  4. [Aufruf] ZigBee CC253x Adapter
1.1k Beiträge 131 Kommentatoren 488.6k Aufrufe 7 Beobachtet
    Sinalco
    #182
    Bei meinem Osram Band bekomme ich momentan immer die Fehlermeldung (siehe unten), ich kann grad gar nichts mehr machen, es ist grad an aber egal welchen Wert ich setze es passiert nichts:
    zigbee.0	2018-09-16 20:16:57.427	error	Zigbee publish to '0x7cb03eaa000024ef', lightingColorCtrl - moveToColor - {"colorx":37800.587999999996,"colory":25499.6685,"transtime":0} - 3 failed with error Error: AF data request fails, status cod
    zigbee.0	2018-09-16 20:16:55.051	error	Zigbee publish to '0x7cb03eaa000024ef', genLevelCtrl - moveToLevel - {"level":254,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
    zigbee.0	2018-09-16 20:16:52.427	error	Zigbee publish to '0x7cb03eaa000024ef', lightingColorCtrl - moveToColorTemp - {"colortemp":370,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
    zigbee.0	2018-09-16 20:16:49.946	error	Zigbee publish to '0x7cb03eaa000024ef', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
    zigbee.0	2018-09-16 20:16:47.987	error	Zigbee publish to '0x7cb03eaa000024ef', lightingColorCtrl - moveToColorTemp - {"colortemp":370,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
    zigbee.0	2018-09-16 20:16:46.568	error	Zigbee publish to '0x7cb03eaa000024ef', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
    zigbee.0	2018-09-16 20:16:44.142	error	Zigbee publish to '0x7cb03eaa000024ef', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
    EDIT:
    Hab wohl auf das grüne Pairing Zeichen des Osram Bandes geklickt.
    Für was auch immer der Button ist??? Wenn man da drauf klickt funktioniert wohl das Gerät nicht mehr. Bei meinen Sensoren gibt es keinen so einen grünen Button.
    Jetzt hab ich auf den normalen Pairing Button oben rechts geklickt und das Band neu verbunden.
    Jetzt funktioniert es wieder!
    Übrigens funktionieren auch nur 6 Stellige Hex Farbcodes, wie auf der Seite und auch nicht alle:
    http://www.december.com/html/spec/colorhslhex10.html
    Weis jemand wie man das konvertieren kann um es in vis darzustellen?
    • arteckA Offline
      arteckA Offline
      arteck
      #183
      @der_Auge:
      Ist hier ein Problem?
      new dev 0x000b57fffecae610 `
      nein das passiert ab und an bei mir auch nach dem Adapter neustart..warum auc himmer.. aber dann auch nur mit den Osram Teilen.. ich vermute die werden nicht richtig in den Betrieb zustan genommen.. ergo laufen die in den Erkennungsmodus rein… funktionieren aber ganz normal
      und ja man Benötigt ein DEbug modul
      wobei ALLE DIE DEN STICK VON MIR HABEN DIESES FILE DRAUF
      zu dem Band Problem.. hast du mal den Stecker gezogen.. und wieder rein.. das Band müsste sich dann rekonnencten..
      der grüne Button am Gerät sollte das auch machen ..
      • F Offline
        Feliiix
        #184
        habe ein Problem mit dem Tradfri Dimmer von IKEA. Er wird erkannt jedoch werden keine Objekte angelegt. Gibt es dafür eine Lösung?
        Gruß Felix
        • arteckA Offline
          arteckA Offline
          arteck
          #185
          der geht nicht… bist nich der erste der das feststellt
          • F Offline
            Feliiix
            #186
            @arteck:
            der geht nicht… bist nich der erste der das feststellt `
            Bei zigbee2mqtt wird der Dimmer unterstützt: https://github.com/Koenkk/zigbee2mqtt/w … ed-devices
            Woran liegt es, dass das Gerät mit dem ioBroker Adapter nicht funktioniert?
            • arteckA Offline
              arteckA Offline
              arteck
              #187
              weil er noch nicht implementiert ist im Adapter..
              stell bitte auf GIT ein issue
              • F Offline
                Feliiix
                #188
                Okay. Das hat schon jemand für mich erledigt ;)
                https://github.com/ioBroker/ioBroker.zigbee/issues/54
                • a200A Offline
                  a200A Offline
                  a200
                  #189
                  Moin,
                  wie ist jetzt der Stand?
                  @der_Auge:
                  Ist zwar keine Antwort auf deine Frage:
                  Aber:
                  Was hast du für Bewegungsmelder?
