  4. Ical Setzen eines Events
159 Beiträge 32 Kommentatoren 47.7k Aufrufe 2 Beobachtet
  • wendy2702W
    wendy2702W
    #135
    vielen Dank für die ausführliche Untersuchung.
    Korrekt am 11.4. gab es um 19:08Uhr eine Ansage:
    `2018-04-11 19:08:00.237  - [32minfo[39m: sayit.0 saying: Gelbe Säcke Mülltonne wird morgen abgeholt. Bitte stell die Tonne an die Straße!
    2018-04-11 19:08:00.815  - [32minfo[39m: sayit.0 Set "chromecast.0.Ansage_Flur.player.announcement to {"url":"http://192.168.178.18:8082/state/sayit.0.tts.mp3","volume":"60"}
    2018-04-11 19:08:00.817  - [32minfo[39m: sayit.0 Copied file "/opt/iobroker/node_modules/iobroker.sayit/lib/../say.mp3" to "/opt/iobroker/cache/80ac330bcc8aaabfc03dc3a30e3084d9.mp3"
    2018-04-11 19:08:00.821  - [32minfo[39m: chromecast.0 Ansage Flur - Try to launch default player
    2018-04-11 19:08:00.838  - [32minfo[39m: chromecast.0 Ansage Flur - Try to join player
    2018-04-11 19:08:00.838  - [32minfo[39m: chromecast.0 Ansage Flur - Connected player
    2018-04-11 19:08:00.838  - [32minfo[39m: chromecast.0 Ansage Flur - Default player lauched
    2018-04-11 19:08:00.838  - [32minfo[39m: chromecast.0 Ansage Flur - Player joint
    2018-04-11 19:08:00.839  - [32minfo[39m: chromecast.0 Ansage Flur - Try to play announcement - "http://192.168.178.18:8082/state/sayit.0.tts.mp3"
    2018-04-11 19:08:00.839  - [32minfo[39m: chromecast.0 Ansage Flur - Try to play url - http://192.168.178.18:8082/state/sayit.0.tts.mp3
    2018-04-11 19:08:00.852  - [32minfo[39m: chromecast.0 Ansage Flur - Try to play playlist with 1 items
    2018-04-11 19:08:00.880  - [32minfo[39m: chromecast.0 Ansage Flur - set volume to 60
    2018-04-11 19:08:01.812  - [32minfo[39m: chromecast.0 Ansage Flur - Playing playlist with 1 items
    2018-04-11 19:08:04.864  - [32minfo[39m: chromecast.0 Ansage Flur - Playing - http://192.168.178.18:8082/state/sayit.0.tts.mp3
    2018-04-11 19:08:09.234  - [32minfo[39m: chromecast.0 Ansage Flur - Finished playing announcement[/code]`
    Werde das mal in das Script einbauen, die Änderung machen und beobachten.
    • T
      T
      tempestas
      #136
      ok, dann muss es so sein, dass der trigger nicht wieder auf false gesetzt wurde, warum auch immer. Nun ist er es ja wieder, offenbar gab es da ein Problem vom 11. auf den 12.4
      Grund bleibt unklar
      <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
      • E
        E
        eve11
        #137
        Hallo zusammen, ich benutze dieses Script für die Anzeige des Mülls.
