  4. [Gelöst] ÖPNV durch Google API integrieren
    6.3k
20 Beiträge 5 Kommentatoren 4.1k Aufrufe 1 Beobachtet
  • C Offline
    cernst1980
    @Walkinlarge2010!:
    Habe im Internet gesehen das es woh einen API seitens Google gibt. Hat damit schon jemand Erfahrungen gemacht? `
    Ich habe mir einen node-red Flow erstellt, welcher alle 10 Minuten bei Google schaut, wie lange ich mit dem Auto in die Arbeit brauche (Traffic) und welches die schnellste Route ist.
    "id": "ae4b669.ff40f98",
    "type": "http request",
    "z": "6015ef4a.448fa",
    "name": "askGoogle",
    "method": "use",
    "ret": "obj",
    "url": "",
    "tls": "",
    "x": 630,
    "y": 40,
    "wires": [
    "f04f6c00.5d74e"
    "id": "8b2ca3ef.9d2dc",
    "type": "function",
    "name": "prepareRequest",
    "func": "msg.method = "GET";\nmsg.url = encodeURI("https://maps.googleapis.com/maps/api/directions/json?\"+\n "origin="+msg.config.origin+\n "&destination="+msg.config.destination+\n "&key="+msg.config.key+\n "&departure_time="+msg.config.departure_time);\ndelete msg.payload;\ndelete msg.topic;\n\nreturn msg;",
    "outputs": 1,
    "noerr": 0,
    "x": 440,
    "y": 40,
    "wires": [
    "ae4b669.ff40f98"
    "id": "3743bbe5.c70434",
    "type": "function",
    "name": "setConfig",
    "func": "msg.config = {\n origin: "Taufkirchen",\n destination: "München",\n key: "1234567890",\n departure_time: "now",\n name: "Home2Work",\n topic_prefix: "node-red.0.Google_Maps"\n};\n\nreturn msg;",
    "outputs": 1,
    "noerr": 0,
    "x": 260,
    "y": 40,
    "wires": [
    "8b2ca3ef.9d2dc"
    "id": "6b432baa.b60024",
    "type": "inject",
    "name": "Trigger",
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "repeat": "600",
    "crontab": "",
    "once": false,
    "onceDelay": "",
    "x": 100,
    "y": 40,
    "wires": [
    "3743bbe5.c70434"
    "id": "f04f6c00.5d74e",
    "type": "function",
    "name": "extractData",
    "func": "var distance = (msg.payload.routes[0].legs[0].distance.value / 1000).toFixed(1); // km\nvar duration = Math.ceil(msg.payload.routes[0].legs[0].duration.value / 60); // min\nvar duration_in_traffic = Math.ceil(msg.payload.routes[0].legs[0].duration_in_traffic.value / 60); // min\nvar start_address = msg.payload.routes[0].legs[0].start_address;\nvar end_address = msg.payload.routes[0].legs[0].end_address;\nvar summary = msg.payload.routes[0].summary;\n\nvar msgTraffic = [\n {\n topic: msg.config.topic_prefix + "." + msg.config.name + ".distance",\n payload: distance\n },\n {\n topic: msg.config.topic_prefix + "." + msg.config.name + ".duration",\n payload: duration\n },\n {\n topic: msg.config.topic_prefix + "." + msg.config.name + ".duration_in_traffic",\n payload: duration_in_traffic\n },\n { \n topic: msg.config.topic_prefix + "." + msg.config.name + ".delay",\n payload: duration_in_traffic - duration\n },\n {\n topic: msg.config.topic_prefix + "." + msg.config.name + ".start_address",\n payload: start_address\n },\n {\n topic: msg.config.topic_prefix + "." + msg.config.name + ".end_address",\n payload: end_address\n },\n {\n topic: msg.config.topic_prefix + "." + msg.config.name + ".summary",\n payload: summary\n }\n];\n\nreturn [msgTraffic];",
    "outputs": 1,
    "noerr": 0,
    "x": 810,
    "y": 40,
    "wires": [
    "8b7a1415.d81d48"
    "id": "8b7a1415.d81d48",
    "type": "ioBroker out",
    "name": "ioBroker",
    "topic": "",
    "ack": "true",
    "autoCreate": "true",
    "x": 980,
    "y": 40,
    "wires": []
    Sollte sich die schnellste Route ändern oder die Fahrzeit einen Schwellwert überschreiten, werde ich rechtzeitig durch ein Blockly/Javascript per Telegram benachrichtigt (Beta).
