  4. Einfach mal zeigen will….. :-) - Teil 2
916 Beiträge 185 Kommentatoren 536.1k Aufrufe 68 Beobachtet
  • MicM Offline
    MicM Offline
    Mic
    schrieb am zuletzt editiert von Jey Cee
    #364
    @stephan2k:
    Könntest du mal ein Beispiel exportieren bezüglich der Menüleiste? `
    Gerne.Also hier für die Menüleiste ein Script, Legt Datenpunkt javascript.0.mic.vis-support.sidebar-left-switch an.
     * Sidebar States
     * 28.10.2018
    // Set States and hide sidebar after 10 seconds
    const LEFT_SIDEBAR_STATE = 'javascript.0.mic.vis-support.sidebar-left-switch';
    MG_createState(LEFT_SIDEBAR_STATE, 'Sidebar on/off', 'boolean', 'switch', false);
    on({id: LEFT_SIDEBAR_STATE, change: 'any'}, function(obj) {
        if ((obj.state.val !== false) && (obj.state.val !== 0)) {
            setStateDelayed(LEFT_SIDEBAR_STATE, false, 10000);
    // Hide sidebar on view change
    const VIS_PROJECT = 'Pad'; // Name des Projekts z.B. aus URL; http://xxxx:8082/vis/edit.html?Pad
    on({id: 'vis.0.control.command', val:'changedView'}, function(obj) {
        let currView = getState('vis.0.control.data').val;
        currView = currView.substring(0, VIS_PROJECT.length);
        if (currView === VIS_PROJECT) {
            setState(LEFT_SIDEBAR_STATE, false);
     * Create States - General
     * @param {string} stId      ID
     * @param {string} stName    Name, Description
     * @param {mixed}  stType     Datatype: string, boolean, etc.
     * @param {string} stRole    Role: button, etc.
     * @param {mixed}  stDef      Default value
    function MG_createState(stId, stName, stType, stRole, stDef) {
        createState(stId, {
            'name': stName,
            'desc': stName,
            'type': stType,
            'read': true,
            'write': true,
            'role': stRole,
            'def': stDef,
    Widget oben links (Menü-Schaltknopf mit den 3 Streifen):
    [{"tpl":"tplHqButton","data":{"oid":"javascript.0.mic.vis-support.sidebar-left-switch","min":"false","max":"true","iconName":"/icons-mic/mw_eigene/menu_white.png","btIconWidth":"30","offsetAuto":false,"leftOffset":"23","topOffset":"17","caption":"","captionOn":"","iconOn":"/icons-mic/mw_eigene/menu_white.png","pushButton":false,"usejQueryStyle":false,"g_visibility":false,"styleActive":"hq-button-no-background","styleNormal":"hq-button-no-background","changeEffect":"","testActive":false,"g_css_shadow_padding":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_gestures":false,"g_ccontrol":false,"g_leftRight":true,"g_css_font_text":false,"g_css_border":false,"g_fixed":false,"timeAsInterval":true,"infoLeftFontSize":"12","infoFontRightSize":"12","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","descriptionLeft":"test","descriptionLeftDisabled":true},"style":{"left":"3px","top":"1px","width":"50px","height":"40px","z-index":"120","background-color":"","opacity":"","background":""},"widgetSet":"hqwidgets"}]
    View für die Menüleiste, die eingebettet wird:
    widgets.txt
    Widget "view in Widget", das dann auf jeder Seite angezeigt wird:
    [{"tpl":"tplContainerView","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"nLeft","visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","views":["pBad","pFlur","pKueche","pMusic","pSpotify","pSystem","pSZ","pUeberall","pWeather","pWZ","s_pKueche_Eier"],"visibility-oid":"javascript.0.mic.vis-support.sidebar-left-switch"},"style":{"left":"3px","top":"60px","width":"220px","height":"530px","z-index":"100","overflow-x":"","border-radius":"7px"},"widgetSet":"basic"}]
    CSS, kann sein dass da noch was fehlt:
    #vis_container .mic-navleft-huawei .label {
      font-size: 100% !important;
      font-family: RobotoCondensed-Light !important;
      text-align: left !important;
      text-shadow: 2px 2px 2px #000000 !important;
      padding: 0 !important;
      margin: -3px 0px 0px 50px !important;
    /* Nicht selektiert */
    #vis_container .mic-navleft-huawei .bg-orange {
        background: none !important;
        box-shadow: none !important; /* Rahmen weg */
    /* selektiert */
    #vis_container .mic-navleft-huawei .bg-green {
        background: rgba(182, 17, 138, 0.64) !important;
      dos1973
      #365
      das mit dem "Burger" Menü ist supercool, das werde ich "schamlos" übernehmen, vielleicht in einer etwas weniger femininen Farbe…
      Küche= Rosa :lol:
        deta
        #366
        bin noch recht am Anfang,
        Könnt Ihr mir kurz sagen, wo ich was einfügen muss?
        Skripe ok
        Widget oben links importieren als Widget ok
        View für die Menuleiste ?? Wo ? Wie?
        CSS wo wie ?
        cu Deta
        • E Offline
          exnutzer
          #367
          Hi kann bitte mir Bilder geben, für Fenster offen / geschlossen und gekippt. Danke
          :D :D :D
          • MicM Offline
            MicM Offline
            Mic
            #368
            @deta:
            View für die Menuleiste ?? Wo ? Wie? `
            Diese einfach als View einfügen und Namen "nLeft" vergeben.
            Die Inhalte der View werden dann im Widget "view in Widget" angezeigt.