                  1. Generation
                  2. Generation des Bewegungsmelders , da diese einen Lichtsensor besitzt.
                  Ich habe :
                  Jürgen `
                  welche Generation ist jetzt dein Bewegungsmelder? Ich habe welche mit einem Loch (wie bei deinem Foto) und mit einem Taster gesehen.
                  Welche Version ist jetzt die aktuelle und lassen sich beide einbinden?
                  Vielen herzlichen Dank für die Infos.
                  a200.
                  IoBroker auf QNAP TS-451, Raspi und NUC
                  • H Offline
                    hawi1981
                    #190
                    Ich habe beide Versionen und beide angebunden. Der mit dem Taster von Aquara ist einfacher einzubinden, da man bei den Sensoren nur einmal den Taster für 3 Sekunden drücken muss und geht es. Bei den anderen ist es ein wenig schwieriger, wie auch auf der Adapterseite bei Github beschrieben:
                    https://github.com/Koenkk/zigbee2mqtt/w … ng-devices
                    ` > Xiaomi
                    Different devices require different pairing methods. In case you get an Error [ERR_UNHANDLED_ERROR]: Unhandled error. (Cannot get the Node Descriptor of the Device: 0x00158d0001720111) you should try a different pairing method. See Supported devices to figure out if your device is MiJia or Aqara.
                    Most MiJia devices: press and hold the reset button on the device for +- 5 seconds (until the blue light starts blinking). IMPORTANT: Release and start pressing the reset button every second. This keeps the device awake, otherwise pairing will fail!.
                    Most Aqara devices: press and hold reset button on the device for +- 5 seconds (until the blue light starts blinking), release and wait.
                    Most Aqara wall switches: press and hold the button on the device for +- 10 seconds (until the blue light starts blinking and stops blinking), release and wait. `
                      mafe68
                      #191
                      Konnte mein Problem jetzt lösen mit den Fenster Türkontakte da sie nach kurzen Zeit keine Verbindern mehr aufgebaut haben und ich sie dann jedes mal neu Anlernen musste. Die Lösung war ich habe nach dem Tipp von @arteck die aktuelle Firmware auf den CC2531 Zigbee Stick geflasht und jetzt geht es. Danke an @arteck nochmal für den Tipp
                      LG. Mario
                      ioBroker LXC Container Proxmox
                      ioBroker BananaPi M1
                      • Lenny.CBL Offline
                        Lenny.CBL Offline
                        Lenny.CB
                        #192
                        seit gestern macht mein zigbee-Adapter faxen…
                        Woher kommt das?
                        Caught	2018-09-22 09:11:24.014	error	by controller[33]: Sat, 22 Sep 2018 07:11:23 GMT cc-znp:SREQ --> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
                        Caught	2018-09-22 09:11:24.014	error	by controller[33]: Sat, 22 Sep 2018 07:11:23 GMT zigbee-shepherd:request REQ --> ZDO:mgmtPermitJoinReq
                        Caught	2018-09-22 09:11:24.014	error	by controller[32]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } } { cid: 'msPressureMeasurement', modelId: 'lumi.weather' }
                        Caught	2018-09-22 09:11:24.014	error	by controller[32]: { cid: 'msPressureMeasurement',
                        Caught	2018-09-22 09:11:24.014	error	by controller[32]: report: [Function] } ],
                        Caught	2018-09-22 09:11:24.009	error	by controller[32]: write: [Function],
                        Caught	2018-09-22 09:11:24.004	error	by controller[32]: read: [Function],
                        Caught	2018-09-22 09:11:24.004	error	by controller[32]: unbind: [Function],
                        Caught	2018-09-22 09:11:24.003	error	by controller[32]: bind: [Function],
                        Caught	2018-09-22 09:11:24.003	error	by controller[32]: functional: [Function],
                        Caught	2018-09-22 09:11:24.003	error	by controller[32]: foundation: [Function],
                        Caught	2018-09-22 09:11:24.003	error	by controller[32]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:24.003	error	by controller[32]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:24.003	error	by controller[32]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:24.003	error	by controller[32]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: clusters: [Object],
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: devId: 24321,
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: epId: 1,
                        Caught	2018-09-22 09:11:24.002	error	by controller[32]: profId: 260,
                        Caught	2018-09-22 09:11:24.001	error	by controller[32]: device: [Object],
                        Caught	2018-09-22 09:11:24.001	error	by controller[32]: isLocal: [Function],
                        Caught	2018-09-22 09:11:24.001	error	by controller[32]: [ Endpoint {
                        Caught	2018-09-22 09:11:24.001	error	by controller[32]: endpoints:
                        Caught	2018-09-22 09:11:24.001	error	by controller[32]: 2018-09-22T07:11:15.646Z zigbee:controller event devChange { type: 'devChange',
                        Caught	2018-09-22 09:11:24.001	error	by controller[31]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } }
                        Caught	2018-09-22 09:11:24.001	error	by controller[31]: { cid: 'msPressureMeasurement',
                        Caught	2018-09-22 09:11:24.000	error	by controller[31]: report: [Function] } ],
                        Caught	2018-09-22 09:11:24.000	error	by controller[31]: write: [Function],
                        Caught	2018-09-22 09:11:24.000	error	by controller[31]: read: [Function],
