metro.0 : vis-metro - enabled
          system.adapter.vis-players.0 : vis-players - enabled
          system.adapter.vis-timeandweather.0 : vis-timeandweather - enabled
          system.adapter.vis.0 : vis - enabled
          system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          root@ioBroker-Rock64:/opt/iobroker# `
          OK, die node und npm sind unterschiedlich: PI –> npm = 4.6.1 node = 8.11.2 / Rock --> npm = 3.10.10 node = 6.14.4
          Bei reinstall.sh kommt folgende Meldung: reinstall.sh: command not found
          Die CCU ist mom. nicht erreichbar, baue hier gerade so einiges um. Die CCU ist auf nem PI und der soll auf die Hutschiene mit in den Verteilerkasten.
          Viele Grüße
          w00dy
            wendy2702W Offline
            Bist du beim Ausführen derreinstall.shin````
            /opt/iobroker/
            ls -la /opt/iobroker/
            • W Offline
              W Offline
              w00dy
              Ja,
              root@ioBroker-Rock64:/opt/iobroker# ls -la /opt/iobroker/
              total 72
              drwxrwxrwx   8 root root  4096 Nov 19 12:27 .
              drwxr-xr-x   3 root root  4096 Dez 11  2017 ..
              drwxrwxrwx   2 root root  4096 Nov 18 21:15 backups
              drwxrwxrwx   2 root root  4096 Nov 19 13:15 cache
              drwxrwxrwx   2 root root  4096 Dez 11  2017 etc
              -rwxrwxrwx   1 root root   297 Dez 11  2017 install.sh
              -rwxrwxrwx   1 root root    67 Dez 11  2017 iobroker
              drwxrwxrwx   5 root root  4096 Nov 18 22:17 iobroker-data
              -rwxrwxrwx   1 root root    92 Nov 18 22:00 killall.sh
              drwxrwxrwx   2 root root  4096 Nov 19 13:12 log
              drwxrwxrwx 618 root root 20480 Nov 19 12:27 node_modules
              -rwxrwxrwx   1 root root   827 Nov 19 12:27 package.json
              -rw-r--r--   1 root root   676 Nov 19 01:00 reinstall.dos
              -rw-r--r--   1 root root   676 Nov 19 01:03 reinstall.sh
              root@ioBroker-Rock64:/opt/iobroker# reinstall.sh
              Viele Grüße
              w00dy
              • paul53P Offline
                @Hicks:
                PI –> npm = 4.6.1 node = 8.11.2 / Rock --> npm = 3.10.10 node = 6.14.4 `
                Dann sollte Node/NPM <u>vor</u> dem Einspielen des Backups auf die entsprechende Version "hochgezogen" werden. In dem Fall braucht es kein ./reinstall.sh nach dem Restore.
                  wendy2702W Offline
                  chmod +x reinstall.sh
                  dann erneut testen…. oder so wie Paul53 schreibt
                  • W Offline
                    W Offline
                    w00dy
                    Hm, reinstall geht immer nocht nicht:
                    root@ioBroker-Rock64:/opt/iobroker# chmod +x reinstall.sh
                    Muss ich das System jetzt neu aufsetzen, da ich den Backup nun schon eingespielt habe?
                    Viele Grüße
                    w00dy
                    • paul53P Offline
                      @Hicks:
                      reinstall geht immer nocht nicht `
                      ./reinstall.sh
                      • W Offline
                        W Offline
                        w00dy
                        Ups, sorry bin schon ganz wirsch.
                        Jetzt tut sich was, melde mich wieder wenn er fertig ist.
                        Liebe Grüße und vielen Dank für eure Hilfe!
                        Viele Grüße
                        w00dy
                        • W Offline
                          W Offline
                          w00dy
                          Hallo ihr beiden,
                          er lebt! "./reinstall" ist fertig, das Webif. ist erreichbar und alle Adapter sind grün :D
                          Jetzt bekommt der Kleine ein lauschiges Plätzchen neben der CCU im Verteilerschrank.
                          Nochmals besten Dank euch beiden für die schnelle Hilfe.
                          Viele Grüße
                          w00dy
                          • paul53P Offline
                            @Hicks:
                            das Webif. ist erreichbar und alle Adapter sind grün `
                            [gelöst] im Betreff des ersten Beitrags bitte nicht vergessen.