            @deta:
            CSS wo wie ? `
            Hab dazu auch schon eine PM eines anderen Users bekommen. Hier den CSS-Code einfügen:
            Außerdem verwende ich u.a. folgende Adapter/Widgets:
            • Homer.J.H Offline
              Homer.J.H Offline
              Homer.J.
              #369
              @Mic:
              @deta:
              @deta:
              CSS wo wie ? `
              adapter.png `
              Hi Mic,
              ich bekomme das ccs nicht ans laufen wenn ich es einfüge bekomme ich diese Fehler und an der Oberfläche an sich ändert sich auch nichts.
              5373_screenshot_2018-11-14_edit_vis_1_.png 5373_screenshot_2018-11-14_edit_vis.png
              • arteckA Offline
                arteckA Offline
                arteck
                #370
                lösche alles was nach````
                !important;
                also /* und in dern nächsten Zeile Rahmen weg */
                  deta
                  #371
                  Danke.
                  Irgend was stimmt da noch nicht…
                  • Homer.J.H Offline
                    Homer.J.H Offline
                    Homer.J.
                    #372
                    @arteck:
                    !important;
                    also /* und in dern nächsten Zeile Rahmen weg */ `
                    Morgen Arteck,
                    Fehler bleibt trotzdem. muss ich es unter Global oder Projekt anlegen. ?
                    • RöstkartoffelR Offline
                      Röstkartoffel
                      #373
                      in der letzten Zeile fehlt das
                      Also so:
                      /* selektiert */
                      NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
                      • Homer.J.H Offline
                        Homer.J.H Offline
                        Homer.J.
                        #374
                        @Röstkartoffel:
                        Also so:
                        /* selektiert */
                        Hab ich auch schon gesehen hab es geändert führte trotzdem nicht zum Erfolg.
                        Greift das Script auf irgend ein Ordner zu den ich vielleicht noch ändern muss.?
                          Baerny
                          #375
                          wenn ich das richtig sehe ist die CSS Klasse in der nLeft falsch eingetragen. Versuchs mal so
                          CCU 2 | Intel NUC mit Proxmox
                          • Homer.J.H Offline
                            Homer.J.H Offline
                            Homer.J.
                            #376
                            @Baerny:
                            wenn ich das richtig sehe ist die CSS Klasse in der nLeft falsch eingetragen. Versuchs mal so `
                            Hallo Baerny hattest recht Danke dir.
                              deta
                              #377
                              Bei mir gehts immer noch nicht, trotz klammer und CSS Klasse.
                              Sieht genauso aus wie im anderen Post..
                                deta
                                #378
                                Irgendwo ist der Wurm drinnen, ich bekomme das Menu nicht hin..
                                Jemand eine Idee wo da noch was faul ist..
                                • Homer.J.H Offline
                                  Homer.J.H Offline
                                  Homer.J.
                                  #379
                                  @deta:
                                  Jemand eine Idee wo da noch was faul ist.. `
                                  was bekommst du nicht ans laufen. ?
                                  Script oder CSS
                                    deta
                                    #380
                                    Siehst du , wie es im Screenshot aussieht..
                                    • Homer.J.H Offline
                                      Homer.J.H Offline
                                      Homer.J.
                                      #381
                                      @deta:
                                      Siehst du , wie es im Screenshot aussieht.. `
                                      Füg mal das in die CSS Klasse ein danach hat es bei mir funktioniert.
                                      mic-navleft-huawei
                                      • RummelmugR Offline
                                        RummelmugR Offline
                                        Rummelmug
                                        #382
                                        Sooo, Licht am Ende des Tunnels. Seit vor ein paar Wochen mein FI das erste mal mein Dateisystem zerschossen hat, ist im wahrsten Sinne des Wortes der Wurm drin…
                                        ioBroker neu aufgesetzt und nur noch Fehlermeldungen am laufenden Band, also Fehlersuche und nochmal neu aufgesetzt. Immernoch Fehler, weitergesucht, wieder neu aufgesetzt.
                                        Hurra, alles läuft wieder. Ein paar Tage später ruft meine Frau mich auf der arbeit an: "Hier fliegt andauernd die Sicherung raus!"
                                        ...Fehlersuche ergab, Wasserkocher kaputt... ...Dateisystem am Raspberry ebenfalls...
                                        Wieder alles neu aufgesetzt...
                                        Ein paar Tage später auf der Arbeit fällt plötzlich jede Maschine aus... Stromausfall in allen umliegenden Ortschaften, weil ein Trafo im Umspannwerk kaputt ist.. ...das kommt dem Dateisystem natürlich wie gerufen...
                                        Wieder alles neu aufgesetzt und voller Wut endlich das Thema USV angegangen. Jetzt habe ich alles wieder am Laufen, stromausfallsicher, mehr oder weniger alle Fehlermeldungen beseitigt und mein Mobiles UI wieder hergestellt. Zwar etwas abgewandelt wie in meinem letzten Post aber dafür nun endlich auch mit einem funktionierendem Projektexport. Firefox sei dank :D
                                        P.S.: Aufgrund der Dateigröße hab ich den Export ohne die Hintergründe der einzelnen Räume gespeichert.
                                        7700_2018-11-15-op5t.zip
                                        7700_screenshot_20181115-212218.jpg 7700_screenshot_20181115-212350.jpg 7700_screenshot_20181115-212307.jpg 7700_screenshot_20181115-212243.jpg
                                          Annuit20
                                          #383
                                          Sieht gut aus! Danke fürs Teilen!