    on({id: 'node-red.0.Google_Maps.Home2Work.summary', change: "ne"}, function (obj) {
      var value = obj.state.val;
      if (getState("javascript.0.Anwesenheitssteuerung.Userlist.Chris").val == true) {
        sendTo("telegram", "send", {
            text: (String('Neue Route in die Arbeit: ') + String(getState("node-red.0.Google_Maps.Home2Work.summary").val))
    on({id: 'node-red.0.Google_Maps.Home2Work.duration_in_traffic', change: "ne"}, function (obj) {
      if (getState("javascript.0.Anwesenheitssteuerung.Userlist.Chris").val == true && getState("node-red.0.Google_Maps.Home2Work.duration_in_traffic").val > 30) {
            text: (['Achtung: Fahrzeit in die Arbeit beträgt aktuell ',getState("node-red.0.Google_Maps.Home2Work.duration_in_traffic").val,' Minuten!'].join(''))
    node-red.0.Google_Maps.Home2Work.duration_in_traffic lasse ich mir auch noch per flot Adapter graphisch darstellen.
     ![4997_bildschirmfoto_2018-04-04_um_23.44.40.png](/assets/uploads/files/4997_bildschirmfoto_2018-04-04_um_23.44.40.png)
    Das könnte man jetzt noch mit einem Urlaubskalender oder zumindest dem Wochentag verknüpfen bzw. von Auto auf ÖPNV umstellen.
    Wenn ich mal Zeit und Lust habe, wollte ich das mal auf mehrere konfigurierbare Routen umstellen…
    • W Offline
      W Offline
      Walkinlarge2010
      Das klingt alles interessant, aber ist glaube nicht das was ich suche. Zeil wäre eine Anzeige die sagt, zum Ziel a) um XX Uhr den Bus ABC von der Haltstelle DEF nehmen. So zumindest mein Wunsch [emoji848]
      • C Offline
        cernst1980
        @Walkinlarge2010!:
        Das klingt alles interessant, aber ist glaube nicht das was ich suche. Zeil wäre eine Anzeige die sagt, zum Ziel a) um XX Uhr den Bus ABC von der Haltstelle DEF nehmen. `
        Geht genauso, wie ich geschrieben habe…
        Musst in der Google API URL nur "&travel_mode=transit" anhängen.
        In der JSON Antwort stecken dann die gewünschten Informationen, müssen halt entsprechend geparsed werden.
        https://developers.google.com/maps/docu ... sitDetails
        • Ziel A --> end_address
        • um XX UHR --> departure_time
        • Bus ABC --> line
        • Haltestelle DEF --> departure_stop
        • W Offline
          W Offline
          Walkinlarge2010
          Danke, dann werde ich mich am Wochenende mal damit beschäftigen um das ganze besser zu verstehen :)
          • W Offline
            W Offline
            Walkinlarge2010
            Moin zusammen,
            @arteck:
            es hat einer mal die https://forum.iobroker.net/viewtopic.php?f=8&t=4019&hilit=Stauerkennung von A nach B sich darstellen lassen.. `
            hat nun doch etwas länger gedauert bis ich dazu gekommen bin was zu machen. Danke für den Hinweis, hat auch soweit funktioniert. Sprich ich habe mir den Java Code geschnappt und durch testen so weit umbauen können, dass er fürs erste funktioniert. Gerne würde ich nun noch den Namen für die Haltestelle und zuküftig weitere Informationen anzeigen lassen und da hänge ich nun an einer Stelle, da es in der JSON Antwort ein paar ebenen tiefer hängt.