        `/* Kalenderevent in der Zukunft suchen
        sucht im iCal Adapter nach events, die noch kommen
        viewtopic.php?f=21&t=3761&sid=4319378b32a0ce096bbbbfc0ebd859ce#p34975
        20.09.2016 erstellt von pix
        13.11.2016 angepasst für Sven
        // User Anpassungen
        var aSuchstringLiteral = ['Rest', 'Bio', 'Papier', 'Gelber Sack']; // Suchbegriff
        var aSuchstring = ['Rest', 'Bio', 'Papier', 'Gelber Sack'];
        var stichtag = 1; // 0 heute; 1 morgen; 2 übermorgen; 3 In 3 Tagen
        var idTabelle = 'ical.0.data.table'; // Instanz eintragen
        var logging = false; // debug Log ein/ausschalten
        // Ende User Anpassungen
        for (var j = 0; j < aSuchstring.length; j++) {
        createState('Muellwarnung.' + aSuchstring[j], false, {
        type: 'boolean',
        name: aSuchstringLiteral[j] + ' wird morgen abgeholt',
        desc: aSuchstringLiteral[j] + ' wird morgen abgeholt (Boolean)',
        def: false
        var idEventState = 'Muellwarnung.' + aSuchstring[j];
        log (idEventState);
        setState(idEventState, false);
        var tage = ['Heute','Morgen','Übermorgen','In 3 Tagen']; // dafür relative Datumsangabe in iCal-Adapter einschalten und ggf. übersetzen
        function datum(x) {
        var jetzt = new Date();
        if (logging) log('Jetztzeit: ' + jetzt);
        //var zeit = new Date(jetzt.getTime() + x * 24 * 60 * 60 * 1000); // es werden genau x Tage, als x * 24 Stunden zugezählt --> nicht gut
        var zeit = new Date (jetzt.getFullYear(), jetzt.getMonth(), jetzt.getDate() + x); // in drei Tagen um Mitternacht
        if (logging) log('Zielzeit: ' + zeit);
        var jahr = zeit.getFullYear();
        var monat = (zeit.getMonth()+1 < 10) ? '0' + (zeit.getMonth()+1) : zeit.getMonth()+1;
        var tag = (zeit.getDate() < 10) ? '0' + zeit.getDate() : zeit.getDate();
        return (tag + '.' + monat + '.' + jahr);
        function pruefeKalender() {
        var kalender = getState(idTabelle).val;
        var tag = datum(parseInt(stichtag,10));
        if (logging) log(tag);
        try{
        var ereignisse = JSON.stringify(kalender, null, 2); // Ausgabe als String
        if (logging) log(ereignisse);
        for(var i = 0; i <kalender.length; 19/i++)/{/alle/events/durchgehen/if/(/(kalender[i].date.indexof(tag)/!="-1)" ||/(kalender[i].date.indexof(tage[stichtag])/)/string/datum/oder/relatives/(nicht/nicht)/gefunden,/also/gefunden/var/termin="kalender[i].event;" (termin.indexof(asuchstringliteral[j])/log('treffer:/'/+/tage[stichtag]/asuchstringliteral[j]);/hier/wird/später/vielleicht/stichtag_array/verwendet/setstate(ideventstate,/true);/break;/}/else/false);/catch/(fehler_try)/log('fehler/beim/kalenderevents/einlesen/fehler_try,/'error');/schedule("00/*/*",/function(){/bei/mehreren/müllskripts/den/ersten/wert/verändern/(minuten)/for/(var/j="0;" </asuchstring.length;/j++)/ideventstate="Muellwarnung." asuchstring[j];/event="getState(idEventState).val;" (event)/ansage="aSuchstringLiteral[j]" morgen/abgeholt./bitte/stell/die/tonne/an/straße!';/kann/sayit/push/gesetzt/werden/sendto("pushover.0",/ansage);/});/aktualisierung/on/({id:/idtabelle,/change:/'any'},/function(data)/pruefekalender();/1min/nach/mitternacht/schedule("1/pruefekalender);/skriptstart/pruefekalender();<e=""></kalender.length;>`
        Nur der gelbe Sack wird nicht verarbeitet, da im Import in den Google Kalender "Gelber Sack" mit einem Leerzeichen angegeben ist. Ich habe einen Termin ohne angelegt und anschließend das Script dementsprechend angepaßt. Anschließend ist alles OK. Was müsste ich verändern, dass das Leerzeichen berücksichtigt wird.
        Vielen Dank.
        eve11
          [6450_iobroker.jpg](/assets/uploads/files/6450_iobroker.jpg)
          [6450_iobroker2.jpg](/assets/uploads/files/6450_iobroker2.jpg)  [/i][/i][/i]
        • M
          M
          mikiline
          #138
          einfach nach "Gelber" suchen und den Sack weglassen :lol:
          • E
            E
            eve11
            #139
            Nu hast natürlich recht.