                        Caught	2018-09-22 09:11:24.000	error	by controller[31]: unbind: [Function],
                        Caught	2018-09-22 09:11:24.000	error	by controller[31]: bind: [Function],
                        Caught	2018-09-22 09:11:24.000	error	by controller[31]: functional: [Function],
                        Caught	2018-09-22 09:11:24.000	error	by controller[31]: foundation: [Function],
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: clusters: [Object],
                        Caught	2018-09-22 09:11:23.999	error	by controller[31]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: devId: 24321,
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: epId: 1,
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: profId: 260,
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: device: [Object],
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: isLocal: [Function],
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: [ Endpoint {
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: endpoints:
                        Caught	2018-09-22 09:11:23.998	error	by controller[31]: 2018-09-22T07:11:15.643Z zigbee:controller debug handleMessage { type: 'devChange',
                        Caught	2018-09-22 09:11:23.997	error	by controller[30]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } } { cid: 'msRelativeHumidity', modelId: 'lumi.weather' }
                        Caught	2018-09-22 09:11:23.997	error	by controller[30]: report: [Function] } ],
                        Caught	2018-09-22 09:11:23.997	error	by controller[30]: write: [Function],
                        Caught	2018-09-22 09:11:23.997	error	by controller[30]: read: [Function],
                        Caught	2018-09-22 09:11:23.997	error	by controller[30]: unbind: [Function],
                        Caught	2018-09-22 09:11:23.997	error	by controller[30]: bind: [Function],
                        Caught	2018-09-22 09:11:23.997	error	by controller[30]: functional: [Function],
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: foundation: [Function],
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:23.996	error	by controller[30]: clusters: [Object],
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: devId: 24321,
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: epId: 1,
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: profId: 260,
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: device: [Object],
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: isLocal: [Function],
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: [ Endpoint {
                        Caught	2018-09-22 09:11:23.995	error	by controller[30]: endpoints:
                        Caught	2018-09-22 09:11:23.994	error	by controller[30]: 2018-09-22T07:11:15.639Z zigbee:controller event devChange { type: 'devChange',
                        Caught	2018-09-22 09:11:23.994	error	by controller[29]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } }
                        Caught	2018-09-22 09:11:23.994	error	by controller[29]: report: [Function] } ],
                        Caught	2018-09-22 09:11:23.994	error	by controller[29]: write: [Function],
                        Caught	2018-09-22 09:11:23.994	error	by controller[29]: read: [Function],
                        Caught	2018-09-22 09:11:23.994	error	by controller[29]: unbind: [Function],
                        Caught	2018-09-22 09:11:23.994	error	by controller[29]: bind: [Function],
                        Caught	2018-09-22 09:11:23.994	error	by controller[29]: functional: [Function],
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: foundation: [Function],
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:23.993	error	by controller[29]: clusters: [Object],
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: devId: 24321,
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: epId: 1,
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: profId: 260,
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: device: [Object],
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: isLocal: [Function],
                        Caught	2018-09-22 09:11:23.992	error	by controller[29]: [ Endpoint {
                        Caught	2018-09-22 09:11:23.991	error	by controller[29]: endpoints:
                        Caught	2018-09-22 09:11:23.991	error	by controller[29]: 2018-09-22T07:11:15.636Z zigbee:controller debug handleMessage { type: 'devChange',
                        Caught	2018-09-22 09:11:23.991	error	by controller[28]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } } { cid: 'msPressureMeasurement', modelId: 'lumi.weather' }
                        Caught	2018-09-22 09:11:23.991	error	by controller[28]: { cid: 'msPressureMeasurement',
                        Caught	2018-09-22 09:11:23.991	error	by controller[28]: report: [Function] } ],
                        Caught	2018-09-22 09:11:23.991	error	by controller[28]: write: [Function],
                        Caught	2018-09-22 09:11:23.991	error	by controller[28]: read: [Function],
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: unbind: [Function],
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: bind: [Function],
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: functional: [Function],
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: foundation: [Function],
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:23.990	error	by controller[28]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: clusters: [Object],
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: devId: 24321,
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: epId: 1,
                        Caught	2018-09-22 09:11:23.989	error	by controller[28]: profId: 260,