            Nun mal konkret :)
            Der umgebaute /angepasste Code:
            var request = require('request');
            var logging = true;
            createState('Verkehr.Bahn_HBF_Abfahrt', 0, {
            createState('Verkehr.Bahn_HBF_Dauer', 0, {
            createState('Verkehr.Bahn_HBF_Haltestelle', 0, {
            createState('Verkehr.Bahn_HBF_Linie', 0, {
            function datenlesen() {
                var link = 'Google Link' ;
                log('Google Daten einlesen');
                request(link, function (error, response, body) {
                    if (!error && response.statusCode == 200) {
                        var result;
                        try{
                            result = JSON.parse(body);
                            if (logging) log('Kein Fehler beim Einlesen Google Daten');
                        } catch (e) {
                            log('Parse Fehler (Roofi Modul):' + e);
                        if (result) {
                            var Abfahrtszeit;
                            var Dauer;
                            var Haltestelle;
                            if (logging) log(result.routes[0].legs[0].departure_time.text);
                            if (logging) log(result.routes[0].legs[0].duration.text);
                            //if (logging) log(result.routes[0].legs[0].steps[0].transit_details[0].start_location.text);
                            Abfahrtszeit = result.routes[0].legs[0].departure_time.text;
                            Dauer = result.routes[0].legs[0].duration.text;
                            //Haltestelle = result.routes[0].legs[0].steps[0].transit_details[0].start_location.text;
                            setState("javascript.0.Verkehr.Bahn_HBF_Abfahrt",Abfahrtszeit);
                            setState("javascript.0.Verkehr.Bahn_HBF_Dauer",Dauer);
                            //setState("javascript.0.Verkehr.Bahn_HBF_Haltestelle",Haltestelle);
                    } else log('Fehler (Google Daten Abfrage: ' + error);
                });   // Ende request
                log('Google Daten eingelesen');
            –> Abfahrtszeit und Dauer klappt, aber die Haltestelle nicht (aktuell mit den // außer betrieb gesetzt).
            Hier die JSON Antwort von Google, daraus möchte ich noch den Namen von departure_stop ziehen:
               "geocoded_waypoints" : [
                     "geocoder_status" : "OK",
                     "place_id" : "Ei1Hb2Rlc2JlcmdlciBBbGxlZSA5MCwgNTMxNzUgQm9ubiwgRGV1dHNjaGxhbmQ",
                     "types" : [ "street_address" ]
                     "place_id" : "ChIJAwsLOp_hvkcRMZDtxvyPpBc",
                     "types" : [ "premise" ]
               "routes" : [
                     "bounds" : {
                        "northeast" : {
                           "lat" : 50.732347,
                           "lng" : 7.141497999999999
                        "southwest" : {
                           "lat" : 50.696774,
                           "lng" : 7.0970019
                     "copyrights" : "Kartendaten © 2018 GeoBasis-DE/BKG (©2009), Google",
                     "legs" : [
                           "arrival_time" : {
                              "text" : "18:50",
                              "time_zone" : "Europe/Berlin",
                              "value" : 1524934200
                           "departure_time" : {
                              "text" : "18:38",
                              "value" : 1524933480
                           "distance" : {
                              "text" : "5,3 km",
                              "value" : 5261
                           "duration" : {
                              "text" : "12 Minuten",
                              "value" : 720
                           "end_address" : "Empfangsgebäude Bonn Hauptbahnhof, Am Hauptbahnhof 1, 53111 Bonn, Deutschland",
                           "end_location" : {
                              "lat" : 50.7323073,
                              "lng" : 7.0970019
                           "start_address" : "Godesberger Allee 90, 53175 Bonn, Deutschland",
                           "start_location" : {
                              "lat" : 50.696774,
                           "steps" : [
                                 "distance" : {
                                    "text" : "5,3 km",
                                    "value" : 5261