            Peinlich.
            Aber trotzdem Danke
            eve11
            • C
              C
              csamaggi
              #140
              ich habe schon seit einiger Zeit das Script von Pix im Einsatz.
              Doch nun ist mir aufgefallen dass ein paar meiner Müllscripte nicht geändert werden.
              Also im Klartext der Ical Kaleneder wird geladen auch das Script erkennt wohl dass es dort eine Änderung gibt aber der Wert wird unter den Datenpunkten nicht geändert, es bleibt also bei "false" und wird nicht auf "true" gesetzt.
              Die Scripte sind identisch eben nur die jeweilige Tonne wird geändert bei einigen gehts bei den anderen nicht.
              Nun dachte ich mir ok wenn das für Müll geht warum nicht auch für den Dienstplan meiner Frau.
              Also habe ich hier das gleiche Script genommen und dann eben nur mit den Diensten angepasst aber auch hier tut sich nichts kein Wert wird geändert.
              http://forum.iobroker.net/viewtopic.php?f=21&t=3761&sid=4319378b32a0ce096bbbbfc0ebd859ce#p34975
              // User Anpassungen
              var suchstring =   'Früh';              // Suchbegriff
              var stichtag =      0;                   // 0 heute;  1 morgen; 2 übermorgen; 3 In 3 Tagen
              var idTabelle =    'ical.1.data.table'; // Instanz eintragen
              var logging =      true;                // debug Log ein/ausschalten
              createState('Dienste_Nina.' + suchstring, false, {
                   type: 'boolean',
                   name: suchstring + ' Dienst',
                   desc: suchstring + ' Dienst (Boolean)',
                   def: false
              var idEventState = 'Dienste_Nina.' + suchstring;
              function datum(x) {
                  try{
                      for(var i = 0; i <kalender.length; i++)/{/alle/events/durchgehen/if/(/(kalender[i].date.indexof(tag)/!="-1)" ||/(kalender[i].date.indexof(tage[stichtag])/)/string/datum/oder/relatives/(nicht/nicht)/gefunden,/also/gefunden/var/termin="kalender[i].event;" (termin.indexof(suchstring)/log('treffer:/'/+/tage[stichtag]/suchstring);/hier/wird/später/vielleicht/stichtag_array/verwendet/setstate(ideventstate,/true);/}/else/false);/catch/(fehler_try)/log('fehler/beim/kalenderevents/einlesen/fehler_try,/'error');/schedule("00/01/*/*",/function(){/bei/mehreren/müllskripts/den/ersten/wert/verändern/(minuten)/event="getState(idEventState).val;" (event)/ansage="suchstring" morgen/abgeholt./bitte/rausstellen!';/kann/sayit/push/gesetzt/werden/setstate("sayit.0.tts.text"/*text/to/speech*/,/ansage);/});/aktualisierung/on/({id:/idtabelle,/change:/'any'},/function(data)/pruefekalender();/1min/nach/mitternacht/schedule("1/pruefekalender);/skriptstart/pruefekalender();<e=""></kalender.length;>`
              Hier mal das für einen Dienst. Im Anschluß habe ich dann nur mittels VIS einen Button auf dem Früh steht und der dann einen Datenpunkt liest.
              MFG Maggi[/i][/i][/i]
              • L
                L
                lutzer
                #141
                Ich habe mal eine ganz doofe Frage: was mache ich nach dem iCal und die Scripte angelegt sind?
                Was muss ich jetzt im Vis machen das ich dort eine Zahl stehen habe? Also 1 (…1 Tag bis zum Termin/Abholung)...
                "String (unescaped) " zeigt ja nur den ganzen Kalender an...
                Bitte nicht steinigen ;)
                • M
                  M
                  mikiline
                  #142
                  wenn die Skripte angelegt sind gibt es auch sicher neue Objekte die Du abrufen kannst…..
                  • L
                    L
                    lutzer
                    #143
                    Ja unter Javascript, aber da steht dann auch nur true/false.
