  3. Cloud Dienste
  4. Neuer Adapter: iobroker.alexa2
581 Beiträge 76 Kommentatoren 218.5k Aufrufe 3 Beobachtet
  • Matten MattenM Offline
    Matten Matten
    #266
    v 0.3.5 geladen multiroom sprachausgabe getestet und folgender fehler:
    host.tinkerboard	2018-07-27 10:54:58.177	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
    Caught	2018-07-27 10:54:58.177	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
    Caught	2018-07-27 10:54:58.177	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:80:11)
    Caught	2018-07-27 10:54:58.176	error	by controller[0]: at endReadableNT (_stream_readable.js:978:12)
    Caught	2018-07-27 10:54:58.176	error	by controller[0]: at IncomingMessage.emit (events.js:185:7)
    Caught	2018-07-27 10:54:58.176	error	by controller[0]: at emitNone (events.js:91:20)
    Caught	2018-07-27 10:54:58.176	error	by controller[0]: at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:360:60)
    Caught	2018-07-27 10:54:58.176	error	by controller[0]: at commandCallback (/opt/iobroker/node_modules/iobroker.alexa2/main.js:588:51)
    Caught	2018-07-27 10:54:58.176	error	by controller[0]: at AlexaRemote.Alexa.iterateMultiroom (/opt/iobroker/node_modules/iobroker.alexa2/main.js:584:29)
    Caught	2018-07-27 10:54:58.175	error	by controller[0]: at AlexaRemote.find (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:682:45)
    Caught	2018-07-27 10:54:58.174	error	by controller[0]: TypeError: Cannot read property 'toLowerCase' of undefined
    alexa2.0	2018-07-27 10:54:58.115	warn	Exception: TypeError: Cannot read property 'toLowerCase' of undefined
    alexa2.0	2018-07-27 10:54:58.112	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    alexa2.0	2018-07-27 10:54:58.112	error	at _combinedTickCallback (internal/process/next_tick.js:80:11)
    alexa2.0	2018-07-27 10:54:58.112	error	at endReadableNT (_stream_readable.js:978:12)
    alexa2.0	2018-07-27 10:54:58.112	error	at IncomingMessage.emit (events.js:185:7)
    alexa2.0	2018-07-27 10:54:58.112	error	at emitNone (events.js:91:20)
    alexa2.0	2018-07-27 10:54:58.112	error	at IncomingMessage. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:360:60)
    alexa2.0	2018-07-27 10:54:58.112	error	at commandCallback (/opt/iobroker/node_modules/iobroker.alexa2/main.js:588:51)
    alexa2.0	2018-07-27 10:54:58.112	error	at AlexaRemote.Alexa.iterateMultiroom (/opt/iobroker/node_modules/iobroker.alexa2/main.js:584:29)
    alexa2.0	2018-07-27 10:54:58.112	error	at AlexaRemote.find (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:682:45)
    alexa2.0	2018-07-27 10:54:58.112	error	TypeError: Cannot read property 'toLowerCase' of undefined
    alexa2.0	2018-07-27 10:54:58.111	error	uncaught exception: Cannot read property 'toLowerCase' of undefined</anonymous></anonymous>
    ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
    • liv-in-skyL Offline
      liv-in-skyL Offline
      #267
      @matten
      kannst du bitte etwas ausprobieren mit multiroom - apollon fragte, ob ich mich mit dir kurzschliessen könnte um fehler nachzuvollziehen.
      wenn ich etwas im provider-tunein eingeben spielt anstatt multiroom nur ein echo - wenn ich anschliessend play im object auf true setze fangt multiroom mit allen an.
      setzte ich rockantenne - kommt sprachausgabe mit geht nicht …
      setze ich ROCK ANTENNE - spielt ein nur echo - in der alexa app wird multiroom nicht angezeigt
      setze ich dann play - multiroom - alle echos spielen.
      danke
      • C Offline
        Camuri
        #268
        Huhu nach Update auf 0.3.2 hab ich beim Fire HD 10 nur noch den Ordner Info und beim Fire TV Cube nur noch die Ordner Info, Music-Provider und Player, es fehlen die Commands Ordner :(
          liv-in-skyL Offline
          #269
          wegen der vis schalter und alexa sprachbefehl (spiele tunein)
          bei wird nur der current.state aktualisiert (nach updatetime). somit kann ich im vis nur aktualisierte zustände bekommen, wenn ich ein script erstelle, welches mit play, pause, state den vis schalter aktualisiert - ist das bei euch auch so
          ist auch in v 0.3.4 so
            Matten Matten
            #270
            @ liv-in-sky
            ja so ist das bei mir auch.
            ich finde das aber auch doppelt gemoppelt, einmal hat man Music-Provider/TuneIn und nocheinmal Player/TuneIn-Direct.
            aber irgendwie wirds nicht auf multiroom wieder gegeben.
            kannst du sonst mal was in deiner main.js mit Notepad++ abändern?
            in Zeile 684
            value += ' auf ' + device._name + ' music';
            aktuell sollte folgendes noch in der Zeile stehen:
            value += ' auf multiroom music';
            download/file.php?mode=view&id=31478
            Matten Matten
            3476___tinkerboard_iobroker_iobroker_node_modules_iobroker.alexa2_main.js_-notepad_-27.07.2018_11_35_45.png
              liv-in-skyL Offline
              #271
              ich helfe gerne - aber solche änderungen sind mir eher noch suspekt. node und ich stehen noch auf "unlike"
              du müßtest mir schon genau sagen, wo ich diese datei finde
              unter tunein-direct funktioniert es bei mir
              • sigi234S Online
                sigi234S Online
                #272
                teste gerade den Adapter, ist Super.