                        Caught	2018-09-22 09:11:23.988	error	by controller[28]: device: [Object],
                        Caught	2018-09-22 09:11:23.988	error	by controller[28]: isLocal: [Function],
                        Caught	2018-09-22 09:11:23.988	error	by controller[28]: [ Endpoint {
                        Caught	2018-09-22 09:11:23.988	error	by controller[28]: endpoints:
                        Caught	2018-09-22 09:11:23.988	error	by controller[28]: 2018-09-22T07:11:15.631Z zigbee:controller event attReport { type: 'attReport',
                        Caught	2018-09-22 09:11:23.988	error	by controller[27]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } }
                        Caught	2018-09-22 09:11:23.988	error	by controller[27]: { cid: 'msPressureMeasurement',
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: report: [Function] } ],
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: write: [Function],
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: read: [Function],
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: unbind: [Function],
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: bind: [Function],
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: functional: [Function],
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: foundation: [Function],
                        Caught	2018-09-22 09:11:23.987	error	by controller[27]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: clusters: [Object],
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:23.986	error	by controller[27]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: devId: 24321,
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: epId: 1,
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: profId: 260,
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: device: [Object],
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: isLocal: [Function],
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: [ Endpoint {
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: endpoints:
                        Caught	2018-09-22 09:11:23.985	error	by controller[27]: 2018-09-22T07:11:15.629Z zigbee:controller debug handleMessage { type: 'attReport',
                        Caught	2018-09-22 09:11:23.984	error	by controller[26]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                        Caught	2018-09-22 09:11:23.984	error	by controller[25]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } } { cid: 'msRelativeHumidity', modelId: 'lumi.weather' }
                        Caught	2018-09-22 09:11:23.984	error	by controller[25]: report: [Function] } ],
                        Caught	2018-09-22 09:11:23.984	error	by controller[25]: write: [Function],
                        Caught	2018-09-22 09:11:23.984	error	by controller[25]: read: [Function],
                        Caught	2018-09-22 09:11:23.984	error	by controller[25]: unbind: [Function],
                        Caught	2018-09-22 09:11:23.984	error	by controller[25]: bind: [Function],
                        Caught	2018-09-22 09:11:23.984	error	by controller[25]: functional: [Function],
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: foundation: [Function],
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:23.983	error	by controller[25]: clusters: [Object],
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: devId: 24321,
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: epId: 1,
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: profId: 260,
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: device: [Object],
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: isLocal: [Function],
                        Caught	2018-09-22 09:11:23.982	error	by controller[25]: [ Endpoint {
                        Caught	2018-09-22 09:11:23.981	error	by controller[25]: endpoints:
                        Caught	2018-09-22 09:11:23.981	error	by controller[25]: 2018-09-22T07:11:15.624Z zigbee:controller event attReport { type: 'attReport',
                        Caught	2018-09-22 09:11:23.981	error	by controller[24]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } }
                        Caught	2018-09-22 09:11:23.981	error	by controller[24]: report: [Function] } ],
                        Caught	2018-09-22 09:11:23.981	error	by controller[24]: write: [Function],
                        Caught	2018-09-22 09:11:23.981	error	by controller[24]: read: [Function],
                        Caught	2018-09-22 09:11:23.981	error	by controller[24]: unbind: [Function],
                        Caught	2018-09-22 09:11:23.981	error	by controller[24]: bind: [Function],
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: functional: [Function],
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: foundation: [Function],
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: onZclFunctional: null,
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: onZclFoundation: null,
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfIncomingMsgExt: null,
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfIncomingMsg: null,
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfReflectError: null,
                        Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfDataConfirm: null,
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: clusters: [Object],
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: outClusterList: [Object],
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: inClusterList: [Object],
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: devId: 24321,
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: epId: 1,
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: profId: 260,
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: device: [Object],