                    Ich dachte da kommt eine Zahl raus. "4" (in Tagen …)
                    So wie im vba oder sql wo man mit today/now - xxx eine Zahl raus hat.
                    Aslo man hat ja "heute", kann das nächste Ereigniss finden was den kleinsten Abstand zu "heute" hat und gibt den Zähler aus.
                    Der Rest ist ja dann nur Darsetllung im Vis. Also bei Zahl < 2 blinkt dann das Icon oder so.
                    Mit der Sprachausgabe hab ich es nicht so, deswegen konnte ich den anderen nicht mehr folgen.
                    • M
                      M
                      mikiline
                      #144
                      welches Skript denn?
                      Falls z.B Müll gewünscht ist kannst du dieses hier nehmen (natürlich anpassen)
                      Im Skript hab ich dir markiert was du anpassen musst mit "//HIER ANPASSEN!!!!!!!!!!!!!!!!!!!!!"
                      // Anlegen JS State für VIS
                      createState('javascript.0.muell.restmuell', 0); //. gelb, blau usw entsprechend erstellen
                      createState('javascript.0.muell.gelbersack', 0); //. gelb, blau usw entsprechend erstellen
                      createState('javascript.0.muell.papiertonne', 0); //. gelb, blau usw entsprechend erstellen
                      createState('javascript.0.muell.papierholsammlung', 0); //. gelb, blau usw entsprechend erstellen
                      createState('javascript.0.muell.biotonne', 0); //. gelb, blau usw entsprechend erstellen
                      ! schedule("05 00 * * *", function () {
                      // TESTSKRIPT FÜR NOXX
                      ! // Annahme ist, dass jede Müllart mindestens einmal im Monat abgeholt wird. Nicht getestet und eventuell problematisch ist es, wenn Müll seltener abgeholt wird.
                      ! debug = true;
                      ! // Suchvariablen
                      var restmuell= "Restm"; // weitere Varialben für die anderen Müllsorten eintragen
                      var gelbersack= "Gelber"; // weitere Varialben für die anderen Müllsorten eintragen
                      var papiertonne= "Papier"; // weitere Varialben für die anderen Müllsorten eintragen
                      var biotonne= "Bio"; // weitere Varialben für die anderen Müllsorten eintragen
                      var papierholsammlung= "Papier Hol"; // weitere Varialben für die anderen Müllsorten eintragen
                      ! // Kalender auslesen (HTML Format)
                      // Termine auswerten aus html. Bereinigung der HTML Tags und Konvertierung in Plain Text
                      //HIER den ical ANPASSEN!!!!!!!!!!!!!!!!!!!!!
                      var inhalt = getState("ical.2.data.html"/HTML iCal table/); // an deinen eigenen Kalender anpassen
                      var inhaltString = inhalt.val.toString();
                      var inhaltStringReplace = inhaltString;
                      var inhaltStringText;
                      var i_search;
                          // remove all inside SCRIPT and STYLE tags
                          inhaltStringReplace=inhaltStringReplace.replace(/<script.*>[\w\W]{1,}(.*?)[\w\W]{1,}<\/script>/gi, "");
                          inhaltStringReplace=inhaltStringReplace.replace(/<style.*>[\w\W]{1,}(.*?)[\w\W]{1,}<\/style>/gi, "");
                          // remove BR tags
                      /gi, "");
                      inhaltStringReplace=inhaltStringReplace.replace(/<br\s>/gi, "");
                      inhaltStringReplace=inhaltStringReplace.replace(/<br>/gi, "");
                          // remove all else
                          inhaltStringReplace=inhaltStringReplace.replace(/<(?:.|\s)*?>/g, "");
                          // get rid of html-encoded characters:
                          inhaltStringReplace=inhaltStringReplace.replace(/ /gi," ");
                          inhaltStringReplace=inhaltStringReplace.replace(/&/gi,"&");
                          inhaltStringReplace=inhaltStringReplace.replace(/"/gi,'"');
                          inhaltStringReplace=inhaltStringReplace.replace(/</gi,'<');
                          inhaltStringReplace=inhaltStringReplace.replace(/>/gi,'>');
                          if(debug) log(inhaltStringReplace);
                          //HIER welche States gewünscht sind ANPASSEN!!!!!!!!!!!!!!!!!!!!!
