  4. {Gelöst} Harmony Adapter uncaught exception: bind EADDRINUSE 0.0.0.0:5224[/cod
    5.3k
4 Beiträge 2 Kommentatoren 860 Aufrufe
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    Hi leuts,
    Habe soeben den Harmony adapter auf meinem dicker host installiert, leider meckert er und möchte nicht starten jemand eine idee was man damit anfangen könnte ?
    Auf meiner regulären VM-Ware läuft alles :
    host.iObroker	2018-06-21 10:40:00.902	info	Restart adapter system.adapter.harmony.0 because enabled
    host.iObroker	2018-06-21 10:40:00.902	error	instance system.adapter.harmony.0 terminated with code 0 (OK)
    Caught	2018-06-21 10:40:00.902	error	by controller[0]: port: 5224 }
    Caught	2018-06-21 10:40:00.902	error	by controller[0]: address: '0.0.0.0',
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: syscall: 'bind',
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: errno: 'EADDRINUSE',
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: code: 'EADDRINUSE',
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: at _handle.lookup (dgram.js:219:18)
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
    Caught	2018-06-21 10:40:00.901	error	by controller[0]: at Object.exports._errnoException (util.js:1020:11)
    Caught	2018-06-21 10:40:00.900	error	by controller[0]: { Error: bind EADDRINUSE 0.0.0.0:5224
    harmony.0	2018-06-21 10:40:00.887	info	terminating
    harmony.0	2018-06-21 10:40:00.887	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    harmony.0	2018-06-21 10:40:00.887	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
    harmony.0	2018-06-21 10:40:00.887	error	at _handle.lookup (dgram.js:219:18)
    harmony.0	2018-06-21 10:40:00.887	error	at exports._exceptionWithHostPort (util.js:1043:20)
    harmony.0	2018-06-21 10:40:00.887	error	at Object.exports._errnoException (util.js:1020:11)
    harmony.0	2018-06-21 10:40:00.887	error	Error: bind EADDRINUSE 0.0.0.0:5224
    harmony.0	2018-06-21 10:40:00.887	error	uncaught exception: bind EADDRINUSE 0.0.0.0:5224
    • apollon77A Offline
      Die Meldung heisst das ein anderer prozess auf Port 5224 auf dem Rechner schon läuft … Finde raus was es ist
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        @apollon77:
        Die Meldung heisst das ein anderer prozess auf Port 5224 auf dem Rechner schon läuft … Finde raus was es ist `
        grr keiner meiner dicker container belegt diesen port aber auf dem NAS ist er im gebrauch … mal schauen ob es irgendein NAS service ist :
        xx@xxr:~$ netstat -a | grep 522
        udp        0      0 0.0.0.0:5224            0.0.0.0:*
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          gefunden : Plesk license abfragen …. grmbl, danke
          Edit : grmbl hatte nichts mit plesk zu tun sondern Homebridge.
          Hatte dort das harmony Plugin installiert logisch das der Port belegt war