                                 "duration" : {
                                    "value" : 720
                                 "end_location" : {
                                    "lat" : 50.7323073,
                                    "lng" : 7.0970019
                                 "html_instructions" : "Straßenbahn in Richtung Köln, Niehl Sebastianstr.",
                                 "polyline" : {
                                    "points" : "yultHkyqj@c^b^wWtY}_@p_@ac@vg@s\\|c@oXzQi[vRaMff@Fd_@"
                                    "lat" : 50.696774,
                                 "transit_details" : {
                                    "arrival_stop" : {
                                       "location" : {
                                          "lat" : 50.7323073,
                                          "lng" : 7.0970019
                                       "name" : "Bonn Hbf"
                                    "arrival_time" : {
                                       "text" : "18:50",
                                    "departure_stop" : {
                                       "location" : {
                                          "lat" : 50.696774,
                                       "name" : "Bonn, Plittersdorf Hochkreuz/Deutsches Museum Bonn"
                                       "text" : "18:38",
                                    "headsign" : "Köln, Niehl Sebastianstr.",
                                    "line" : {
                                       "agencies" : [
                                             "name" : "KVB Kölner Verkehrs-Betriebe AG",
                                             "phone" : "011 49 221 5470",
                                             "url" : "http://www.kvb-koeln.de/"
                                       "short_name" : "16",
                                       "vehicle" : {
                                          "icon" : "//maps.gstatic.com/mapfiles/transit/iw2/6/tram2.png",
                                          "name" : "Straßenbahn",
                                          "type" : "TRAM"
                                    "num_stops" : 9
                                 "travel_mode" : "TRANSIT"
                           "traffic_speed_entry" : [],
                           "via_waypoint" : []
                     "overview_polyline" : {
                     "summary" : "",
                     "warnings" : [],
                     "waypoint_order" : []
               "status" : "OK"
            und hier die Fehlermeldung aus dem Log wenn ich das Script laufen lasse:
            18:51:46.732	[info]	javascript.0 Start javascript script.js.Verkehr_Test_2
            18:51:46.732	[info]	javascript.0 script.js.Verkehr_Test_2: Google Daten einlesen
            18:51:46.732	[info]	javascript.0 script.js.Verkehr_Test_2: Google Daten eingelesen
            18:51:46.732	[info]	javascript.0 script.js.Verkehr_Test_2: registered 0 subscriptions and 1 schedule
            18:51:47.311	[info]	javascript.0 script.js.Verkehr_Test_2: Kein Fehler beim Einlesen Google Daten
            18:51:47.312	[info]	javascript.0 script.js.Verkehr_Test_2: 18:52
            18:51:47.312	[info]	javascript.0 script.js.Verkehr_Test_2: 13 Minuten
            18:51:47.313	[error]	javascript.0 TypeError: Cannot read property '0' of undefined at Request._callback (script.js.Verkehr_Test_2:45:83) at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22) at emitTwo (events.js:106:13) at Request.emit (events.js:191:7) at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10) at emitOne (events.js:96:13) at Request.emit (events.js:188:7) at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12) at IncomingMessage.g (events.js:292:16) at emitNone (events.js:91:20)
            18:51:47.811	[error]	Caught by controller[0]: at Request._callback (script.js.Verkehr_Test_2:45:83)
            Kann mir jemand erklären was ich anders machen muss und vielleicht auch kurz sagen warum? Bisher war es try & error. Gerne würde ich besser verstehen was hier im Script
            , u. a. in den Eckigen klammern passiert und verstehen :)
            danke!
            Viele Grüße Walkinlarge
            • ruhr70R Offline
              ruhr70R Offline
              ruhr70
              @Walkinlarge2010!:
              , u. a. in den Eckigen klammern passiert und verstehen :) `
              Am besten Du schaust Dir das JSON mit einem JSON Editor an.