                          setState('javascript.0.muell.restmuell', getPos(restmuell));
                          setState('javascript.0.muell.gelbersack', getPos(gelbersack));
                          setState('javascript.0.muell.papiertonne', getPos(papiertonne));
                          setState('javascript.0.muell.biotonne', getPos(biotonne));
                          setState('javascript.0.muell.papierholsammlung', getPos(papierholsammlung));
                      ! // n-ten Treffer finden
                      ! function nthIndex(str, pat, n){
                      var L= str.length, i= -1;
                      while(n-- && i++ <l){ i="str.indexOf(pat," i);/if/(i/</0)/break;/}/i_search="i;" funktion/zum/tage/im/monat/zählen/function/daysinmonth(month,/year)/{/return/new/date(year,/month,/0).getdate();/position/bestimmen/getpos(pos_welche_tonne)/var/pos="inhaltStringReplace.indexOf(pos_welche_tonne," 1);/if(debug)/log("pos/ist:/"+pos);/inhaltstringtext="inhaltStringReplace.substring((pos-13),pos-1);" log("datum/"+inhaltstringtext);/nthindex(inhaltstringtext,/".",/t_m="inhaltStringText.slice(0," i_search);/pos1="i_search+1;" log("pos1:/"/+pos1/);/2);/m_m="inhaltStringText.slice(pos1," pos2="i_search+1;" log("pos2:/+pos2/j_m="inhaltStringText.slice(pos2," inhaltstringtext.len/log(t_m/+"/,/+m_m/+j_m);/datum/heute/ermitteln/today="new" date();/log(today);/tag/t="today.getDate();" m="today.getMonth()+1;" jahr/j="today.getFullYear();" "+t+m+j);/berechnung/tagesdifferenzen/diff="0;" dim="DaysInMonth(m," j);/des/aktuellen/monats/log("tage/aktueller/monat:/"+dim);/if(j_m="">j || m_m > m) { // Prüfung: Jahr_Müll größer als aktuelles Jahr? Relevant bei Jahreswechsel ODEr Monat Müll größer aktueller Monat?
                              diff = parseInt(dim) - parseInt(t) + parseInt(t_m);
                          else diff = parseInt(t_m) - parseInt(t);
                            if(debug) log("Tage bis zum nächsten Müll: "+diff);
                            return diff;
                      });</l){></br></br\s></style.></script.>
                      • L
                        L
                        lutzer
                        #145
                        Guten Morgen,
                        ja es geht um Müll :D
                        Danke für das Skript und die Kommentare die sind für Einsteiger sehr wichtig.
                        Wie mache ich jetzt weiter?
                        Ich habe das Skript angepasst (Kalender und Tonnennamen) und es unter Skripte erstellt.
                        Jetzt steht unter Objekte bei dem Javaskript true. Und es wurde ein Ordner muell erstellt, wo alle Tonnen und ein json drin ist.
                        Wo stehen jetzt die Werte die erzeugt wurden und mit was stelle ich diese in Vis dar?
                        Ich hab da irgendwie ein Verständnis Problem… :?
                        So sieht es im Vis bei mir aus. (Tonnen und Termine sind noch zum testen etwas durcheinander...)
                        Links das ist das "json" und rechts die iCal Tabelle
                        Sorry das "json" kam aus einem anderen Skript - das ist der Nachteil am Testen, es bleibt immer was zurück...
                        • M
                          M
                          mikiline
                          #146
                          In dem neuen ordner "muell" sind doch jetzt die Objekte mit zahlen, was die Tage bis zur Abholung anzeigt.
                          Das kannst Du mit jedem Widget darstellen.