                        Caught	2018-09-22 09:11:23.979	error	by controller[24]: isLocal: [Function],
                        Caught	2018-09-22 09:11:23.978	error	by controller[24]: [ Endpoint {
                        Caught	2018-09-22 09:11:23.978	error	by controller[24]: endpoints:
                        Caught	2018-09-22 09:11:23.978	error	by controller[24]: 2018-09-22T07:11:15.621Z zigbee:controller debug handleMessage { type: 'attReport',
                        Caught	2018-09-22 09:11:23.978	error	by controller[23]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                        Caught	2018-09-22 09:11:23.978	error	by controller[22]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                        Caught	2018-09-22 09:11:23.978	error	by controller[21]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                        Caught	2018-09-22 09:11:23.978	error	by controller[20]: Sat, 22 Sep 2018 07:11:15 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 1027, srcaddr: 23198, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 55, secur
                        Caught	2018-09-22 09:11:23.977	error	by controller[19]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                        Caught	2018-09-22 09:11:23.977	error	by controller[18]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                        Caught	2018-09-22 09:11:23.977	error	by controller[17]: Sat, 22 Sep 2018 07:11:15 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 1029, srcaddr: 23198, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 55, secur
                        Caught	2018-09-22 09:11:23.977	error	by controller[16]: data: { measuredValue: 2319 } } } { cid: 'msTemperatureMeasurement', modelId: 'lumi.weather' }
                        Caught	2018-09-22 09:11:23.977	error	by controller[16]: { cid: 'msTemperatureMeasurement',
                        Caught	2018-09-22 09:11:23.977	error	by controller[16]: report: [Function] } ],
                        Caught	2018-09-22 09:11:23.977	error	by controller[16]: write: [Function],
                        Caught	2018-09-22 09:11:23.976	error	by controller[16]: read: [Function],
                        Caught	2018-09-22 09:11:23.976	error	by controller[16]: unbind: [Function],
                        Caught	2018-09-22 09:11:23.976	error	by controller[16]: bind: [Function],
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #193
                          hmm auch nach restart ?? des adapters ??
                          • Lenny.CBL Offline
                            Lenny.CBL Offline
                            Lenny.CB
                            #194
                            nach restart ist es weg. kommt aber im laufe der Zeit wieder…
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              #195
                              das ist doch der eckige temp sensor der meckert….
                              stoppe mal den adapter lösche das das eine Object und starte den adapter wieder..
                              ansonsten was für firmware hast du drauf ?? die aus wiki ??
                              • Lenny.CBL Offline
                                Lenny.CBL Offline
                                Lenny.CB
                                #196
                                im Moment läuft es…
                                ja ist alles aus dem Wiki...
                                die FW ist von der Seite: https://github.com/Koenkk/zigbee2mqtt/w … ng-started
                                hier der Direktdownload: https://github.com/Koenkk/Z-Stack-firmw … CC2531/bin
                                  daniello
                                  #197
                                  Hallo allerseits, ich würde gerne einen Aqara Cutbe von 03.2018 pairen .. sehe im Log aber nur "Zigbee: allowing new devices to join." Bin auch schon dichter an den Stick gegangen (noch keine Ahnung über die ReichweiteI .. passiert aber nüscht. Könnte sein, das sich mich zu doof anstelle den Linkmodus zu initiieren .. diese chinesische Anleitung hilft nicht weiter.
                                  • L Offline
                                    Lupla
                                    #198
                                    @daniello:
                                    passiert aber nüscht. Könnte sein, das sich mich zu doof anstelle den Linkmodus zu initiieren .. diese chinesische Anleitung hilft nicht weiter. `
                                    Hast Du den Knopf im Cube zum pairen gedrückt?
                                    Gruß,
                                    Bastian
                                      daniello
                                      #199
                                      @Lupla
                                      Logo! Hab's inzwischen auch geschaft .. danke trotzdem für die Reaktion.
                                        Kueppert
                                        #200
                                        Hi, du musst den Knopf 3 sek halten bis die blaue Lampe 3 Mal blinkt, dann im Sekunden Takt einmal kurz drücken, damit der Cube aktiv bleibt. Dann sollte es klappen…@daniello:
                                        @Lupla
                                        Logo! `
                                        Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                                          daniello
                                          #201
                                          Ja .. hab ich gemacht und inzwischen auch geschafft .. aber es gibt noch einen Tipp den man geben kann: Bei der stay-awake Drückerei muss die Response der LED ein mehrfachblinken sein. Geht sie nur kurz an ist man zu weit weg vom Controller.
                                          Hoffentlich ist die Reichweite beim Gebrauch höher als beim Pairen.