              Gibt es auch online.
              https://jsoneditoronline.org/?id=8e2f0a … 051f237f59
              filename="öpnv_json.png" index="0">~~
              routes[0] bedeutet, dass es ein Array von Routen ist.
              Bei Dir ist es nur eine Route. Der erste Eintrag im Array ist die [0]. Wenn es mehrere Routen gebe, gehen die dann mit 2, 3, usw. weiter.
              • W Offline
                W Offline
                Walkinlarge2010
                Danke, dann komme ich glaub eher weiter. Im Safari war mir die Struktur nicht so wirklich klar :) teste es mal mit dem Editor.
                –> Danke für den Tipp mit dem Editor. So klappt es! 1000 Dank!
                Gesendet von iPad mit Tapatalk
                  Torsten_MG
                  @Walkinlarge2010!:
                  Gesendet von iPad mit Tapatalk `
                  Hallo Walkinlarge,
                  wie genau hast du das jetzt umgesetzt?
                  Ich habe noch kein iobroker am laufen und mache mich schlau was so möglich ist, bevor ich umsteige. Bin durch Zufall auf diesen Thread gestoßen, habe aber auch Interesse so etwas bei mir anzeigen zu lassen.
                  • W Offline
                    W Offline
                    Walkinlarge2010
                    Gute Frage. Hatte damals funktioniert nur aufgrund eines Systemwechsels habe ich das Script nicht mehr. Vielleicht ist es noch auf einer alten Datensicherung. Mache mich mal auf die Suche, wollte das eh wieder bei mir integrieren. Falls ich es nicht finde baue ich es neu, kann ja nicht so schwer gewesen sein ;)
                    Melde mich in paar Tagen wenn ich es wieder habe :) Die obige Variante war ja noch nicht vollständig bzw. final.
                      Torsten_MG
                      @Walkinlarge2010!:
                      Melde mich in paar Tagen wenn ich es wieder habe :) ` Das wäre super[emoji106]
                      Gesendet von meinem SM-J730F mit Tapatalk
                      • W Offline
                        W Offline
                        Walkinlarge2010
                        So, hier nun wie ich es umgesezt habe.
                        Erst mal muss man sich bei Google einen API besorgen. Infos zum API und zur Anwendung gibt es hier:
                        https://developers.google.com/maps/docu … ntro?hl=de
                        Wenn du dir eine Abfrage gebaut hast, so wie diese hier z.B. (habe den API KEY von mir raus genommen, bitte durch eigenen ersetzen)
                        https://maps.googleapis.com/maps/api/directions/json?origin=place_id:ChIJ_xXrLmzkvkcRQacjsrOKAv0&&destination=place_id:ChIJAwsLOp_hvkcRMZDtxvyPpBc&key=###KEY_Eintragen###&mode=transit&language=de
                        kannst du diese im Browser ausführn und bekommst, wenn alles richtig ist, eine JSON zurück mit allen Infos. Um diese Infos im Script einfach anpassen zu können, koiere das ergebnis am besten in folgenden JSON Editor https://jsoneditoronline.org/
                        im Beitrag weiter oben im Bild ist gut beschrieben, was wie zu lesen und anzupassen ist.
                        Hier hast du noch das Script, was bei mir Datenpunkte erstellt usw. Das habe ich nicht selbst geschrieben, sondern nur für mich angepasst.