                          z.B. mit diesem hier, das kannst Dir mal importieren
                          [{"tpl":"tplIconState","data":{"oid":"javascript.0.muell.biotonne","g_fixed":false,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":true,"visibility-cond":">","visibility-val":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":"0","signals-icon-0":"/vis.0/iPad/icons/Exclamation-mark-icon.png","signals-icon-size-0":"36","signals-blink-0":true,"signals-horz-0":"","signals-vert-0":"","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"src":"/vis.0/iPad/icons/tonne_bio.png","imageHeight":"100","value":"14","text":"{javascript.0.muell.biotonne}","visibility-oid":"","lc-type":"timestamp","lc-is-interval":true,"lc-format":"hh:mm:ss","lc-position-vert":"top","lc-position-horz":"left","lc-offset-vert":"3","lc-offset-horz":"89","lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-is-moment":true,"lc-zindex":0,"lc-oid":"","signals-oid-0":"javascript.0.muell.biotonne","signals-text-0":"Heute"},"style":{"left":"232px","top":"431px","width":"70px","height":"70px","z-index":"3","text-align":"center","font-size":"small","border-color":"","border-width":""},"widgetSet":"jqui"}]
                          • L
                            L
                            lutzer
                            #147
                            Da sind bei mir alles Nullen…
                            Irgendetwas scheint es nicht zu finden...
                            Der Kalender wird richtig abgeholt, dass sieht man ja an der normalen Übersicht.
                            Wie oft wird das aktualisiert?
                            Beim iCal muss da der Haken bei "Ersetze Datum mit Worten" drin sein?
                            • M
                              M
                              mikiline
                              #148
                              wird heute Nacht um 0:05 aktualisiert….. oder du kommentierst den "schedule" mal aus mit "//" (wie bei den Kommentaren)
                              Dann läuft das Skript einmal durch und es zeigt dir Werte an. Dann die Auskommentierung wieder rausnehmen
                              Haken brauch man nicht.
                              • L
                                L
                                lutzer
                                #149
                                auskommentieren ist so ne Sache weil da eine { bis zum ende das Codes geht.
                                Ich habe es mit ***** aushebeln können. Das sollte ja immer aktualisieren oder?
                                Ich kann mit den Zahlen schon mal einen Erfolg melden. Jetzt werden die Tage ordentlich gezählt.
                                Vielen Dank für die Hilfe und Geduld.
                                Eine Frage zu dem Widget: Was macht der Wert 14? Ist das so eine Art Rückmeldung und zurrück setzen?
                                Dann muss die Aktualisierung ja tatsächlich 5 nach 12 gemacht werden, sonst wird die 14 ja immer wieder überschrieben.
                                • M
                                  M
                                  mikiline
                                  #150
                                  Ja die setzt einfach den Wert auf 14 Tage und wird in der Nacht wieder auf den nächsten richtigen Müllabholtag überschrieben. Das ist, da ich die Signalbilder verwende am Tag "0" (an dem der Müll abgeholt wird)…...Dann blinkt dies nicht den ganzen Tag ;)
                                  • M
                                    M
                                    Marc1970
                                    #151
                                    @ pix
                                    Hallo, ich habe erfolgreich dein Müllscript im Einsatz:
                                    http://forum.iobroker.net/viewtopic.php … 9ce#p34975
                                    tolle Arbeit.
                                    Ich habe es auch schon mehrmals für andere Abfragen (heute, morgen) genutzt,
                                    nun meine Frage:
                                    Ist es möglich auch Termine von gestern abzufragen und was müßte dafür im Script geändert werden?
                                    MfG Marc
                                    <u>Hat sich erledigt, hab es anders gelöst….</u>
                                    Gruß Marc
                                    Und denkt immer daran, blau ist rot und Plus ist Minus…
                                    • W
                                      W
                                      w00dy
                                      schrieb am zuletzt editiert von w00dy
                                      #152
                                      ich versuche schon seit Tagen den Fehler zu finden, ich hoffe ihr könnt mir helfen.
                                      Ich habe das Script oben von @mikiline angepasst und den Shedule vorerst zum Testen mit "* * * * *" gespeichert.
                                      Im neuen Ordner "muell" werden mir die Tonnen auch angezeigt, aber die Werte bleiben immer auf "0", bzw. es wird nichts angezeigt.