                Ich habe mir eine Vis erstellt, wo ich die Routinen abrufe usw.. Geht sehr gut.
                Das einzige was ich noch klären muss, ist das es beim abruf ja nur den Dot nimmt die ich in den Objekt ID eingetragen habe.
                Also müsste ich für jeden Dot eine View bauen? Überlege gerade wie ich das am Besten lösen kann.
                Ist ein (jqui - ctrl - Icon State / val - Icon Bool) Widget.
                Aha, sehe gerade das JEDER Dot Routinen hat…..
                  Matten Matten
                  #273
                  @ liv-in-sky
                  kommst du unter windows an die iobroker ordner ran?
                  dann unter
                  iobroker\node_modules\iobroker.alexa2
                  und die main.js datei mit notepad++ öffnen.
                  in Zeile 684
                  Wenn ich das bei mir abändere funktioniert es. ABER Wenn der Multiroom device name nur aus großbuchstaben besteht zb "MULTIROOM" funktioniert es nicht. Apollon77 müsste das so umbauen das, wenn der Multiroom device name nur aus großbuchstaben besteht das in kleinbuchstaben konvertiert wird bevor der befehl abgeschickt wird.
                  Matten Matten
                  • sigi234S Online
                    sigi234S Online
                    #274
                    Was ist eigentlich der Datenpunkt:
                    Request Result
                      Matten Matten
                      #275
                      @sigi234:
                      Request Result `
                      requestResult = Error info for TuneIn requests
                        liv-in-skyL Offline
                        #276
                        hab ich gemacht - ändert aber nichts am verhalten
                        habe andere zeilenzahl -ist das normal
                          Matten Matten
                          #277
                          @liv-in-sky:
                          habe andere zeilenzahl -ist das normal `
                          welche version hast du?
                            liv-in-skyL Offline
                            #278
                            0.3.4
                              Matten Matten
                              #279
                              @liv-in-sky:
                              0.3.4 `
                              lade mal 0.3.5
                              und ändere noch einmal.
                              Wie hast du deine multiroomgruppe bezeichnet?
                                liv-in-skyL Offline
                                #280
                                die heißt "alles" -
                                wo kriege ich die version her - habe nur 3.4. auf github
                                  Matten Matten
                                  #281
                                  @liv-in-sky:
                                  die heißt "alles" -
                                  wo kriege ich die version her - habe nur 3.4. auf github `
                                  ok dann kann das mit der Großschrift bei dir nicht sein.
                                  hast du mal Music-Provider.Amazon Music getestet, ob sich das da auch so verhält?
                                    liv-in-skyL Offline
                                    #282
                                    hab ich nicht - benutze nur tunein und bibliothek
                                    bibliothek selbes problem - gebe titel ein und nur ein echo spielt bei multihome my library music provider
                                    genau heißt sie "Alles"
                                    • apollon77A Offline
                                      #283
                                      @Camuri:
                                      Huhu nach Update auf 0.3.2 hab ich beim Fire HD 10 nur noch den Ordner Info und beim Fire TV Cube nur noch die Ordner Info, Music-Provider und Player, es fehlen die Commands Ordner :( `
                                      Und die Devices können diese Dinge alle?
                                      Dann bitte aus "Info" mit die "device-type" nennen dann aktiviere ich das wieder. Bitte auch den Inhalt von "Info.capabilities" mitschicken
                                      Ich versuche nur das an STates anzulegen was die geräte auch können.
                                        #284
                                        @Matten Matten:
                                        @liv-in-sky:
                                        die heißt "alles" -
                                        hast du mal Music-Provider.Amazon Music getestet, ob sich das da auch so verhält? `
                                        Wartet mal … da ist eine Änderung verschwunden ... gleich kommt update
                                          #285
                                          uiuiui … da hatte sich was eingeschlichen.
                                          Also bitte 0.3.6 vom Github und vor allem die die Probleme hatten feedback geben.
                                          Gefixt sein sollte:
                                          • Multiroom geht mal und mal nicht und komisch :-) (@liv-in-sky vor allem du bitte :-) )
                                          • speak wird jetzt immer als zeichenkette genommen auch wenn mal was anderes reinschreibt (was man dennoch nicht tun sollte!!)
                                          • shuffle/repeat gehen (gingen noch nie)