                        var logging = true;
                        createState('Verkehr.Aktualisieren', false, {
                                desc: 'Werte aktualisieren',
                                type: 'boolean',
                                def:  false,
                                role: 'indicator'
                        createState('Verkehr.Bonn-HBF.Startzeit', 0, {
                        createState('Verkehr.Bonn-HBF.Abfahrtszeit', 0, {
                        createState('Verkehr.Bonn-HBF.Ankunftszeit', 0, {
                        createState('Verkehr.Bonn-HBF.Haltestelle', 0, {
                        createState('Verkehr.Bonn-HBF.Linie', 0, {
                        createState('Verkehr.Bonn-HBF.Verkehrsmittel', 0, {
                            //Hochkreuzalle nach HBF ohne Waypoints
                            var link = 'https://maps.googleapis.com/maps/api/directions/json?origin=place_id:ChIJ_xXrLmzkvkcRQacjsrOKAv0&&destination=place_id:ChIJAwsLOp_hvkcRMZDtxvyPpBc&key=###API_KEY_EINFÜGEN###&mode=transit&language=de' ;
                                    var result;
                                    try{
                                    } catch (e) {
                                    if (result) {
                                        var Startzeit;
                                        var Abfahrtszeit;
                                        var Ankunftszeit;
                                        var Haltestelle;
                                        var Linie;
                                        var Verkehrsmittel;
                                        if (logging) log(result.routes[0].legs[0].steps[1].transit_details.departure_time.text);
                                        if (logging) log(result.routes[0].legs[0].arrival_time.text);
                                        if (logging) log(result.routes[0].legs[0].steps[1].transit_details.departure_stop.name);
                                        if (logging) log(result.routes[0].legs[0].steps[1].transit_details.line.short_name);
                                        if (logging) log(result.routes[0].legs[0].steps[1].transit_details.line.vehicle.name);
                                        Startzeit = result.routes[0].legs[0].departure_time.text;
                                        Abfahrtszeit = result.routes[0].legs[0].steps[1].transit_details.departure_time.text;
                                        Ankunftszeit = result.routes[0].legs[0].arrival_time.text;
                                        Haltestelle = result.routes[0].legs[0].steps[1].transit_details.departure_stop.name;
                                        Linie = result.routes[0].legs[0].steps[1].transit_details.line.short_name;
                                        Verkehrsmittel = result.routes[0].legs[0].steps[1].transit_details.line.vehicle.name;
                                        setState("javascript.0.Verkehr.Bonn-HBF.Startzeit",Startzeit);
                                        setState("javascript.0.Verkehr.Bonn-HBF.Abfahrtszeit",Abfahrtszeit);
                                        setState("javascript.0.Verkehr.Bonn-HBF.Ankunftszeit",Ankunftszeit);
                                        setState("javascript.0.Verkehr.Bonn-HBF.Haltestelle",Haltestelle);
                                        setState("javascript.0.Verkehr.Bonn-HBF.Linie",Linie);
                                        setState("javascript.0.Verkehr.Bonn-HBF.Verkehrsmittel",Verkehrsmittel);
                                        setState("javascript.0.Verkehr.Aktualisieren", false);
                                        setState("javascript.0.VIS.Overlay", 5);
                                    //    setState("javascript.0.VIS.Overlay_iPhoneX", 5);
                            });   // Ende request
                        datenlesen ();
                        Hilfreich für mich, war noch die Suche nach den Place-ID´s. Das geht über https://developers.google.com/places/place-id
                        Ich hoffe ich habe nichts vergessen und du kannst was mit der Anleitung anfangen. Die erzeugten Datenpunkte kannst du dann auslesen und im VIS darstellen lassen. Lies dich mal durch den API Guide, es gibt hier noch viele spannende Variationsmöglichkeiten.
                        So habe ich es visualisiert:
                        Wenn jemand dazu noch weitere spannende Ideen hat, freue ich mich natürlich and er Stelle auch über eine Info ;)
                        Viele Grüße
                        Matthias
                          Torsten_MG
                          Hallo Mathias,
                          erstmal vielen Dank, dass du dir die Mühe gemacht hast. Ich habe es jetzt erstmal soweit mir möglich ausprobiert (IoBroker läuft noch nicht)
                          Ich habe die station ID´s auf meine Heimatadresse und den Platz vor unserem HBF angepasst. Meine Google API (ich hatte schon eine) eingegeben und dden neuen Link im Browser eingegeben. Die zurückgegebene Json-Datei dann im Editor eingegeben, um den Klartext zu lesen. Was bei mir leider schiefläuft:
                          Vor meinem Haus ist eine Haltestelle wo 2 Busse abfahren, die beide zum HBF fahren.