                                      In ical ist "Ersetze Datum mit Worten" angehakt und Ereignisse sind auch genug vorhanden.
                                      Das Log vom Script:
                                      17:15:00.556	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: -1
                                      17:15:00.556	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist:
                                      17:15:00.556	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 0
                                      17:15:00.556	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 0
                                      17:15:00.556	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: , ,
                                      17:15:00.556	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 17:15:00 GMT+0200 (CEST)
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: NaN
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 33
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: Übermorgen
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 0
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 0
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Übermorgen , Übermorgen , Übermorgen
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 17:15:00 GMT+0200 (CEST)
                                      17:15:00.557	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: -1
                                      17:15:00.558	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: , ,
                                      17:15:00.558	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 17:15:00 GMT+0200 (CEST)
                                      17:15:00.558	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                      17:15:00.558	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                      17:15:00.558	[info]	javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: NaN
                                      Mein angepasstes Script:
                                      createState('javascript.0.muell.restabfall', 0);   //. gelb, blau usw entsprechend erstellen
                                      createState('javascript.0.muell.altpapier', 0);   //. gelb, blau usw entsprechend erstellen
                                      createState('javascript.0.muell.bioabfall', 0);   //. gelb, blau usw entsprechend erstellen
                                      schedule("* * * * *", function () {
                                      debug = true;
                                      // Suchvariablen
                                      var restabfall= "Restm";     // weitere Varialben für die anderen Müllsorten eintragen
                                      var altpapier= "Papier";     // weitere Varialben für die anderen Müllsorten eintragen
                                      var bioabfall= "Bio";     // weitere Varialben für die anderen Müllsorten eintragen
                                              var inhalt = getState("ical.0.data.html"/*HTML iCal table*/);           // an deinen eigenen Kalender anpassen
                                              var i_search;
                                              // remove BR tags
                                      /gi, "");
                                              inhaltStringReplace=inhaltStringReplace.replace(/<br\s\>/gi, "");
                                              inhaltStringReplace=inhaltStringReplace.replace(/<br\>/gi, "");
                                              // remove all else
                                              setState('javascript.0.muell.restabfall', getPos(restabfall));
                                              setState('javascript.0.muell.altpapier', getPos(altpapier));
                                              setState('javascript.0.muell.bioabfall', getPos(bioabfall));
                                                return diff;
                                      });</l){></br\></br\s\></style.*></script.*>
                                      Habe ich doch irgendwo was übersehen?
                                      <size size="150">EDIT:
                                      Sorry, habe ein paar Eingabefehler gemacht. Werde alt, muss mir unbedingt ne Brille zulegen. Altpapier und Restabfall wird jetzt angezeigt, Gelber Sack und Bio noch nicht. Den Fehler finde ich hoffentlich auch noch…</size>
                                      Viele Grüße
                                      w00dy
                                      • M
                                        M
                                        mikiline
                                        #153
                                        "Ersetze Datum mit Worten" muss nicht angehakt sein und es brauch für das Skript auch keine Ereignisse
                                        Die Suchworte müssen natürlich auch genau so im Kalender vorhanden sein!
                                        Such mal nur nach "bio" dann sollte dort auch was angezeigt werden, denn das Wort "abfall" kommt bei dir auch in restabfall vor ;)
                                        Dann evtl auch nur nach "gelb" oder "gelber" suchen…..
                                        Solltest Du in der ical Instanz auch nur z.B 5 Tage bei "Tagesvorschau" eingestellt haben, kann er auch keinen Termin finden der erst in 7 Tagen stattfindet. Dort kannst z.B 31 Tage einstellen
                                        • W
                                          W
                                          w00dy
                                          #154
                                          Hallo @mikiline, danke für deine Hilfe!
                                          Habe die Suchvorgaben mal geändert, aber Bioabfall und Gelber Sack werden einfach nicht angezeigt, obwohl diese im Kalender vorhanden sind.
                                          Die Vorschau in ical ist auf 31 Tage eingestellt.