                          ca 10min Fußweg von meiner Wohnung ist auch noch ein kleiner Bf wo eine Regiobahn zum HBF fährt.
                          In der Json wird mir aber leider nur der Zug angezeigt, weißt du oder jemand anderes, was ich abändern muß?
                          EDIT:
                          Hat sich erledigt. Rufe die Json-Datei jetzt woanders ab:
                          https://dbf.finalrewind.org/
                          bzw.
                          https://vrrf.finalrewind.org/
                          Ist zwar "nur" der Abfahrtmonitor, es reicht mir aber!
                          Den Rest probiere ich aus, sobald ich den ioBroker am laufen habe
                          • W Offline
                            W Offline
                            Walkinlarge2010
                            Ich würde versuchen als Startpunkt deine Heimatadresse zu nehmen. Dann als Waypoint die Bushaltestelle. Evtl. kannst du noch das Verkehrsmittel in der Anfrage auswählen oder einen weiteren Waypoint über eine der folgenden Bushaltestellen machen. Ich vermute der Weg mit der Bahn ist schneller als mit dem Bus. Eigentlich nimmt er die Route, die am schnellsten am Ziel ist. Wenn der Zug abgefahren ist, müsste er auf den Bus zurückgreifen, denke ich mal
                              Torsten_MG
                              Leider ist JSON und co für mich noch neuland (bin aber lernfähig :D )
                              Habe jetzt das Script für mich abgepasst. Da ich aber gerne so eine Art Abfahrtmonitor mit den nächsten 5 Abfahrten machen möchte, muß ich ja alles 5x auslesen.
                              Hier mal der Auszug aus meinem angepassten Script, wo ich die Abfrage 1x mache
                              var Startzeit;
                              var Verspaetung;
                              var Linie;
                              //Startzeit
                              if (logging) log(result.raw[0].sched_time);
                              //Verspaetung
                              if (logging) log(result.raw[0].delay);
                              //Linie
                              if (logging) log(result.raw[0].linie);
                              Startzeit = result.raw[0].prev_route.sched_time;
                              Verspaetung = result.raw[0].delay;
                              Linie = result.raw[0].linie;
                              setState("javascript.0.Verkehr.Haltestelle.Startzeit",Startzeit);
                              setState("javascript.0.Verkehr.Haltestelle.Verspaetung",Verspaetung);
                              setState("javascript.0.Verkehr.Haltestelle.Linie",Linie);
                              Nun müßte ich ja bei den anderen Abfahrtzeiten die 0 in die jeweils nächste Zahl ändern. (1-4)
                              if (logging) log(result.raw[0].prev_route.sched_time);
                              und dann natürlich hier auch noch die Zahlen dranhängen
                              Leider weiß ich aber nicht wie :?
                              Natürlich könnte ich das ja alles 5x untereinander schreiben, aber das ist nicht die saubere Art.
                              • W Offline
                                W Offline
                                Walkinlarge2010
                                Ich glaube da muss man das Script dann kopieren und mit der Anfahrtszeit spielen. Aber ich hatte da eine andere Anforderung. Danke für den tip mit dem Fahrplan. Kann ich vielleicht auch noch brauchen [emoji51]
                                  Torsten_MG
                                  Ich habe jetzt mal meine Test SD-Karte in den Raspi gesteckt um das Script zu Testen. Da ja eigentlich immer noch Fhem bei mir läuft weil ich noch nicht alle Komponente für den Umstieg habe.