                                          Hier mal die VIS-Ausgabe zu den nächsten Müll-Terminen:
                                          <code>[code]Heute Gelber Sack
                                          Übermorgen Bioabfall Braune Tonne
                                          31.10.2018 Restabfall Graue Tonne
                                          05.11.2018 Gelber Sack
                                          07.11.2018 Bioabfall Braune Tonne
                                          09.11.2018 Altpapier Grüne Tonne
                                          14.11.2018 Restabfall Graue Tonne
                                          19.11.2018 Gelber Sack
                                          21.11.2018 Bioabfall Braune Tonne[/code]</code>
                                          Mein aktuelles Script:
                                          >! schedule("* * * * *", function () {
                                          >! debug = true;
                                          >! // Suchvariablen
                                          var restabfall= "Rest";     // weitere Varialben für die anderen Müllsorten eintragen
                                          var gelbersack= "Gelb";     // weitere Varialben für die anderen Müllsorten eintragen
                                          var altpapier= "Alt";     // weitere Varialben für die anderen Müllsorten eintragen
                                                  var i_search;
                                                  // remove BR tags
                                          /gi, "");
                                                  // remove all else
                                                    return diff;
                                          Und hier ein aktueller Log vom Script:
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Heute Gelber Sack Übermorgen Bioabfall Braune Tonne 31.10.2018 Restabfall Graue Tonne 05.11.2018 Gelber Sack 07.11.2018 Bioabfall Braune Tonne 09.11.2018 Altpapier Grüne Tonne 14.11.2018 Restabfall Graue Tonne 19.11.2018 Gelber Sack 21.11.2018 Bioabfall Braune Tonne
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 69
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: 31.10.2018
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 3
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 6
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: 31 , 10 , 2018
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                          18:28:00.165 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: 9
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 8
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: Heute
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 0
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 0
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Heute , Heute , Heute
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.166 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: NaN
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 166
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: 09.11.2018
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 3
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 6
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: 09 , 11 , 2018
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: 18
                                          18:28:00.167 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 33
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: Übermorgen
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 0
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 0
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Übermorgen , Übermorgen , Übermorgen
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.168 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: NaN
                                          18:28:00.987 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Heute Gelber Sack Übermorgen Bioabfall Braune Tonne 31.10.2018 Restabfall Graue Tonne 05.11.2018 Gelber Sack 07.11.2018 Bioabfall Braune Tonne 09.11.2018 Altpapier Grüne Tonne 14.11.2018 Restabfall Graue Tonne 19.11.2018 Gelber Sack 21.11.2018 Bioabfall Braune Tonne
                                          18:28:00.988 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 69
                                          18:28:00.988 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: 31.10.2018
                                          18:28:00.988 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 3
                                          18:28:00.988 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 6
                                          18:28:00.988 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: 31 , 10 , 2018
                                          18:28:00.989 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: 9
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 8
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: Heute
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 0
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 0
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Heute , Heute , Heute
                                          18:28:00.990 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: NaN
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 166
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: 09.11.2018
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 3
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 6
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: 09 , 11 , 2018
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.991 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                          18:28:00.992 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.998 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: 18
                                          18:28:00.998 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos ist: 33
                                          18:28:00.998 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum ist: Übermorgen
                                          18:28:00.998 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos1: 0
                                          18:28:00.998 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: pos2: 0
                                          18:28:00.999 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Übermorgen , Übermorgen , Übermorgen
                                          18:28:00.999 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Mon Oct 22 2018 18:28:00 GMT+0200 (CEST)
                                          18:28:00.999 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Datum heute ist: 22102018
                                          18:28:00.999 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage aktueller Monat: 31
                                          18:28:00.999 [info] javascript.0 script.js.Müll-Kalendertermine_vorzeitig_anzeigen: Tage bis zum nächsten Müll: NaN
                                          Hast du evtl. noch ne Idee was ich falsch gemacht haben könnte?
                                          [6677_objekte.jpeg](/assets/uploads/files/6677_objekte.jpeg)
                                          Viele Grüße
                                          w00dy
                                          84.2k