                                  var logging = true;
                                          type: 'boolean',
                                          def:  false,
                                          role: 'indicator'
                                  createState('Verkehr.meine_Haltestelle.Startzeit', 0, {
                                  createState('Verkehr.meine_Haltestelle.Verspaetung', 0, {
                                  //createState('Verkehr.meine_Haltestelle.inMinuten', 0, {
                                  createState('Verkehr.meine_Haltestelle.Haltestelle', 0, {
                                  createState('Verkehr.meine_Haltestelle.Linie', 0, {
                                  //createState('Verkehr.meine_Haltestelle.Verkehrsmittel', 0, {
                                      //Von meiner Haltestelle Richtung HBF
                                      var link = 'https://vrrf.finalrewind.org/xxx/xxx.json?frontend=json&backend=efa.VRR&platform=2' ;
                                      log('Verkehr Daten einlesen');
                                              var result;
                                              try{
                                                  if (logging) log('Kein Fehler beim Einlesen Verkehr Daten');
                                              } catch (e) {
                                              if (result) {
                                                  var Startzeit;
                                                  var Verspaetung;
                                                  var inMinuten;
                                                  var Haltestelle;
                                                  var Linie;
                                              //    var Verkehrsmittel;
                                  				//Startzeit
                                  				//Verspaetung
                                  				//Bus kommt in Minuten
                                                  if (logging) log(result.raw[0].countdown);
                                  				//Ziel Haltestelle
                                                  if (logging) log(result.raw[0].destination);
                                  				//Linie
                                                  if (logging) log(result.raw[0].line);
                                  				//Verkehrsmittel
                                              //    if (logging) log(result.raw[0].legs[0].steps[1].transit_details.line.vehicle.name);
                                                  inMinuten = result.raw[0].countdown;
                                                  Haltestelle = result.raw[0].destination;
                                              //    Verkehrsmittel = result.raw[0].legs[0].steps[1].transit_details.line.vehicle.name;
                                                  setState("javascript.0.Verkehr.meine_Haltestelle.Startzeit",Startzeit);
                                                  setState("javascript.0.Verkehr.meine_Haltestelle.Verspaetung",Verspaetung);
                                                  setState("javascript.0.Verkehr.meine_Haltestelle.inMinuten",inMinuten);
                                                  setState("javascript.0.Verkehr.meine_Haltestelle.Haltestelle",Haltestelle);
                                                  setState("javascript.0.Verkehr.meine_Haltestelle.Linie",Linie);
                                              //    setState("javascript.0.Verkehr.meine_Haltestelle.Verkehrsmittel",Verkehrsmittel);
                                          } else log('Fehler (Verkehr Daten Abfrage: ' + error);
                                      });   // Ende request
                                      log('Verkehr Daten eingelesen');
                                  datenlesen ();
                                  Er hat mir auch Brav alle Objekte erstellt und gefüllt. Aber nur 1x. Läuft das Script nicht permanent durch? Muß ich es mit einem weiteren Script immer wieder anstoßen? Oder habe ich noch einen Fehler im Script und er läuft nicht immer wieder durch?
                                  Entschuldige die vielen Fragen, aber mit Script bauen habe ich 0 Erfahrung! Bin aber bereit zu lernen :D
                                  • W Offline
                                    W Offline
                                    Walkinlarge2010
                                    Ich habe mir eingebaut, dass es auf Knopfdruck im VIS aktualisiert wird (habe ein Button, das die Verkehrsübersicht aufruft, gleichzeitig wird das Script gestartet. Somit habe ich Abfrage nur wenn ich Sie auch benötige.
                                    Hier der Code, den einfach unten einfügen und mit einem eigenen Status (bei mir ist es "javascript.0.Verkehr.Aktualisieren") verknüpfen:
                                    on({id:'javascript.0.Verkehr.Aktualisieren'}, function (obj) {
                                        if (!obj.state.ack && obj.state.val) datenlesen ()
                                    Oder du kannst ihn auch alle x Minuten laufen lassen.
                                    Dazu musst du folgenden Code am ende deiner Funktion einfügen:
                                    schedule("*/5 * * * *", datenlesen);
                                    Viel Erfolg!
                                      Torsten_MG
                                      Danke!
